FHEM - Hausautomations-Systeme > Home Connect
HC Log Meldung
(1/1)
eddy242:
Ich erhalte diese Logeinträge - die hcconn war zu dem Zeitpunkt sauber da, also nicht logged out etc. Hat jemand eine Idee?
--- Code: ---2022.11.04 08:08:57.497 2: WAX32E91: http request failed: /security/oauth/token: malformed or unsupported URL
2022.11.04 08:08:57.497 1:     main::CallFn                        called by fhem.pl (782)
2022.11.04 08:08:57.497 1:     main::FW_Read                       called by fhem.pl (3972)
2022.11.04 08:08:57.497 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2022.11.04 08:08:57.497 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (1028)
2022.11.04 08:08:57.497 1:     main::AnalyzeCommand                called by ./FHEM/01_FHEMWEB.pm (2840)
2022.11.04 08:08:57.497 1:     main::CommandSet                    called by fhem.pl (1274)
2022.11.04 08:08:57.497 1:     main::DoSet                         called by fhem.pl (1994)
2022.11.04 08:08:57.497 1:     main::CallFn                        called by fhem.pl (1962)
2022.11.04 08:08:57.497 1:     main::HomeConnect_Set               called by fhem.pl (3967)
2022.11.04 08:08:57.497 1:     main::HomeConnect_Init              called by ./FHEM/48_HomeConnect.pm (217)
2022.11.04 08:08:57.497 1:     main::HomeConnectConnection_request called by ./FHEM/48_HomeConnect.pm (293)
2022.11.04 08:08:57.497 1:     main::HomeConnectConnection_RefreshToken called by ./FHEM/48_HomeConnectConnection.pm (309)
2022.11.04 08:08:57.497 1:     main::__ANON__                      called by ./FHEM/48_HomeConnectConnection.pm (233)
2022.11.04 08:08:57.497 1: stacktrace:
2022.11.04 08:08:57.497 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/48_HomeConnectConnection.pm line 233.
--- Ende Code ---
Navigation
[0] Themen-Index
Zur normalen Ansicht wechseln
