AutoShuttersControl - empty name in readingsBeginUpdate
Begonnen von Aeroschmelz, 17 November 2022, 20:01:56
Aeroschmelz
Hallo
ich erhalte im logfile folgende sich immer wiederholende Meldung, mit der ich leider nichts anfangen kann:
2022.11.17 19:43:36 1: ERROR: empty name in readingsBeginUpdate
2022.11.17 19:43:36 1: stacktrace:
2022.11.17 19:43:36 1:     main::readingsBeginUpdate           called by fhem.pl (5168)
2022.11.17 19:43:36 1:     main::readingsSingleUpdate          called by lib/FHEM/Automation/ShuttersControl.pm (890)
2022.11.17 19:43:36 1:     FHEM::Automation::ShuttersControl::UserAttributs_Readings_ForShutters called by lib/FHEM/Automation/ShuttersControl.pm (360)
2022.11.17 19:43:36 1:     FHEM::Automation::ShuttersControl::Undef called by fhem.pl (3972)
2022.11.17 19:43:36 1:     main::CallFn                        called by fhem.pl (1496)
2022.11.17 19:43:36 1:     main::CommandRereadCfg              called by fhem.pl (1274)
2022.11.17 19:43:36 1:     main::AnalyzeCommand                called by fhem.pl (1125)
2022.11.17 19:43:36 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2842)
2022.11.17 19:43:36 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (2622)
2022.11.17 19:43:36 1:     main::FW_style                      called by ./FHEM/01_FHEMWEB.pm (1204)
2022.11.17 19:43:36 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2022.11.17 19:43:36 1:     main::FW_Read                       called by fhem.pl (3972)
2022.11.17 19:43:36 1:     main::CallFn                        called by fhem.pl (782)
2022.11.17 19:43:36 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 5022.
2022.11.17 19:43:36 1: readingsUpdate(,associatedWith,Rollladenautomatik,none) missed to call readingsBeginUpdate first.
2022.11.17 19:43:36 1:     main::readingsBulkUpdate            called by fhem.pl (5169)
2022.11.17 19:43:36 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4758.
Das endet dann mit:
2022.11.17 19:43:40 1:     main::readingsBulkUpdate            called by fhem.pl (5169)
2022.11.17 19:43:40 1:     main::readingsSingleUpdate          called by lib/FHEM/Automation/ShuttersControl.pm (890)
2022.11.17 19:43:40 1:     FHEM::Automation::ShuttersControl::UserAttributs_Readings_ForShutters called by lib/FHEM/Automation/ShuttersControl.pm (360)
2022.11.17 19:43:40 1:     FHEM::Automation::ShuttersControl::Undef called by fhem.pl (3972)
2022.11.17 19:43:40 1:     main::CallFn                        called by fhem.pl (1496)
2022.11.17 19:43:40 1:     main::CommandRereadCfg              called by fhem.pl (1274)
2022.11.17 19:43:40 1:     main::AnalyzeCommand                called by fhem.pl (1125)
2022.11.17 19:43:40 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2842)
2022.11.17 19:43:40 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (2622)
2022.11.17 19:43:40 1:     main::FW_style                      called by ./FHEM/01_FHEMWEB.pm (1204)
2022.11.17 19:43:40 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2022.11.17 19:43:40 1:     main::FW_Read                       called by fhem.pl (3972)
2022.11.17 19:43:40 1:     main::CallFn                        called by fhem.pl (782)
2022.11.17 19:43:40 3: AutoShuttersControl (Rollladenautomatik) - delete device Rollladenautomatik
Das Device habe ich bereits neu angelegt, das hat aber nichts gebracht. Teilweise fahren die Rollläden auch nicht und das behebt sich erst nach einem Neustart, allerdings kommen die Log-Meldungen auch nicht zeitgleich dazu. Folgende weitere Info. Ich habe in einem Rollladen-Device ein userreadings angelegt, um die Anwesenheit des Resident Devices von "Schläft" über ein DoIF auf "Home" zu setzen.
define Rollo_OG_Schlafzimmer DUOFERN XXXX
setuuid Rollo_OG_Schlafzimmer 62532e4e-f33f-3d79-bd7c-05274824c425d584
attr Rollo_OG_Schlafzimmer userattr ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforeDayOpen ASC_BlockingTime_beforeNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_CommandTemplate ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_BetweenTheTime ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_ShuttersPlace:window,terrace,awning,EG_window ASC_SlatPosCmd_SlatDevice ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate
attr Rollo_OG_Schlafzimmer ASC 1
attr Rollo_OG_Schlafzimmer ASC_BlockingTime_afterManual 600
attr Rollo_OG_Schlafzimmer ASC_BlockingTime_beforeNightClose 300
attr Rollo_OG_Schlafzimmer ASC_BrightnessSensor Schlafzimmer:luminosity
attr Rollo_OG_Schlafzimmer ASC_Mode_Down always
attr Rollo_OG_Schlafzimmer ASC_Mode_Up absent
attr Rollo_OG_Schlafzimmer ASC_Pos_Reading position
attr Rollo_OG_Schlafzimmer ASC_Roommate_Device rgr_Bewohner
attr Rollo_OG_Schlafzimmer ASC_Shading_Min_OutsideTemperature 20
attr Rollo_OG_Schlafzimmer ASC_Shading_Mode always
attr Rollo_OG_Schlafzimmer ASC_Shading_Pos 60
attr Rollo_OG_Schlafzimmer ASC_Shading_StateChange_SunnyCloudy 8000:700
attr Rollo_OG_Schlafzimmer ASC_Shading_WaitingPeriod 720
attr Rollo_OG_Schlafzimmer ASC_TempSensor Norden:temperature
attr Rollo_OG_Schlafzimmer ASC_Time_Down_Early 17:00
attr Rollo_OG_Schlafzimmer ASC_Time_Down_Late 21:30
attr Rollo_OG_Schlafzimmer ASC_Time_Up_Early 06:40
attr Rollo_OG_Schlafzimmer ASC_Time_Up_Late 07:00
attr Rollo_OG_Schlafzimmer ASC_Time_Up_WE_Holiday 09:00
attr Rollo_OG_Schlafzimmer devStateIcon opened:fts_shutter_10@green closed:fts_shutter_100@yellow 9\d.*:fts_shutter_90 8\d.*:fts_shutter_80 7\d.*:fts_shutter_70 6\d.*:fts_shutter_60 5\d.*:fts_shutter_50 4\d.*:fts_shutter_40 3\d.*:fts_shutter_30 2\d.*:fts_shutter_20 1\d.*:fts_shutter_10 0\d.*:fts_shutter_100
attr Rollo_OG_Schlafzimmer event-min-interval position:3600
attr Rollo_OG_Schlafzimmer event-on-change-reading position:10
attr Rollo_OG_Schlafzimmer genericDeviceType blind
attr Rollo_OG_Schlafzimmer group Rollladenstatus
attr Rollo_OG_Schlafzimmer oldreadings position
attr Rollo_OG_Schlafzimmer room Homekit,Rollladen
attr Rollo_OG_Schlafzimmer siriName Rollladen Schlafzimmer
attr Rollo_OG_Schlafzimmer sortby 6
attr Rollo_OG_Schlafzimmer userReadings pos_old:position.* { OldReadingsVal("Rollo_OG_Schlafzimmer","position",0) }
attr Rollo_OG_Schlafzimmer webCmd position
Danke schon im voraus.
Viele Grüsse
Marcus
CoolTux
Hallo Marcus,
Ich brauche bitte ein list vom ASC Device und eines von einem Beispiel Rolladen.
Das TuxNet Wiki:
https://www.cooltux.net
Aeroschmelz
#2
Sorry, daran hätte ich denken können ;-) Hier das Listing des ASC Devices:
   .FhemMetaInternals 1
   FUUID      636e7644-f33f-0756-46c5-4669bc60a03b71ac
   FVERSION   73_AutoShuttersControl.pm:v0.10.24-s26357/2022-08-29
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       Rollladenautomatik
   NOTIFYDEV  global,Rollladenautomatik,Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer,Rollo_OG_Bad,Rollo_OG_Schlafzimmer,Astro,Rollo_OG_Buero,Rollo_EG_Kueche_gr,Tuer_EG_Wohnzimmer,rgr_Bewohner,Rollo_EG_Wohnzimmer,Rollo_EG_Esszimmer,Fenster_OG_Bad,Rollo_EG_Kueche_kl
   NR         347
   NTFY_ORDER 51-Rollladenautomatik
   STATE      manual
   TYPE       AutoShuttersControl
   VERSION    v0.10.24
   eventCount 54
   .attraggr:
   .attrminint:
   Helper:
     DBLOG:
       Rollo_EG_Esszimmer_PosValue:
         myDbLog:
           TIME       1668753078.5029
           VALUE      100
       Rollo_EG_Esszimmer_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.77958
           VALUE      18.11.2022 - 07:49
       Rollo_EG_Kueche_gr_PosValue:
         myDbLog:
           TIME       1668753078.67141
           VALUE      100
       Rollo_EG_Kueche_gr_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.81753
       Rollo_EG_Kueche_kl_PosValue:
         myDbLog:
           TIME       1668753078.64677
           VALUE      0
       Rollo_EG_Kueche_kl_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.85601
       Rollo_EG_Wohnzimmer_PosValue:
         myDbLog:
           TIME       1668753078.54456
           VALUE      0
       Rollo_EG_Wohnzimmer_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.88617
       Rollo_OG_Bad_PosValue:
         myDbLog:
           TIME       1668753078.59653
           VALUE      0
       Rollo_OG_Bad_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.91298
           VALUE      18.11.2022 - 17:00
       Rollo_OG_Buero_PosValue:
         myDbLog:
           TIME       1668753078.62131
           VALUE      0
       Rollo_OG_Buero_nextAstroTimeEvent:
         myDbLog:
           TIME       1668750447.94014
       Rollo_OG_Schlafzimmer_PosValue:
         myDbLog:
           TIME       1668753320.53394
           VALUE      0
       Rollo_OG_Schlafzimmer_nextAstroTimeEvent:
         myDbLog:
           TIME       1668751202.00838
       controlShading:
         myDbLog:
           TIME       1668750454.36298
           VALUE      on
       state:
         myDbLog:
           TIME       1668753320.54027
           VALUE      manual
   OLDREADINGS:
     2022-11-15 21:05:53   .monitoredDevs  {"Rollo_EG_Wohnzimmer":{},"Fenster_OG_Bad":{"Rollo_OG_Bad":"ASC_WindowRec"},"Rollo_EG_Kueche_gr":{},"Rollo_EG_Esszimmer":{},"Rollo_OG_Bad":{},"Rollo_OG_Buero":{},"Rollo_EG_Kueche_kl":{},"Tuer_EG_Wohnzimmer":{"Rollo_EG_Wohnzimmer":"ASC_WindowRec"},"Astro":{"Rollladenautomatik":"ASC_twilightDevice"},"rgr_Bewohner":{"Rollo_OG_Schlafzimmer":"ASC_Roommate_Device","Rollladenautomatik":"ASC_residentsDev","Rollo_EG_Wohnzimmer":"ASC_Roommate_Device"},"Rollo_OG_Schlafzimmer":{}}
     2022-11-18 07:31:18   Rollo_EG_Esszimmer_PosValue 100
     2022-11-17 07:46:23   Rollo_EG_Esszimmer_lastPosValue 100
     2022-11-18 06:47:27   Rollo_EG_Esszimmer_nextAstroTimeEvent 18.11.2022 - 07:49
     2022-11-18 07:31:18   Rollo_EG_Kueche_gr_PosValue 100
     2022-11-17 07:46:23   Rollo_EG_Kueche_gr_lastPosValue 100
     2022-11-18 06:47:27   Rollo_EG_Kueche_gr_nextAstroTimeEvent 18.11.2022 - 07:49
     2022-11-18 07:31:18   Rollo_EG_Kueche_kl_PosValue 0
     2022-11-17 07:46:23   Rollo_EG_Kueche_kl_lastPosValue 100
     2022-11-18 06:47:27   Rollo_EG_Kueche_kl_nextAstroTimeEvent 18.11.2022 - 07:49
     2022-11-18 07:31:18   Rollo_EG_Wohnzimmer_PosValue 0
     2022-11-17 07:46:23   Rollo_EG_Wohnzimmer_lastPosValue 100
     2022-11-18 06:47:27   Rollo_EG_Wohnzimmer_nextAstroTimeEvent 18.11.2022 - 07:49
     2022-11-18 07:31:18   Rollo_OG_Bad_PosValue 0
     2022-11-17 06:30:02   Rollo_OG_Bad_lastPosValue 100
     2022-11-18 06:47:27   Rollo_OG_Bad_nextAstroTimeEvent 18.11.2022 - 17:00
     2022-11-18 07:31:18   Rollo_OG_Buero_PosValue 0
     2022-11-17 06:30:02   Rollo_OG_Buero_lastPosValue 100
     2022-11-18 06:47:27   Rollo_OG_Buero_nextAstroTimeEvent 18.11.2022 - 17:00
     2022-11-18 07:35:20   Rollo_OG_Schlafzimmer_PosValue 0
     2022-11-17 14:48:20   Rollo_OG_Schlafzimmer_lastPosValue 100
     2022-11-18 07:00:02   Rollo_OG_Schlafzimmer_nextAstroTimeEvent 18.11.2022 - 17:00
     2022-11-11 17:21:35   ascEnable       on
     2022-11-18 06:47:34   controlShading  on
     2022-11-11 17:21:35   hardLockOut     off
     2022-11-18 06:47:23   room_Homekit_Rollladen Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer
     2022-11-11 17:21:35   selfDefense     off
     2022-11-18 07:35:20   state           manual
     2022-11-12 07:08:40   sunriseTimeWeHoliday on
     2022-11-18 06:47:23   userAttrList    rolled out
   helper:
     shuttersList:
       Rollo_EG_Esszimmer
       Rollo_EG_Kueche_gr
       Rollo_EG_Kueche_kl
       Rollo_EG_Wohnzimmer
       Rollo_OG_Bad
       Rollo_OG_Buero
   monitoredDevs:
     Astro:
       Rollladenautomatik ASC_twilightDevice
     Fenster_OG_Bad:
       Rollo_OG_Bad ASC_WindowRec
     Rollo_EG_Esszimmer:
     Rollo_EG_Kueche_gr:
     Rollo_EG_Kueche_kl:
     Rollo_EG_Wohnzimmer:
     Rollo_OG_Bad:
     Rollo_OG_Buero:
     Rollo_OG_Schlafzimmer:
     Tuer_EG_Wohnzimmer:
       Rollo_EG_Wohnzimmer ASC_WindowRec
     rgr_Bewohner:
       Rollladenautomatik ASC_residentsDev
       Rollo_EG_Wohnzimmer ASC_Roommate_Device
   ASC_autoAstroModeEvening HORIZON
   ASC_autoAstroModeEveningHorizon -3
   ASC_autoAstroModeMorning REAL
   ASC_autoShuttersControlComfort on
   ASC_autoShuttersControlEvening on
   ASC_autoShuttersControlMorning on
   ASC_freezeTemp 3
   ASC_residentsDev rgr_Bewohner:state
   ASC_shuttersDriveDelay 300
   ASC_tempSensor Norden:temperature
   ASC_twilightDevice Astro
   devStateIcon { ShuttersControl_DevStateIcon($name) }
   icon       fts_shutter_automatic
   room       Rollladen
   sortby     1
   verbose    3
und hier das List des Beispiel-Rollladens:
   .attreocr-thresholdposition 0
   .lastTimeposition 1668753320.52537
   CODE       XXXXXX
   DEF        XXXXXX
   FUUID      62532e4e-f33f-3d79-bd7c-05274824c425d584
   IODev      Rademacher
   LASTInputDev Rademacher
   MODEL      Rohrmotor-Aktor
   MSGCNT     3
   NAME       Rollo_OG_Schlafzimmer
   NR         366
   Rademacher_MSGCNT 3
   Rademacher_RAWMSG 0FFF0F230900020750321300400013422138FFFFFF01
   Rademacher_TIME 2022-11-18 07:35:20
   STATE      opened
   SUBTYPE    Rohrmotor-Aktor
   TYPE       DUOFERN
   eventCount 4
   .attraggr:
   .attreocr:
     position:10
   .attrminint:
     position:3600
   .or:
     position
   .userReadings:
     HASH(0x46423c8)
   Helper:
     DBLOG:
       position:
         myDbLog:
           TIME       1668753320.53008
           VALUE      0
   OLDREADINGS:
     2022-11-18 07:09:46   position        69
     2022-09-10 13:06:21   .ASC_AttrUpdateChanges_v0.10.24 1
     2022-04-17 11:28:12   ASC_Enable      on
     2022-11-18 06:47:41   ASC_ShadingMessage <html> </html>
     2022-11-18 07:35:20   ASC_ShuttersLastDrive manual
     2022-11-18 07:00:02   ASC_Time_DriveDown 18.11.2022 - 17:00
     2022-11-18 07:00:02   ASC_Time_DriveUp 19.11.2022 - 09:00
     2022-11-18 06:46:59   IODev           Rademacher
     2022-11-18 06:47:24   associatedWith  Rollladenautomatik
     2022-11-18 07:35:20   blindsMode      off
     2022-11-18 07:35:20   dawnAutomatic   on
     2022-11-18 07:35:20   duskAutomatic   on
     2022-11-18 07:35:20   manualMode      off
     2022-11-18 07:35:20   motorDeadTime   off
     2022-11-18 07:35:20   moving          stop
     2022-11-18 07:35:20   pos_old         69
     2022-11-18 07:35:20   position        0
     2022-11-18 07:35:20   rainAutomatic   off
     2022-11-18 07:35:20   rainDirection   up
     2022-11-18 07:35:20   rainMode        off
     2022-11-18 07:35:20   reversal        off
     2022-11-18 07:35:20   runningTime     19
     2022-11-18 07:35:20   state           opened
     2022-11-18 07:35:20   sunAutomatic    on
     2022-11-18 07:35:20   sunMode         off
     2022-11-18 07:35:20   sunPosition     50
     2022-11-18 07:35:20   timeAutomatic   on
     2022-05-22 08:21:55   userposition    0
     2022-11-18 07:35:20   ventilatingMode off
     2022-11-18 07:35:20   ventilatingPosition 80
     2022-11-18 07:35:20   version         4.0
     2022-11-18 07:35:20   windAutomatic   off
     2022-11-18 07:35:20   windDirection   up
     2022-11-18 07:35:20   windMode        off
   helper:
   ASC        1
   ASC_Mode_Up absent
   ASC_Shading_Pos 60
   sortby     6
   webCmd     position
CoolTux
Sieht alles gut soweit aus.
Bekommst Du die Fehler jedes mal wenn ASC die Rollos fährt?
Wenn nicht dann mach bitte noch mal ein list vom ASC Device nachdem der Fehler wieder kam.
Hast Du irgendwo ein Rollo wo ASC Attribute gesetzt sind welches aber nicht im Internal NOTIFYDEV im ASC Device auf taucht?
Das TuxNet Wiki:
Aeroschmelz
sorry hat etwas länger gedauert, habe meinen Raspberry komplett mit Raspbian (Debian Bullseye) neu aufgesetzt, da ich gehofft habe damit alle anderen Probleme zu lösen. Leider taucht die Fehlermeldung von Zeit zu Zeit immer wieder auf. Hier das List vom ASC Device. Die Rollos tauchen alle im ASC Device auf.
   NOTIFYDEV  global,Rollladenautomatik,Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer,Rollo_EG_Kueche_gr,Fenster_OG_Bad,Rollo_OG_Buero,rgr_Bewohner,Rollo_OG_Schlafzimmer,Rollo_OG_Bad,Astro,Rollo_EG_Esszimmer,Rollo_EG_Kueche_kl,Tuer_EG_Wohnzimmer,Rollo_EG_Wohnzimmer
   NR         381
   STATE      manual
   VERSION    v0.10.24
   eventCount 10
   .attraggr:
   .attrminint:
   Helper:
     DBLOG:
         myDbLog:
           TIME       1672076721.76269
           VALUE      100
         myDbLog:
           TIME       1672076751.58802
           VALUE      100
         myDbLog:
           TIME       1672076721.56167
           VALUE      100
         myDbLog:
           TIME       1672076751.82785
           VALUE      100
         myDbLog:
           TIME       1672076721.99357
           VALUE      100
       state:
         myDbLog:
           TIME       1672076751.8306
           VALUE      manual
     2022-12-26 18:45:21   Rollo_EG_Esszimmer_PosValue 100
     2022-12-26 08:30:02   Rollo_EG_Esszimmer_lastPosValue 100
     2022-12-26 18:45:51   Rollo_EG_Kueche_gr_PosValue 100
     2022-12-26 08:30:02   Rollo_EG_Kueche_gr_lastPosValue 100
     2022-12-26 18:45:21   Rollo_EG_Kueche_kl_PosValue 100
     2022-12-26 08:30:02   Rollo_EG_Kueche_kl_lastPosValue 100
     2022-12-26 18:41:53   Rollo_EG_Wohnzimmer_PosValue 100
     2022-12-26 08:30:02   Rollo_EG_Wohnzimmer_lastPosValue 100
     2022-12-26 18:45:51   Rollo_OG_Bad_PosValue 100
     2022-12-26 16:45:56   Rollo_OG_Bad_lastPosValue 0
     2022-12-26 18:09:36   Rollo_OG_Buero_PosValue 100
     2022-12-26 16:45:56   Rollo_OG_Buero_lastPosValue 0
     2022-12-26 18:45:21   Rollo_OG_Schlafzimmer_PosValue 100
     2022-12-26 16:45:56   Rollo_OG_Schlafzimmer_lastPosValue 0
     2022-12-17 17:18:07   ascEnable       on
     2022-12-26 16:56:25   controlShading  on
     2022-12-26 16:56:19   room_Homekit_Rollladen Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer
     2022-12-26 18:45:51   state           manual
     2022-12-26 18:44:54   userAttrList    rolled out
   helper:
     shuttersList:
       Rollo_EG_Esszimmer
       Rollo_EG_Kueche_gr
       Rollo_EG_Kueche_kl
       Rollo_EG_Wohnzimmer
       Rollo_OG_Bad
       Rollo_OG_Buero
   monitoredDevs:
     Astro:
     Fenster_OG_Bad:
     Rollo_EG_Esszimmer:
     Rollo_EG_Kueche_gr:
     Rollo_EG_Kueche_kl:
     Rollo_OG_Bad:
     Rollo_OG_Buero:
     Tuer_EG_Wohnzimmer:
     rgr_Bewohner:
   ASC_freezeTemp 1
   room       Rollladen
   sortby     1
   verbose    3
CoolTux
Kannst du bitte die aktuelle Fehlermeldung hier posten
Das TuxNet Wiki:
Aeroschmelz
#6
Anbei ein Ausschnitt aus dem Log mit der Fehlermeldung:
2022.12.30 11:37:45 1: ERROR: empty name in readingsBeginUpdate
2022.12.30 11:37:45 1: stacktrace:
2022.12.30 11:37:45 1:     main::readingsBeginUpdate           called by fhem.pl (5176)
2022.12.30 11:37:45 1:     main::readingsSingleUpdate          called by lib/FHEM/Automation/ShuttersControl.pm (890)
2022.12.30 11:37:45 1:     FHEM::Automation::ShuttersControl::UserAttributs_Readings_ForShutters called by lib/FHEM/Automation/ShuttersControl.pm (360)
2022.12.30 11:37:45 1:     FHEM::Automation::ShuttersControl::Undef called by fhem.pl (3976)
2022.12.30 11:37:45 1:     main::CallFn                        called by fhem.pl (1498)
2022.12.30 11:37:45 1:     main::CommandRereadCfg              called by fhem.pl (1276)
2022.12.30 11:37:45 1:     main::AnalyzeCommand                called by fhem.pl (1127)
2022.12.30 11:37:45 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2846)
2022.12.30 11:37:45 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (2626)
2022.12.30 11:37:45 1:     main::FW_style                      called by ./FHEM/01_FHEMWEB.pm (1204)
2022.12.30 11:37:45 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2022.12.30 11:37:45 1:     main::FW_Read                       called by fhem.pl (3976)
2022.12.30 11:37:45 1:     main::CallFn                        called by fhem.pl (784)
2022.12.30 11:37:45 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 5030.
2022.12.30 11:37:45 1: readingsUpdate(,associatedWith,Rollladenautomatik,none) missed to call readingsBeginUpdate first.
2022.12.30 11:37:45 1:     main::readingsBulkUpdate            called by fhem.pl (5177)
2022.12.30 11:37:45 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4766.
Das endet dann mit:
2022.12.30 11:39:07 1:     main::readingsBulkUpdate            called by fhem.pl (5177)
2022.12.30 11:39:07 1:     main::readingsSingleUpdate          called by lib/FHEM/Automation/ShuttersControl.pm (890)
2022.12.30 11:39:07 1:     FHEM::Automation::ShuttersControl::UserAttributs_Readings_ForShutters called by lib/FHEM/Automation/ShuttersControl.pm (360)
2022.12.30 11:39:07 1:     FHEM::Automation::ShuttersControl::Undef called by fhem.pl (3976)
2022.12.30 11:39:07 1:     main::CallFn                        called by fhem.pl (1498)
2022.12.30 11:39:07 1:     main::CommandRereadCfg              called by fhem.pl (1276)
2022.12.30 11:39:07 1:     main::AnalyzeCommand                called by fhem.pl (1127)
2022.12.30 11:39:07 1:     main::AnalyzeCommandChain           called by ./FHEM/01_FHEMWEB.pm (2846)
2022.12.30 11:39:07 1:     main::FW_fC                         called by ./FHEM/01_FHEMWEB.pm (2626)
2022.12.30 11:39:07 1:     main::FW_style                      called by ./FHEM/01_FHEMWEB.pm (1204)
2022.12.30 11:39:07 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (609)
2022.12.30 11:39:07 1:     main::FW_Read                       called by fhem.pl (3976)
2022.12.30 11:39:07 1:     main::CallFn                        called by fhem.pl (784)
2022.12.30 11:39:07 3: AutoShuttersControl (Rollladenautomatik) - delete device Rollladenautomatik
Hier auch das zugehörige List des ASC Devices 20 min später:
   NOTIFYDEV  global,Rollladenautomatik,Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer,Rollo_OG_Buero,Fenster_OG_Bad,Rollo_EG_Kueche_kl,rgr_Bewohner,Rollo_OG_Bad,Rollo_EG_Kueche_gr,Tuer_EG_Wohnzimmer,Astro,Rollo_EG_Esszimmer,Rollo_OG_Schlafzimmer,Rollo_EG_Wohnzimmer
   NR         383
   STATE      manual
   VERSION    v0.10.24
   eventCount 12
   .attraggr:
   .attrminint:
   Helper:
     DBLOG:
         myDbLog:
           TIME       1672396812.24308
           VALUE      0
         myDbLog:
           TIME       1672396782.15684
           VALUE      0
         myDbLog:
           TIME       1672396812.1518
           VALUE      0
         myDbLog:
           TIME       1672396812.43557
           VALUE      0
         myDbLog:
           TIME       1672396782.57026
           VALUE      0
         myDbLog:
           TIME       1672396782.622
           VALUE      50
       state:
         myDbLog:
           TIME       1672396812.43827
           VALUE      manual
     2022-12-30 11:40:12   Rollo_EG_Esszimmer_PosValue 0
     2022-12-30 08:30:02   Rollo_EG_Esszimmer_lastPosValue 100
     2022-12-30 11:39:42   Rollo_EG_Kueche_gr_PosValue 0
     2022-12-30 08:30:02   Rollo_EG_Kueche_gr_lastPosValue 100
     2022-12-30 11:38:24   Rollo_EG_Kueche_kl_PosValue 0
     2022-12-30 08:30:02   Rollo_EG_Kueche_kl_lastPosValue 0
     2022-12-30 11:40:12   Rollo_EG_Wohnzimmer_PosValue 0
     2022-12-30 08:30:02   Rollo_EG_Wohnzimmer_lastPosValue 100
     2022-12-30 11:40:12   Rollo_OG_Bad_PosValue 0
     2022-12-30 06:15:02   Rollo_OG_Bad_lastPosValue 100
     2022-12-30 11:39:42   Rollo_OG_Buero_PosValue 0
     2022-12-30 06:15:02   Rollo_OG_Buero_lastPosValue 100
     2022-12-30 11:39:42   Rollo_OG_Schlafzimmer_PosValue 50
     2022-12-29 16:48:13   Rollo_OG_Schlafzimmer_lastPosValue 0
     2022-12-28 15:46:28   controlShading  on
     2022-12-27 07:10:35   partyMode       off
     2022-12-28 15:46:21   room_Homekit_Rollladen Rollo_EG_Esszimmer,Rollo_EG_Kueche_gr,Rollo_EG_Kueche_kl,Rollo_EG_Wohnzimmer,Rollo_OG_Bad,Rollo_OG_Buero,Rollo_OG_Schlafzimmer
     2022-12-30 11:40:12   state           manual
     2022-12-30 11:39:15   userAttrList    rolled out
   helper:
     shuttersList:
       Rollo_EG_Esszimmer
       Rollo_EG_Kueche_gr
       Rollo_EG_Kueche_kl
       Rollo_EG_Wohnzimmer
       Rollo_OG_Bad
       Rollo_OG_Buero
   monitoredDevs:
     Astro:
     Fenster_OG_Bad:
     Rollo_EG_Esszimmer:
     Rollo_EG_Kueche_gr:
     Rollo_EG_Kueche_kl:
     Rollo_OG_Bad:
     Rollo_OG_Buero:
     Tuer_EG_Wohnzimmer:
     rgr_Bewohner:
   ASC_freezeTemp 1
   room       Rollladen
   sortby     1
   verbose    3
gestein
Seit ein paar Tagen habe ich auch solche Einträge im log-File.
Die kommen aber von verschiedenen Devices - auch von einem selbstgeschriebenen DOIF.
Lg, Gerhard
CoolTux
Der hier erwähnte Fehler ist nachvollziehbar für mich. Passt also. Ich werde es die Tage fixen
Das TuxNet Wiki:
Aeroschmelz
der Fehler tritt leider immer noch auf. Mir ist aufgefallen, dass aktuell immer der Fall ist, wenn man etwas an der Konfig ändert, ansonsten passiert das nicht (mehr).
Danke im voraus fürs Nachsehen.
Viele Grüsse
Marcus
CoolTux
Das TuxNet Wiki:
Aeroschmelz
Dann ist ja gut und es ist wenigstens kein neuer Fehler ;-) Keinen Stress...
Aeroschmelz
gab es dazu schon eine Fehlerbehebung?
Marcus
CoolTux
Leider noch nicht. Liege aktuell mit Männergrippe flach.
Das TuxNet Wiki:
Aeroschmelz
