Autor Thema: Wago /SPS über Modbus(TCP/IP) in FHEM steuern  (Gelesen 144667 mal)
Offline bitvilla
  • New Member
Antw:Wago /SPS über Modbus(TCP/IP) in FHEM steuern
« Antwort #480 am: 08 November 2018, 18:33:59 »
Hallo ChrisD,
habe die angehängte Datei eingespielt und FHEM neu gestartet.
Anbei die Ausgaben im Logfile mit verbose 4:
2018.11.08 18:15:32 3: WagoMD216: I/O device is wago
2018.11.08 18:15:32 3: WagoMD217: I/O device is wago
2018.11.08 18:15:32 3: WagoMW206: I/O device is wago
2018.11.08 18:15:32 3: WagoMW207: I/O device is wago
2018.11.08 18:15:32 1: Including FHEM/fhem_myConfig_allgemein.cfg
2018.11.08 18:15:33 3: SUSV: using I2C Address 15
2018.11.08 18:15:34 3: SUSV: Found firmware 2.61 - Basic
2018.11.08 18:15:34 1: Including ./log/fhem.save
2018.11.08 18:15:34 3: Opening wago device 192.168.13.240:502
2018.11.08 18:15:34 4: AddRQueue [20 10 00 00 00 06] 00 03 20 10 00 01
2018.11.08 18:15:34 4: AddRQueue [20 11 00 00 00 06] 00 03 20 11 00 01
2018.11.08 18:15:34 4: AddRQueue [20 12 00 00 00 06] 00 03 20 12 00 01
2018.11.08 18:15:34 4: AddRQueue [20 13 00 00 00 06] 00 03 20 13 00 01
2018.11.08 18:15:34 4: AddRQueue [20 14 00 00 00 06] 00 03 20 14 00 01
2018.11.08 18:15:34 4: AddRQueue [10 22 00 00 00 06] 00 03 10 22 00 04
2018.11.08 18:15:34 3: wago device opened
2018.11.08 18:15:34 0: Featurelevel: 5.9
2018.11.08 18:15:34 0: Server started with 176 defined entities (fhem.pl:17652/2018-10-31 perl:5.020002 os:linux user:fhem pid:3546)
2018.11.08 18:15:35 3: telnetForBlockingFn_1541697335: port 32961 opened
2018.11.08 18:15:37 4: RQUEUE: 5
2018.11.08 18:15:37 4: RQUEUE: 4
2018.11.08 18:15:37 4: RQUEUE: 3
2018.11.08 18:15:37 4: RQUEUE: 2
2018.11.08 18:15:38 4: RQUEUE: 1
2018.11.08 18:15:42 4: AddRQueue [FD E8 00 00 00 06] 00 03 30 C8 00 08
2018.11.08 18:15:42 4: AddRQueue [FD E9 00 00 00 06] 00 03 31 90 00 26
2018.11.08 18:15:42 4: AddRQueue [FA 00 00 00 00 06] 00 01 00 20 00 20
2018.11.08 18:15:42 4: AddRQueue [FA 01 00 00 00 06] 00 01 02 28 00 18
2018.11.08 18:15:42 4: AddRQueue [FA 02 00 00 00 06] 00 01 10 00 00 50
2018.11.08 18:15:42 4: AddRQueue [FA 03 00 00 00 06] 00 01 36 40 00 30
2018.11.08 18:15:42 4: RQUEUE: 5
2018.11.08 18:15:42 4: RQUEUE: 4
2018.11.08 18:15:42 4: RQUEUE: 3
2018.11.08 18:15:44 4: RQUEUE: 2
2018.11.08 18:15:44 4: RQUEUE: 1
Die Meldung "ModbusTCPServer_Parse: except (code 2)" erscheint jetzt nicht mehr.
Ein Funktionstest der aktuellen Konfiguration war ebenfalls erfolgreich.
Habe aktuell leider keinen Zugriff bzw. keinen Bedarf für eine analoge Schnittstellenkarte.
Sonst könnte ich anbieten den kompletten Datenaustausch zwischen FHEM und WAGO über analoge Werte zu testen.
Vielen Dank für Deine Entwicklungsarbeit!
Freundliche Grüße
bitvilla
Offline bitvilla
  • New Member
« Antwort #481 am: 15 Dezember 2018, 15:57:43 »
Hallo ChrisD,
habe die letzte Version von Modbus_TCPServer (#479) nun seit ca. 5 Wochen erfolgreich im Einsatz.
Wollte mal Fragen ob die Version offiziell eingecheckt wird?
Aktuell überschreibt FHEM die angepasste Datei bei jedem Update.
Freundliche Grüße
bitvilla
Offline der-Lolo
« Antwort #482 am: 15 Dezember 2018, 16:24:42 »
Die Meldung
2018.12.15 15:01:13 2: ModbusTCPServer_Parse: except (code 2)
hab ich auch bei jedem neustart, wäre natürlich schön wenn die weg wäre.
Offline ChrisD
  • Sr. Member
« Antwort #483 am: 15 Dezember 2018, 17:31:13 »
Ich hatte leider vergessen die Module auf Github zu aktualisieren. Ich habe dies jetzt nachgeholt so dass bei einem Update die aktuelle Version heruntergeladen werden sollte.
Grüße,
ChrisD
Offline WagoAndreas
  • Newbie
« Antwort #484 am: 27 Dezember 2018, 21:32:10 »
Hallo Leute,
DANKE für diesen tollen Beitrag hier. Ohne den ich es nicht geschafft hätte eine Kommunikation zwischen FHEM und meiner 750-841 zu erstellen.
Ich hänge gerade leider ein bisschen. Vielleicht hat jemand einen Tipp für mich? Wahrscheinlich habe ich es mindestens 5x überlesen. Aber ich bekomm es nicht hin.
ich habe ein FHZ1300 über den ich Werte von meinen FS20 Temperaturreglern bekomme. Dies funktioniert einwandfrei. Kommunikation zur WAGO SPS steht auch, wie hier beschrieben. Jedoch schaffe ich es nicht EINEN Temperaturwert in das MW21 z.b. zu schreiben.
Bad ist z.b. so deklariert:
FHT_DachBad
19.3 °C
 FHT_DachBad
Internals
CODE
4409
DEF
4409
FHZ_0_MSGCNT
150
FHZ_0_RAWMSG
810c04f00909a00144090000b63a
FHZ_0_TIME
2018-12-27 21:16:15
IODev
FHZ_0
LASTInputDev
FHZ_0
MSGCNT
150
NAME
FHT_DachBad
NR
30
STATE
measured-temp: 19.3
TYPE
FHT
Readings
ack
30
2018-12-27 21:10:32
actuator
8%
2018-12-27 21:25:53
battery
ok
2018-12-27 21:10:31
desired-temp
19.0
2018-12-27 19:09:13
end-xmit
30
2018-12-27 20:58:58
lowtemp
ok
2018-12-27 21:10:31
measured-temp
19.3
2018-12-27 21:10:31
state
measured-temp: 19.3
2018-12-27 21:10:31
temperature
19.3
2018-12-27 21:10:31
warnings
none
2018-12-27 21:10:31
window
closed
2018-12-27 21:10:31
windowsensor
ok
2018-12-27 21:10:31
Dann ein Wort als INT was zur zeit ein Slider ist um es halt testen zu können ob werte in die SPS übertragen werden mit folgenden
Attributes
Internals
CFGFN
CHANGED
DEF
wago MW21
IODev
SPS
LASTInputDev
SPS
MSGCNT
8641
ModbusRegister_lastRcv
2018-12-27 21:28:55
NAME
MB_T_RolloAuf
NOTIFYDEV
global
NR
220
NTFY_ORDER
50-MB_T_RolloAuf
IODev
SPS
deleteattr
event-on-change-reading
deleteattr
plcDataType
INT
deleteattr
setList
state:slider,10,2,30
deleteattr
webCmd
state
deleteattr
Derzeit schreibt er brav ins MW21 wenn ich etwas an dem slider spiele. So wie kann ich nun diese zwei Variabeln verbinden???
VIELEN DANK FÜR EURE HILFE!!!!!!!!!!!!!!!!!!!!!!
Offline ChrisD
  • Sr. Member
« Antwort #485 am: 28 Dezember 2018, 08:25:41 »
Du kannst den Wert vom FHT mit Hilfe von 'notify' weitersenden. Informationen zu 'notify' findest du hier.
Zum Übertragen der Ist-Temperatur sollte dies funktionieren:
define n_FHT_DachBad_MW21 notify FHT_DachBad:measured-temp.* set MB_T_RolloAuf $EVTPART1 Hiermit wird die Temperatur ohne Nachkommastelle übertragen.
Wenn die Nachkommastelle auch übertragen werden soll gibt es 2 Möglichkeiten:
- die Temperatur wird vor dem Senden mit 10 multipliziert, im SPS-Programm wird dann aus 19.3 der Wert 193:
attr MB_T_RolloAuf conversion 0.1:0
- der Wert wird als Gleitkommazahl übertragen, dazu muss die Definition von MB_T_RolloAuf geändert werden, z.B.:
defmod MB_T_RolloAuf wago MF200im SPS-Programm muss die Deklaration der Variable auch angepasst werden:
MB_T_RolloAuf AT %MD200 : REAL;
Grüße,
ChrisD
Offline WagoAndreas
  • Newbie
« Antwort #486 am: 29 Dezember 2018, 14:00:45 »
VIELEN VIELEN DANK funktioniert wunderbar. So jetzt werd ich noch bissl basteln. DANKE!
Offline peter.oehlmann@web.de
  • Newbie
« Antwort #487 am: Gestern um 21:32:43 »
Hallo ,
ich habe meine Wago an FHEM angebunden , um Werte von Sensoren in die Wago einzulesen und FHEM als Gateway für die Wago zu verwenden. Die Kopplung von einzelnen Bits und Messwerten funktioniert eigentlich tadellos.
Problem : das zyklische Schreiben von dem Reading "brightness" auf das Modbus Register wago MF100. In der Komandozeile kann ich eingeben:
set MF100 1234
und der Wert wird wunderbar in die SPS geschrieben.Dafür habe ich nun das Notify mit folgendem Inhalt angelegt:
Motion_Kota:brightness:.* set MF100 $EVENT
Fehlermeldung im Logfile ist :
MF100_NF return value: Unknown argument brightness:, choose one of off on  on-till-overnight on-for-timer off-till-overnight blink off-till off-for-timer on-till toggle intervals
Das Format des Wertes in Reading passt aus meiner Sicht und da ich ja mit der Kommandozeile den Wert schreiben kann,
beweist , dass es geht.
Ich probiere seit Tagen verschiedene Varianten aus und lese Anleitungen , aber das Notify will nicht funktionieren.
Ich hoffe, ihr seid so nett und könnt mir helfen. Der Zeitaufwand vom ersten Gedanken das Gateway FHEM zu nutzen
und alles durch Anlesen zu erlernen ist schon recht hoch. Das hätte ich nicht gedacht. Eine Beschreibung über Modbus
und die Definitionen , die sich aus "wago" ergeben kann ich auch nicht finden. Man muss immer das ganze Forum durchstöbern.
Gibt es da etwas?
Peter
Offline ChrisD
  • Sr. Member
« Antwort #488 am: Gestern um 21:52:03 »
Dies ist kein Modbus oder Wago-Problem sondern ein Problem mit deinem notify. $EVENT enthält das gesamte Ereignis, in deinem Fall z.B.
brightness: 160
Damit führt das notify folgenden Befehl aus
set MF100 brightness: 160was natürlich nicht funktioniert.
In deinem Fall dürfte dies dagegen funktionieren:
Motion_Kota:brightness:.* set MF100 $EVTPART1
Weitere Details zum notify findest du sowohl in der Commandref als auch im Wiki.
Eine Beschreibung über Modbus und die Definitionen , die sich aus "wago" ergeben kann ich auch nicht finden.
Wenn du 'wago' verwendest kannst du die gleichen Adressen wie im Koppler verwenden. Das Modul sorgt intern dafür dass die richtigen Parameter für Modbus-Adresse, Datenlänge und Datentyp gesetzt werden.
Grüße,
ChrisD
  • Newbie
« Antwort #489 am: Gestern um 22:39:43 »
Erstmal vielen Dank,
ich habe $EVTPART1 gerade eingetragen und es kam ein Wert vom Sensor , dann hat es funktioniert.
$EVTPART1 hatte ich vorher schon ohne Erfolg getestet , da kam aber kein echter Wert vom Sensor,
sondern ich habe mit "trigger MF100_NF" das Notify getriggert. Wenn ich das jetzt wieder mache,
passiert wieder nichts. Ist ja eine nützliche Funktion das Triggern , aber wie macht man es richtig?
Jetzt muss ich bis morgen warten , bis der Sensor wieder hell sieht , um sicher zu gehen , dass es
geht.
Peter
Offline ChrisD
  • Sr. Member
« Antwort #490 am: Gestern um 22:48:56 »
Du solltest nicht das notify triggern sondern den Auslöser, also z.B.
trigger Motion_Kota brightness: 160
Grüße,
ChrisD
decade-submarginal
