Hallo Otto,
Ich hänge mich da mal an. Ich habe etwas ähnliches geschrieben, allerdings in Perl.
root@h-phoscongw:~# cat /usr/local/bin/deCONZrestart.pl
#!/usr/bin/perl
# Developed with Kate
# (c) 2019 Copyright: Marko Oldenburg (marko.oldenburg at araneaconsult dot de)
# All rights reserved
# This script is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# any later version.
# The GNU General Public License can be found at
# http://www.gnu.org/copyleft/gpl.html.
# A copy is found in the textfile GPL.txt and important notices to the license
# from the author is found in LICENSE.txt distributed with these scripts.
# This script is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
use strict;
use warnings;
use POSIX;
use IO::Socket::INET;
# Forward declarations
sub deconzDaemonSystemctl($$);
sub deconzDaemonState($);
sub sendStateToFHEM();
sub deconzDaemonCpuLast();
# Variables:
my $self = {};
$self->{daemons} = ['deconz','deconz-wifi'];
# Start the program
my ($arg,$debug,$acount);
exit 'Usage status|restart' unless ( scalar(@ARGV) > 0 );
$arg = shift @ARGV;
$debug = 0;
if ( $arg eq 'restart' ) {
deconzDaemonSystemctl('restart',$self->{daemons}->[0]);
deconzDaemonSystemctl('stop',$self->{daemons}->[1]);
$acount = 0;
foreach ( @{ $self->{daemons} } ) {
deconzDaemonState($self->{daemons}->[$acount]);
$acount++;
deconzDaemonCpuLast() if ( $arg eq 'restart' or $arg eq 'status' );
sendStateToFHEM();
sub deconzDaemonSystemctl($$) {
my ( $ctlCmd, $daemon ) = @_;
system('systemctl ' . $ctlCmd . ' ' . $daemon);
return 0;
sub deconzDaemonState($) {
my $daemon = shift;
$self->{daemons}->[$acount] = { daemon => $daemon };
if ( open( STATE, "systemctl status $daemon 2>&1 |" ) ) {
while ( my $line = <STATE> ) {
chomp($line);
print qq($line\n) if ( $debug == 1 );
if ( $line =~ m#^\s+Loaded:\s(\S+)# ) {
$self->{daemons}->[$acount]->{loaded} = $1;
elsif ( $line =~ m#^^\s+Active:\s(\S+\s\S+)\s\S+\s(\S+\s\S+\s\S+\s\S+);\s(\S+)# ) {
$self->{daemons}->[$acount]->{active} = $1;
$self->{daemons}->[$acount]->{timestamp} = $2;
$self->{daemons}->[$acount]->{timeago} = $3;
close(STATE);
else {
die "Couldn't use STATE: $!\n";
$self->{daemons}->[$acount]->{error} = 'Couldn\'t use STATE: ' . $;;
return 1;
return 0;
sub deconzDaemonCpuLast() {
if ( open( STATE, 'ps uax 2>&1 |' ) ) {
chomp($line);
if ( $line =~ m#^marko\s+\d+\s+(\d+.\d*).+\/usr\/bin\/deCONZ# ) {
$self->{daemons}->[0]->{cpuLast} = $1;
close(STATE);
else {
$self->{daemons}->[0]->{error} = 'Couldn\'t use STATE: ' . $;;
return 1;
return 0;
sub sendStateToFHEM() {
my $fhemDummy = 'dummyDeconzDaemonState';
print 'test' . "\n";
my $HOSTNAME = "p-fhem.tuxnet.lan";
my $HOSTPORT = "7072";
my $socket = IO::Socket::INET->new('PeerAddr' => $HOSTNAME,'PeerPort' => $HOSTPORT,'Proto' => 'tcp')
or die 'Cant\'t connect to FHEM Instance';
$acount = 0;
while ( my ( $r, $v ) = each %{$self->{daemons}->[$acount]} ) {
$socket->print('setreading ' . $fhemDummy . ' ' . $self->{daemons}->[$acount]->{daemon} . '_' . $r . ' ' . $v . "\n") if ( $v ne $self->{daemons}->[$acount]->{daemon} );
$socket->print('setreading ' . $fhemDummy . ' state ' . $v ."\n") if ( $r eq 'active' and $self->{daemons}->[$acount]->{daemon} eq 'deconz' );
$acount++;
$socket->close;
Abgefragt werden die Zustände meines DeConz Dienstes. Die erhaltenen Werte und Zustände werden dann an einen Dummy in FHEM als Reading gesendet.
