Ich habe ein Plot gefunden das noch geht.
# Created by FHEM/98_SVG.pm, 2022-05-09 06:03:37
set output '<OUT>.png'
set xdata time
set xlabel " "
set title ''
set ytics
set y2tics
set grid y2tics
set ylabel ""
set y2label "kwh"
set y2range [0:200]
#DbLog.SMA_EM SMA_Energymeter:SMAEM3009886953_Bezug_Wirkleistung_yesterday::
#DbLog.SMA_EM SMA_Energymeter:SMAEM3009886953_Einspeisung_Wirkleistung_yesterday::
#DbLog.Anwesenheit Inverters:SPOT_EYESTERDAY:::$val=$val/1000
#lp DbLog:DbLog.HKV,offset=-60*60*12:Dum.Energy:TotalConsumptionYDay::
#lp DbLog:DbLog.HKV,offset=-60*60*12:Dum.Energy:TotalConsumptionHomeYDay::
#lp DbLog:DbLog.HKV,offset=-60*60*12:EV_CHarger_22:Energie_YD:::$val=$val/1000
plot "<IN>" using 1:2 axes x1y2 title 'Bezug_Wirkleistung' ls l0fill lw 1 with bars,\
"<IN>" using 1:2 axes x1y2 title 'Einspeisung_Wirkleistung' ls l1fill lw 1 with bars,\
"<IN>" using 1:2 axes x1y2 title 'PV Erzeugung' ls l2 lw 1 with bars,\
"<IN>" using 1:2 axes x1y2 notitle ls l5 lw 2 with points,\
"<IN>" using 1:2 axes x1y2 title 'Verbrauch Gesamt' ls l3 lw 1.5 with lines,\
"<IN>" using 1:2 axes x1y2 title 'Verbrauch Haus' ls l4 lw 1.5 with lines,\
"<IN>" using 1:2 axes x1y2 title 'Verbrauch WB' ls l6 lw 1.5 with lines
