FHEM > Automatisierung
HTTPMOD json auslesen (grocy)
Kharim:
Hi ihr,
ich habe hier ein grocy laufen....
(https://grocy.info/de)
Das Teil hat eine API und soll Json zurück geben.
Leider bekomme ich dies mit HTTPMOD nicht ausgelesen...
Sieht jemand den Fehler?
Ausgabe im Browser:
--- Code: ---{
"due_products": [],
"overdue_products": [
"amount": "2",
"amount_aggregated": "2",
"value": "0.0",
"best_before_date": "2020-08-30",
"amount_opened": "1",
"amount_opened_aggregated": "1",
"is_aggregated_amount": "0",
"due_type": "1",
"product_id": "4",
"product": {
"id": "4",
"name": "Vomacur",
"description": "<p>Bei Schwindel, Übelkeit und Erbrechen<br /></p>",
"product_group_id": "1",
"active": "1",
"location_id": "4",
"shopping_location_id": "",
"qu_id_purchase": "4",
"qu_id_stock": "4",
"qu_factor_purchase_to_stock": "1.0",
"min_stock_amount": "0",
"default_best_before_days": "0",
"default_best_before_days_after_open": "0",
"default_best_before_days_after_freezing": "0",
"default_best_before_days_after_thawing": "0",
"picture_file_name": "",
"enable_tare_weight_handling": "0",
"tare_weight": "0.0",
"not_check_stock_fulfillment_for_recipes": "0",
"parent_product_id": "24",
"calories": "0",
"cumulate_min_stock_amount_of_sub_products": "0",
"due_type": "1",
"quick_consume_amount": "1.0",
"hide_on_stock_overview": "0",
"default_stock_label_type": "0",
"should_not_be_frozen": "0",
"row_created_timestamp": "2022-06-25 10:25:28",
"treat_opened_as_out_of_stock": "1",
"no_own_stock": "0",
"default_consume_location_id": "4",
"move_on_open": "0"
"amount": "3",
"amount_aggregated": "3",
"value": "0.0",
"best_before_date": "2020-12-30",
"amount_opened": "0",
"amount_opened_aggregated": "0",
"due_type": "1",
"product_id": "5",
"product": {
"id": "5",
"name": "Otriven",
"description": "<p>Schnupfen und Nasentropfen<br /></p>",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"parent_product_id": "22",
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 10:27:54",
"move_on_open": "0"
"amount": "3",
"amount_aggregated": "3.0",
"value": "0.0",
"best_before_date": "2021-03-30",
"amount_opened_aggregated": "0.0",
"due_type": "1",
"product_id": "16",
"product": {
"id": "16",
"name": "Zinkoxidsalbe",
"description": "",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"parent_product_id": null,
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 10:54:22",
"default_consume_location_id": "",
"move_on_open": "0"
"amount": "2",
"value": "0.0",
"best_before_date": "2020-10-30",
"due_type": "1",
"product_id": "17",
"product": {
"id": "17",
"name": "Salbubronch",
"description": "",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"default_best_before_days_after_open": "120",
"parent_product_id": "23",
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 10:58:12",
"move_on_open": "0"
"amount": "1",
"amount_aggregated": "1.0",
"value": "0.0",
"best_before_date": "2022-01-30",
"amount_opened_aggregated": "1.0",
"due_type": "1",
"product_id": "18",
"product": {
"id": "18",
"name": "Fiebersaft Paracetamol",
"description": "<p>Fiebersaft<br /></p>",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"min_stock_amount": "1",
"default_best_before_days_after_open": "180",
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 11:01:26",
"move_on_open": "0"
"amount": "0",
"amount_aggregated": "5.0",
"value": "0",
"is_aggregated_amount": "1",
"due_type": "1",
"product_id": "22",
"product": {
"id": "22",
"name": "SA Nasentropfen ",
"description": "",
"product_group_id": "",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"picture_file_name": null,
"calories": "0",
"cumulate_min_stock_amount_of_sub_products": "1",
"due_type": "1",
"row_created_timestamp": "2022-06-25 11:12:06",
"move_on_open": "0"
"amount": "0",
"value": "0",
"amount_opened_aggregated": "2.0",
"due_type": "1",
"product_id": "23",
"product": {
"id": "23",
"name": "SA Hustensaft ",
"description": "",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 11:12:50",
"move_on_open": "0"
"amount": "0",
"value": "0",
"due_type": "1",
"product_id": "24",
"product": {
"id": "24",
"name": "SA Übelkeit ",
"description": "",
"active": "1",
"location_id": "4",
"qu_id_stock": "4",
"calories": "0",
"due_type": "1",
"row_created_timestamp": "2022-06-25 11:14:38",
"move_on_open": "0"
"expired_products": [],
"missing_products": [
"id": "18",
"amount_missing": "1.0",
"is_partly_in_stock": "1"
"id": "20",
"name": "Zäpfchen Nurofen",
--- Ende Code ---
HTTPMOD Device:
--- Code: ---Internals:
BUSY 0
DEF http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14 0
FUUID 62b72336-f33f-8ab7-2d88-66a1f39d2622b0d1
Interval 0
MainURL http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14
ModuleVersion 4.1.12 - 19.4.2022
NAME grocy
NOTIFYDEV global
NR 495
NTFY_ORDER 50-grocy
STATE ???
TYPE HTTPMOD
value
HttpUtils:
NAME
addr http://192.168.xxx.xxx:9283
auth 0
code 200
compress 1
conn
data
displayurl http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14
header GROCY-API-KEY: 9spjl8oNvKVopd6c7gXXXXXXXXXXXXXX5MT4bw28J
host 192.168.xxx.xxx
httpheader HTTP/1.1 200 OK
Server: nginx/1.20.2
Date: Sat, 25 Jun 2022 15:08:30 GMT
Content-Type: application/json
Connection: close
X-Powered-By: PHP/8.0.13
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS
Access-Control-Allow-Headers: *
httpversion 1.0
hu_blocking 0
hu_filecount 1
hu_port 9283
hu_portSfx :9283
ignoreredirects 1
loglevel 4
path /api/stock/volatile?due_soon_days=14
protocol http
redirects 0
timeout 2
sslargs:
QUEUE:
REQUEST:
context reading
data
ignoreredirects 0
num unknown
retryCount 0
type update
getHeader1 Content-Type: application/json
getHeader2 Accept: */*
reading01JSON name
reading01Name Name
reading01RecombineExpr join ",", @matchlist
requestHeader01 GROCY-API-KEY: 9spjl8oNvKVopd6c7gXXXXXXXXXXXXXX5MT4bw28J
room Grocy
userattr get01URL getHeader1:textField-long getHeader2:textField-long getURL reading01JSON reading01Name reading01RecombineExpr:textField-long requestHeader01
verbose 5
--- Ende Code ---
FHEM Log:
--- Code: ---2022.06.25 17:15:10 5: grocy: set called with reread
2022.06.25 17:15:10 4: grocy: GetUpdate called (reread)
2022.06.25 17:15:10 5: grocy: AddToQueue adds type update to URL http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14, no data, header GROCY-API-KEY: 9spjl8oNvKVopd6c7gXXXXXXXXXXXXXX5MT4bw28J, retry 0, initial queue len: 0
2022.06.25 17:15:10 5: grocy: HandleSendQueue called from HTTPMOD::AddToSendQueue, qlen = 1
2022.06.25 17:15:10 4: grocy: HandleSendQueue sends update with timeout 2 to http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14, No Data,
header: GROCY-API-KEY: 9spjl8oNvKVopd6c7gXXXXXXXXXXXXXX5MT4bw28J
2022.06.25 17:15:10 5: grocy: ReadCallback called from __ANON__
2022.06.25 17:15:10 4: grocy: Read callback: request type was update retry 0,
header: HTTP/1.1 200 OK
Date: Sat, 25 Jun 2022 15:15:10 GMT
Connection: close
Access-Control-Allow-Headers: *, body length 9176
2022.06.25 17:15:10 5: grocy: Read callback: body
{"due_products":[],"overdue_products":[{"amount":"2","amount_aggregated":"2","value":"0.0","best_before_date":"2020-08-30","amount_opened":"1","amount_opened_aggregated":"1","is_aggregated_amount":"0","due_type":"1","product_id":"4","product":{"id":"4","name":"Vomacur","description":"<p>Bei Schwindel, \u00dcbelkeit und Erbrechen<br \/><\/p>","product_group_id":"1","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"0","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":"","enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":"24","calories":"0","cumulate_min_stock_amount_of_sub_products":"0","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 10:25:28","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}},{"amount":"3","amount_aggregated":"3","value":"0.0","best_before_date":"2020-12-30","amount_opened":"0","amount_opened_aggregated":"0","is_aggregated_amount":"0","due_type":"1","product_id":"5","product":{"id":"5","name":"Otriven","description":"<p>Schnupfen und Nasentropfen<br \/><\/p>","product_group_id":"1","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"0","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":"","enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":"22","calories":"0","cumulate_min_stock_amount_of_sub_products":"0","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 10:27:54","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}},{"amount":"3","amount_aggregated":"3.0","value":"0.0","best_before_date":"2021-03-30","amount_opened":"0","amount_opened_aggregated":"0.0","is_aggregated_amount":"0","due_type":"1","product_id":"16","product":{"id":"16","name":"Zinkoxidsalbe","description":"","product_group_id":"1","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"0","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":"","enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":null,"calories":"0","cumulate_min_stock_amount_of_sub_products":"0","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 10:54:22","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"","move_on_open":"0"}},{"amount":"2","amount_aggregated":"2","value":"0.0","best_before_date":"2020-10-30","amount_opened":"1","amount_opened_aggregated":"1","is_aggregated_amount":"0","due_type":"1","product_id":"17","product":{"id":"17","name":"Salbubronch","description":"","product_group_id":"1","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"0","default_best_before_days":"0","default_best_before_days_after_open":"120","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":"","enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":"23","calories":"0","cumulate_min_stock_amount_of_sub_products":"0","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 10:58:12","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}},{"amount":"1","amount_aggregated":"1.0","value":"0.0","best_before_date":"2022-01-30","amount_opened":"1","amount_opened_aggregated":"1.0","is_aggregated_amount":"0","due_type":"1","product_id":"18","product":{"id":"18","name":"Fiebersaft Paracetamol","description":"<p>Fiebersaft<br \/><\/p>","product_group_id":"1","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"1","default_best_before_days":"0","default_best_before_days_after_open":"180","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":"","enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":null,"calories":"0","cumulate_min_stock_amount_of_sub_products":"0","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 11:01:26","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"","move_on_open":"0"}},{"amount":"0","amount_aggregated":"5.0","value":"0","best_before_date":"2020-12-30","amount_opened":"0","amount_opened_aggregated":"0.0","is_aggregated_amount":"1","due_type":"1","product_id":"22","product":{"id":"22","name":"SA Nasentropfen ","description":"","product_group_id":"","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"1","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":null,"enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":null,"calories":"0","cumulate_min_stock_amount_of_sub_products":"1","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 11:12:06","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}},{"amount":"0","amount_aggregated":"5.0","value":"0","best_before_date":"2020-10-30","amount_opened":"0","amount_opened_aggregated":"2.0","is_aggregated_amount":"1","due_type":"1","product_id":"23","product":{"id":"23","name":"SA Hustensaft ","description":"","product_group_id":"","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"1","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":null,"enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":null,"calories":"0","cumulate_min_stock_amount_of_sub_products":"1","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 11:12:50","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}},{"amount":"0","amount_aggregated":"3.0","value":"0","best_before_date":"2020-08-30","amount_opened":"0","amount_opened_aggregated":"1.0","is_aggregated_amount":"1","due_type":"1","product_id":"24","product":{"id":"24","name":"SA \u00dcbelkeit ","description":"","product_group_id":"","active":"1","location_id":"4","shopping_location_id":"","qu_id_purchase":"4","qu_id_stock":"4","qu_factor_purchase_to_stock":"1.0","min_stock_amount":"1","default_best_before_days":"0","default_best_before_days_after_open":"0","default_best_before_days_after_freezing":"0","default_best_before_days_after_thawing":"0","picture_file_name":null,"enable_tare_weight_handling":"0","tare_weight":"0.0","not_check_stock_fulfillment_for_recipes":"0","parent_product_id":null,"calories":"0","cumulate_min_stock_amount_of_sub_products":"1","due_type":"1","quick_consume_amount":"1.0","hide_on_stock_overview":"0","default_stock_label_type":"0","should_not_be_frozen":"0","row_created_timestamp":"2022-06-25 11:14:38","treat_opened_as_out_of_stock":"1","no_own_stock":"0","default_consume_location_id":"4","move_on_open":"0"}}],"expired_products":[],"missing_products":[{"id":"18","name":"Fiebersaft Paracetamol","amount_missing":"1.0","is_partly_in_stock":"1"},{"id":"20","name":"Z\u00e4pfchen Nurofen","amount_missing":"1.0","is_partly_in_stock":"1"}]}
2022.06.25 17:15:10 4: grocy: BodyDecode found no charset header (bodyDecode was set to auto)
2022.06.25 17:15:10 4: grocy: extracted JSON values to internal
2022.06.25 17:15:10 5: grocy: GetCookies is looking for Cookies
2022.06.25 17:15:10 5: grocy: ExtractSid called, context reading, num unknown
2022.06.25 17:15:10 4: grocy: checking for redirects, code=200, ignore=0
2022.06.25 17:15:10 4: grocy: no redirects to handle
2022.06.25 17:15:10 5: grocy: Read callback sets LAST_REQUEST to update
2022.06.25 17:15:10 5: grocy: CheckAuth decided no authentication required
2022.06.25 17:15:10 5: grocy: UpdateReadingList created list of reading.* nums to parse during getUpdate as 01
2022.06.25 17:15:10 5: grocy: Read starts parsing response to update with defined readings: 01
2022.06.25 17:15:10 5: grocy: ExtractReading Name with json name ...
2022.06.25 17:15:10 5: grocy: ExtractReading Name with json name did not match a key directly - trying regex match to create a list
2022.06.25 17:15:10 5: grocy: ExtractReading Name with json /^name/ got keylist
2022.06.25 17:15:10 5: grocy: ExtractReading Name did not match
2022.06.25 17:15:10 4: grocy: Read response to update didn't match any Reading
2022.06.25 17:15:10 5: grocy: HandleSendQueue called from HTTPMOD::ReadCallback, qlen = 0
2022.06.25 17:15:10 5: grocy: HandleSendQueue found no usable entry in queue
--- Ende Code ---
Im Read callback: body liegt der Inhalt... Zugang und Abfrageergebnis sind also da.....aber er findet nichts??
Danke,
Kharim
betateilchen:
Warum nimmst Du nicht JsonMod?
Deinen JSON-Inhalt habe ich in eine Datei /tmp/grocy.json geschrieben, die am Ende fehlende geschweifte Klammer ergänzt und folgendes probiert:
--- Code: ---defmod json_test JsonMod file://tmp/grocy.json
attr json_test readingList complete()
--- Ende Code ---
Das liefert als Ergebnis
--- Code: ---setstate json_test 2022-06-25 17:44:30 missing_products.0.amount_missing 1.0
setstate json_test 2022-06-25 17:44:30 missing_products.0.id 18
setstate json_test 2022-06-25 17:44:30 missing_products.0.is_partly_in_stock 1
setstate json_test 2022-06-25 17:44:30 missing_products.0.name Fiebersaft Paracetamol
setstate json_test 2022-06-25 17:44:30 missing_products.1.amount_missing 1.0
setstate json_test 2022-06-25 17:44:30 missing_products.1.id 20
setstate json_test 2022-06-25 17:44:30 missing_products.1.is_partly_in_stock 1
setstate json_test 2022-06-25 17:44:30 missing_products.1.name Zäpfchen Nurofen
setstate json_test 2022-06-25 17:44:30 overdue_products.0.amount 2
setstate json_test 2022-06-25 17:44:30 overdue_products.0.amount_aggregated 2
setstate json_test 2022-06-25 17:44:30 overdue_products.0.amount_opened 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.amount_opened_aggregated 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.best_before_date 2020-08-30
setstate json_test 2022-06-25 17:44:30 overdue_products.0.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.is_aggregated_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.cumulate_min_stock_amount_of_sub_products 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.description <p>Bei Schwindel, Übelkeit und Erbrechen<br /></p>
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.min_stock_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.name Vomacur
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.parent_product_id 24
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.product_group_id 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.row_created_timestamp 2022-06-25 10:25:28
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.0.product_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.0.value 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.amount 3
setstate json_test 2022-06-25 17:44:30 overdue_products.1.amount_aggregated 3
setstate json_test 2022-06-25 17:44:30 overdue_products.1.amount_opened 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.amount_opened_aggregated 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.best_before_date 2020-12-30
setstate json_test 2022-06-25 17:44:30 overdue_products.1.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.1.is_aggregated_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.cumulate_min_stock_amount_of_sub_products 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.description <p>Schnupfen und Nasentropfen<br /></p>
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.id 5
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.min_stock_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.name Otriven
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.parent_product_id 22
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.product_group_id 1
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.row_created_timestamp 2022-06-25 10:27:54
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.1.product_id 5
setstate json_test 2022-06-25 17:44:30 overdue_products.1.value 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.amount 3
setstate json_test 2022-06-25 17:44:30 overdue_products.2.amount_aggregated 3.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.amount_opened 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.amount_opened_aggregated 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.best_before_date 2021-03-30
setstate json_test 2022-06-25 17:44:30 overdue_products.2.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.2.is_aggregated_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.cumulate_min_stock_amount_of_sub_products 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_consume_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.description
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.id 16
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.min_stock_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.name Zinkoxidsalbe
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.parent_product_id
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.product_group_id 1
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.row_created_timestamp 2022-06-25 10:54:22
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.2.product_id 16
setstate json_test 2022-06-25 17:44:30 overdue_products.2.value 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.amount 2
setstate json_test 2022-06-25 17:44:30 overdue_products.3.amount_aggregated 2
setstate json_test 2022-06-25 17:44:30 overdue_products.3.amount_opened 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.amount_opened_aggregated 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.best_before_date 2020-10-30
setstate json_test 2022-06-25 17:44:30 overdue_products.3.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.is_aggregated_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.cumulate_min_stock_amount_of_sub_products 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_best_before_days_after_open 120
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.description
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.id 17
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.min_stock_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.name Salbubronch
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.parent_product_id 23
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.product_group_id 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.row_created_timestamp 2022-06-25 10:58:12
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.3.product_id 17
setstate json_test 2022-06-25 17:44:30 overdue_products.3.value 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.amount_aggregated 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.amount_opened 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.amount_opened_aggregated 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.best_before_date 2022-01-30
setstate json_test 2022-06-25 17:44:30 overdue_products.4.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.is_aggregated_amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.cumulate_min_stock_amount_of_sub_products 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_best_before_days_after_open 180
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_consume_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.description <p>Fiebersaft<br /></p>
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.id 18
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.min_stock_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.name Fiebersaft Paracetamol
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.parent_product_id
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.product_group_id 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.row_created_timestamp 2022-06-25 11:01:26
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.4.product_id 18
setstate json_test 2022-06-25 17:44:30 overdue_products.4.value 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.amount_aggregated 5.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.amount_opened 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.amount_opened_aggregated 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.best_before_date 2020-12-30
setstate json_test 2022-06-25 17:44:30 overdue_products.5.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.is_aggregated_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.cumulate_min_stock_amount_of_sub_products 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.description
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.id 22
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.min_stock_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.name SA Nasentropfen
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.parent_product_id
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.product_group_id
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.row_created_timestamp 2022-06-25 11:12:06
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.5.product_id 22
setstate json_test 2022-06-25 17:44:30 overdue_products.5.value 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.amount_aggregated 5.0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.amount_opened 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.amount_opened_aggregated 2.0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.best_before_date 2020-10-30
setstate json_test 2022-06-25 17:44:30 overdue_products.6.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.is_aggregated_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.cumulate_min_stock_amount_of_sub_products 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.description
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.id 23
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.min_stock_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.name SA Hustensaft
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.parent_product_id
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.product_group_id
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.row_created_timestamp 2022-06-25 11:12:50
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.6.product_id 23
setstate json_test 2022-06-25 17:44:30 overdue_products.6.value 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.amount 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.amount_aggregated 3.0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.amount_opened 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.amount_opened_aggregated 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.best_before_date 2020-08-30
setstate json_test 2022-06-25 17:44:30 overdue_products.7.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.is_aggregated_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.active 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.calories 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.cumulate_min_stock_amount_of_sub_products 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_best_before_days 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_best_before_days_after_freezing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_best_before_days_after_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_best_before_days_after_thawing 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_consume_location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.default_stock_label_type 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.description
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.due_type 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.enable_tare_weight_handling 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.hide_on_stock_overview 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.id 24
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.location_id 4
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.min_stock_amount 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.move_on_open 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.name SA Übelkeit
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.no_own_stock 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.not_check_stock_fulfillment_for_recipes 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.parent_product_id
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.picture_file_name
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.product_group_id
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.qu_factor_purchase_to_stock 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.qu_id_purchase 4
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.qu_id_stock 4
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.quick_consume_amount 1.0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.row_created_timestamp 2022-06-25 11:14:38
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.shopping_location_id
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.should_not_be_frozen 0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.tare_weight 0.0
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product.treat_opened_as_out_of_stock 1
setstate json_test 2022-06-25 17:44:30 overdue_products.7.product_id 24
setstate json_test 2022-06-25 17:44:30 overdue_products.7.value 0
--- Ende Code ---
Einfacher geht es doch gar nicht?
Kharim:
Weil es mir da nicht gelingt, eine vernünftige Rückmeldung zu bekommen.
Vermutlich durch den nötigen API Key....
Log:
--- Code: ---2022.06.26 13:58:08 5: HttpUtils url=http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14
2022.06.26 13:58:08 4: IP: 192.168.xxx.xxx -> 192.168.xxx.xxx
2022.06.26 13:58:08 5: HttpUtils request header:
GET /api/stock/volatile?due_soon_days=14 HTTP/1.0
Host: 192.168.xxx.xxx:9283
User-Agent: fhem
Accept-Encoding: gzip,deflate
Accept: application/json
Accept-Charset: utf-8, iso-8859-1
2022.06.26 13:58:08 4: http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14: HTTP response code 401
2022.06.26 13:58:08 5: HttpUtils http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14: Got data, length: 0
2022.06.26 13:58:08 5: HttpUtils response header:
HTTP/1.1 401 Unauthorized
Date: Sun, 26 Jun 2022 11:58:08 GMT
Content-Type: text/html; charset=UTF-8
Connection: close
2022.06.26 13:58:08 4: [grocy2] api encoding is UTF-8, designated encoder is utf-8-strict
--- Ende Code ---
Device:
API_LAST_RES 1656244800.16419
API__LAST_MSG invalid server response
FUUID 62b84962-f33f-8ab7-46cc-e2533cf93dd8bb66
NAME grocy2
NEXT 2022-06-26 15:00:00
NR 19461
SECRETS GROCY-API-KEY
SOURCE http://192.168.xxx.xxx:9283/api/stock/volatile?due_soon_days=14 (401)
STATE ???
SVN 22987 2020-10-18 13:26:05 UTC
TYPE JsonMod
CONFIG:
IN_REQUEST 0
SECRET:
room Grocy
verbose 5
--- Ende Code ---
Es gibt ja hier keinen requestHeader, sondern nur dieses secret...das will aber irgendwie nicht....
betateilchen:
--- Zitat von: Kharim am 26 Juni 2022, 14:01:57 ---Weil es mir da nicht gelingt, eine vernünftige Rückmeldung zu bekommen.
--- Ende Zitat ---
Entweder gibst Du den API Key einfach in der URL mit
--- Code: ---defmod grocy JsonMod https://<myGrocyServer>/api/stock?GROCY-API-KEY=eJLluu0x...
--- Ende Code ---
oder Du verwendest das Attribut httpHeader
attr grocy httpHeader GROCY-API-KEY: eJLluu0x...
--- Ende Code ---
Das funktioniert beides einwandfrei.
--- Zitat von: Kharim am 26 Juni 2022, 14:01:57 ---Es gibt ja hier keinen requestHeader
--- Ende Zitat ---
Doch, gibt es. Siehe zweite Variante.
Die Variante mit dem secret funktioniert bei mir auch nicht dauerhaft zuverlässig, deshalb habe ich den APIkey in das Attribut gepackt.
Kharim:
Ah...ich danke dir.
Dann werde ich das noch einmal umbauen....
Meine Fehler oben beim HTTPMOD habe ich nun doch noch gefunden...
Nicht nach "name" suchen, sondern nach "missing_products_[0-9]{2}_name"
Keine Ahnung ob typisch JSON oder Anwendungsfall, aber man muss quasi den "Pfad" angeben und dann auch noch per RegEx durchzählen.
Navigation
[0] Themen-Index
[#] Nächste Seite
Zur normalen Ansicht wechseln
