Autor Thema: PanStamp Board RGB,CW,WW;DMX;IR  (Gelesen 209880 mal)
Offline Markus Bloch
  • Administrator
Antw:PanStamp Board RGB,CW,WW;DMX;IR
« Antwort #240 am: 02 Januar 2014, 13:17:43 »
2014.01.02 13:19:15.374 5: panStick: 0003002C000308A4C8 -70 47
2014.01.02 13:19:15.375 5: panStick dispatch 0003002C000308A4C8
2014.01.02 13:19:15.375 4: LED_Filmeregal -> broadcast (0,0-2C): status LED_Filmeregal 08:A4C8
2014.01.02 13:19:15.429 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.451 5: SW: 03010000010309
2014.01.02 13:19:15.469 5: panStamp/RAW: /(0730)00
2014.01.02 13:19:15.471 5: panStamp/RAW: (0730)00/03002D00
2014.01.02 13:19:15.473 5: panStamp/RAW: (0730)0003002D00/030903
2014.01.02 13:19:15.474 5: panStamp/RAW: (0730)0003002D00030903
2014.01.02 13:19:15.475 5: panStick: 0003002D00030903 -70.5 48
2014.01.02 13:19:15.475 5: panStick dispatch 0003002D00030903
2014.01.02 13:19:15.476 4: LED_Filmeregal -> broadcast (0,0-2D): status LED_Filmeregal 09:03
2014.01.02 13:19:15.529 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.551 5: SW: 0301000001030A
2014.01.02 13:19:15.569 5: panStamp/RAW: /(072F)0
2014.01.02 13:19:15.571 5: panStamp/RAW: (072F)0/003002E0
2014.01.02 13:19:15.573 5: panStamp/RAW: (072F)0003002E0/0030AFF
2014.01.02 13:19:15.574 5: panStamp/RAW: (072F)0003002E00030AFF/FF
2014.01.02 13:19:15.575 5: panStick: 0003002E00030AFFFF -70.5 47
2014.01.02 13:19:15.575 5: panStick dispatch 0003002E00030AFFFF
2014.01.02 13:19:15.576 4: LED_Filmeregal -> broadcast (0,0-2E): status LED_Filmeregal 0A:FFFF
2014.01.02 13:19:15.629 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.651 5: SW: 03010000010300
2014.01.02 13:19:15.669 5: panStamp/RAW: /(07
2014.01.02 13:19:15.671 5: panStamp/RAW: (07/30)00030
2014.01.02 13:19:15.672 5: panStamp/RAW: (0730)00030/02F00030
2014.01.02 13:19:15.674 5: panStamp/RAW: (0730)0003002F00030/0000000
2014.01.02 13:19:15.676 5: panStamp/RAW: (0730)0003002F000300000000/22000000
2014.01.02 13:19:15.678 5: panStamp/RAW: (0730)0003002F00030000000022000000/03
2014.01.02 13:19:15.679 5: panStick: 0003002F0003000000002200000003 -70.5 48
2014.01.02 13:19:15.679 5: panStick dispatch 0003002F0003000000002200000003
2014.01.02 13:19:15.680 4: LED_Filmeregal -> broadcast (0,0-2F): status LED_Filmeregal 00:0000002200000003
2014.01.02 13:19:15.681 5: panStick sending 0000010300
2014.01.02 13:19:15.682 5: panStick sending 0000010301
2014.01.02 13:19:15.682 5: panStick sending 0000010302
2014.01.02 13:19:15.683 5: panStick sending 0000010303
2014.01.02 13:19:15.683 5: panStick sending 0000010304
2014.01.02 13:19:15.684 5: panStick sending 0000010305
2014.01.02 13:19:15.685 5: panStick sending 0000010306
2014.01.02 13:19:15.685 5: panStick sending 0000010307
2014.01.02 13:19:15.686 5: panStick sending 0000010308
2014.01.02 13:19:15.686 5: panStick sending 0000010309
2014.01.02 13:19:15.687 5: panStick sending 000001030A
2014.01.02 13:19:15.729 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.750 5: SW: 03010000010301
2014.01.02 13:19:15.769 5: panStamp/RAW: /(0731)00
2014.01.02 13:19:15.771 5: panStamp/RAW: (0731)00/0300300
2014.01.02 13:19:15.773 5: panStamp/RAW: (0731)000300300/00301001
2014.01.02 13:19:15.774 5: panStamp/RAW: (0731)00030030000301001/00000
2014.01.02 13:19:15.775 5: panStick: 0003003000030100100000 -70.5 49
2014.01.02 13:19:15.775 5: panStick dispatch 0003003000030100100000
2014.01.02 13:19:15.776 4: LED_Filmeregal -> broadcast (0,0-30): status LED_Filmeregal 01:00100000
2014.01.02 13:19:15.829 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.851 5: SW: 03010000010302
2014.01.02 13:19:15.869 5: panStamp/RAW: /(0731)
2014.01.02 13:19:15.871 5: panStamp/RAW: (0731)/00030031
2014.01.02 13:19:15.873 5: panStamp/RAW: (0731)00030031/0003020
2014.01.02 13:19:15.874 5: panStamp/RAW: (0731)000300310003020/0020001
2014.01.02 13:19:15.876 5: panStamp/RAW: (0731)0003003100030200020001
2014.01.02 13:19:15.877 5: panStick: 0003003100030200020001 -70.5 49
2014.01.02 13:19:15.877 5: panStick dispatch 0003003100030200020001
2014.01.02 13:19:15.878 4: LED_Filmeregal -> broadcast (0,0-31): status LED_Filmeregal 02:00020001
2014.01.02 13:19:15.929 2: panStamp TRANSMIT LIMIT EXCEEDED
2014.01.02 13:19:15.951 5: SW: 03010000010303
2014.01.02 13:19:15.969 5: panStamp/RAW: /(072E)000
2014.01.02 13:19:15.971 5: panStamp/RAW: (072E)000/30032000
2014.01.02 13:19:15.973 5: panStamp/RAW: (072E)00030032000/30301
2014.01.02 13:19:15.973 5: panStick: 0003003200030301 -70.5 46
2014.01.02 13:19:15.973 5: panStick dispatch 0003003200030301
2014.01.02 13:19:15.974 4: LED_Filmeregal -> broadcast (0,0-32): status LED_Filmeregal 03:01
Hier nochmal mit verbose.
LED_Filmeregal hat den neuen Sketch
edit: hatte noch reverse_logs an. Jetzt ist die reihenfolge richtig rum zu erkennen :-)
« Letzte Änderung: 02 Januar 2014, 13:20:33 von Markus Bloch »
Offline justme1968
« Antwort #241 am: 02 Januar 2014, 13:37:12 »
mist. fehler gefunden. ich hab es eben eingecheckt.
du kannst bei dir bis auf weiteres die zeile 935 auskommentieren.
  andre
FS20:fs20as4,fs20bs,fs20di
AKCP:THS01,WS15
CUL_WS:S300TH
  • Administrator
« Antwort #242 am: 02 Januar 2014, 14:24:37 »
In welchem File genau? EDIT: habs gefunden :-)
Vielen Dank
« Letzte Änderung: 02 Januar 2014, 14:26:30 von Markus Bloch »
  • Administrator
« Antwort #243 am: 02 Januar 2014, 14:36:36 »
Jetzt funktioniert es. Allerdings habe ich nun folgende Probleme bei den jeweiligen SET Befehlen:
- set LED_Filmeregal  rgb FF0000
FF000000 is not a valid rgb color
Egal welcher Farbcode verwendet wird.
- set LED_Filmeregal fadeTo 00FF00 3
Der LED geht sofort auf 00FF00. Es findet kein Fading statt
- set LED_Filmeregal fadeTo 000000 3
Funktioniert super. Er fadet schön aus.
Mein Wunsch währe noch, das der Sketch bei on und off ebenfalls fadet mit 2 Sekunden. Ich persönlich bin kein Fan von hart ein und hart aus. Ist nur ein Vorschlag.
Offline justme1968
« Antwort #244 am: 02 Januar 2014, 14:40:19 »
was steht bei den internals unter CHANNELS ?
je nach sketch konfiguration erwarteter er 3 oder 4 kanäle. beides muss zusammen passen.
spätestens nach einem fhem neustart sollte es passen.
zur zeit wird beim ausschalten und bei jedem wechsel per fernbedienung gefaded. nur ein geht sofort.
wenn das fadeTo nicht überblendet stimmt oben bei den channels etwas noch nicht.
  andre
edit: das globale konfigurieren der fade in zeit steht oben schon auf der todo liste :)
AKCP:THS01,WS15
CUL_WS:S300TH
  • Administrator
« Antwort #245 am: 02 Januar 2014, 15:00:43 »
Es sind 3 Channels:
   CHANNELS   3
   CMD_SIZE   10
   DEF        03 0000002200000003
   Developer  justme
   IODev      panStick
   LASTInputDev panStick
   MSGCNT     55
   NAME       LED_Filmeregal
   NR         149
   Product    RGB driver board with IR
   STATE      off
   SWAP_00-ProductCode 0000002200000003
   SWAP_00.1-ManufacturerID 00000022
   SWAP_00.2-ProductID 00000003
   SWAP_01-HardwareVersion 00100000
   SWAP_02-FirmwareVersion 00020001
   SWAP_03-SystemState 01
   SWAP_04-FrequencyChannel 02
   SWAP_05-SecurityOption 00
   SWAP_06-SecurityPassword 00
   SWAP_07-SecurityNonce 5D
   SWAP_08-NetworkID A4C8
   SWAP_09-DeviceAddress 03
   SWAP_0A-PeriodicTxInterval FFFF
   SWAP_MISSED 0
   SWAP_Sent_unconfirmed 1 Sent_unconfirmed
   SWAP_lastRcv 2014-01-02 14:35:09
   SWAP_lastSend 2014-01-02 14:35:08
   SWAP_nonce 8A
   TYPE       SWAP_0000002200000003
   addr       03
   devices
   nonce      12
   panStick_LQI 46
   panStick_MSGCNT 55
   panStick_RAWMSG (082E)0003008A00030B00000000
   panStick_RSSI -70
   panStick_TIME 2014-01-02 14:35:09
   Readings:
     2014-01-02 14:35:09   0B-RGBlevel     000000
     2014-01-02 14:35:09   0B.1-Red        00
     2014-01-02 14:35:09   0B.2-Green      00
     2014-01-02 14:35:09   0B.3-Blue       00
     2014-01-02 13:00:56   0B.4-White      00
     2014-01-02 13:00:56   0B.5-White2     0
     2014-01-02 13:00:56   0C-IRCommand    0
     2014-01-02 13:00:56   0C.1-Type       0
     2013-12-31 02:55:21   0C.2-Value      00000000
     2014-01-02 14:27:21   0D-InternalTemperature 00000016
     2014-01-02 13:00:56   0E-PowerOnState 0100000000
     2014-01-02 13:00:56   0E.1-State      01
     2014-01-02 13:00:56   0E.2-Brightness 00
     2014-01-02 13:00:56   0E.3-Color      000000
     2014-01-02 14:35:09   0F-Command      11000000000000000000
     2014-01-02 14:35:09   0F.1-Cmd        11
     2014-01-02 14:35:09   0F.2-Args       000000000000000000
     2014-01-02 13:00:56   10-Maximum_hop  0
     2014-01-02 13:00:56   11-Brightness   0
     2014-01-02 13:00:56   12-DMX_Base     0
     2014-01-02 13:00:56   13-LedPower     0
     2014-01-02 14:27:21   internaltemperature 22
     2014-01-02 14:35:09   state           off
   Product:
     label      RGB driver board with IR
     name       rgbdriver
     pwrdownmode 0
     Registers:
       11:
         HASH(0xc20940)
         HASH(0xc209a0)
         HASH(0xc19460)
       12:
         hwmask     02
         name       IRrecv
         swversion
         type       regular
         endpoints:
           HASH(0xc208e0)
           HASH(0xc19120)
           HASH(0xc19470)
       13:
         hwmask
         name       Temp
         swversion
         type       regular
         endpoints:
           HASH(0xc1fd80)
       14:
         hwmask
         name       PowerOn
         swversion
         type       config
         endpoints:
           HASH(0xd885f0)
           HASH(0xd99110)
           HASH(0xd995d0)
           HASH(0xc2e578)
       15:
         HASH(0xc1fef0)
         HASH(0xc19050)
       16:
         hwmask     08
         name       Repeater mode
         swversion
         type       config
         endpoints:
           HASH(0xd99190)
       17:
         hwmask     01
         name       Bri
         swversion
         type       regular
         endpoints:
           HASH(0xc18ec0)
       18:
         hwmask     04
         name       DMX
         swversion  00020001
         type       config
         endpoints:
           HASH(0xd99510)
       19:
         hwmask     10
         name       LedPower
         swversion
         type       regular
         endpoints:
           HASH(0xbfa3a0)
       20:
         hwmask     20
         name       IRsend
         swversion
         type       regular
         endpoints:
           HASH(0xc18fa0)
           HASH(0xbfa310)
           HASH(0xbfa010)
           HASH(0xbf9f00)
   sentList:
     ARRAY(0x1054648)
   devStateIcon {(SWAP_0000002200000003_devStateIcon($name),"toggle")}
   group      Licht
   lightSceneParamsToSave 0B-RGBlevel -> rgb
   room       Wohnzimmer
   userReadings internaltemperature:0D-InternalTemperature {hex(ReadingsVal($name,"0D-InternalTemperature","0"))}
   webCmd     rgb:rgb ff00ff:rgb ff0000:rgb 00ff00:rgb 0000ff:toggle:on:off
hier meine config.h:
#ifndef CONFIG_H
#define CONFIG_H
//#define USE_SOFT_PWM
//#define ENABLE_IR_RECV
//#define ENABLE_IR_SEND
//#define ENABLE_DMX
//#define ENABLE_REPEATER
//#define ENABLE_LED_POWER
//#define ENABLE_BRIGHTNESS
#ifdef ENABLE_LED_POWER
#  define LED_POWER_PIN A1
#endif
#ifdef ENABLE_BRIGHTNESS
#  define BRI_PIN A2
#endif
#endif
panStamp mit dem Standard RGB Carrier Board
  • Administrator
« Antwort #246 am: 02 Januar 2014, 15:14:35 »
nachdem ich mit fadeTo FF00FF 3 die Farbe geändert habe, habe ich folgenden Status:
state         FF00FF03         2014-01-02 15:12:19
dabei sollte da ja nur FF00FF stehen.
Offline justme1968
« Antwort #247 am: 02 Januar 2014, 15:15:43 »
aus irgendeinem grund denkt der sketch er hat 4 kanäle.
ich schaue heute abend. kann von hier aus nicht flashen.
  andre
AKCP:THS01,WS15
CUL_WS:S300TH
  • Administrator
« Antwort #248 am: 02 Januar 2014, 15:17:51 »
kein Problem.
Danke Dir
Offline Porky666
  • Full Member
« Antwort #249 am: 02 Januar 2014, 15:51:32 »
gerade update gemacht und beim Neustart erscheint im Log folgendes:
Subroutine SWAP_Initialize redefined at ./FHEM/34_SWAP.pm line 74, <$fh> line 113.
Subroutine SWAP_loadDevices redefined at ./FHEM/34_SWAP.pm line 97, <$fh> line 113.
Subroutine readDeviceXML redefined at ./FHEM/34_SWAP.pm line 133, <$fh> line 113.
Subroutine SWAP_Define redefined at ./FHEM/34_SWAP.pm line 227, <$fh> line 113.
Subroutine SWAP_Undef redefined at ./FHEM/34_SWAP.pm line 297, <$fh> line 113.
Subroutine SWAP_getRegister redefined at ./FHEM/34_SWAP.pm line 317, <$fh> line 113.
Subroutine SWAP_Set redefined at ./FHEM/34_SWAP.pm line 357, <$fh> line 113.
Subroutine SWAP_Get redefined at ./FHEM/34_SWAP.pm line 628, <$fh> line 113.
Subroutine SWAP_regName redefined at ./FHEM/34_SWAP.pm line 735, <$fh> line 113.
Subroutine SWAP_readDeviceXML redefined at ./FHEM/34_SWAP.pm line 748, <$fh> line 113.
Subroutine SWAP_Fingerprint redefined at ./FHEM/34_SWAP.pm line 766, <$fh> line 113.
Subroutine SWAP_updateReadings redefined at ./FHEM/34_SWAP.pm line 778, <$fh> line 113.
Subroutine SWAP_findFreeAddress redefined at ./FHEM/34_SWAP.pm line 829, <$fh> line 113.
Subroutine SWAP_Parse redefined at ./FHEM/34_SWAP.pm line 843, <$fh> line 113.
Subroutine SWAP_Send redefined at ./FHEM/34_SWAP.pm line 1025, <$fh> line 113.
Subroutine SWAP_PushCmdStack redefined at ./FHEM/34_SWAP.pm line 1052, <$fh> line 113.
Subroutine SWAP_ProcessCmdStack redefined at ./FHEM/34_SWAP.pm line 1064, <$fh> line 113.
Subroutine SWAP_Attr redefined at ./FHEM/34_SWAP.pm line 1087, <$fh> line 113.
und dann fortwährend:
Use of uninitialized value in string eq at ./FHEM/98_JsonList.pm line 337.
hmm ???
weiss jemand mehr ?
Gruß und Frohes Neues Stefan
ODROID U3 1GB Ubuntu immer aktuell
FHEM immer das aktuellste Development
Defined modules:
COC; CULv3; HMLAN :HM-CC-SCD,HM-CC-TC,HM-LC-SW4-PCB,HM-LC-Sw1PBU-FM,HM-OU-LED16,HM-SCI-3-FM,HM-SEC-SC,HM-SEC-WIN,HM-WDS10-TH-O; ESA2000; FS20; HUEBridge; Huedevices; IT; JeeLink :PCA301 :panstamp:
  • Administrator
« Antwort #250 am: 02 Januar 2014, 15:53:52 »
dieses Subroutine SWAP_Initialize redefined  ist kein Fehler, sondern nur eine Information, das diese Funktion erneut geladen wurde.
der andere Fehler Use of uninitialized value in string eq at ./FHEM/98_JsonList.pm line 337. ist ein Fehler in dem Modul JsonList. Hat aber mit panStamp nix zu tun.
Markus
Offline justme1968
« Antwort #251 am: 02 Januar 2014, 21:58:06 »
in der letzen version gab es leider noch ein paar inkompatibilitäten zwischen sketch versionen mit einer unterschiedlichen anzahl an kanälen. ich denke in dieser version sollte das sehr viel besser sein.
in config.h gibt es jetzt noch einen parameter MAX_CHANNELS. den kann man auf 3 setzen wenn tatsächlich nur 3 kanäle da sind auch wenn die sonstige konfiguration mehr erlauben würde.
in dieser version geht jetzt das soft on auch wirklich mit dem wert vor dem letzten ausschalten. hierzu ist das register 0E.1 wie folgt zu setzen: 0x02 um nach hard power on den letzten rgb wert zu haben, 0x08 um nach soft on den letzten wert zu haben. für beides zusammen 0x0a.
am besten auch das 34_SWAP.pm modul aus dem update morgen verwenden.
  andre
AKCP:THS01,WS15
CUL_WS:S300TH
  • Administrator
« Antwort #252 am: 02 Januar 2014, 23:30:04 »
hab soeben den neuen Sketch, 34_SWAP.pm und deiner angehangenen Version der 35_SWAP_0000002200000003.pm installiert
2014.01.02 23:26:28.840 3: panStick device opened
2014.01.02 23:26:31.156 5: panStamp/RAW (ReadAnswer):
Modem ready!
2014.01.02 23:26:31.156 5: SW: +++
2014.01.02 23:26:33.186 5: panStamp/RAW (ReadAnswer): OK-Command mode
2014.01.02 23:26:33.187 5: SW: ATHV?
2014.01.02 23:26:33.206 5: panStamp/RAW (ReadAnswer): 100
2014.01.02 23:26:33.206 5: SW: ATFV?
2014.01.02 23:26:33.226 5: panStamp/RAW (ReadAnswer): 101
2014.01.02 23:26:33.226 5: SW: ATSW=A4C8
2014.01.02 23:26:33.246 5: panStamp/RAW (ReadAnswer): OK
2014.01.02 23:26:33.246 5: SW: ATSW?
2014.01.02 23:26:33.266 5: panStamp/RAW (ReadAnswer): A4C8
2014.01.02 23:26:33.266 5: SW: ATCH=02
2014.01.02 23:26:33.286 5: panStamp/RAW (ReadAnswer): OK
2014.01.02 23:26:33.286 5: SW: ATCH?
2014.01.02 23:26:33.306 5: panStamp/RAW (ReadAnswer): 2
2014.01.02 23:26:33.306 5: SW: ATDA=01
2014.01.02 23:26:33.326 5: panStamp/RAW (ReadAnswer): OK
2014.01.02 23:26:33.326 5: SW: ATDA?
2014.01.02 23:26:33.346 5: panStamp/RAW (ReadAnswer): 1
2014.01.02 23:26:33.346 5: SW: ATO
2014.01.02 23:26:33.366 5: panStamp/RAW (ReadAnswer): OK-Data mode
2014.01.02 23:26:33.366 5: SW: 00010000010000
2014.01.02 23:27:01.103 5: panStick sending 0000010300
2014.01.02 23:27:01.103 5: SW: 03010000010300
2014.01.02 23:27:01.116 5: panStick sending 0000010301
2014.01.02 23:27:01.117 5: panStick sending 0000010302
2014.01.02 23:27:01.118 5: panStick sending 0000010303
2014.01.02 23:27:01.118 5: panStick sending 0000010304
2014.01.02 23:27:01.119 5: panStick sending 0000010305
2014.01.02 23:27:01.119 5: panStick sending 0000010306
2014.01.02 23:27:01.120 5: panStick sending 0000010307
2014.01.02 23:27:01.121 5: panStick sending 0000010308
2014.01.02 23:27:01.121 5: panStick sending 0000010309
2014.01.02 23:27:01.122 5: panStick sending 000001030A
2014.01.02 23:27:01.122 5: panStick sending 000001030B
2014.01.02 23:27:01.123 5: panStick sending 000001030C
2014.01.02 23:27:01.124 5: panStick sending 000001030D
2014.01.02 23:27:01.124 5: panStick sending 000001030E
2014.01.02 23:27:01.125 5: panStick sending 000001030F
2014.01.02 23:27:01.126 5: panStick sending 0000010310
2014.01.02 23:27:01.126 5: panStick sending 0000010311
2014.01.02 23:27:01.127 5: panStick sending 0000010312
2014.01.02 23:27:01.128 5: panStick sending 0000010313
2014.01.02 23:27:01.128 5: panStick sending 0000010314
2014.01.02 23:27:01.262 5: SW: 03010000010301
2014.01.02 23:27:01.337 5: SW: 03010000010302
2014.01.02 23:27:01.418 5: SW: 03010000010303
2014.01.02 23:27:01.498 5: SW: 03010000010304
2014.01.02 23:27:01.578 5: SW: 03010000010305
2014.01.02 23:27:01.658 5: SW: 03010000010306
2014.01.02 23:27:01.738 5: SW: 03010000010307
2014.01.02 23:27:01.818 5: SW: 03010000010308
2014.01.02 23:27:01.898 5: SW: 03010000010309
2014.01.02 23:27:01.978 5: SW: 0301000001030A
2014.01.02 23:27:02.088 5: SW: 0301000001030B
2014.01.02 23:27:02.168 5: SW: 0301000001030C
2014.01.02 23:27:02.248 5: SW: 0301000001030D
2014.01.02 23:27:02.328 5: SW: 0301000001030E
2014.01.02 23:27:02.408 5: SW: 0301000001030F
2014.01.02 23:27:02.488 5: SW: 03010000010310
2014.01.02 23:27:02.568 5: SW: 03010000010311
2014.01.02 23:27:02.648 5: SW: 03010000010312
2014.01.02 23:27:02.728 5: SW: 03010000010313
2014.01.02 23:27:02.808 5: SW: 03010000010314
Aufgrund dessen fehlen die ganzen Internal Values um den Sketch richtig anzusprechen.
Wenn ich aber via SWAPdmt das ganze probiere funktioniert es und er erkennt den panstamp sofort.
Kannst du dir das erklären?
« Letzte Änderung: 02 Januar 2014, 23:56:54 von Markus Bloch »
Offline justme1968
« Antwort #253 am: 03 Januar 2014, 00:32:21 »
sie zeilen sind die reaktion auf den start des sketches. das fhem modul fragt ein mal alle register ab. der teil ist ok. aber der sketch scheint nicht zu antworten. du müsstest in den internals alles als uncomfirmed sehen.
was passiert wenn du rgb board auf reset drückst?
kommt wenigstens die erste nachricht vom rgb board an ?
was macht die status led?
  andre
AKCP:THS01,WS15
CUL_WS:S300TH
  • Administrator
« Antwort #254 am: 03 Januar 2014, 01:00:56 »
OK der Fehler war denkbar einfach und dumm.
Der panStamp steckte nicht richtig im Sockel und höchstwahrscheinlich nichtmal in den richtigen Pins drin. Ich konnte ihn direkt ohne Kraft runternehmen. Er hat so fröhlich vor sich hin die Farben zwischen blau und grün geändert aber nicht reagiert.
Sorry für die Aufregung.
Gute Nacht und vielen Dank nochmals.
decade-submarginal
