ASC Rollos Fahren nicht nach brightness und shading geht leider auch nicht
Begonnen von HoTi, 28 Juli 2022, 11:13:04
HoTi
Also fahren will das Rollo trotzdem nicht. Es bleibt bei der Information
Zitat2022-08-01 12:53:12   ASC_ShadingMessage INFO: current shading status is 'in' - next check in 0.5m
Bedingungen sind alle erfüllt.
   DEF        PEQ0181126:1
   FUUID      62d7fb06-f33f-8029-526f-fcc6453529b85677
   IODev      d_ccu
   NAME       HM_EG_RO_Wohnzimmer_links
   NR         25
   STATE      open
   TYPE       HMCCUCHN
   ccuaddr    PEQ0181126:1
   ccudevstate active
   ccuif      BidCos-RF
   ccuname    HM-LC-Bl1PBU-FM PEQ0181126:1
   ccurolectrl BLIND
   ccurolestate BLIND
   ccusubtype HM-LC-Bl1PBU-FM
   ccutype    HM-LC-Bl1PBU-FM
   eventCount 37
   firmware   2.11
   readonly   no
     2022-07-20 15:31:55   ASC_Enable      on
     2022-08-01 07:20:07   ASC_Time_DriveDown 01.08.2022 - 22:00
     2022-08-01 07:20:07   ASC_Time_DriveUp 02.08.2022 - 07:00
     2022-08-01 06:39:54   DIRECTION       none
     2022-07-28 13:27:12   INHIBIT         false
     2022-07-28 13:26:44   IODev           d_ccu
     2022-08-01 06:39:54   LEVEL           open
     2022-08-01 06:39:54   WORKING         no
     2022-07-28 13:27:12   activity        alive
     2022-07-28 13:26:44   associatedWith  Rollosteuerung
     2022-08-01 06:39:54   control         open
     2022-08-01 06:39:54   devstate        ok
     2022-08-01 06:39:54   hmstate         open
     2022-08-01 06:39:54   level           open
     2022-08-01 06:39:54   pct             100
     2022-07-28 13:27:12   rssidevice      -58
     2022-07-28 13:27:12   rssipeer        -54
     2022-07-28 13:27:12   sign            off
     2022-08-01 06:39:54   state           open
   hmccu:
     channels   1
     detect     1
     devspec    PEQ0181126:1
     nodefaults 1
     role       1:BLIND
     setDefaults 0
     cmdlist:
       get
       set        up pct open:noArg stop:noArg down close:noArg toggle:noArg
     control:
       chn        1
       dpt        LEVEL
     dp:
       0.AES_KEY:
         VALUES:
           NVAL       0
           ONVAL      0
           OSVAL      off
           OVAL       0
           SVAL       off
           VAL        0
       0.CONFIG_PENDING:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       0.DEVICE_IN_BOOTLOADER:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       0.DUTYCYCLE:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       0.RSSI_DEVICE:
         VALUES:
           NVAL       -58
           ONVAL      -58
           OSVAL      -58
           OVAL       198
           SVAL       -58
           VAL        198
       0.RSSI_PEER:
         VALUES:
           NVAL       -54
           ONVAL      -54
           OSVAL      -54
           OVAL       202
           SVAL       -54
           VAL        202
       0.STICKY_UNREACH:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       0.UNREACH:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      alive
           OVAL       false
           SVAL       alive
           VAL        false
       0.UPDATE_PENDING:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       1.DIRECTION:
         VALUES:
           NVAL       0
           ONVAL      1
           OSVAL      up
           OVAL       1
           SVAL       none
           VAL        0
       1.INHIBIT:
         VALUES:
           NVAL       false
           ONVAL      false
           OSVAL      false
           OVAL       false
           SVAL       false
           VAL        false
       1.LEVEL:
         VALUES:
           NVAL       100
           ONVAL      12
           OSVAL      12
           OVAL       0.120000
           SVAL       open
           VAL        1.000000
       1.WORKING:
         VALUES:
           NVAL       0
           ONVAL      1
           OSVAL      yes
           OVAL       1
           SVAL       no
           VAL        0
     roleCmds:
       get:
       set:
         close:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:LEVEL:0
           usage      close
           subcmd:
             000:
               args       0
               dpt        LEVEL
               fnc
               max        1.000000
               min        0.000000
               parname    LEVEL
               partype    3
               ps         VALUES
               scn        000
               unit       100%
         down:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:LEVEL:?delta=-20
           usage      down [delta]
           subcmd:
             000:
               args       -20
               dpt        LEVEL
               fnc
               max        1.000000
               min        0.000000
               parname    delta
               partype    2
               ps         VALUES
               scn        000
               unit       100%
         open:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:LEVEL:100
           usage      open
           subcmd:
             000:
               args       100
               dpt        LEVEL
               fnc
               max        1.000000
               min        0.000000
               parname    LEVEL
               partype    3
               ps         VALUES
               scn        000
               unit       100%
         pct:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:LEVEL:?level
           usage      pct level
           subcmd:
             000:
               args
               dpt        LEVEL
               fnc
               max        1.000000
               min        0.000000
               parname    level
               partype    2
               ps         VALUES
               scn        000
               unit       100%
         stop:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:STOP:1
           usage      stop
           subcmd:
             000:
               args       1
               dpt        STOP
               fnc
               max        1
               min        0
               parname    STOP
               partype    3
               ps         VALUES
               scn        000
               unit
         up:
           channel    1
           role       BLIND
           subcount   1
           syntax     V:LEVEL:?delta=+20
           usage      up [delta]
           subcmd:
             000:
               args       +20
               dpt        LEVEL
               fnc
               max        1.000000
               min        0.000000
               parname    delta
               partype    2
               ps         VALUES
               scn        000
               unit       100%
     state:
       chn        1
       dpt        LEVEL
   ASC        2
   ASC_BrightnessSensor HM_GT_LS_Sued:LUX
   ASC_Down   brightness
   ASC_Pos_Reading pct
   ASC_Shading_BetweenTheTime 9:00-14:30
   ASC_Shading_InOutAzimuth 95:265
   ASC_Shading_MinMax_Elevation 25.0:100.0
   ASC_Shading_Min_OutsideTemperature 15
   ASC_Shading_Mode always
   ASC_Shading_StateChange_SunnyCloudy 3500:2500
   ASC_Shading_WaitingPeriod 30
   ASC_TempSensor HM_GT_Wetter:TEMPERATURE
   ASC_Time_Down_Early 19:00
   ASC_Time_Down_Late 22:00
   ASC_Time_Up_Early 6:00
   ASC_Time_Up_Late 7:00
   ASC_Time_Up_WE_Holiday 8:00
   ASC_Up     brightness
   cmdIcon    open:fts_shutter_up stop:fts_shutter_manual close:fts_shutter_down
   event-on-change-reading .*
   group      Rollladen
   room       Rollladen
   substexcl  pct
   userattr   ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforeDayOpen ASC_BlockingTime_beforeNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_CommandTemplate ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_BetweenTheTime ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_ShuttersPlace:window,terrace,awning,EG_window ASC_SlatPosCmd_SlatDevice ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate
   webCmd     pct:open:close:stop
   widgetOverride pct:slider,0,10,100
Viele Grüße aus  Oberbayern
Tim (RettungsTim)
kjmEjfu
Dubios. Denn jetzt erkannt ASC ja richtig, dass es abschatten sollte.
Wenn du aus dem ASC-Device heraus ein "set wiggle" auf das Rollo machst, passiert dann was?
Migriere derzeit zu Home Assistant
HoTi
Ja genau das was es soll.
Shutters Next DriveUp Next DriveDown ASC Up ASC Down ASC Mode Up ASC Mode Down Partymode Lock-Out Last Drive Position Last Position Shading Info
HM_EG_RO_Esszimmer 02.08.2022 - 07:00:01 01.08.2022 - 22:00:01 brightness brightness always always off off none 100 100 out - 13:26:44
HM_EG_RO_Kueche 02.08.2022 - 07:00:01 01.08.2022 - 22:00:01 brightness brightness always always off off none 100 100 out - 13:26:44
HM_EG_RO_WC 02.08.2022 - 07:00:01 01.08.2022 - 22:00:01 brightness brightness always always off off none 100 0 out - 13:26:44
HM_EG_RO_Wohnzimmer_links 02.08.2022 - 07:00:01 01.08.2022 - 22:00:01 brightness brightness always always off off none 100 100 in - 13:20:34
HM_EG_RO_Wohnzimmer_rechts 02.08.2022 - 07:00:01 01.08.2022 - 22:00:01 brightness brightness always always off off none 100 100 in - 13:20:34
HM_OG_RO_Kinderzimmer_Amelie_li 02.08.2022 - 06:00:02 01.08.2022 - 19:30:02 astro astro always always off off none 100 100 out - 13:26:44
HM_OG_RO_Kinderzimmer_Amelie_re 02.08.2022 - 06:00:02 01.08.2022 - 19:30:02 astro astro always always off off none 100 100 out - 13:26:44
HM_OG_RO_Kinderzimmer_Oliver 02.08.2022 - 06:00:02 01.08.2022 - 19:30:02 astro astro always always off off none 100 100 out - 13:26:44
HM_OG_RO_Schlafzimmer 02.08.2022 - 06:00:02 01.08.2022 - 19:30:02 astro astro always always off off manual 49 100 out - 13:26:44
Spannend das Shading Info auf in steht bei den zwei Rollos und die Position 100 ist :-(
Tim (RettungsTim)
kjmEjfu
Manchmal macht ASC merkwürdige Dinge und muss sich erst "fangen", bevor es wie gewünscht funktioniert ...
Du könntest im ASC-Device mal ein "renewAllTimer" auslösen, das hilft hin und wieder auch.
Ansonsten kannst du auch mal schauen was ASC macht, wenn du das Rollo manuell auf 30% fährst. Der Default-Wert für die Abschattung liegt ja bei 20% und nach Ablauf der Blocking-Zeit fürs manuelle Fahren sollte dann irgendwas passieren.
CoolTux
bitte ändern in
ASC_Shading_BetweenTheTime 09:00-14:30
Das TuxNet Wiki:
https://www.cooltux.net
HoTi
bitte ändern in
Danke für den Hinweis habe ich gemacht. Mal sehen ob es morgen dann geht.
Es müsste dann mal die Hilfe angepasst werden  ;)
Tim (RettungsTim)
CoolTux
Ja entweder das oder ich schaue das es auch ohne die 0 funktioniert. Bin leider noch nicht dazu gekommen.
Das TuxNet Wiki:
