Worauf Achten bei IP Änderung im LAN?
Begonnen von misux, 30 Januar 2023, 06:29:24
MadMax-FHEM
#15
Zitat von: misux am 30 Januar 2023, 20:07:25
Mist... Hat vielleicht einer mal eben den inhalt von interfaces.d und vielleicht auch die dhcpd ?
Welches OS?
Version?
EDIT: hier mal für Raspbian OS Bullseye
:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source /etc/network/interfaces.d/*
:~ $ ll /etc/network/interfaces.d/
total 8
drwxr-xr-x 2 root root 4096  4. Nov 2020  .
drwxr-xr-x 7 root root 4096 27. Mai 2022  ..
:~ $ cat /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Most distributions have NTP support.
#option ntp_servers
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
Kann man die Datei auch irgendwie am PC bearbeiten? Denn ssh geht auch nicht...
Ja, wenn du Ext4 (vermute ich) lesen/schreiben kannst...
...oder mit einer Linux-Live booten.
Gruß, Joachim
FHEM PI3 Buster (Test)
misux
raspbian lite bullseye oder die vorherige... sollte sehr ähnlich sein... ext4 kann ich am win lesen...
misux
OK, habs hinbekommen...
Bis jetzt scheint alles zu funktionieren... Bin gespannt... werde morgen ein paar neustarts durchführen.
