Hallo Stefan,
ging leider nicht eher...,
habe das "interval 60 300" gesetzt und set "raw" h:
2021.09.28 17:23:17 4: ArducounterMapleCUN2: set raw h called
2021.09.28 17:23:17 5: SW: h.
2021.09.28 17:23:17 5: attribute board is set to NANO and is overwriting board PRO reported by device
2021.09.28 17:23:17 5: ArducounterMapleCUN2: device sent hello: ArduCounter V4.26 on PRO compiled Sep 25 2021 18:29:38 Hello
2021.09.28 17:23:17 5: ArducounterMapleCUN2: Device Time 822.79, Offset 1632841.775, Drift 0.025s in 822.316s, 0.00%
2021.09.28 17:23:17 4: ArducounterMapleCUN2: device sent time info: N822790,0B499,0
2021.09.28 17:23:17 4: ArducounterMapleCUN2: device sent interval config 30,60,2,2,50,4
2021.09.28 17:23:17 4: ArducounterMapleCUN2: device sent devVerbose 0,0,0,0,0
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigureDevice: send config
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigurePin creates command 4,2,1,25a
2021.09.28 17:23:18 5: SW: 4,2,1,25a.
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigurePin creates command 5,2,1,25a
2021.09.28 17:23:18 5: SW: 5,2,1,25a.
2021.09.28 17:23:18 5: ArducounterMapleCUN2: PinNumber called from ConfigureDevice returns 17 for A3
2021.09.28 17:23:18 5: ArducounterMapleCUN2: PinNumber called from ParsePin returns 17 for A3
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigurePin creates command 17,3,1,4,27,120,220a
2021.09.28 17:23:18 5: SW: 17,3,1,4,27,120,220a.
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigurePin creates command 6,3,0,2a
2021.09.28 17:23:18 5: SW: 6,3,0,2a.
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigureDevice: no pins in running config without attribute in Fhem
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigureIntervals creates command 60,300,0,0,50,4i
2021.09.28 17:23:18 5: SW: 60,300,0,0,50,4i.
2021.09.28 17:23:18 5: ArducounterMapleCUN2: ConfigureVerboseLevels creates command 1,0,0,0,0v
2021.09.28 17:23:18 5: SW: 1,0,0,0,0v.
2021.09.28 17:23:18 5: SW: s.
2021.09.28 17:23:18 3: ArducounterMapleCUN2: device: Error: command a Illegal pin specification 1
2021.09.28 17:23:18 3: ArducounterMapleCUN2: device: Error: command i missing parameter number 2
2021.09.28 17:23:18 4: ArducounterMapleCUN2: device: Status: ArduCounter V4.26 on PRO compiled Sep 25 2021 18:29:38
2021.09.28 17:23:18 4: ArducounterMapleCUN2: device sent interval config 30,60,2,2,50,4
2021.09.28 17:23:18 4: ArducounterMapleCUN2: device sent devVerbose 0,0,0,0,0
2021.09.28 17:23:18 4: ArducounterMapleCUN2: device: no config in EEPROM
2021.09.28 17:23:18 4: ArducounterMapleCUN2: device: Next report in 16673 milliseconds
dann das Attribut enableSerialEcho (auf 2) und wieder set "raw" h:
2021.09.28 17:25:46 5: ArducounterMapleCUN2: Attr called with set ArducounterMapleCUN2 room Kontrollraum
2021.09.28 17:26:14 5: ArducounterMapleCUN2: Attr called with set ArducounterMapleCUN2 enableSerialEcho 2
2021.09.28 17:26:14 5: ArducounterMapleCUN2: ConfigureVerboseLevels creates command 1,2,0,0,0v
2021.09.28 17:26:14 5: SW: 1,2,0,0,0v.
2021.09.28 17:26:58 4: ArducounterMapleCUN2: set raw h called
2021.09.28 17:26:59 5: SW: h.
2021.09.28 17:26:59 5: attribute board is set to NANO and is overwriting board PRO reported by device
2021.09.28 17:26:59 5: ArducounterMapleCUN2: device sent hello: ArduCounter V4.26 on PRO compiled Sep 25 2021 18:29:38 Hello
2021.09.28 17:26:59 5: ArducounterMapleCUN2: Device Time 1044.389, Offset 1632841.775, Drift 0.104s in 1043.994s, 0.01%
2021.09.28 17:26:59 4: ArducounterMapleCUN2: device sent time info: N1044389,0B499,0
2021.09.28 17:26:59 4: ArducounterMapleCUN2: device sent interval config 30,60,2,2,50,4
2021.09.28 17:26:59 4: ArducounterMapleCUN2: device sent devVerbose 0,0,0,0,0
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigureDevice: send config
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigurePin creates command 5,2,1,25a
2021.09.28 17:27:00 5: SW: 5,2,1,25a.
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigurePin creates command 4,2,1,25a
2021.09.28 17:27:00 5: SW: 4,2,1,25a.
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigurePin creates command 6,3,0,2a
2021.09.28 17:27:00 5: SW: 6,3,0,2a.
2021.09.28 17:27:00 5: ArducounterMapleCUN2: PinNumber called from ConfigureDevice returns 17 for A3
2021.09.28 17:27:00 5: ArducounterMapleCUN2: PinNumber called from ParsePin returns 17 for A3
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigurePin creates command 17,3,1,4,27,120,220a
2021.09.28 17:27:00 5: SW: 17,3,1,4,27,120,220a.
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigureDevice: no pins in running config without attribute in Fhem
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigureIntervals creates command 60,300,0,0,50,4i
2021.09.28 17:27:00 5: SW: 60,300,0,0,50,4i.
2021.09.28 17:27:00 5: ArducounterMapleCUN2: ConfigureVerboseLevels creates command 1,2,0,0,0v
2021.09.28 17:27:00 5: SW: 1,2,0,0,0v.
2021.09.28 17:27:00 5: SW: s.
2021.09.28 17:27:00 3: ArducounterMapleCUN2: device: Error: command a Illegal pin specification 1
2021.09.28 17:27:00 3: ArducounterMapleCUN2: device: Error: command i missing parameter number 2
2021.09.28 17:27:00 4: ArducounterMapleCUN2: device: Status: ArduCounter V4.26 on PRO compiled Sep 25 2021 18:29:38
2021.09.28 17:27:00 4: ArducounterMapleCUN2: device sent interval config 30,60,2,2,50,4
2021.09.28 17:27:00 4: ArducounterMapleCUN2: device sent devVerbose 0,0,0,0,0
2021.09.28 17:27:00 4: ArducounterMapleCUN2: device: no config in EEPROM
2021.09.28 17:27:00 4: ArducounterMapleCUN2: device: Next report in 5006 milliseconds
habe den Pro Mini aktuell am USB des Test-FHEM.
hier noch das List:
Board NANO
BoardDet
DEF /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@115200
DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0@115200
FD 5
FUUID 614ee781-f33f-0edb-ff98-c6a184a1fbb7235d
FVERSION 98_ArduCounter.pm:0.142330/2017-05-09
Initialized 1
LASTOPEN 1632841773.1233
NAME ArducounterMapleCUN2
NOTIFYDEV global
NR 703
NTFY_ORDER 50-ArducounterMapleCUN2
PARTIAL
STATE opened
SketchCompile Sep 25 2021 18:29:38
TYPE ArduCounter
VersionFirmware 4.26
VersionModule 7.31 - 11.6.2020
allowedPins 2,3,4,5,6,7,8,9,10,11,12,13,14,A0,15,A1,16,A2,17,A3,18,A4,19,A5,20,A6,21,A7
buffer
deviceBooted 1632841775.22219
devioLoglevel 3
nextOpenDelay 60
2021-09-28 17:09:33 state opened
runningCfg:
I 30,60,2,2,50,4
V 0,0,0,0,0
board NANO
disable 0
enableHistory 1
enableSerialEcho 2
group Arducounter
interval 60 300
pinA3 rising pullup min 4 analog out 27 threshold 120,220
pinD4 falling pullup min 25
pinD5 falling pullup min 25
pinD6 rising
readingPulsesPerUnitD4 1
room Kontrollraum
userReadings WMZ_2.OG {ReadingsVal("ArducounterMapleCUN2","calcCounterD4",0)/1 + ReadingsNum("WMZ_2.OG_Start","Startwert",0)}
userattr readingPulsesPerUnitD4
verbose 5
ich hoffe das hilft.
VG Uwe
