Log voll Meldungen
Begonnen von Tommy82, 07 März 2022, 19:35:29
Tommy82
ich hab seit ich einen neuen HM-CC-RT-DN versuche einzubinden (zum Teil klappt es  https://forum.fhem.de/index.php/topic,126589.0.html) jetzt den Log voll mit diesen Meldungen:
22.03.07 19:29:04.909 1: stacktrace:
2022.03.07 19:29:04.909 1:     main::__ANON__                      called by fhem.pl (4556)
2022.03.07 19:29:04.910 1:     main::resolveAttrRename             called by fhem.pl (4715)
2022.03.07 19:29:04.910 1:     main::AttrVal                       called by ./FHEM/01_FHEMWEB.pm (1858)
2022.03.07 19:29:04.910 1:     main::FW_alias                      called by ./FHEM/01_FHEMWEB.pm (1632)
2022.03.07 19:29:04.911 1:     main::FW_makeTableFromArray         called by ./FHEM/01_FHEMWEB.pm (1600)
2022.03.07 19:29:04.911 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1202)
2022.03.07 19:29:04.912 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (608)
2022.03.07 19:29:04.912 1:     main::FW_Read                       called by fhem.pl (3925)
2022.03.07 19:29:04.912 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2022.03.07 19:29:04.913 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2022.03.07 19:29:04.913 1:     main::__ANON__                      called by fhem.pl (780)
2022.03.07 19:29:04.913 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/01_FHEMWEB.pm line 1637.
2022.03.07 19:29:04.914 1: stacktrace:
2022.03.07 19:29:04.914 1:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (1637)
2022.03.07 19:29:04.915 1:     main::FW_makeTableFromArray         called by ./FHEM/01_FHEMWEB.pm (1600)
2022.03.07 19:29:04.915 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1202)
2022.03.07 19:29:04.916 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (608)
2022.03.07 19:29:04.916 1:     main::FW_Read                       called by fhem.pl (3925)
2022.03.07 19:29:04.916 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2022.03.07 19:29:04.917 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2022.03.07 19:29:04.917 1:     main::__ANON__                      called by fhem.pl (780)
2022.03.07 19:29:04.918 1: PERL WARNING: Use of uninitialized value $txt in concatenation (.) or string at ./FHEM/01_FHEMWEB.pm line 2686.
2022.03.07 19:29:04.918 1: stacktrace:
2022.03.07 19:29:04.918 1:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2686)
2022.03.07 19:29:04.919 1:     main::FW_pH                         called by ./FHEM/01_FHEMWEB.pm (1637)
2022.03.07 19:29:04.919 1:     main::FW_makeTableFromArray         called by ./FHEM/01_FHEMWEB.pm (1600)
2022.03.07 19:29:04.920 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1202)
2022.03.07 19:29:04.920 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (608)
2022.03.07 19:29:04.920 1:     main::FW_Read                       called by fhem.pl (3925)
2022.03.07 19:29:04.921 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2022.03.07 19:29:04.921 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2022.03.07 19:29:04.921 1:     main::__ANON__                      called by fhem.pl (780)
2022.03.07 19:29:12.237 1: Error: >HM_64B1E1< has no TYPE, but following keys: >helper<
Allnetl Wandtablett mit FTUI
Der Verursacher steht doch da: ">HM_64B1E1< has no TYPE".
Das Problem wenig mit FHEMWEB zu tun.
Tommy82
Also eher mit dem Problem was ich unter dem angegeben Link gepostet hab!?
Dann mal sehen ob dort einer eine idee hat.
