Autor Thema: Abbruch fhem seit heute auf fb7390  (Gelesen 3038 mal)
Offline Bernhard
  • Full Member
« am: 16 August 2013, 20:13:36 »
seit heutigem Update bricht fhem ab. Ursache offensichtlich ein Fehler in Twilight oder sunpos oder owtherm
kurz nach Start fhem
Scalar value @compassPoints[$idx] better written as $compassPoints[$idx] at ./FHEM/98_sunpos.pm line 220, <$fh> line 801.
Argument "" isn't numeric in numeric lt (<) at ./FHEM/21_OWTHERM.pm line 950.
später bei Aufruf verschiederner Räume
Use of uninitialized value $file in substitution (s///) at ./FHEM/98_SVG.pm line 523.
Use of uninitialized value $fileesc in substitution (s///) at ./FHEM/98_SVG.pm line 526.
Use of uninitialized value $fileesc in concatenation (.) or string at ./FHEM/98_SVG.pm line 527.
Expandieren des Device Twilight:
Undefined subroutine &main::Twilight_GetUpdate called at ./FHEM/59_Twilight.pm line 88.
# $Id: fhem.pl 3682 2013-08-13 08:41:17Z rudolfkoenig $
# $Id: 00_CUL.pm 3659 2013-08-10 08:42:31Z rudolfkoenig $
# $Id: 09_CUL_FHTTK.pm 2076 2012-11-04 13:49:43Z rudolfkoenig $
# $Id: 14_CUL_TX.pm 2407 2013-01-03 12:55:22Z rudolfkoenig $
# $Id: 14_CUL_WS.pm 3482 2013-07-23 10:14:27Z rudolfkoenig $
# $Id: 72_FB_CALLMONITOR.pm 3669 2013-08-11 14:27:47Z markusbloch $
# $Id: 01_FHEMWEB.pm 3706 2013-08-15 12:40:30Z rudolfkoenig $
# $Id: 11_FHT.pm 3302 2013-06-17 19:10:25Z rudolfkoenig $
# $Id: 11_FHT8V.pm 3576 2013-08-02 06:14:49Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 3456 2013-07-19 21:49:24Z ulimaass $
# $Id: 10_FS20.pm 3659 2013-08-10 08:42:31Z rudolfkoenig $
# $Id: 92_FileLog.pm 3697 2013-08-14 15:08:15Z rudolfkoenig $
# $Id: 21_OWID.pm 3062 2013-04-11 06:17:17Z pahenning $
# $Id: 21_OWTHERM.pm 3062 2013-04-11 06:17:17Z pahenning $
# $Id: 00_OWX.pm 2737 2013-02-15 22:05:08Z ntruchsess $
# $Id: 98_PID.pm 3219 2013-05-25 07:46:54Z rudolfkoenig $
# $Id: 95_PachLog.pm 3328 2013-06-25 07:52:46Z rudolfkoenig $
# $Id: 99_SUNRISE_EL.pm 3480 2013-07-23 06:03:39Z rudolfkoenig $
# $Id: 98_SVG.pm 3697 2013-08-14 15:08:15Z rudolfkoenig $
# $Id: 99_Utils.pm 3595 2013-08-05 05:38:48Z tobiasfaust $
# $Id: 59_Weather.pm 3588 2013-08-03 09:26:56Z borisneubert $
# $Id: 90_at.pm 3694 2013-08-14 06:12:47Z rudolfkoenig $
# $Id: 98_autocreate.pm 3651 2013-08-09 18:19:13Z rudolfkoenig $
# $Id: 98_dummy.pm 3343 2013-06-27 14:19:47Z rudolfkoenig $
# $Id: 95_holiday.pm 3602 2013-08-07 13:06:49Z rudolfkoenig $
# $Id: 99_myUtils.pm 1932 2012-10-06 20:15:33Z ulimaass $
# $Id: 91_notify.pm 3189 2013-05-17 07:35:48Z rudolfkoenig $
# $Id: 98_telnet.pm 3635 2013-08-09 08:02:30Z rudolfkoenig $
# $Id: 91_watchdog.pm 2998 2013-03-30 12:12:14Z rudolfkoenig $
# $Id: 98_weblink.pm 3707 2013-08-15 14:43:43Z rudolfkoenig $
Offline Puschel74
Aw: Abbruch fhem seit heute auf fb7390
« Antwort #1 am: 16 August 2013, 20:27:26 »
Das heisst was?
Also was genau "bricht" ab.
Startet FHEM nicht -
FHEM lässt sich nicht bedienen -
Der USB-Stick an der FB ist defekt (so einer dran ist) -
Was sagt das FHEM-Logfile?
Edith:
heisst was genau?
Steht das so im Logfile oder wo steht das?
Offline stromer-12
« Antwort #2 am: 16 August 2013, 21:04:58 »
Habe mal nachgesehen im Modul, die Routine Twilight_GetUpdate fehlt.
FHEM 5.9(SVN) auf cubietruck mit HMUSB
FHEM 5.9(SVN) auf RPi1B mit HMser | CUNO
FHEM 5.9(SVN) virtuell mit HMLAN | CUL
Offline Bernhard
  • Full Member
« Antwort #3 am: 16 August 2013, 21:08:58 »
das habe ich noch im Log gefunden, war wohl der letzte automatische Start (shutdown restart oder so)
- CUL steckt und ist in Ordnung
- FHEM läuft bis ....
  auf die Gerätedefinition myTwiligt geklickt wird, um die interen Werte zu sehen,
  dann kommt FMWEB nicht mehr zurück
  als "http://fritz.box:8083/fhem?detail=myTwilight", dann Ergebnis Fehler: Seitenladefehler, Verbindung unterbrochen
  im Log steht jetzt nichts, da fhem jetzt von Konsole (Putty) gestartet. Obige Fehlermeldung in Konsole
  perl fhem ist beendet
Offline Dietmar63
« Antwort #4 am: 16 August 2013, 21:24:51 »
War noch ein bug drin, gefixed sollte funzen:
http://forum.fhem.de/index.php?t=msg&goto=90522&rid=405#msg_90522
Gruß Dietmar
FB7390, CUL, 2 FHT, FS20
Offline Dietmar63
« Antwort #5 am: 16 August 2013, 21:31:29 »
Die Funktion von 98_sunpos.pm wird jetzt von Twilight bereitgestellt.
Ich habe sunpos in TW integriert. Somit dämmen wir ein wenig die Modulflut ein.
Gruß Dietmar
Offline Bernhard
  • Full Member
« Antwort #6 am: 17 August 2013, 13:56:40 »
So,
jetzt läufts wieder.
- Könnte man nicht auch noch die aktuelle Temperatur aus den Wetterdaten in den Readings einblenden?
- wie bekomme ich die Windrose jetzt bei Twilight zum ticken?
  Attr devStateIcon south:ws_S_kl south-southwest:ws_SSW_kl southwest:ws_SW_kl west-southwest:ws_WSW_kl west:ws_W_kl west-northwest:ws_WNW_kl northwest:ws_NW_kl north-northwest:ws_NNW_kl north:ws_N_kl north-northeast:ws_NNO_kl northeast:ws_NO_kl east-northeast:ws_ONO_kl east:ws_O_kl east-southeast:ws_OSO_kl southeast:ws_SO_kl south-southeast:ws_SSO_kl
  ist gesetzt.
  Wie muss Attr icon gesetzt werden?
Offline stromer-12
« Antwort #7 am: 17 August 2013, 21:00:42 »
noch folgendes Attribut setzen:
attr myTwilight stateFormat compasspoint
Offline Dietmar63
« Antwort #8 am: 17 August 2013, 23:03:32 »
Ja könnte man machen.
Für das Wetter ist aber das Wettermodul zuständig.
die Wetterdaten von yahoo werden in TW nicht regelmäßig nachgelesen - nur ca. 1 Stunde vor den weather_horizon-Ereignissen.
Gruß Dietmar
Offline Bernhard
  • Full Member
« Antwort #9 am: 17 August 2013, 23:45:30 »
Danke für den Hinweis.
Damit ist also auch der gelieferte Wert für condition und condition_txt für eine Beobachtung nicht brauchbar
Offline Dietmar63
« Antwort #10 am: 18 August 2013, 00:03:06 »
Ja, so ist es.
Gruß Dietmar
