Modul zur Anbindung Viessmann Heizung (Vitotronic 200 KW1)
Begonnen von Adam, 15 Februar 2014, 18:17:35
buec65
Die Meldung mit dem angepassten Modul
2016.06.03 15:19:44 5: Cmd: >define HeizungA VCONTROL /dev/ttyUSB2 89_VCONTROL.cfg 180<
2016.06.03 15:19:44 5: Loading ./FHEM/89_VCONTROL.pm
2016.06.03 15:19:44 1: reload: Error:Modul 89_VCONTROL deactivated:
syntax error at ./FHEM/89_VCONTROL.pm line 996, near "){"
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1000, <$fh> line 321.
syntax error at ./FHEM/89_VCONTROL.pm line 1006, near "elsif"
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1006, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1007, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1008, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1009, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1010, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1011, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1012, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1013, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1014, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1015, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1016, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1017, <$fh> line 321.
Global symbol "@cfgarray" requires explicit package name at ./FHEM/89_VCONTROL.pm line 1018, <$fh> line 321.
syntax error at ./FHEM/89_VCONTROL.pm line 1022, near "elsif"
./FHEM/89_VCONTROL.pm has too many errors.
Wenn ich vorher die vorhergende Version lade und dann wieder diese dann startet das Modul, aber wohin werden die Readings geschrieben?
Adam
#991
Sorry... Noch ein Versuch
buec65
Werde es testen sobald ich dazu komme.
Super, das die Anpassung so schnell geht.
buec65
Die folgende Meldung kommt
2016.06.05 16:22:23 5: Cmd: >define HeizungA VCONTROL /dev/ttyUSB2 89_VCONTROL.cfg 180<
2016.06.05 16:22:23 5: Loading ./FHEM/89_VCONTROL.pm
2016.06.05 16:22:23 3: VCONTROL: Define open DATEI '89_VCONTROL.cfg'
2016.06.05 16:22:23 3: VCONTROL: open DATEI '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile #####################################################################################
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile # Polling Commands GWG_VBEM ID 2053
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile ######################################################################################
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile #POLL,SENDCMD , PARSE, DIVISOR, READING-NAME , KUMULATION?
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile PROTOCOL, GWG
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB6F0104, 1ByteS, 2 , Aussentemperatur , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB6F0104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB700104, 1ByteS, 1 , Temperatur_Kessel , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB700104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB170104, 1ByteS, 1 , BEMK50Brennerlaufzeit , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB170104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB3F0104, 1ByteS, 1 , Fehlermeldung , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB3F0104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB410104, 1ByteS, 1 , HKB_Vorlauftemperatur , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB410104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB420104, 1ByteS, 10 , TrinkwassertemperaturSensor1 , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB420104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB440104, 1ByteS, 1 , RuecklaufTemperatur , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB440104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB510104, mode , state , GWG_Betriebsprogramm , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB510104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB5C0104, 1ByteS, 10 , GWG_Trinkwasser_Solltemperatur, -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB5C0104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB630104, 1ByteS, 1 , VorlaufSollTemperaturHKB , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB630104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB640104, 1ByteS, 1 , GWG_Niveau_HKA , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB640104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB650104, 1ByteS, 1 , GWG_Neigung_HKA , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB650104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB690104, 1ByteS, 1 , VorlaufSollTemperaturHKA , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB690104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB710104, 1ByteS, 1 , KesselSollTemperatur , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB710104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBB00104, 1ByteS, 1 , GWG_Drehzahl_Soll , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBB00104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBC40104, 1ByteU, 1 , GWG_Neigung_HKB , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBC40104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBC50104, 1ByteU, 1 , GWG_Niveau_HKB , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBC50104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBA90104, 1ByteU, 1 , Umwaelzpumpe , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBA90104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBC50104, 1ByteU, 1 , Heizkessel_Ext_Anfo , -
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBC70104, 1ByteU, 1 , Sommer-Winter , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBC70104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CBF80104, 4Byte , 1 , SystemIdentifikation , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CBF80104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile POLL, 01CB000104, 1ByteU, state , GWG_ExternSperren , -
2016.06.05 16:22:23 3: VCONTROL: wrong Address '01CB000104' in '89_VCONTROL.cfg'
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile # M1 Possible TIMER Get commands
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile # M1 Possible Warm Water TIMER Get commands
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile # M1 Possible Set commands which are complete
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile #SET,SETCMD , SENDCMD , CONV , NEXT_CMD or DAY for timer
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile # Possible TIMER Set commands prefix
2016.06.05 16:22:23 5: VCONTROL: CmdConfig-Zeile #Possible Warm Water Timer Set commands prefix
2016.06.05 16:22:23 3: VCONTROL: DATEI '89_VCONTROL.cfg' refreshed
2016.06.05 16:22:23 3: VCONTROL opening VCONTROL device /dev/ttyUSB2
2016.06.05 16:22:23 3: VCONTROL opened VCONTROL device /dev/ttyUSB2
2016.06.05 16:22:23 5: SW: 04
2016.06.05 16:22:23 3: VCONTROL: Initialization
2016.06.05 16:22:23 5: VCONTROL set InternalTimer +1 to 1465136544.72403
2016.06.05 16:22:56 4: VCONTROL: Start of Poll !
2016.06.05 16:22:56 5: VCONTROL: set InternalTimer to 1465136756.29703
2016.06.05 16:22:56 5: VCONTROL_READ
2016.06.05 16:22:56 5: VCONTROL: VCONTROL_Read '050505050505050505050505050505050505050505050505050505'
2016.06.05 16:22:56 4: VCONTROL: End of Poll ! Duration: 0.01
2016.06.05 16:23:07 5: VCONTROL_READ
2016.06.05 16:23:07 5: VCONTROL: VCONTROL_Read '05050505050505050505'
2016.06.05 16:23:38 5: VCONTROL_READ
2016.06.05 16:23:38 5: VCONTROL: VCONTROL_Read '05050505050505050505050505050505050505050505050505'
2016.06.05 16:23:38 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:39 5: VCONTROL_READ
2016.06.05 16:23:39 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:40 5: VCONTROL_READ
2016.06.05 16:23:40 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:41 5: VCONTROL_READ
2016.06.05 16:23:41 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:43 5: VCONTROL_READ
2016.06.05 16:23:43 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:44 5: VCONTROL_READ
2016.06.05 16:23:44 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:45 5: VCONTROL_READ
2016.06.05 16:23:45 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:46 5: VCONTROL_READ
2016.06.05 16:23:46 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:47 5: VCONTROL_READ
2016.06.05 16:23:47 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:49 5: VCONTROL_READ
2016.06.05 16:23:49 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:50 5: VCONTROL_READ
2016.06.05 16:23:50 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:51 5: VCONTROL_READ
2016.06.05 16:23:51 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:52 5: VCONTROL_READ
2016.06.05 16:23:52 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:53 5: VCONTROL_READ
2016.06.05 16:23:53 5: VCONTROL: VCONTROL_Read '05'
2016.06.05 16:23:55 5: VCONTROL_READ
2016.06.05 16:23:55 5: VCONTROL: VCONTROL_Read '05'
buec65
Adam
Schwierig wenn man es nicht selber testen kann ....
So bitte noch ein Versuch!
buec65
Jetzt funktioniert es  :)
Die Konfiguration der Werte muss ich noch überprüfen, aber das Modul läuft jetzt mit der "alten" GWG-Viessmann-Heizung.
Super Leistung - @Adam
Vielen Dank
Adam
wurde doch langsam zeit  ;D
Dann viel Spaß beim testen.
Ich warte noch was mit dem einchecken der GWG Version.
Roman
#998
Hallo Adam,
die GWG Erweiterung kam genau zur rechten Zeit :) Ich hab am Samstag meinen Optolink-Adapter erhalten.
Einbindung hat mit der letzten Version soweit auf Anhieb geklappt, Ich kann meine Werte auslesen.
Folgendes hab ich noch festgestellt:
Der Intervall scheint nicht richtig zu funktionieren, scheint es eine Endlosschleife zu sein ohne Pausen zwischendrin. Egal ob default bei 180 steht oder der Wert höher wie z.B. 900 Sekunden gesetzt wird
EDIT: hat sich wohl erledigt, kann aber nicht sagen wo das Problem lag. Hab das Device nochmal gelöscht, neu angelegt und einen FHEM Neustart, seitdem läuft es wie gewollt im 10 Minuten Takt.
Mit der Brennerlaufzeit hab ich auch noch ein Problem, da muss ich aber nochmal in die Config schauen, vclient meldet einen Wert über 26600 das Modul einen Wert von 108.
Roman
funclass
Nun muss ich auch mal was fragen.
Habe gestern von meinem Installateur ein Vitoconnect 100 Set bekommen. Da ich vor einiger Zeit schonmal mit nem selbstgebauten Optolink-Adapter mit dem Modul Werte ausgelesen habe, hab ich nun das originale Optolink-Kabel geschnappt und die Heizung mal wieder in FHEM eingebunden (per USB am Raspberry).
Das Auslesen der Werte funktioniert ganz problemlos, wie damals schon. Ich bekomme jedoch keinen einzigen SET-Befehl hin. z.B. ein Auszug aus dem Log (Verbose 5) beim Versuch die Raumtemperatur auf 25 zu setzen:
2016.06.12 12:41:57 5: VCONTROL_READ
2016.06.12 12:41:57 5: VCONTROL: VCONTROL_Read '05'
2016.06.12 12:41:58 5: VCONTROL: DEBUG SET <-> SET / Einstellung_Raumtemperatur <-> Einstellung_Betriebsart
2016.06.12 12:41:58 5: VCONTROL: DEBUG SET <-> SET / Einstellung_Raumtemperatur <-> Einstellung_Raumtemperatur
2016.06.12 12:41:59 5: VCONTROL_READ
2016.06.12 12:41:59 5: VCONTROL: VCONTROL_Read '05'
2016.06.12 12:41:59 5: VCONTROL: send '01F42000021900'
2016.06.12 12:41:59 5: SW: 01f42000021900
2016.06.12 12:41:59 5: VCONTROL: VCONTROL_Read '00'
2016.06.12 12:41:59 5: VCONTROL: Poll SET!
Hab auch schon diverse Tests mit disable etc. gemacht, aber meine Vitocal 222-G ignoriert sämtliche SET-Befehle. Die ausgelesenen Werte ändern sich nicht.
Woran könnte es liegen?
funclass
Anbei noch meine Config-Datei:
POLL, 01F7010102, 2ByteS, 10, Aussentemperatur , -
POLL, 01F7010D02, 2ByteS, 10, Temperatur_Speicher_Warmwasser , -
POLL, 01F7200002, 2ByteS, 10, Einstellung_Raumtemperatur , -
POLL, 01F7600002, 2ByteS, 10, Einstellung_Temperatur_Warmwasser , -
POLL, 01F7600C02, 2ByteS, 10, Einstellung_Temperatur_Warmwasser2 , -
POLL, 01F7040001, 1ByteU, state, Status_Verdichter , -
SET, Einstellung_Betriebsart, 01F4B00001, 1ByteS , -
SET, Einstellung_Raumtemperatur, 01F4200002, 2ByteS , -
SET, Einstellung_Raumtemperatur_Reduziert, 01F4200102, 2ByteS , -
SET, Einstellung_Raumtemperatur_Party, 01F4202202, 2ByteS , -
SET, Einstellung_Heizkennlinie_Niveau, 01F4200602, 2ByteS , -
SET, Einstellung_Heizkennlinie_Steigung, 01F4200702, 2ByteS , -
SET, Einstellung_Temperatur_Warmwasser, 01F4600002, 2ByteS , -
SET, Einstellung_Temperatur_Warmwasser2, 01F4600C02, 2ByteS , -
SET, Einstellung_Hysterese_Speicher_Heizung, 01F4720302, 2ByteS , -
SET, Einstellung_Hysterese_Speicher_Warmwasser, 01F4600702, 2ByteS , -
buec65
Das Modul läuft jetzt bei mir 1 Woche mit dem Protokoll GWG wunderbar.
Anbei die Konfiguration für meine Vitodens WB2 aus 2002
PROTOCOL, GWG
POLL, 01CB700104, 1ByteS, 2 , Temp_Kessel_IST , -
POLL, 01CB710104, 1ByteS, 2 , Temp_Kessel_Soll , -
POLL, 01CB5C0104, 1ByteS, 2 , TempWW_Soll, -
POLL, 01CB420104, 1ByteS, 2 , TempWW_IST, -
POLL, 01CB530104, 1ByteS, 1 , RaumSollTag, -
POLL, 01CB540104, 1ByteS, 1 , RaumSollNacht, -
#POLL, 01CB540104, 1ByteS, 1 , RaumSoll_Red_M1, -
POLL, 01CB220104, mode, state , BrennerStatus, -
#POLL, 01CB170104, 1ByteS, 1 , Brennerlaufzeit, -
#POLL, 01CB640104, 1ByteS, 1 , Niveau_M1, -
#POLL, 01CB000104, 1ByteS, 1 , ExtBetriebsumschaltung, -
POLL, 01CB410104, 1ByteS, 1 , Vorlauftemperatur_HKA , -
#POLL, 01CB420104, 1ByteS, 10 , TrinkwassertemperaturSensor1 , -
#POLL, 01CB440104, 1ByteS, 1 , RuecklaufTemperatur , -
POLL, 01CB510104, mode , state , Betriebsprogramm , -
POLL, 01CB630104, 1ByteS, 1 , VorlaufSollTemperatur_HKB , -
#POLL, 01CB640104, 1ByteS, 1 , Niveau_HKA , -
#POLL, 01CB650104, 1ByteS, 1 , Neigung_HKA , -
POLL, 01CB690104, 1ByteS, 1 , VorlaufSollTemperatur_HKA , -
#POLL, 01CBB00104, 1ByteS, 1 , GWG_Drehzahl_Soll , -
#POLL, 01CBC40104, 1ByteU, 1 , Neigung_HKB , -
#POLL, 01CBC50104, 1ByteU, 1 , Niveau_HKB , -
#POLL, 01CBA90104, 1ByteU, 1 , Umwaelzpumpe , -
#POLL, 01CBC50104, 1ByteU, 1 , Heizkessel_Ext_Anfo , -
#POLL, 01CBC70104, 1ByteU, 1 , Sommer-Winter , -
#POLL, 01CBF80104, 4Byte , 1 , SystemIdentifikation , -
#POLL, 01CB000104, 1ByteU, state , GWG_ExternSperren , -
Nicht benutzte sind auskommentiert
und hier noch readingsProxy zum Einbinden in den Floorplan
define VitoAT readingsProxy HeizungA:Aussentemperatur
define VitoFM readingsProxy HeizungA:Fehlermeldung
define VitoWist readingsProxy HeizungA:TempWW_IST
define VitoWsoll readingsProxy HeizungA:TempWW_Soll
define VitoKist readingsProxy HeizungA:Temp_Kessel_IST
define VitoKsoll readingsProxy HeizungA:Temp_Kessel_Soll
define VitoZ readingsProxy HeizungA:UpdateTime
define VitoBS readingsProxy HeizungA:BrennerStatus
kvo1
@buec65
was bringen dir die readingsProxy zum Einbinden in den Floorplan ?
PS: okay, hab mich bisher aber auch nicht damit beschäftigt !
funclass
Zitat von: funclass am 12 Juni 2016, 12:52:45
... Ich bekomme jedoch keinen einzigen SET-Befehl hin. z.B. ein Auszug aus dem Log (Verbose 5) beim Versuch die Raumtemperatur auf 25 zu setzen...
Hat Keiner ne Idee?
buec65
#1004
@kvo1
Da steht z.B. VitoAT  20 und nicht nur 20 - ist momentan für mich übersichtlicher
Bei mir läuft das Modul ständig, das eingetragene Zeitintervall funktioniert nicht immer.
