« Antwort #20 am: 01 Dezember 2022, 22:48:38 »
Du kannst auch mal die logfile in fhem leeren und schauen was beim erneuten Aufruf passiert.
Probier mal mit:
defmod c_dellog cmdalias dellog AS {qx(truncate $currlogfile --size 0);;Log 1, "Logfile gelöscht";;}
attr c_dellog room System
setstate c_dellog defined
und oben einfach dellog eingeben + Enter
gemacht .. logfile schön gelöscht . aber immer noch nur über WinSCP zu öffnen...
Inhalt (Auszug):
2022.12.01 22:44:10 1: PERL WARNING: Argument "= 2" isn't numeric in numeric eq (==) at ./FHEM/01_FHEMWEB.pm line 2127.
2022.12.01 22:44:10 1: PERL WARNING: Argument "= 2" isn't numeric in numeric eq (==) at ./FHEM/98_SVG.pm line 272.
2022.12.01 22:44:11 1: PERL WARNING: Argument "= 2" isn't numeric in numeric eq (==) at ./FHEM/98_SVG.pm line 272.
2022.12.01 22:44:12 1: PERL WARNING: Argument "= 1" isn't numeric in addition (+) at ./FHEM/01_FHEMWEB.pm line 592.
2022.12.01 22:44:12 1: No Logdevice /dblog_THB/
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::CallFn" at fhem.pl line 3884.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::BindingsIo_readWebsocketMessage" at ./FHEM/10_BindingsIo.pm line 409.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::BindingsIo_processMessage" at ./FHEM/10_BindingsIo.pm line 676.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::BindingsIo_readWebsocketMessage" at ./FHEM/10_BindingsIo.pm line 425.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::readingsEndUpdate" at (eval 3282) line 1.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::DoTrigger" at fhem.pl line 4988.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::FW_Notify" at fhem.pl line 3972.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::FW_devState" at ./FHEM/01_FHEMWEB.pm line 3220.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::getAllSets" at ./FHEM/01_FHEMWEB.pm line 3327.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::CommandSet" at fhem.pl line 2900.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::DoSet" at fhem.pl line 1994.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::fhempy_Set" at fhem.pl line 3972.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::IOWrite" at ./FHEM/10_fhempy.pm line 91.
2022.12.01 22:44:16 1: PERL WARNING: Deep recursion on subroutine "main::BindingsIo_Write" at fhem.pl line 1062.
2022.12.01 22:44:16 1: PERL WARNING: Use of uninitialized value in string eq at (eval 3287) line 1.
2022.12.01 22:44:23 1: PERL WARNING: Use of uninitialized value in string eq at (eval 4244) line 1.
2022.12.01 22:44:24 1: PERL WARNING: Use of uninitialized value in string eq at (eval 4439) line 1.
Gespeichert
1 RASPI4B, 1 RASPI3B, 2 CUL, 2 Jeelink, 60 Tuya-Devices (Schalter, Dimmer, Sensoren, Cameras), 30 HUE-Lampen, 5 MAX! WTs, 16 MAX! HTs, 12 MAX! FKs, 1 Bresser 5in1, 1 OilFox, 8 ALEXA Echos und Dots, FHEM, 5 Tasmota-Devices, SonOff -Bridge, PowerFox, Buderus KM200
