.AttrList der Internals bei allen CUL_HM Objekten mit Schrotteinträgen gefüllt.
Begonnen von Homalix99, 16 Mai 2022, 15:18:55
Homalix99
seit Kurzem ist mir aufgefallen, dass alle Homematic-Geräte in Fhem in den .AttrList (Internals) beliebige Schrotteinträge beinhalten.
   .AttrList  .devInfo .mId .stc IODev IOgrp actCycle actStatus aesCommReq:1,0 aesKey:5,4,3,2,1,0 autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto commStInCh:on,off do_not_notify:1,0 dummy:1,0 event-aggregator event-min-interval event-on-change-reading event-on-update-reading expert:multiple,defReg,allReg,rawReg,templ,none firmware hmKey hmKey2 hmKey3 hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger ignore:1,0 levelMap levelRange model modelForce:ACTIONDETECTOR,ACTIONDETECTOR,ASH550,ASH550I,CCU-FHEM,CMM,DORMA_ATENT,DORMA_BRC-H,DORMA_RC-H,HM-CC-RT-DN,HM-CC-RT-DN-BOM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-DIS-EP-WM55,HM-DIS-TD-T,HM-DIS-WM55,HM-DW-WM,HM-ES-PMSW1-DR,HM-ES-PMSW1-PL,HM-ES-PMSW1-PL-DN-R1,HM-ES-PMSW1-PL-DN-R2,HM-ES-PMSW1-PL-DN-R3,HM-ES-PMSW1-PL-DN-R4,HM-ES-PMSW1-PL-DN-R5,HM-ES-PMSW1-SM,HM-ES-TX-WM,HM-HM-LC-DW-WM,HM-LC-AO-SM,HM-LC-BL1-FM,HM-LC-BL1-FM-2,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-BL1-SM-2,HM-LC-BL1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-CV-2,HM-LC-DIM1L-CV-644,HM-LC-DIM1L-PL,HM-LC-DIM1L-PL-2,HM-LC-DIM1L-PL-3,HM-LC-DIM1L-PL-644,HM-LC-DIM1PWM-CV,HM-LC-DIM1PWM-CV-2,HM-LC-DIM1T-CV,HM-LC-DIM1T-CV-2,HM-LC-DIM1T-CV-644,HM-LC-DIM1T-DR,HM-LC-DIM1T-FM,HM-LC-DIM1T-FM-2,HM-LC-DIM1T-FM-644,HM-LC-DIM1T-FM-LF,HM-LC-DIM1T-PL,HM-LC-DIM1T-PL-2,HM-LC-DIM1T-PL-3,HM-LC-DIM1T-PL-644,HM-LC-DIM1TPBU-FM,HM-LC-DIM1TPBU-FM-2,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2L-SM-2,HM-LC-DIM2L-SM-644,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM,HM-LC-DIM2T-SM-2,HM-LC-JA1PBU-FM,HM-LC-RGBW-WM,HM-LC-SW1-BA-PCB,HM-LC-SW1-DR,HM-LC-SW1-FM,HM-LC-SW1-FM-2,HM-LC-SW1-PB-FM,HM-LC-SW1-PCB,HM-LC-SW1-PL,HM-LC-SW1-PL-3,HM-LC-SW1-PL-CT-R1,HM-LC-SW1-PL-CT-R2,HM-LC-SW1-PL-CT-R3,HM-LC-SW1-PL-CT-R4,HM-LC-SW1-PL-CT-R5,HM-LC-SW1-PL-DN-R1,HM-LC-SW1-PL-DN-R2,HM-LC-SW1-PL-DN-R3,HM-LC-SW1-PL-DN-R4,HM-LC-SW1-PL-DN-R5,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-2,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW1PBU-FM,HM-LC-SW2-DR,HM-LC-SW2-DR-2,HM-LC-SW2-FM,HM-LC-SW2-FM-2,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW2PBU-FM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-DR-2,HM-LC-SW4-PCB,HM-LC-SW4-PCB-2,HM-LC-SW4-SM,HM-LC-SW4-SM-2,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-SW4-WM-2,HM-MOD-EM-8,HM-MOD-EM-8BIT,HM-MOD-RE-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CFM-TW,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-2-PBU-FM,HM-RC-2-PBU-FM-2,HM-RC-4,HM-RC-4-2,HM-RC-4-3,HM-RC-4-3-D,HM-RC-4-B,HM-RC-8,HM-RC-DIS-H-X-EU,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-KEY4-2,HM-RC-KEY4-3,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-SEC4-2,HM-RC-SEC4-3,HM-SCI-3-FM,HM-SEC-CEN,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-MDIR-3,HM-SEC-RHS,HM-SEC-RHS-2,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCO,HM-SEC-SD,HM-SEC-SD-2,HM-SEC-SFA-SM,HM-SEC-SIR-WM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-DB-PCB,HM-SEN-EP,HM-SEN-LI-O,HM-SEN-MDIR-O,HM-SEN-MDIR-O-2,HM-SEN-MDIR-O-3,HM-SEN-MDIR-SM,HM-SEN-MDIR-WM55,HM-SEN-RD-O,HM-SEN-WA-OD,HM-SWI-3-FM,HM-SYS-SRP-PL,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS100-C6-O-2,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-OT2-SM-2,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550TECH,IS-WDS-TH-OD-S-R3,KFM-DISPLAY,KFM-SENSOR,KS550,KS550LC,KS550TECH,KS888,OLIGO-SMART-IQ-HM,PS-SWITCH,PS-TH-SENS,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FFK,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FSS-UP3,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,S550IA,SCHUECO_263-130,SCHUECO_263-131,SCHUECO_263-132,SCHUECO_263-133,SCHUECO_263-134,SCHUECO_263-135,SCHUECO_263-144,SCHUECO_263-145,SCHUECO_263-146,SCHUECO_263-147,SCHUECO_263-155,SCHUECO_263-157,SCHUECO_263-158,SCHUECO_263-160,SCHUECO_263-162,SCHUECO_263-167,SCHUECO_263-XXX,SENSOTIMER-ST-6,VIRTUAL,WDF-SOLAR,WS888 msgRepeat oldreadings param peerIDs readOnly:0,1 readingOnDead:multiple,noChange,state,periodValues,periodString,channels rssiLog:1,0 serialNr showtime:1,0 stateFormat:textField-long subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,display,keyMatic,motionAndBtn,motionDetector,no,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,rgb,senBright,sensRain,sensor,singleButton,siren,smokeDetector,swi,switch,thermostat,threeStateSensor,timer,tipTronic,virtual,winMatic timestamp-on-change-reading
   CFGFN      ./FHEM/00_config_HM_LAN.conf
   DEF        687F37
   FUUID      5df22240-f33f-5615-62ca-e4a195caafa441b3
   HMLAN1_MSGCNT 969
   HMLAN1_RAWMSG E687F37,0000,8444285F,FF,FFB1,E4A610687F3726EB1306010000
   HMLAN1_RSSI -79
   HMLAN1_TIME 2022-05-16 15:04:59
   HMLAN2_MSGCNT 868
   HMLAN2_RAWMSG 0501004BE4A610687F3726EB1306010000
   HMLAN2_RSSI -75
   HMLAN2_TIME 2022-05-16 15:04:59
   HMUSB1_MSGCNT 970
   HMUSB1_RAWMSG 0500003CE4A610687F3726EB1306010000
   HMUSB1_RSSI -60
   HMUSB1_TIME 2022-05-16 15:04:59
   IODev      HMLAN2
   LASTInputDev HMLAN1
   MSGCNT     2807
   NAME       FTS_1.OG_Bad
   NR         180
   NTFY_ORDER 48-FTS_1.OG_Bad
   STATE      closed
   TYPE       CUL_HM
   chanNo     01
   disableNotifyFn 1
   lastMsg    No:E4 - t:10 s:687F37 d:26EB13 06010000
   peerList   WT_1.OG_Bad_WindowRec
   protLastRcv 2022-05-16 15:04:59
   protRcv    970 last_at:2022-05-16 15:04:59
   protRcvB   127 last_at:2022-05-16 14:46:19
   protSnd    843 last_at:2022-05-16 15:04:59
   protState  CMDs_done
   rssi_at_HMLAN1 cnt:969 min:-99 max:-71 avg:-78.84 lst:-79
   rssi_at_HMLAN2 cnt:868 min:-85 max:-55 avg:-69.38 lst:-75
   rssi_at_HMUSB1 cnt:970 min:-73 max:-50 avg:-60.73 lst:-60
   .attraggr:
   .attreocr:
     state
   .attrminint:
     2021-12-11 18:37:45   .D-devInfo      810101
     2021-12-11 18:37:45   .D-stc          80
     2021-12-11 18:37:46   .RegL_00.       00:00 02:01 09:01 0A:26 0B:EB 0C:13 10:01 14:06
     2021-12-11 18:37:47   .RegL_01.       00:00 08:00 20:9C 21:00 30:06
     2021-12-11 18:37:48   .RegL_04.WT_1.OG_Bad_WindowRec 00:00 01:01
     2022-04-21 23:36:51   .associatedWith FTS_1.OG_Bad,FTS_1.OG_Bad,WT_1.OG_Bad_WindowRec
     2021-12-11 18:37:47   .peerListRDate  2021-12-11 18:37:47
     2022-05-16 15:04:59   .protLastRcv    20220516150459
     2022-04-21 23:46:49   Activity        alive
     2021-12-11 18:37:46   CommandAccepted yes
     2021-12-11 18:37:45   D-firmware      1.0
     2021-12-11 18:37:45   D-serialNr      PEQ0568528
     2022-05-16 15:04:59   IODev           HMLAN2
     2022-05-16 14:46:19   Last_State      closed
     2021-12-11 18:37:47   PairedTo        0x26EB13
     2021-12-11 18:37:48   R-WT_1.OG_Bad_WindowRec-expectAES off
     2021-12-11 18:37:48   R-WT_1.OG_Bad_WindowRec-peerNeedsBurst on
     2021-12-11 18:36:17   R-cyclicInfoMsg on
     2021-12-11 18:37:47   R-eventDlyTime  0 s
     2021-12-11 18:37:47   R-msgScPosA     open
     2021-12-11 18:37:47   R-msgScPosB     closed
     2021-12-11 18:36:17   R-pairCentral   0x26EB13
     2021-12-11 18:36:17   R-sabotageMsg   on
     2021-12-11 18:37:47   R-sign          off
     2021-12-11 18:36:17   R-transmDevTryMax 6
     2021-12-11 18:37:47   R-transmitTryMax 6
     2022-05-16 15:04:44   Signal_repetitions 0
     2022-05-16 09:57:44   Timer           -1
     2022-05-16 15:04:59   alive           yes
     2022-05-16 15:04:59   battery         ok
     2021-12-11 19:07:18   cfgState        PeerVerf
     2022-05-16 15:04:59   commState       CMDs_done
     2022-05-16 15:04:59   contact         closed (to HMVCCU)
     2022-04-21 23:36:51   peerList        WT_1.OG_Bad_WindowRec
     2022-05-16 15:04:59   recentStateType info
     2022-05-16 15:04:59   sabotageError   off
     2022-05-16 15:04:59   state           closed
     2022-05-16 14:46:20   trigger_cnt     54
   helper:
     HM_CMDNR   228
     lastMsgTm  1652706299.3799
     mId        00C7
     peerFriend peerAct,peerVirt
     peerIDsState complete
     peerOpt    4:threeStateSensor
     regLst     0,1,4p
     rxType     28
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    WT_1.OG_Bad_WindowRec:no:1650577011.3397
       TmplTs     1650577011.3397
       cmdKey     1:1:0::FTS_1.OG_Bad:00C7:01:WT_1.OG_Bad_WindowRec
       cmdLst:
         assignHmKey noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         deviceRename -newName-
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerChan   -btnNumber- -actChn- [({single})] [({set}|unset)] [actor|remote|both]
         peerSmart  -peerOpt-
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         tplSet_WT_1.OG_Bad_WindowRec -tplPeer-
         trgEventL  -peer- -condition-
         trgEventS  -peer- -condition-
         trgPressL  [(-peer-|{all})]
         trgPressS  [(-peer-|{all})]
         unpair     noArg
       lst:
         condition  closed,open,tilted
         peer       WT_1.OG_Bad_WindowRec
         peerOpt    remove_WT_1.OG_Bad_WindowRec,1K_Aktor,4K_Switch_K1,4K_Switch_K2,4K_Switch_K3,4K_Switch_K4,FSA_Energiemesser_Sw,FSA_Fhem_Speaker,FSA_WaMa_Sw,GTor_Antrieb,HMVCCU_Btn4,HM_686E79_WindowRec,HM_686E79_remote,HT_1.OG_Bad_WindowRec,HT_1.OG_Bad_remote,HT_Arbeitszimmer_WindowRec,HT_Arbeitszimmer_remote,HT_Kueche_WindowRec,HT_Kueche_remote,RolloAktor_AZ_l,RolloAktor_Kueche,RolloAktor_WZ_Fenster,RolloAktor_WZ_Terrassentuer,WT_1.OG_Bad_remote,WT_Arbeitszimmer_WindowRec,WT_Arbeitszimmer_remote
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        0
       tpl        0
     io:
       flgs       0
       newChn     +687F37,00,03,00
       nextSend   1652706299.47628
       rxt        2
       vccu       HMVCCU
       p:
         687F37
         00
         03
         00
       prefIO:
         HMLAN2
     mRssi:
       mNo        E4
       io:
         HMLAN1:
           -79
           -79
         HMLAN2:
           -73
           -73
         HMUSB1:
           -60
           -60
     peerIDsH:
       00000000   broadcast
       686DD103   WT_1.OG_Bad_WindowRec
     prt:
       bErr       0
       sProc      0
       sleeping   1
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
     rpt:
       IO         HMUSB1
       flg        A
       ts         1652706299.3799
       ack:
         HASH(0xaaab199efb50)
         E4800226EB13687F3700
     rssi:
       at_HMLAN1:
         avg        -78.8410732714138
         cnt        969
         lst        -79
         max        -71
         min        -99
       at_HMLAN2:
         avg        -69.3847926267281
         cnt        868
         lst        -75
         max        -55
         min        -85
       at_HMUSB1:
         avg        -60.7319587628866
         cnt        970
         lst        -60
         max        -50
         min        -73
     tmpl:
   .mId       00C7
   AA_Examine on
   AA_Level   high
   Batt_Changedate 2020-12-01
   DbLogExclude .*
   IOgrp      HMVCCU:HMLAN2
   Init_Timer 15
   Signal_Rep_Count 3
   Signal_Rep_Time 5
   Temp_control 1
   Voicetext  Badfenster im ersten Stock offen
   actCycle   028:00
   actStatus  alive
   autoReadReg 4_reqStatus
   comment    Fensterkontakt ist mit WT gepeert
   devStateIcon open:fts_window_1w_open@red closed:fts_window_1w@green deact:fts_window_1w@lightgrey
   enable     1
   event-on-change-reading state
   expert     defReg,allReg
   firmware   1.0
   group      FTS
   icon       fts_window_1w@black
   model      HM-SEC-SCO
   peerIDs    00000000,686DD103
   room       1.OG_Nord,CUL
   serialNr   PEQ0568528
   subType    threeStateSensor
   userattr   AA_Examine AA_Level Init_Timer Signal_Rep_Count Signal_Rep_Time Temp_control
Frage mich, woher das kommen könnte und habe im Forum dazu noch nichts gefunden.
Modulversion: 10_CUL_HM.pm          25298 2021-12-05 08:23:08Z martinp876
Vielen Dank im voraus für Hinweise.
Alex
- RPI 4 fhem in Docker, 2 x Arduino Uno, HM-GW, HM-Dev. (Fensterkontakte, HK-Thermostate, div. Aktoren), JeeLink,
- GPIOs, HM-LAN, ESPs (MQTT2)
-Überwachung Fenster/Türen/Licht, HK-Thermostatregelung, Rollosteuerung, Überw. Betriebstemperaturen Heizung, Erfassung Gas/Wasser, PV-Anl., Wetter (WS1600)
frank
FHEM: 6.0(SVN) => Pi3(buster)
TomLee
Zitat von: Homalix99 am 16 Mai 2022, 15:18:55
seit Kurzem ...
Frage mich, woher das kommen könnte ...
Vor Kurzem showInternalValues in global aktiviert ?
Homalix99
Danke für den Hinweis,
kann mich zwar nicht mehr erinnern, ob und zu welchem Zweck ich das gesetzt haben sollte. Vielleicht kam es mit Umstellung auf Docker, keine Ahnung.
Alex
