Videostreams von IP-Kamera als E-Mail und Live (NVR, h.264, IPC, HLS, FFmpeg)
Begonnen von Torxgewinde, 01 Dezember 2022, 19:17:18
Torxgewinde
Sorry, schon wieder zeitgleich,
Ich hatte gerade noch ein Skript für nur einen Parameter ergänzt. Klappt das?
kroonen
Same issue here. The video works, but only gives last 5 seconds and than it stops, and there comes no new video. In the video dir I get new hd_*.tls files that are newer. Tested with firefox and safari
#!/bin/bash
#Put HLS output into $WEBFOLDER
WEBFOLDER="/opt/fhem/www/video/"
#High resolution RTSP stream
STREAMHIGH="rtsp://user:pass@192.168.180.55:554/"
function cleanup () {
echo "cleaning up..."
exit 0
trap cleanup INT EXIT
cd
#download hls.js if not present
if [ ! -f "$WEBFOLDER/hls.js" ]; then
##wget "https://cdn.jsdelivr.net/npm/hls.js@latest" -O "$WEBFOLDER/hls.js" || exit 1
curl "https://cdn.jsdelivr.net/npm/hls.js@latest" --no-progress-meter --output "$WEBFOLDER/hls.js" || exit 1
fi
#this is a simple webpage with the HLS video.
#Safari plays it without Javascript, Firefox needs hls.js
cat << 'EOM' > "$WEBFOLDER/index.html"
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<script src="hls.js"></script>
<style>
body {
margin: 0;
padding: 0;
video {
object-fit: fill;
width: 100%;
height: auto;
</style>
</head>
<body>
<video id="video" controls autoplay>
<source src="stream.m3u8" type="application/x-mpegURL">
</video>
<script>
if (Hls.isSupported()) {
var video = document.getElementById('video');
var config = {
autoStartLoad: true,
startPosition: 30,
backBufferLength: 60
var hls = new Hls(config);
hls.loadSource('stream.m3u8');
hls.attachMedia(video);
//autoplay, many browsers are configured to only allow autoplay when muted
hls.on(Hls.Events.MANIFEST_PARSED, function() {
video.muted = true;
video.volume = 0;
video.play();
hls.on(Hls.Events.FRAG_LOADED, function() {
video.currentTime = video.duration - 5;
</script>
</body>
</html>
EOM
# https://ffmpeg.org/ffmpeg.html#Advanced-options
# https://ffmpeg.org/ffmpeg-formats.html#hls-2
# -hide_banner: Hide the infos at startup
# -rtsp_transport tcp: Default is to use UDP, which reveals skipped packets in my network
# -i $STREAMHIGH: the input at high resolution
# -i $STREAMLOW: the input at low resultion
# -codec copy: do not transcode, just remux - this is essential for embedded devices!
# -b:v:0 1024k Describe the bandwidth of video of the first input (index starts at 0)
# -b:v:1 256k  For the low resolution stream the bandwidth is about 256kBit/s
# -map 0:v include the videostream of the first input
# -map 1:v include the videostream of second input as well
# -map 0:a for audio of first input (not used here)
# -copytb 1 Use the demuxer timebase
# -copyts copy timestamps from input to output
# -f hls output is HLS
# -var_stream_map 'v:0,name:hd,agroup:my_stream v:1,name:sd,agroup:my_stream' select first video stream, name it "hd", assign a group + select second video stream, name it "sd", assign it to group
# -hls_time 5 each *.ts file has a length of ~5 seconds
# -hls_allow_cache 0 client must not cache the file
# -hls_list_size 10 limit the number of files to this value
# -hls_flags delete_segments+append_list+program_date_time : delete unreferenced (old) *.ts files, append new ts files to playlist, insert recorded date+time
# -hls_segment_filename '$WEBFOLDER/%v_file%d.ts' pattern for the *.ts filename
# -master_pl_name stream.m3u8 pattern for the the HLS master playlist
# -master_pl_publish_rate 10 publish a current master playlist after creating N *.ts segments
# '$WEBFOLDER/%v_stream.m3u8' the output for HLS playlists
while true; do
ffmpeg -hide_banner \
  -rtsp_transport tcp -i $STREAMHIGH \
  -codec copy \
  -b:v:0 2M \
  -map 0:v \
  -copytb 1 -copyts \
  -f hls \
  -var_stream_map 'v:0,name:hd,agroup:my_stream' \
  -hls_time 5 \
  -hls_allow_cache 0 \
  -hls_list_size 10 \
  -hls_flags delete_segments+append_list+program_date_time \
  -hls_segment_filename "$WEBFOLDER/%v_file%d.ts" \
  "$WEBFOLDER/stream.m3u8"
sleep 1
done
exit 0
Torxgewinde
@kroonen:
Please try removing the Javascript:
If that does not work, I can only suggest to check the Developer-Console by pressing F12 on Firefox. Safari does not rely on HLS.js and if that also fails it might be something else. Strange indeed.
