FHEM - Hausautomations-Systeme > Homematic
Slider ergibt systemabsturz
DK4RST:
Hallo , ich habe mehrere WTH-2 mit der Automatik ;
get d_ccu createDev ;
angelegt
list S_Bad
--- Code: ---Save config
HMCCUCHN
HMCCURPCPROC
Heizung
Homematic
MQTT2_DEVICE
Unsorted
icoEverything Everything
Logfile
Commandref
Remote doc
Edit files
Select style
Event monitor
DEF 000A97098ED065:1
FUUID 638e377d-f33f-e8dd-a230-41e2f738a5c285a9
IODev d_ccu
NAME S_Bad
NR 49
STATE 19.1
TYPE HMCCUCHN
ccuaddr 000A97098ED065:1
ccudevstate active
ccuif HmIP-RF
ccuname S_Bad:1
ccutype HmIP-WTH-2
eventCount 10
readonly no
2022-12-07 12:39:22 ACTIVE_PROFILE 1
2022-12-07 12:39:22 ACTUAL_TEMPERATURE 20.1
2022-12-07 12:39:22 ACTUAL_TEMPERATURE_STATUS 0
2022-12-07 12:39:22 BOOST_MODE 0
2022-12-07 12:39:22 BOOST_TIME 0
2022-12-07 12:39:22 FROST_PROTECTION 0
2022-12-07 12:39:22 HEATING_COOLING 0
2022-12-07 12:39:22 HUMIDITY 50
2022-12-07 12:39:22 HUMIDITY_STATUS 0
2022-12-06 11:04:39 IODev d_ccu
2022-12-07 12:39:22 PARTY_MODE 0
2022-12-07 08:46:07 PARTY_SET_POINT_TEMPERATURE 0.0
2022-12-07 08:46:07 PARTY_TIME_END
2022-12-07 08:46:07 PARTY_TIME_START
2022-12-07 12:39:22 QUICK_VETO_TIME 0
2022-12-07 12:39:22 SET_POINT_MODE 1
2022-12-07 12:39:22 SET_POINT_TEMPERATURE 23.0
2022-12-07 12:39:22 SWITCH_POINT_OCCURED 0
2022-12-07 12:39:22 WINDOW_STATE 0
2022-12-07 12:39:21 activity alive
2022-12-07 12:39:21 battery ok
2022-12-06 10:49:36 control 23.0
2022-12-06 10:49:36 desired-temp 23.0
2022-12-07 12:39:22 devstate ok
2022-12-07 12:39:22 hmstate 19.1
2022-12-06 10:49:36 humidity 51
2022-12-06 10:49:36 measured-temp 19.1
2022-12-07 12:39:21 rssidevice -63
2022-12-07 08:46:07 rssipeer -69
2022-12-06 10:49:36 state 19.1
2022-12-07 12:39:21 voltage 2.4
hmccu:
channels 1
detect 0
devspec 000A97098ED065:1
nodefaults 1
setDefaults 0
cmdlist:
control:
dp:
0.CONFIG_PENDING:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
0.DUTY_CYCLE:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
0.INSTALL_TEST:
VALUES:
NVAL true
ONVAL true
OSVAL true
OVAL true
SVAL true
VAL true
0.LOW_BAT:
VALUES:
NVAL 0
ONVAL 0
OSVAL ok
OVAL 0
SVAL ok
VAL 0
0.OPERATING_VOLTAGE:
VALUES:
NVAL 2.4
ONVAL 2.4
OSVAL 2.4
OVAL 2.4
SVAL 2.4
VAL 2.4
0.OPERATING_VOLTAGE_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
0.RSSI_DEVICE:
VALUES:
NVAL -63
ONVAL -65
OSVAL -65
OVAL -65
SVAL -63
VAL -63
0.RSSI_PEER:
VALUES:
NVAL -69
ONVAL -69
OSVAL -69
OVAL 187
SVAL -69
VAL 187
0.UNREACH:
VALUES:
NVAL 0
ONVAL 0
OSVAL alive
OVAL 0
SVAL alive
VAL 0
0.UPDATE_PENDING:
VALUES:
NVAL false
ONVAL false
OSVAL false
OVAL false
SVAL false
VAL false
1.ACTIVE_PROFILE:
VALUES:
NVAL 1
ONVAL 1
OSVAL 1
OVAL 1
SVAL 1
VAL 1
1.ACTUAL_TEMPERATURE:
VALUES:
NVAL 20.1
ONVAL 19.9
OSVAL 19.9
OVAL 19.9
SVAL 20.1
VAL 20.1
1.ACTUAL_TEMPERATURE_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.BOOST_MODE:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.BOOST_TIME:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.FROST_PROTECTION:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.HEATING_COOLING:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.HUMIDITY:
VALUES:
NVAL 50
ONVAL 50
OSVAL 50
OVAL 50
SVAL 50
VAL 50
1.HUMIDITY_STATUS:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.PARTY_MODE:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.PARTY_SET_POINT_TEMPERATURE:
VALUES:
NVAL 0.000000
ONVAL 0.000000
OSVAL 0.0
OVAL 0.000000
SVAL 0.0
VAL 0.000000
1.PARTY_TIME_END:
VALUES:
NVAL
ONVAL
OSVAL
OVAL
SVAL
VAL
1.PARTY_TIME_START:
VALUES:
NVAL
ONVAL
OSVAL
OVAL
SVAL
VAL
1.QUICK_VETO_TIME:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.SET_POINT_MODE:
VALUES:
NVAL 1
ONVAL 1
OSVAL 1
OVAL 1
SVAL 1
VAL 1
1.SET_POINT_TEMPERATURE:
VALUES:
NVAL 23.0
ONVAL 23.0
OSVAL 23.0
OVAL 23.0
SVAL 23.0
VAL 23.0
1.SWITCH_POINT_OCCURED:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
1.WINDOW_STATE:
VALUES:
NVAL 0
ONVAL 0
OSVAL 0
OVAL 0
SVAL 0
VAL 0
roleCmds:
get:
set:
state:
cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
room HMCCUCHN,Heizung
substexcl desired-temp
webCmd desired-temp:auto:manu:boost:on:off
widgetOverride desired-temp:slider,4.5,0.5,30.5,1
wie man sieht wird dabei webCMD und WidgetOverride angelegt
direkt nach dem anlegen funktioniert es, nach einiger Zeit kommt jedoch bei bedienung des Sliders die Fehlermeldung :
Unknown argument desired-temp choose one of clear defaults:reset,update,old,forceReset
readingFilter:multiple-strict,ACTIVE_PROFILE,ACTUAL_TEMPERATURE,ACTUAL_TEMPERATURE_STATUS,
BOOST_MODE,BOOST_TIME,FROST_PROTECTION,HEATING_COOLING,HUMIDITY,HUMIDITY_STATUS,PARTY_MODE,
PARTY_SET_POINT_TEMPERATURE,PARTY_TIME_END,PARTY_TIME_START,QUICK_VETO_TIME,SET_POINT_MODE,
SET_POINT_TEMPERATURE,SWITCH_POINT_OCCURED,WINDOW_STATE config datapoint
mit dem eintrag im Logfile:
--- Ende Code ---
--- Code: ---2022.12.07 12:02:07 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
2022.12.07 12:02:08 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
2022.12.07 12:02:12 2: HMCCU [d_ccu] Can't get device description for 000615699CED0A HMCCU_DetectDevice:8126 HMCCU_SetDefaultSCDatapoints:8240 HMCCU_GetSCDatapoints:4748 HMCCU_UpdateParamsetReadings:4959 HMCCU_UpdateMultipleDevices:878 HMCCURPCPROC_Read:3976 CallFn:784
--- Ende Code ---
nun habe ich mich an lesen und suchen gegeben, auch habe ich versucht zap eine PM zu senden, leider alles ohne ein Ergebnis , was dies löst.
auch eine Änderung der Werte
webCmd desired-temp
widgetOverride desired-temp:uzsuDropDown,5,18,18.5,19,19.5,20,20.5,21,21.5,22,22.5,23
hilft nicht
kann mir dazu einer etwas sagen?
Besten DAnk
frank:
--- Zitat ---Can't get device description for 000615699CED0A
--- Ende Zitat ---
das ist dein problematischer FAL24, hat also primär nichts mit dem WTH-2 zu tun.
vermutlich hast du sie gepeert und das setzen der desired-temp erzeugt eine änderung im FAL24.
konzentriere dich auf den FAL24.
DK4RST:
Der FAL ist gar nicht mehr im System! und ok aber worauf sollte ich mich dort Konzentrieren, bitte?
Ich habe Ihnraus genommen weil ich das auch dachte. Nur es liegt nicht an Ihm!
--- Code: ---Type list <name> for detailed info.
Global:
global (no definition)
MQTT2_SERVER:
m2server (Initialized)
m2server_192.168.178.119_60016 (Connected)
m2server_192.168.178.122_54889 (Connected)
FHEMWEB:
WEB (Initialized)
WEB_192.168.178.136_59680 (Connected)
WEB_192.168.178.136_61546 (Connected)
WEB_192.168.178.136_61557 (Connected)
MQTT2_DEVICE:
MQTT2_Hausverteiler_oben_12 (???)
MQTT2_Hausverteiler_unten_10_10 (???)
HMCCU:
d_ccu (running/OK)
HMCCUCHN:
S_AWohnZ (23.3)
S_Bad (19.1)
S_PC (18.5)
S_SchlafZ (17.6)
HMCCURPCPROC:
d_rpc178003BidCos_RF (running/OK)
d_rpc178003HmIP_RF (running/OK)
d_rpc178003VirtualDevices (running/OK)
FileLog:
FileLog_MQTT2_Hausverteiler_oben_12 (active)
FileLog_MQTT2_Hausverteiler_unten_10_10 (active)
FileLog_S_Bad (active)
Logfile (active)
DOIF:
Nachricht_Ausfall (cmd_2)
SVG:
SVG_FileLog_S_Bad_1 (initialized)
autocreate:
autocreate (active)
readingsWatcher:
myreadingsWatcher (ok)
telnet:
telnetForBlockingFn_1670413968.94859 (Initialized)
--- Ende Code ---
--- Code: ---attr global userattr cmdIcon devStateIcon:textField-long devStateStyle icon readingsWatcher sortby webCmd webCmdLabel:textField-long widgetOverride
attr global altitude 47
attr global autosave 0
attr global backup_before_update 1
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global nrarchive 7
attr global sendStatistics onUpdate
attr global statefile ./log/fhem.save
attr global verbose 3
setuuid WEB 63721405-f33f-e8dd-18df-98cd77497037aa63
attr WEB JavaScripts codemirror/fhem_codemirror.js
attr WEB detailLinks 6
attr WEB editConfig 1
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log Logfile
setuuid Logfile 63721405-f33f-e8dd-b3eb-9e2ffff0b824dbbe
define autocreate autocreate
setuuid autocreate 63721405-f33f-e8dd-e3fe-d7cd02f667bd5dc3
attr autocreate filelog ./log/%NAME-%Y-%m.log
define m2server MQTT2_SERVER 1883 global
setuuid m2server 63888cd8-f33f-e8dd-97d7-8289592d949b5955
attr m2server autocreate complex
attr m2server room MQTT2_DEVICE
define myreadingsWatcher readingsWatcher global
setuuid myreadingsWatcher 638dd137-f33f-e8dd-c36f-458ca1c51e5d0b72
attr myreadingsWatcher interval 10
attr myreadingsWatcher readingActivity none
define Nachricht_Ausfall DOIF ([myreadingsWatcher:dead] > 0) ()
setuuid Nachricht_Ausfall 638dd4b6-f33f-e8dd-afb0-ad1cc9fb54c5fd42
attr Nachricht_Ausfall do always
define d_ccu HMCCU 192.168.178.3 ccudelay=180
setuuid d_ccu 638e351a-f33f-e8dd-b597-a57d5b76103f2e06
attr d_ccu ccudef-substitute AES_KEY!(0|false):off,(1|true):on;;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;;UNREACH!(0|false):alive,(1|true):dead;;MOTION!(0|false):noMotion,(1|true):motion;;DIRECTION!0:stop,1:up,2:down,3:undefined;;WORKING!0:false,1:true;;INHIBIT!(0|false):unlocked,(1|true):locked
attr d_ccu ccuflags procrpc
attr d_ccu ccuget Value
attr d_ccu cmdIcon on:general_an off:general_aus
attr d_ccu room Homematic
attr d_ccu rpcinterfaces BidCos-RF,CUxD,HmIP-RF,VirtualDevices
attr d_ccu rpcserver on
attr d_ccu stateFormat rpcstate/state
define d_rpc178003BidCos_RF HMCCURPCPROC http://192.168.178.3 BidCos-RF
setuuid d_rpc178003BidCos_RF 638e351a-f33f-e8dd-6b43-272c993eb745754e
attr d_rpc178003BidCos_RF alias CCU 178003 RPC BidCos-RF
attr d_rpc178003BidCos_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003BidCos_RF room HMCCURPCPROC,Homematic
attr d_rpc178003BidCos_RF stateFormat rpcstate/state
attr d_rpc178003BidCos_RF verbose 2
define d_rpc178003VirtualDevices HMCCURPCPROC http://192.168.178.3 VirtualDevices
setuuid d_rpc178003VirtualDevices 638e351b-f33f-e8dd-c447-e97c934f9d86f9a6
attr d_rpc178003VirtualDevices alias CCU 178003 RPC VirtualDevices
attr d_rpc178003VirtualDevices eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003VirtualDevices room HMCCURPCPROC,Homematic
attr d_rpc178003VirtualDevices stateFormat rpcstate/state
attr d_rpc178003VirtualDevices verbose 2
define d_rpc178003HmIP_RF HMCCURPCPROC http://192.168.178.3 HmIP-RF
setuuid d_rpc178003HmIP_RF 638e351b-f33f-e8dd-b7db-f8d37225d25ff6ef
attr d_rpc178003HmIP_RF alias CCU 178003 RPC HmIP-RF
attr d_rpc178003HmIP_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc178003HmIP_RF room HMCCURPCPROC,Homematic
attr d_rpc178003HmIP_RF stateFormat rpcstate/state
attr d_rpc178003HmIP_RF verbose 2
define S_AWohnZ HMCCUCHN 000A97098ED86C:1
setuuid S_AWohnZ 638e3722-f33f-e8dd-a30a-764ec75d72ae60fc
attr S_AWohnZ cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_AWohnZ room Heizung,HMCCUCHN,Homematic
attr S_AWohnZ webCmd desired-temp
attr S_AWohnZ widgetOverride desired-temp:uzsuDropDown,5,18,18.5,19,19.5,20,20.5,21,21.5,22,22.5,23
define S_Bad HMCCUCHN 000A97098ED065:1
setuuid S_Bad 638e377d-f33f-e8dd-a230-41e2f738a5c285a9
attr S_Bad cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_Bad room HMCCUCHN,Heizung
attr S_Bad substexcl desired-temp
attr S_Bad webCmd desired-temp:auto:manu:boost:on:off
attr S_Bad widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define S_SchlafZ HMCCUCHN 000A97098EDA27:1
setuuid S_SchlafZ 638e5250-f33f-e8dd-6a84-50b47830acccf745
attr S_SchlafZ cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_SchlafZ room HMCCUCHN,Heizung
attr S_SchlafZ substexcl desired-temp
attr S_SchlafZ webCmd desired-temp:auto:manu:boost:on:off
attr S_SchlafZ widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define S_PC HMCCUCHN 000A97098ED06C:1
setuuid S_PC 638e5269-f33f-e8dd-ee2a-f52b89b7b825ce78
attr S_PC cmdIcon auto:sani_heating_automatic manu:sani_heating_manual boost:sani_heating_boost on:general_an off:general_aus
attr S_PC room HMCCUCHN,Heizung
attr S_PC substexcl desired-temp
attr S_PC webCmd desired-temp:auto:manu:boost:on:off
attr S_PC widgetOverride desired-temp:slider,4.5,0.5,30.5,1
define SVG_FileLog_S_Bad_1 SVG FileLog_S_Bad:SVG_FileLog_S_Bad_1:CURRENT
setuuid SVG_FileLog_S_Bad_1 638f07f6-f33f-e8dd-0b23-4ba79329b830eb76
define MQTT2_Hausverteiler_unten_10_10 MQTT2_DEVICE Hausverteiler_unten_10_10
setuuid MQTT2_Hausverteiler_unten_10_10 638f0c2a-f33f-e8dd-c0ba-6a7beae13ea8b357
attr MQTT2_Hausverteiler_unten_10_10 readingList Hausverteiler_unten_10_10:Hausverteiler_unten_10/Heiz_Unten2/T02:.* T02\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/Heiz_Unten/T01:.* T01\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/status/LWT:.* LWT\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/freeRAM:.* freeRAM\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/freeStack:.* freeStack\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/SysLoad:.* SysLoad\
Hausverteiler_unten_10_10:Hausverteiler_unten_10/EE2_SysInf/WifiRSSI:.* WifiRSSI
attr MQTT2_Hausverteiler_unten_10_10 room MQTT2_DEVICE
define FileLog_MQTT2_Hausverteiler_unten_10_10 FileLog ./log/MQTT2_Hausverteiler_unten_10_10-%Y-%m.log MQTT2_Hausverteiler_unten_10_10
setuuid FileLog_MQTT2_Hausverteiler_unten_10_10 638f0c2a-f33f-e8dd-cff7-a3ae14fd8a2fdb70
attr FileLog_MQTT2_Hausverteiler_unten_10_10 logtype text
attr FileLog_MQTT2_Hausverteiler_unten_10_10 room MQTT2_DEVICE
define MQTT2_Hausverteiler_oben_12 MQTT2_DEVICE Hausverteiler_oben_12
setuuid MQTT2_Hausverteiler_oben_12 638f0d8d-f33f-e8dd-4bf1-4c94ee492102c125
attr MQTT2_Hausverteiler_oben_12 readingList Hausverteiler_oben_12:Hausverteiler_oben/Vorlauf_1/t_1_1:.* t_1_1\
Hausverteiler_oben_12:Hausverteiler_oben/Vorlauf_2/t_1_2:.* t_1_2\
Hausverteiler_oben_12:Hausverteiler_oben/status/LWT:.* LWT
attr MQTT2_Hausverteiler_oben_12 room MQTT2_DEVICE
define FileLog_MQTT2_Hausverteiler_oben_12 FileLog ./log/MQTT2_Hausverteiler_oben_12-%Y-%m.log MQTT2_Hausverteiler_oben_12
setuuid FileLog_MQTT2_Hausverteiler_oben_12 638f0d8d-f33f-e8dd-c8aa-5422e720160d5156
attr FileLog_MQTT2_Hausverteiler_oben_12 logtype text
attr FileLog_MQTT2_Hausverteiler_oben_12 room MQTT2_DEVICE
define FileLog_S_Bad FileLog ./log/S_Bad-%Y-%m.log S_Bad
setuuid FileLog_S_Bad 638f12cd-f33f-e8dd-6f64-3ac0d50bd7b54525
attr FileLog_S_Bad logtype text
attr FileLog_S_Bad room HMCCUCHN,Heizung
--- Ende Code ---
das ist ein WTH-2 define S_PC HMCCUCHN 000A97098ED06C:1
neuester Fehler:
--- Code: ---2022.12.07 14:28:47 2: HMCCU [d_ccu] Error during HTTP request: http://192.168.178.3:8181/tclrega.exe: Select timeout/error:
2022.12.07 14:28:47 1: HMCCUCHN [S_PC] HMCCUCHN: S_PC Execution of CCU script or command failed
--- Ende Code ---
frank:
--- Zitat ---Der FAL ist gar nicht mehr im System!
--- Ende Zitat ---
aber in der ccu, oder?
oder direkte verknüpfungen, die im wth existieren.
DK4RST:
gerne alles was mich in diesen Punkzen weiter bringt.
Global:
MQTT2_SERVER:
m2server_192.168.178.119_52947 (Connected)
m2server_192.168.178.122_60873 (Connected)
FHEMWEB:
WEB (Initialized)
WEB_192.168.178.136_61905 (Connected)
WEB_192.168.178.136_62845 (Connected)
MQTT2_DEVICE:
HMCCU:
d_ccu (running/OK)
HMCCUCHN:
S_AWohnZ (23.4)
S_Bad (21.2)
S_PC (19.4)
S_SchlafZ (19.7)
HMCCURPCPROC:
FileLog:
Logfile (active)
DOIF:
SVG:
autocreate:
autocreate (active)
readingsWatcher:
--- Ende Code ---
welche Verknüpfungen meinst Du?
auch die die auf dem HomeMatic Raspberry pi sind, der stellt ja eigentlich ein ccu2 dar.
Wenn ich es richtig verstehe macht der FAL die vielen probleme, ich hab es aber bisher nicht verstanden wie ich Ihn nutzen kann oder ob er nicht nutzbar ist oder es einfach an mir liegt.
Ich bitte hier wirklich um Hilfe , Beispiele. Oder ein ToDo am besten.
Ich möchte eben das die Stellmotoren auch ansprechbar sind. am besten alles über fhem aber wenn es nicht geht dann wenigstens das ich die Temp sehe und am wth-2 einstellen kann , die Auswirkungen ohne das ich die in fhem sehe aber vollzogen werden, damit es in dem Raum eben auch warm wird.
Besten Dank
Navigation
[0] Themen-Index
[#] Nächste Seite
Zur normalen Ansicht wechseln
