Ich versuchen einen HmIP-BRC2 Taster in Fhem zu integrieren.
Leider werden mir keine Readings von den Tastensignalen angelegt.
Führe ich detectDev aus, werden Datenpunke angezeigt.
controlRoleCount=0,
defAdd=0019DD89B902EF,
defCCh=-1,
defCDP=,
defMod=HMCCUCHN,
defSCh=1,
defSDP=1.PRESS_SHORT,
level=2,
rolePatternCount=0,
stateRole={
1={
datapoint=PRESS_SHORT,
priority=1,
role=KEY_TRANSCEIVER
2={
priority=1,
stateRoleCount=2,
uniqueControlRoleCount=0,
uniqueStateRoleCount=1
Wo liegt das Problem? Was kann ich machen?
defmod HmIP_BRC2_0019DD89B902EF_1 HMCCUCHN 0019DD89B902EF:1
attr HmIP_BRC2_0019DD89B902EF_1 event-on-update-reading .*
attr HmIP_BRC2_0019DD89B902EF_1 room Homematic
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:58 IODev d_ccu
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:59 activity alive
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:59 devstate ok
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:59 rssidevice -60
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:59 rssipeer N/A
setstate HmIP_BRC2_0019DD89B902EF_1 2022-12-03 18:06:59 voltage 0.0
CFGFN
DEF 0019DD89B902EF:1
FUUID 638b8232-f33f-804b-8df7-592402061c674cc5
IODev d_ccu
NAME HmIP_BRC2_0019DD89B902EF_1
NR 9379
STATE ???
TYPE HMCCUCHN
ccuaddr 0019DD89B902EF:1
ccudevstate active
ccuif HmIP-RF
ccuname HmIP-BRC2 0019DD89B902EF:1
ccurolestate KEY_TRANSCEIVER
ccusubtype BRC2
ccutype HmIP-BRC2
eventCount 2
firmware 1.8.8
readonly no
receiver Bad_Spiegel,Bad_Steckdose,DRSI4_Taster,Bad_Wanne,Bad_Dusche
hmccu:
channels 1
detect 1
devspec 0019DD89B902EF:1
nodefaults 0
role 1:KEY_TRANSCEIVER
setDefaults 0
cmdlist:
get
set
control:
dp:
0.CONFIG_PENDING:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
0.DUTY_CYCLE:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
0.INSTALL_TEST:
VALUES:
NVAL true
ONVAL true
OSVAL true
OVAL true
SVAL true
VAL true
0.OPERATING_VOLTAGE:
VALUES:
NVAL 0.000000
ONVAL 0.000000
OSVAL 0.0
OVAL 0.000000
SVAL 0.0
VAL 0.000000
0.OPERATING_VOLTAGE_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
0.RSSI_DEVICE:
VALUES:
NVAL -60
ONVAL -60
OSVAL -60
OVAL 196
SVAL -60
VAL 196
0.RSSI_PEER:
VALUES:
NVAL N/A
ONVAL N/A
OSVAL N/A
OVAL 0
SVAL N/A
VAL 0
0.UNREACH:
VALUES:
NVAL false
ONVAL false
OSVAL alive
OVAL false
SVAL alive
VAL false
0.UPDATE_PENDING:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
roleCmds:
get:
set:
state:
chn 1
dpt PRESS_SHORT
room Homematic
