FHEM - Hausautomations-Systeme > ZWave
Qubino (Goap) ZMNHJD1 Flush Dimmer Pilot Wire Temperatur
(1/1)
Damu:
Hallo
Habe einen Qubino Flush Dimmer Pilot Wire angelernt.
Habe diesem vor der Installation einen Temperatur Sensor eingebaut.
Der Fühler meldet die Temperatur aber nur auf Abfrage.
Denke die XML ist da wohl noch fehlerhaft.
Es werden mir im Device 6 Assoazionsgruppen angezeigt
--- Code: ---define ZWave_SWITCH_MULTILEVEL_14 ZWave eba3b9eb 14
attr ZWave_SWITCH_MULTILEVEL_14 classes ZWAVEPLUS_INFO VERSION MANUFACTURER_SPECIFIC DEVICE_RESET_LOCALLY POWERLEVEL BASIC SWITCH_ALL SWITCH_BINARY SWITCH_MULTILEVEL SENSOR_MULTILEVEL MULTI_CHANNEL ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO CONFIGURATION MARK BASIC
attr ZWave_SWITCH_MULTILEVEL_14 room ZWave
attr ZWave_SWITCH_MULTILEVEL_14 vclasses ASSOCIATION:2 ASSOCIATION_GRP_INFO:2 BASIC:0 CONFIGURATION:1 DEVICE_RESET_LOCALLY:1 MANUFACTURER_SPECIFIC:2 MULTI_CHANNEL:4 MULTI_CHANNEL_ASSOCIATION:3 POWERLEVEL:1 SENSOR_MULTILEVEL:3 SWITCH_ALL:1 SWITCH_BINARY:1 SWITCH_MULTILEVEL:3 VERSION:2 ZWAVEPLUS_INFO:2
# CFGFN
# DEF eba3b9eb 14
# FUUID 6381f3b2-f33f-d169-9fd9-fa18420bf51d72ac
# IODev POE_ZW_OG
# LASTInputDev POE_ZW_OG
# MSGCNT 479
# NAME ZWave_SWITCH_MULTILEVEL_14
# NR 18668
# POE_ZW_OG_MSGCNT 479
# POE_ZW_OG_RAWMSG 0004000e063105012200ccae0000
# POE_ZW_OG_TIME 2022-11-27 11:36:47
# STATE associationAdd 6 1
# TYPE ZWave
# ZWaveSubDevice no
# cmdsPending 0
# endpointChildren ZWave_SENSOR_BINARY_14.01,ZWave_SENSOR_BINARY_14.02,ZWave_SENSOR_BINARY_14.03
# eventCount 309
# homeId eba3b9eb
# isWakeUp
# lastMsgSent 1669545407.89853
# nodeIdHex 0e
# READINGS:
# 2022-11-26 12:08:34 IODev POE_ZW_OG
# 2022-11-27 11:33:12 UNPARSED ASSOCIATION 028506
# 2022-11-27 11:03:50 assocGroupCmdList_1 ZWAVE:25 UNKNOWN_03:26 UNKNOWN_03:31 UNKNOWN_05:32 02
# 2022-11-27 11:33:24 assocGroupName_1 Lifeline
# 2022-11-27 11:04:08 assocGroupName_2 DimmerSetKey
# 2022-11-27 11:04:16 assocGroupName_3 BasicSetKey
# 2022-11-27 11:04:24 assocGroupName_4 BasicSetKey
# 2022-11-27 11:04:30 assocGroupName_5 BasicSetKey
# 2022-11-27 11:04:36 assocGroupName_6 TempRepor
# 2022-11-27 11:13:26 assocGroup_1 Max 1 Nodes POE_ZW_OG
# 2022-11-27 11:13:34 assocGroup_2 Max 16 Nodes
# 2022-11-27 11:05:34 assocGroup_3 Max 16 Nodes
# 2022-11-27 11:13:42 assocGroup_4 Max 16 Nodes
# 2022-11-27 11:05:44 assocGroup_5 Max 16 Nodes
# 2022-11-27 11:35:28 assocGroup_6 Max 16 Nodes POE_ZW_OG
# 2022-11-26 12:10:46 associatedWith ZWave_SENSOR_BINARY_14.01,ZWave_SENSOR_BINARY_14.02,ZWave_SENSOR_BINARY_14.03
# 2022-11-27 11:35:16 associationAdd 6 1
# 2022-11-26 15:17:40 associationDel 1 0
# 2022-11-27 11:04:58 basicReport 99
# 2022-11-26 12:12:02 configInput1ContactType NCNormallyCloseInputType
# 2022-11-26 12:12:02 configInput1FunctionalitySelection Confort
# 2022-11-26 12:12:02 configInput1SwitchType BiStableSwitchType
# 2022-11-26 12:12:02 configInput2ContactType NCNormallyCloseInputType
# 2022-11-26 12:12:02 configInput2FunctionalitySelection Eco
# 2022-11-26 12:12:02 configInput2SwitchType BiStableSwitchType
# 2022-11-26 12:12:02 configInput3ContactType NCNormallyCloseInputType
# 2022-11-26 12:12:02 configInput3FunctionalitySelection HorsGel
# 2022-11-26 12:12:02 configInput3SwitchType BiStableSwitchType
# 2022-11-26 12:12:02 configSavingTheStateOfTheRelayAfterA30 FlushDimmerModuleSavesItsState0
# 2022-11-26 15:27:49 dim 25
# 2022-11-27 11:12:26 mcCapability_01 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
# 2022-11-27 11:12:26 mcCapability_02 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
# 2022-11-27 11:12:26 mcCapability_03 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
# 2022-11-27 11:12:26 mcEndpoints total 3, different
# 2022-11-27 11:07:29 mcaAdd 6 0 1 0
# 2022-11-27 11:34:46 mcaDel 6 0 1 0
# 2022-11-27 11:36:09 mcaGroups 6
# 2022-11-27 11:36:09 mca_1 Max 1 Nodes POE_ZW_OG
# 2022-11-27 11:36:09 mca_2 Max 16
# 2022-11-27 11:36:09 mca_3 Max 16
# 2022-11-27 11:36:09 mca_4 Max 16
# 2022-11-27 11:36:09 mca_5 Max 16
# 2022-11-27 11:36:09 mca_6 Max 16 Nodes POE_ZW_OG
# 2022-11-27 10:40:39 model Qubino (Goap) ZMNHJD1 Flush Dimmer Pilot Wire
# 2022-11-27 10:40:39 modelConfig qubino/ZMNHJD1.xml
# 2022-11-27 10:40:39 modelId 0159-0004-0051
# 2022-11-26 14:37:10 powerlvl current 0 remain 0
# 2022-11-27 11:09:01 reportedState dim 99
# 2022-11-27 11:35:16 state associationAdd 6 1
# 2022-11-27 11:08:38 swa on off
# 2022-11-27 11:08:51 swbStatus 255
# 2022-11-27 11:08:25 swmSwitchType primary Up/Down secondary Undefined
# 2022-11-27 11:36:47 temperature 20.4 C
# 2022-11-27 11:36:47 timeToAck 0.026
# 2022-11-27 11:36:47 transmit OK
# 2022-11-27 11:06:23 version Lib 3 Prot 5.03 App 2.0 HW 1 FWCounter 1 FW 1.0
# 2022-11-27 11:18:16 zwavePlusInfo version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1c00 userIcon:1c00
setstate ZWave_SWITCH_MULTILEVEL_14 associationAdd 6 1
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:08:34 IODev POE_ZW_OG
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:33:12 UNPARSED ASSOCIATION 028506
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:03:50 assocGroupCmdList_1 ZWAVE:25 UNKNOWN_03:26 UNKNOWN_03:31 UNKNOWN_05:32 02
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:33:24 assocGroupName_1 Lifeline
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:08 assocGroupName_2 DimmerSetKey
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:16 assocGroupName_3 BasicSetKey
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:24 assocGroupName_4 BasicSetKey
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:30 assocGroupName_5 BasicSetKey
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:36 assocGroupName_6 \
TempRepor
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:13:26 assocGroup_1 Max 1 Nodes POE_ZW_OG
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:13:34 assocGroup_2 Max 16 Nodes
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:05:34 assocGroup_3 Max 16 Nodes
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:13:42 assocGroup_4 Max 16 Nodes
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:05:44 assocGroup_5 Max 16 Nodes
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:35:28 assocGroup_6 Max 16 Nodes POE_ZW_OG
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:10:46 associatedWith ZWave_SENSOR_BINARY_14.01,ZWave_SENSOR_BINARY_14.02,ZWave_SENSOR_BINARY_14.03
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:35:16 associationAdd 6 1
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 15:17:40 associationDel 1 0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:04:58 basicReport 99
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput1ContactType NCNormallyCloseInputType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput1FunctionalitySelection Confort
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput1SwitchType BiStableSwitchType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput2ContactType NCNormallyCloseInputType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput2FunctionalitySelection Eco
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput2SwitchType BiStableSwitchType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput3ContactType NCNormallyCloseInputType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput3FunctionalitySelection HorsGel
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configInput3SwitchType BiStableSwitchType
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 12:12:02 configSavingTheStateOfTheRelayAfterA30 FlushDimmerModuleSavesItsState0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 15:27:49 dim 25
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:12:26 mcCapability_01 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:12:26 mcCapability_02 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:12:26 mcCapability_03 ZWAVEPLUS_INFO VERSION BASIC SENSOR_BINARY ASSOCIATION MULTI_CHANNEL_ASSOCIATION ASSOCIATION_GRP_INFO MARK BASIC
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:12:26 mcEndpoints total 3, different
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:07:29 mcaAdd 6 0 1 0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:34:46 mcaDel 6 0 1 0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mcaGroups 6
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_1 Max 1 Nodes POE_ZW_OG
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_2 Max 16
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_3 Max 16
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_4 Max 16
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_5 Max 16
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:09 mca_6 Max 16 Nodes POE_ZW_OG
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 10:40:39 model Qubino (Goap) ZMNHJD1 Flush Dimmer Pilot Wire
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 10:40:39 modelConfig qubino/ZMNHJD1.xml
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 10:40:39 modelId 0159-0004-0051
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-26 14:37:10 powerlvl current 0 remain 0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:09:01 reportedState dim 99
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:35:16 state associationAdd 6 1
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:08:38 swa on off
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:08:51 swbStatus 255
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:08:25 swmSwitchType primary Up/Down secondary Undefined
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:47 temperature 20.4 C
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:47 timeToAck 0.026
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:36:47 transmit OK
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:06:23 version Lib 3 Prot 5.03 App 2.0 HW 1 FWCounter 1 FW 1.0
setstate ZWave_SWITCH_MULTILEVEL_14 2022-11-27 11:18:16 zwavePlusInfo version:01 role:AlwaysOnSlave node:Z-Wave+Node installerIcon:1c00 userIcon:1c00
--- Ende Code ---
Werde das XML dann mal anpassen.
Kann ich versuchen die Parameter für die Temperaturanzeige von einem Qubino Dimmer zu versuchen (Options Bit)?
Oder ist es schlecht da etwas umzuschreiben in Parameter die nicht dokumentiert sind?
rudolfkoenig:
--- Zitat ---Werde das XML dann mal anpassen.
--- Ende Zitat ---
Sehr gerne, das wird aber nichts daran aendern, dass die Temperaturdaten nicht freiwillig gemeldet werden.
Sowas behebt man mit Assoziationen, am besten, nachdem man die Doku verstanden hat.
--- Zitat ---Kann ich versuchen die Parameter für die Temperaturanzeige von einem Qubino Dimmer zu versuchen (Options Bit)?
--- Ende Zitat ---
Generell kann man alles versuchen, ich habe es in diesem Umfeld noch nicht erlebt, dass falsche Parameter das Geraet zerstoert haetten.
Allerdings auch nur auesserst selten, dass nicht dokumentierte Parameter was bewirk haetten.
Damu:
Hallo
Habe die XML angepasst.
Sollte so passen.
Das Teil wird wohl sonst nur in Frankreich gebraucht und ist schlecht dokumentiert.
Danke.
Navigation
[0] Themen-Index
Zur normalen Ansicht wechseln
