Homebrige startet fehlerfrei. Das Handy lädt aber die Konfiguration nicht. Es bleibt alles, auch die anderen Aktoren, Schalter... grau hinterlegt.
Ich kann mir vorstellen das es an dem gleichen HM Device Namen liegt, den kann ich ja nicht ändern.
Versuchshalber bin ich jetzt über readingsProxy gegangen. Da funktioniert es.
DEF 00259F298C74D5 sd=13.STATE cd=14.STATE
FUUID 63825596-f33f-804b-62ac-92ceec3a8096ce09
IODev d_ccu
NAME Bad_Dusche
NR 1576
STATE off
TYPE HMCCUDEV
ccuaddr 00259F298C74D5
ccudevstate active
ccuif HmIP-RF
ccuname HmIP-DRSI4 Bad
ccurolectrl SWITCH_VIRTUAL_RECEIVER
ccurolestate SWITCH_TRANSMITTER
ccusubtype DRSI4
ccutype HmIP-DRSI4
eventCount 267
firmware 1.4.2
readonly no
receiver Bad_T1,Bad_T2
sender Bad_T1,Bad_T2
2022-12-04 09:38:00 13.STATE off
2022-12-04 09:37:59 14.STATE off
2022-12-03 23:28:14 IODev d_ccu
2022-12-04 09:37:59 activity alive
2022-12-04 09:37:59 control off
2022-12-04 09:38:00 devstate ok
2022-12-04 09:38:00 hmstate off
2022-12-04 09:37:59 rssidevice -63
2022-12-04 08:30:02 rssipeer -62
2022-12-04 09:38:00 state off
2022-11-30 20:08:08 voltage 0.0
hmccu:
channels 22
defCDP 14.STATE
defSDP 13.STATE
detect 0
devspec 00259F298C74D6
forcedev 0
nodefaults 0
role 0:MAINTENANCE,1:MULTI_MODE_INPUT_TRANSMITTER,2:MULTI_MODE_INPUT_TRANSMITTER,3:MULTI_MODE_INPUT_TRANSMITTER,4:MULTI_MODE_INPUT_TRANSMITTER,5:SWITCH_TRANSMITTER,6:SWITCH_VIRTUAL_RECEIVER,7:SWITCH_VIRTUAL_RECEIVER,8:SWITCH_VIRTUAL_RECEIVER,9:SWITCH_TRANSMITTER,10:SWITCH_VIRTUAL_RECEIVER,11:SWITCH_VIRTUAL_RECEIVER,12:SWITCH_VIRTUAL_RECEIVER,13:SWITCH_TRANSMITTER,14:SWITCH_VIRTUAL_RECEIVER,15:SWITCH_VIRTUAL_RECEIVER,16:SWITCH_VIRTUAL_RECEIVER,17:SWITCH_TRANSMITTER,18:SWITCH_VIRTUAL_RECEIVER,19:SWITCH_VIRTUAL_RECEIVER,20:SWITCH_VIRTUAL_RECEIVER,21:SWITCH_WEEK_PROFILE
setDefaults 0
cmdlist:
get
set on-till on:noArg off:noArg on-for-timer toggle:noArg
control:
chn 14
dpt STATE
dp:
0.ACTUAL_TEMPERATURE:
VALUES:
NVAL 26.0
ONVAL 26.0
OSVAL 26.0
OVAL 26.0
SVAL 26.0
VAL 26.0
0.CONFIG_PENDING:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
0.DUTY_CYCLE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
0.ERROR_CODE:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
0.ERROR_OVERHEAT:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
0.ERROR_POWER_FAILURE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
0.RSSI_DEVICE:
VALUES:
NVAL -63
ONVAL -61
OSVAL -61
OVAL -61
SVAL -63
VAL -63
0.RSSI_PEER:
VALUES:
NVAL -62
ONVAL -59
OSVAL -59
OVAL -59
SVAL -62
VAL -62
0.UNREACH:
VALUES:
NVAL 0
ONVAL 0
OSVAL alive
OVAL 0
SVAL alive
VAL 0
1.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
10.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
10.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
10.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
10.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
11.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
11.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
11.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
11.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
12.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
12.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
12.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
12.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
13.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
13.SECTION:
VALUES:
NVAL 0
ONVAL 2
OSVAL 2
OVAL 2
SVAL 0
VAL 0
13.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
13.STATE:
VALUES:
NVAL 0
ONVAL 1
OSVAL on
OVAL 1
SVAL off
VAL 0
14.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
14.SECTION:
VALUES:
NVAL 0
ONVAL 2
OSVAL 2
OVAL 2
SVAL 0
VAL 0
14.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
14.STATE:
VALUES:
NVAL 0
ONVAL 1
OSVAL on
OVAL 1
SVAL off
VAL 0
15.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
15.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
15.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
15.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
16.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
16.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
16.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
16.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
17.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
17.SECTION:
VALUES:
NVAL 2
ONVAL 2
OSVAL 2
OVAL 2
SVAL 2
VAL 2
17.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
17.STATE:
VALUES:
NVAL 1
ONVAL 1
OSVAL on
OVAL 1
SVAL on
VAL 1
18.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
18.SECTION:
VALUES:
NVAL 2
ONVAL 2
OSVAL 2
OVAL 2
SVAL 2
VAL 2
18.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
18.STATE:
VALUES:
NVAL 1
ONVAL 1
OSVAL on
OVAL 1
SVAL on
VAL 1
19.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
19.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
19.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
19.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
2.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
20.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
20.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
20.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
20.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
21.WEEK_PROGRAM_CHANNEL_LOCKS:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
3.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
4.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL false
OVAL 0
SVAL false
VAL 0
5.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
5.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
5.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
5.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
6.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
6.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
6.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
6.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
7.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
7.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
7.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
7.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
8.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
8.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
8.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
8.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
9.PROCESS:
VALUES:
NVAL 0
ONVAL 0
OSVAL STABLE
OVAL 0
SVAL STABLE
VAL 0
9.SECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
9.SECTION_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL NORMAL
OVAL 0
SVAL NORMAL
VAL 0
9.STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL off
OVAL 0
SVAL off
VAL 0
roleCmds:
get:
set:
off:
channel 14
role SWITCH_VIRTUAL_RECEIVER
subcount 1
syntax V:STATE:0
usage off
subcmd:
000:
args 0
dpt STATE
fnc
max 1
min 0
parname STATE
partype 3
ps VALUES
scn 000
unit
on:
channel 14
subcount 1
syntax V:STATE:1
usage on
subcmd:
000:
args 1
dpt STATE
fnc
max 1
min 0
parname STATE
partype 3
ps VALUES
scn 000
unit
on-for-timer:
channel 14
subcount 2
syntax V:ON_TIME:?duration V:STATE:1
usage on-for-timer duration
subcmd:
000:
args
dpt ON_TIME
fnc
max 8580000.0
min 0.0
parname duration
partype 2
ps VALUES
scn 000
unit s
001:
args 1
dpt STATE
fnc
max 1
min 0
parname STATE
partype 3
ps VALUES
scn 001
unit
on-till:
channel 14
subcount 2
syntax V:ON_TIME:?time V:STATE:1
usage on-till time
subcmd:
000:
args
dpt ON_TIME
fnc
max 8580000.0
min 0.0
parname time
partype 2
ps VALUES
scn 000
unit s
001:
args 1
dpt STATE
fnc
max 1
min 0
parname STATE
partype 3
ps VALUES
scn 001
unit
state:
chn 13
dpt STATE
alias Dusche
ccureadingfilter 13,14.(STATE)
cmdIcon on:general_an off:general_aus
devStateIcon on:10px-kreis-rot off:10px-kreis-gruen
genericDeviceType light
group Bad
homebridgeMapping On=13.STATE,valueOn=on,valueOff=off,cmdOn=on,cmdOff=off
room Bad/WC
stateFormat 13.STATE
