Autor Thema: Fehlermeldung CUL_HM set bad_dg_RT_Clima ?  (Gelesen 323 mal)
Offline Lars_
  • Jr. Member
« am: 20 November 2022, 15:29:07 »
Moin zusammen,
ich bekomme seit neuestem für ein RT die folgende CUL-Meldung:
2022.11.20 12:44:36.910 5: CUL_HM set bad_dg_RT_Clima ?
2022.11.20 12:44:37.006 5: CUL_HM set bad_dg_RT_Clima ?
2022.11.20 12:44:37.061 5: CUL_HM set bad_dg_RT_Clima ?
2
Config Heating Control (CUL_HM = VCCU):
   DEF        24035904
   FUUID      637a19e7-f33f-d7a9-80cf-69d40f4ae71c6b15
   NAME       bad_dg_RT_Clima
   NR         418
   NTFY_ORDER 48-bad_dg_RT_Clima
   STATE      T: 18.8 desired: 17.5 valve: 0
   STILLDONETIME 0
   TYPE       CUL_HM
   chanNo     04
   device     bad_dg_RT
   disableNotifyFn 1
     2022-11-20 12:42:28   CommandAccepted yes
     2021-02-01 21:06:22   R-boostPeriod   10 min
     2021-02-01 21:06:22   R-boostPos      100 %
     2021-02-01 21:06:22   R-btnNoBckLight off
     2021-02-01 21:06:22   R-dayTemp       21 C
     2021-02-01 21:06:22   R-daylightSaveTime on
     2021-02-01 21:06:22   R-decalcTime    11:00
     2021-02-01 21:06:22   R-decalcWeekday Sat
     2021-02-01 21:06:22   R-modePrioManu  all
     2021-02-01 21:06:22   R-modePrioParty all
     2021-02-01 21:06:22   R-nightTemp     17 C
     2021-02-01 21:06:22   R-noMinMax4Manu off
     2021-02-01 21:06:22   R-regAdaptive   on
     2021-02-01 21:06:22   R-reguExtI      15
     2021-02-01 21:06:22   R-reguExtP      30
     2021-02-01 21:06:22   R-reguExtPstart 30
     2022-04-16 16:29:40   R-reguIntI      17
     2022-04-16 16:29:40   R-reguIntP      32
     2022-04-16 16:29:40   R-reguIntPstart 40
     2021-02-01 21:06:22   R-showInfo      time
     2021-02-01 21:06:22   R-showWeekday   off
     2021-02-01 21:06:18   R-sign          off
     2021-02-01 21:06:22   R-tempMax       30.5 C
     2021-02-01 21:06:22   R-tempMin       4.5 C
     2021-02-01 21:06:22   R-tempOffset    0.0K
     2021-02-01 21:06:22   R-valveErrPos   15 %
     2022-09-17 08:40:07   R-valveMaxPos   85 %
     2021-02-01 21:06:22   R-valveOffsetRt 0 %
     2021-02-01 21:06:22   R-winOpnBoost   off
     2021-02-01 21:06:22   R-winOpnDetFall 1.4 K
     2021-02-01 21:06:22   R-winOpnMode    off
     2021-02-01 21:06:22   R-winOpnPeriod  15 min
     2021-02-01 21:06:22   R-winOpnTempI   12 C
     2022-09-17 08:40:07   R_0_tempListSat 06:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_1_tempListSun 06:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_2_tempListMon 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_3_tempListTue 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_4_tempListWed 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_5_tempListThu 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_6_tempListFri 06:00 17.0 09:00 21.0 17:00 17.0 22:00 21.0 24:00 17.0
     2022-09-17 08:40:07   R_tempList_State verified
     2022-11-20 14:59:11   ValvePosition   0
     2022-11-20 14:59:11   boostTime       -
     2022-09-17 08:34:56   cfgState        updating
     2022-11-20 12:42:28   commState       CMDs_done
     2022-11-20 14:59:11   controlMode     manual
     2022-11-20 14:59:11   desired-temp    17.5
     2022-11-20 14:59:11   measured-temp   18.8
     2022-11-20 14:59:11   partyEnd        -
     2022-11-20 14:59:11   partyStart      -
     2022-11-20 14:59:11   partyTemp       -
     2022-11-20 12:42:28   recentStateType ack
     2022-11-20 14:59:11   state           T: 18.8 desired: 17.5 valve: 0
   helper:
     peerFriend peerRTteam2
     peerIDsState complete
     peerOpt    p:thermostat
     regLst     1,7
     cmds:
       TmplKey    :no:noAssTs
       TmplTs     1668952525.26159
       cmdKey     1:0:0::bad_dg_RT:0095:04:
       cmdLst:
         burstXmit  noArg
         clear      [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
         controlManu (on|off|5.0..30.0;0.5)
         controlMode (auto|manual|boost|day|night)
         controlParty -temp- -startDate- -startTime- -endDate- -endTime-
         desired-temp (on|off|5.0..30.0;0.5)
         getConfig  noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         inhibit    [(on|{off})]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerSmart  -peerOpt-
         regBulk    -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         sign       [(on|{off})]
         sysTime    noArg
         tempListFri [(prep|{exec})] -HH:MM- -temp- [...]
         tempListMon [(prep|{exec})] -HH:MM- -temp- [...]
         tempListSat [(prep|{exec})] -HH:MM- -temp- [...]
         tempListSun [(prep|{exec})] -HH:MM- -temp- [...]
         tempListThu [(prep|{exec})] -HH:MM- -temp- [...]
         tempListTmpl [({verify}|restore)] [[-file-:]-templateName-]
         tempListTue [(prep|{exec})] -HH:MM- -temp- [...]
         tempListWed [(prep|{exec})] -HH:MM- -temp- [...]
         tempTmplSet -tempTmpl-
         tplDel     -tplDel-
       lst:
         condition  slider,0,1,255
         peer
         peerOpt    az_RT_ClimaTeam,db_RT_ClimaTeam,ez_RT_ClimaTeam,kz_RT_ClimaTeam,sz1_dg_RT_ClimaTeam,sz2_dg_RT_ClimaTeam,wz_RT_ClimaTeam
         tplDel
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     expert:
       def        1
       det        1
       raw        0
       tpl        0
     peerIDsH:
       00000000   broadcast
     role:
       chn        1
     shRegR:
       07         00
     tmpl:
   DbLogInclude ValvePosition,controlMode,desired-temp,measured-temp
   alias      DG-Bad
   battery_change 2022-03-28 20:47:30
   event-on-change-reading ValvePosition,controlMode,desired-temp,measured-temp
   expert     allReg
   group      Heizung Bedienung
   model      HM-CC-RT-DN
   peerIDs    00000000
   room       Zentrale
   sortby     01
   verbose    5
2
Ich bekomme pro definierter HeatingControl jeweils eine Fehlermeldung, obwohl die Bedingungen nicht zutreffen, d.h. die HC ist per IF Bedingung inaktiv.
Wenn ich diese eigentlich inaktiven HCs auf DISABLE setze, reduzieren sich die Fehlermeldungen im gleichen Verhältnis.
Alle anderen RT's und deren HCs laufen in meiner Installation ohne Probleme.
Da ich nichts geändert habe, kann ich mir das Verhalten nicht erklären.
Hat jemand schon mal ähnliches beobachtet und vlt. schon eine Lösung?
Grüße und danke
Lars
Fhem auf rpi 3   fhem auf rpi b+
1 x CULHM/jeelink v3c   1 x CULHM
7 x HM-CC-RT-DN   3 x HM-CC-RT-DN
5 x HM-Sec-RHS
