aktuell habe ich einen weiteren Vierfach-Aktor für Hutschienen-Montage HM-LC-SW4-DR in Betrieb genommen.
DEF 6333E0
FUUID 5d63bc7c-f33f-ff63-ff3b-b080c7d42c5fc663
HMLAN1_MSGCNT 92
HMLAN1_RAWMSG E6333E0,0000,E88278BC,FF,FFB1,5580026333E037A0AF0101C8004D
HMLAN1_RSSI -79
HMLAN1_TIME 2022-11-30 16:08:00
HMLANGWDG_MSGCNT 84
HMLANGWDG_RAWMSG 0500004F5580026333E037A0AF0101C8004D
HMLANGWDG_RSSI -79
HMLANGWDG_TIME 2022-11-30 16:08:00
HMLANGWOG_MSGCNT 88
HMLANGWOG_RAWMSG 0500004B5580026333E037A0AF0101C8004D
HMLANGWOG_RSSI -75
HMLANGWOG_TIME 2022-11-30 16:08:00
HmUARTKG_MSGCNT 90
HmUARTKG_RAWMSG 040300435580026333E037A0AF0101C8004D
HmUARTKG_RSSI -67
HmUARTKG_TIME 2022-11-30 16:08:00
IODev HmUARTKG
LASTInputDev HMLANGWDG
MSGCNT 354
NAME ZE.Hutschiene.3
NOTIFYDEV global
NR 864
NTFY_ORDER 50-ZE.Hutschiene.3
STATE CMDs_done
TYPE CUL_HM
channel_01 Ga.Lichterkette_Vorgarten
channel_02 HM_6333E0_Sw_02
channel_03 HM_6333E0_Sw_03
channel_04 HM_6333E0_Sw_04
lastMsg No:55 - t:02 s:6333E0 d:37A0AF 0101C8004D
protLastRcv 2022-11-30 16:08:00
protRcv 91 last_at:2022-11-30 16:08:00
protSnd 91 last_at:2022-11-30 16:07:59
protState CMDs_done
rssi_HmUARTKG cnt:71 min:-88 max:-71 avg:-76.46 lst:-77
rssi_at_HMLAN1 cnt:92 min:-94 max:-72 avg:-79.22 lst:-79
rssi_at_HMLANGWDG cnt:84 min:-86 max:-70 avg:-78.94 lst:-79
rssi_at_HMLANGWOG cnt:88 min:-85 max:-68 avg:-74.18 lst:-75
rssi_at_HmUARTKG cnt:90 min:-78 max:-63 avg:-69.16 lst:-67
2018-07-30 17:39:10 CommandAccepted yes
2018-07-30 17:35:04 D-firmware 2.8
2018-07-30 17:35:04 D-serialNr OEQ2000042
2018-07-30 17:35:08 PairedTo 0x37A0AF
2018-07-30 17:35:08 R-pairCentral 0x37A0AF
2018-07-30 17:35:08 RegL_00. 02:01 0A:37 0B:A0 0C:AF 15:FF 18:00 00:00
2022-10-23 15:09:15 powerOn 2022-10-23 15:09:15
2022-11-30 16:08:00 state CMDs_done
helper:
HM_CMDNR 85
PONtest 0
cSnd 1137A0AF6333E00201C80000,1137A0AF6333E00201C80000
mId 0003
peerFriend
peerOpt -:switch
regLst 0
rxType 1
supp_Pair_Rep 0
ack:
expert:
def 1
det 0
raw 1
tpl 0
io:
newChn +6333E0,00,01,00
nextSend 1669820880.57212
prefIO
rxt 0
vccu VCCU
p:
6333E0
00
01
00
mRssi:
mNo 55
io:
HMLAN1:
-79
-79
HMLANGWDG:
-79
-79
HMLANGWOG:
-75
-75
HmUARTKG:
-63
-63
prt:
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
dev 1
prs 1
rssi:
HmUARTKG:
avg -76.4647887323944
cnt 71
lst -77
max -71
min -88
at_HMLAN1:
avg -79.2282608695652
cnt 92
lst -79
max -72
min -94
at_HMLANGWDG:
avg -78.9404761904762
cnt 84
lst -79
max -70
min -86
at_HMLANGWOG:
avg -74.1818181818182
cnt 88
lst -75
max -68
min -85
at_HmUARTKG:
avg -69.1666666666666
cnt 90
lst -67
max -63
min -78
tmpl:
IODev HmUARTKG
IOgrp VCCU
autoReadReg 0_off
expert 2_raw
firmware 2.8
model HM-LC-SW4-DR
room Zentral
serialNr OEQ2000042
subType switch
verbose 5
webCmd getConfig:clear msgEvents
Aktuell ist nur der 1. Kanal belegt:
DEF 6333E001
FUUID 5d63bc7c-f33f-ff63-ba82-6b81631970a4504e
NAME Ga.Lichterkette_Vorgarten
NOTIFYDEV global
NR 866
NTFY_ORDER 50-HM_6333E0_Sw_01
STATE an
TYPE CUL_HM
chanNo 01
device ZE.Hutschiene.3
2022-11-30 16:08:00 CommandAccepted yes
2018-07-30 17:35:09 R-powerUpAction off
2018-07-30 17:35:09 R-sign off
2018-07-30 17:39:27 RegL_01. 08:00 30:0A 57:24 56:00 00:00
2022-11-30 16:08:00 deviceMsg on (to VCCU)
2022-11-30 16:08:00 level 100
2022-11-30 16:08:00 pct 100
2022-11-30 16:08:00 recentStateType ack
2022-11-30 16:08:00 state on
2022-11-30 16:08:00 timedOn off
2022-11-30 16:07:59 trigLast fhem:02
helper:
dlvlCmd ++A01137A0AF6333E00201C80000
peerFriend peerSens,peerVirt
peerOpt 3:switch
regLst 1,3p
expert:
def 1
det 0
raw 1
tpl 0
role:
chn 1
tmpl:
alias Lichterkette Vorgarten
eventMap on:an off:aus
group Licht
icon light_fairy_lights
model HM-LC-SW4-DR
peerIDs 00000000,
room Zentral
verbose 5
webCmd an:aus
Eigentlich wird dieser Kanal nur mit einem DOIF gesteuert:
defmod di_ZE.Weihnachtsdeko_front DOIF ([06:00] or [{sunset(-3600,"16:00","23:00")}])\
(set Ga.Lichterkette_Vorgarten:FILTER=STATE!=an an) \
DOELSEIF (([23:45]) or [{sunrise(3600,"06:10","10:15")}]) \
(set Ga.Lichterkette_Vorgarten:FILTER=STATE!=aus aus)
attr di_ZE.Weihnachtsdeko_front room Zentral
Unerklärlicherweise sehe ich im Log aber immer zwei Schaltaufrufe direkt hintereinander.
z.B.
2022.11.30 08:36:17 3: CUL_HM set Ga.Lichterkette_Vorgarten off
Ich würde das gerne eingrenzen. Ich habe schon die ganze Konfig durchsucht, aber der Aufruf "an" und "aus" findet jeweils nur einmal in dem aufgeführten DOIF statt.
Ich habe schon ein Loging des DOIF aufgesetzt, dort sehe ich m.E. auch den doppelten Aufruf.
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten set_off
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten trigLast: fhem:02
2022-11-30_08:36:17 di_ZE.Weihnachtsdeko_front cmd_nr: 2
2022-11-30_08:36:17 di_ZE.Weihnachtsdeko_front cmd: 2
2022-11-30_08:36:17 di_ZE.Weihnachtsdeko_front cmd_event: timer_4
2022-11-30_08:36:17 di_ZE.Weihnachtsdeko_front cmd_2
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten deviceMsg: aus (to VCCU)
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten level: 0
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten pct: 0
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten aus
2022-11-30_08:36:17 Ga.Lichterkette_Vorgarten timedOn: aus
Wo kommt das her?
Auch ein Hochsetzen des Loging des Aktors "verbose 5" bringt mich nicht weiter. Habt Ihr eine Idee? Ist es eventuell ein Retransmit zum Aktor?
Wie kann ich das sinnvoll eingrenzen und beheben?
Vielen Dank für Eure Hilfe
Christian
