Aber gerne.
"Arg":"Rauchmelder_IT",
"Results": [
"Name":"Rauchmelder_IT",
"PossibleSets":"clear defaults:reset,update,old,forceReset readingFilter:multiple-strict,ERROR_CODE,ERROR_DEGRADED_CHAMBER,SMOKE_DETECTOR_ALARM_STATUS,SMOKE_DETECTOR_TEST_RESULT config datapoint command:RESERVED_ALARM_OFF,INTRUSION_ALARM_OFF,INTRUSION_ALARM,SMOKE_TEST,COMMUNICATION_TEST,COMMUNICATION_TEST_REPEATED",
"PossibleAttrs":"alias comment:textField-long eventMap:textField-long group room suppressReading userattr userReadings:textField-long verbose:0,1,2,3,4,5 IODev ccucalculate ccuflags:multiple-strict,hideStdReadings,replaceStdReadings,noBoundsChecking,ackState,logCommand,noReadings,trace,simulate,showMasterReadings,showLinkReadings,showDeviceReadings,showServiceReadings ccureadingfilter:textField-long ccureadingformat:name,namelc,address,addresslc,datapoint,datapointlc ccureadingname:textField-long ccuSetOnChange ccuReadingPrefix ccuscaleval ccuverify:0,1,2 ccuget:State,Value devStateFlags disable:0,1 hmstatevals:textField-long statevals substitute:textField-long substexcl stripnumber peer:textField-long traceFilter event-aggregator event-min-interval event-on-change-reading event-on-update-reading oldreadings stateFormat:textField-long timestamp-on-change-reading statedatapoint:select,SMOKE_DETECTOR_ALARM_STATUS controldatapoint:select,SMOKE_DETECTOR_COMMAND ASC:0,1,2 DbLogExclude DbLogInclude DbLogValueFn:textField-long MSwitchcmd alarmDevice:Actor,Sensor alarmSettings alexaName alexaProactiveEvents:1,0 alexaRoom appOptions:textField-long autooff cmdIcon devStateIcon:textField-long devStateStyle genericDeviceType:security,ignore,switch,outlet,light,blind,thermometer,thermostat,contact,garage,window,lock,scene homebridgeMapping:textField-long icon msgContactAudio msgContactLight msgContactMail msgContactPush msgContactScreen msgParams msgPriority msgRecipient msgRecipientAudio msgRecipientLight msgRecipientMail msgRecipientPush msgRecipientScreen msgRecipientText msgTitle msgTitleShrt msgType:text,push,mail,screen,light,audio,queue readingsWatcher sortby webCmd webCmdLabel:textField-long widgetOverride Rauchmelder Rauchmelder_map structexclude",
"Internals": {
"DEF": "000A5BE99F458A:1",
"FUUID": "61d0301f-f33f-bf2d-7c7c-c7e1804387679463",
"FVERSION": "88_HMCCUCHN.pm:v5.0.0-s26565/2022-10-20",
"IODev": "MyCCU3",
"NAME": "Rauchmelder_IT",
"NR": "467",
"STATE": "IDLE_OFF",
"TYPE": "HMCCUCHN",
"ccuaddr": "000A5BE99F458A:1",
"ccudevstate": "active",
"ccuif": "HmIP-RF",
"ccuname": "HmIP-SWSD 000A5BE99F458A:1",
"ccurolectrl": "SMOKE_DETECTOR",
"ccurolestate": "SMOKE_DETECTOR",
"ccusubtype": "SD",
"ccutype": "HmIP-SWSD",
"eventCount": "11",
"firmware": "1.0.12",
"readonly": "no"
"Readings": {
"ERROR_CODE": { "Value":"0", "Time":"2022-12-03 11:09:17" },
"ERROR_DEGRADED_CHAMBER": { "Value":"false", "Time":"2022-12-03 11:09:17" },
"IODev": { "Value":"MyCCU3", "Time":"2022-11-21 12:26:45" },
"SMOKE_DETECTOR_ALARM_STATUS": { "Value":"IDLE_OFF", "Time":"2022-12-03 11:09:17" },
"SMOKE_DETECTOR_TEST_RESULT": { "Value":"SMOKE_TEST_OK", "Time":"2022-12-03 11:09:17" },
"activity": { "Value":"alive", "Time":"2022-12-03 11:09:16" },
"battery": { "Value":"ok", "Time":"2022-12-03 11:09:16" },
"battery_volt": { "Value":"", "Time":"2022-07-03 09:44:20" },
"devstate": { "Value":"ok", "Time":"2022-12-03 11:09:17" },
"hmstate": { "Value":"IDLE_OFF", "Time":"2022-12-03 11:09:17" },
"rssidevice": { "Value":"-44", "Time":"2022-12-03 11:09:16" },
"rssipeer": { "Value":"-48", "Time":"2022-10-29 14:12:58" },
"state": { "Value":"IDLE_OFF", "Time":"2022-12-03 11:09:17" }
"Attributes": {
"alarmDevice": "Sensor",
"alarmSettings": "alarm7,|Rauchmelder_IT:.*PRIMARY_ALARM.*|IT-Raum|on",
"alias": "Rauchmelder_IT-Raum",
"appOptions": "{ \"template\": \"smokedetect\",\n \"name\": \"IT-Raum\"}",
"devStateIcon": "IDLE_OFF:15px-green PRIMARY_ALARM:15px-red SECONDARY_ALARM:15px-orange",
"event-on-change-reading": ".*",
"group": "Rauchmelder",
"icon": "secur_smoke_detector",
"room": "Alarm,Haus",
"userattr": "Rauchmelder Rauchmelder_map structexclude"
"totalResultsReturned":1
