Autor Thema: ENOCEAN PI 868  (Gelesen 1290 mal)
Offline littlelegs
  • Newbie
ENOCEAN PI 868
« am: 13 Februar 2022, 23:39:41 »
Hi. I have connected the Enocean module to my raspberry pi and installed fhem which has been discovered.
I have a aico smoke detector which runs homelink and connects the smoke detectors via RF. is there any way I can use fhem with the Enocean transceiver to receive and relay any messages sent over RF? I would ideally like to forward the RF messages to home assistant to enable me to get notifications if the smoke detector is set off when I am away from home.
Many thanks.
Offline MadMax-FHEM
  • NIVEAu ist keine Creme...
Antw:ENOCEAN PI 868
« Antwort #1 am: 14 Februar 2022, 00:03:31 »
There are more things than just frequency: protocol!
The frequency of the enocean module is 868MHz but it only can "talk" enocean "language"...
So receiving of any rf signal in 868MHz: yes
Understand: probably not
Forward: no
Regards, Joachim
« Letzte Änderung: 14 Februar 2022, 00:05:26 von MadMax-FHEM »
FHEM PI3 Buster (Test)
Offline rudolfkoenig
  • Administrator
Antw:ENOCEAN PI 868
« Antwort #2 am: 14 Februar 2022, 10:02:42 »
...and modulation and datarate and encoding and ... :)
