FHEM - Hausautomations-Systeme > MAX
Manually Adjust Temperature
(1/1)
RobinC:
Hi, I hope it is OK to post in English.
I have FHEM running on a raspberry Pi controlling Seven Valves.
I am using the Temperature Scanner and the weekprofile.
If I change the set temperature of a valve on the FHEM page, it changes back to the week profile set within a minute.
Is there any way to make temporary changes to the set temperature which would revert to the weekprofile at the next time interval?
Navigation
[0] Themen-Index
Zur normalen Ansicht wechseln
