Wireless M-Bus für CUL
Begonnen von tostmann, 12 Juni 2014, 17:34:32
matthias soll
Ich empfange jetzt endlich Daten von meinem radio3 (Nagelneue Radio3 module müssen erst aktiviert werden und sind somit wertlos).
2019.10.09 15:49:15 5: CUL/RAW: /**b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B
2019.10.09 15:49:15 4: CUL_Parse: mapleCUN1 **b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B
2019.10.09 15:49:15 5: mapleCUN1: dispatch **b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B
2019.10.09 15:49:15 4: CUL_Parse: mapleCUN2 *b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B
2019.10.09 15:49:15 5: mapleCUN2: dispatch *b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B
2019.10.09 15:49:15 4: CUL_Parse: mapleCUN3 b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B806B -20.5
2019.10.09 15:49:15 5: mapleCUN3: dispatch b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B80::-20.5
2019.10.09 15:49:15 5: WMBUS raw msg b2F446850036036307462ABE1A2069F25350290340000800000000000D63F00000000000000000000000000000000FFFF0000000000040A6B80::-20.5
2019.10.09 15:49:15 2: WMBUS WMBUS_TCH_30366003_116_98 Error during ApplicationLayer parse:Unsupported CI Field a2, remaining payload is 069f2535029034000080000000000000000000000000000000000000000000000000000004
2019.10.09 15:49:15 5: Starting notify loop for WMBUS_TCH_30366003_116_98, 3 event(s), first is RSSI: -20.5
2019.10.09 15:49:15 5: createNotifyHash
2019.10.09 15:49:15 5: End notify loop for WMBUS_TCH_30366003_116_98
Das Techem Modul reagiert leider nicht auf die raw messages woran kann das liegen?
noby
Aber ich bin umgeben von Sontex, kann es nicht sein, dass die Geräte über Autodetect falsch definiert werden.
Raspi 3B, busware cul868, KS300, nanoCul433, jeelinkCul,  2 TX29DTH-IT`s, mySensors Gateway WLAN, 3 mySensors Sensoren, HM IP Wandthermostat 230V, SignalDuino433
pc1246
Moin
Wenn Du Dir Deinen Auszug mal ansiehst, dann ist die Feldstaerke sehr gering, was bedeutet, dass die empfangenen Signale sehr weit weg sind. Ich vermute, dass Deine Sontex gar nicht dabei sind, und Du von den Nachbarn Geraete empfaengst.
Bitte das naechste mal auch den Auszug in Codetags (das '#' ueber den Smilies) setzen. Das macht es lesbarer.
Gruss Christoph
HP T610
Onkyo_AVR;3 Enigma2; SB_Server ; SB_Player; HM-USB mit 15 HM-CC-RT-DN, 3 HM_WDS10_TH_O, 6 HM-Sec-SCo, 4 HM-Sec-MDIR-2, 1 HM-Sen-MDIR-O-2, 8 Ferion 5000 OW ; PhilipsTV; 4 harmony hub; Jeelink mit 9 PCA301; Somfy; S7-300; 3 LGW; HUE; HM-IP auf Charly
noby
Moin, das ist eine schlüssige Erklärung. Dann bin ich wohl mit meinen Sontex in einer Sackgasse. Vielen Dank für Eure Unterstützung.
pc1246
Moin
Vielleicht hat kaihs ja Lust irgendwann Deine Geraete mit aufzunehmen.
Allerdings musst du Sie bis dahin auch mal eingefangen haben. Denn ohne Daten keine Loesung!
Hast Du Dir mal diese Anleitung durchgelesen: https://www.sontex.eu/download/pdf/Bedienungsanleitung_Supercal_739.pdf
Seite 9 ist da sehr interessant.
Gruss Christoph
HP T610
noby
#800
habe die Anleitung Supercal 739 aufmerksam durchgelesen. Würde sehr gerne Daten bereitstellen oder auch Versuche durchführen, aber mir fehlt der Ansatz, wie ich an diese speziellen Daten kommen könnte und damit wohl leider auch das Know-how 😌.
Kann meinen nanoCul auf T-Bus einstellen, ist dann auf 868 MHz, konnte in diesem Modus auch auf 433 MHz umstellen, dachte ich.
Gruß Norbert
pc1246
Moin
Die erste Frage ist doch, welche Option verbaut ist!
Solange Du das nicht weisst, kannst Du auch nicht anfangen.
Gruss Christoph
HP T610
noby
#802
mir ist aufgefallen, dass ich mit meinem NanoCUL433 (a-culfw) beim Umschalten des rfmode von slowRF auf WMBus_T nur freq 868.950, nicht aber 433.920 zur Verfügung habe. Die Anzeige suggeriert dies erst, wird aber mit get cconfig aktualisiert.
Gibt es für das Sammeln möglicher Daten einen Trick, meinen nanoCUL433 unter WMBus_T auf die Frequenz 433.. zu bekommen.
Ebenfalls bin ich Deinem Rat gefolgt und habe mit dem Hersteller Kontakt aufgenommen.
Anfrage an Sontex, Schweiz:
Sehr geehrte Damen und Herren,
für die Integration unserer Sontex-Geräte in bestehendes Smart Home System benötige ich unsere AES-Keys (128bit) für:
Supercom 581 - 22305872 - Bad/WC kalt
Supercom 581 - 22703799 - Bad/WC warm
Supercom 581 - 22321724 - WZ/Kü kalt
Supercom 581 - 22703800 - WZ/Kü warm
Supercal 739 - 22030551 - Heizungsverteiler (leider ist mir hier die genaue Ausstattung nicht klar, ID + RD 22030551, Software-Version 1.06), ich hoffe dies ist ebenfalls eine MBus-Ausführung des HKV
Wir beabsichtigen mittelfristig den gesamten Wohnbereich und evtl. in Folge auch in Abstimmung mit der WEG das Gebäude mit weiteren Sontex-Systemen (Rauchmelder...) nachzurüsten.
Antwort:
die unten aufgeführten Geräte haben alle unseren 433 MHz-Funk und kein wM-Bus (daher auch keine AES-Keys).
Bitte setzen Sie sich bezüglich der Integration in ein bestehendes Smart-Home-System mit Ihrem Lieferanten in Verbindung.
Nachfrage zu Details:
vielen Dank für Ihre rasche Antwort. Es handelt sich wohl doch bei beiden Geräten um einen M-Bus.
Ist die Auskunft verbindlich, dass hier keine 128Bit Verschlüsselung eingesetzt wird?
Hier die Auszüge aus dem Datenblättern
Supercom 581:
Funk  Verfahren FSK, bidirektional Frequenz 433,82 MHz Protokoll Radian, EN60870-5 (M-Bus)  Baudrate 2'400 Baud Reichweite ca. 30 m, je nach Gebäudekonstruktion
Supercal 739:
Der Supercal 739 verfügt über eine grosse Anzahl optionaler Schnittstellen für die Datenfernauslesung: -  Optische Schnittstelle, M-Bus mit Speisung via M-Bus Bidirektionaler Funk Sontex Supercom, Wireless M-Bus, OMS, zwei Pulsausgänge
Antwort:
bei denen mir aufgeführten Spezifikationen handelt es sich um die, die diese Geräte unter anderem als Option haben, was die bei Ihnen verbauten Geräte betrifft hilft mir das nicht weiter. Bitte wenden Sie sich an den Lieferanten, der Ihnen diese Geräte zur Verfügung gestellt bzw. verbaut hat.
Gruß Norbert
kaihs
Die Antwort des Herstellers ist doch ziemlich eindeutig. Die Zähler verwenden kein WMBus sondern ein proprietäres Protokoll.
WMBus ist auch nicht für 433 MHz spezifiziert, deshalb kann der CUL in den WMBUS Modi auch nicht auf die Frequenz eingestellt werden.
Mit WMBUS kommst du da also nicht weiter. Vielleicht wäre der SIGNALduino ein Lösungsansatz.
Banana Pi, Add-On Board mit 1.8" TFT LCD und IR-Sender, CULFW V1.61, div. Homematic Komponenten, Pollin Funksteckdosen, Selbstbau CUL433 MHz, Jeelink Clone, EC3000
Selbstbau CUL868MHz für Wireless M-Bus, SIGNALduino mit Logilink Temp.-sensoren und Auriol Wetterstation
noby
#804
Musste mich erst in das Thema SIGNALduino einlesen und den gesamten Verlauf nochmal durcharbeiten.Würde mit SIGNALduino auf Basis Nano und CC1101 für beide Frequenzen 433/868 Daten sammeln und diese gerne bereitstellen.
ext23
Nabend,
gibt es hier schon Erfahrungen mit:
- Q smoke 5 5R (C-Modus, Qundis)
- KALO Typ XWE (scheint auch C-Modus zu sein wenn die Anleitung passt)
- kaloBLUE K1.5X (Open Metering System (OMS))
(KALO hat Qundis übernommen, ist also dasselbe)
Alles im Walk-by Mode. Das wird doch alles dasselbe sein, die rennen doch nicht mit 3 Tablets durchs Haus beim auslesen oder? Ich habe jetzt einen CUL genommen und den im C-Mode laufen aber da kommt rein gar nichts rein. Und das wurde heute alles installiert, sprich die Rauchmelder sollten noch 2 Tage sone Test Telegramme senden wenn ich das richtig gelesen habe.
Oder haben die wirklich alle ne recht genau Uhr drin weil bei der Wasseruhr steht:
walk-by(*)
alle 128 Sekunden
10 Stunden pro Tag (8.00 - 18.00 Uhr)
Mit den Wasseruhren ist blöd. Da jetzt dieses Funkmodul drauf sitzt komme ich nicht mehr an die Scheibe für die Lichtschranke rann... Kann ich also nicht mehr auslesen.
/Daniel
ext23
#806
heute mal auf Mode-S umgestellt und jetzt bekomme ich ein Haufen Meldungen, aber alle unknown:
2019-11-05 08:02:11 CUL CUL_0 UNKNOWNCODE b494465320382938835083BAC780DFF5F3500820680355A36E8EBED555BE3E97B6483FF3FAF64E1E2EBB96BFC4FC3E58D907BAE19E9C465A7EA2E8C5ED7A63DC7D7653F0AF21EB7A4D474A89E046D0108652B614980::-66
2019-11-05 08:02:18 CUL CUL_0 UNKNOWNCODE b49446532919693883508719F780DFF5F35008205803579EC6BF2D42B5AF50364A7B7700E764EC316035F9E9457306A31BB84B143814DB877ABF54D826C50F40F3ED217B36017EAEADD540CFA046D0208652B05CC80::-64
2019-11-05 08:02:19 CUL CUL_0 UNKNOWNCODE b49446532899693883508C9D8780DFF5F35008205803586620F430341F822217D5637DCA34BAECFCC3B4EC7DB4E414D7F9BC63BD750890CCA70746F300E6DCE9E5E3BDF149D131E18A2A9564F046D0208652B78FD80::-59
2019-11-05 08:02:20 CUL CUL_0 UNKNOWNCODE b494465320511002035086E9B780DFF5F3500820580357AE1F7BD71F9AD701871108E53A226268531F548E6C4F9FEF4B75B19E3FD960FA548A4BE82A39A6175FB39D73666B1BF111F3FC42CE4046D0108652BBE5680::-59.5
2019-11-05 08:02:24 CUL CUL_0 UNKNOWNCODE b49446532028293883508FA24780DFF5F3500820580352ACE7080D9B8CFEAD3D10A7E88E8EC07F562B1ACDB456937FA71A1F8C49737F6B0E93447D387F4E690F8CD0254D807C20A091399ED53046D0208652BBCD980::-64.5
2019-11-05 08:02:43 CUL CUL_0 UNKNOWNCODE b4F4465B2214691243307C0DB780DFF5F35008206803529050E53CF55B054246384F6C3C920469A813DC8E16F4E0814464056279D6B60FBEEC30E0D72CCF0B0D32002AFF7EEE8CF409C4A9FD4046D0208652B54A30C7861684735769480::-66.5
2019-11-05 08:02:50 CUL CUL_0 UNKNOWNCODE b4F4465B29442942433078772780DFF5F350082068035D9B9897D0B64144F6BACF89704BF8818E5FD1D261A3D80FCC5A41F3EF09000083C1B68D1734B4DF02EAEEA8A77275415991D15C53BA0046D0208652B4A610C785868473589D582::-81.5
2019-11-05 08:03:04 CUL CUL_0 UNKNOWNCODE b4F4465B2224691243307BF26780DFF5F3500820680350B679DDF2FAD6816C3C1E961F17395E6E31D00BF69629279E641C6FD223798A058FAC73B2098116874999A9D60999B872339F4700112046D0308652BA14A0C78847147358E7D81::-91
2019-11-05 08:03:04 CUL CUL_0 UNKNOWNCODE b4F4465B2184691243307CFA6780DFF5F3500820680358131FBE7631201A8BDD824C92F9EAA95AC6B95F8FEB43B12F0475EA62B1F391B07D6EF46E3B1E7606023F75EDD446327ABDEBCFDC704046D0308652B84630C7886714735F81D80::-60
2019-11-05 08:03:13 CUL CUL_0 UNKNOWNCODE b494465329296938835080E62780DFF5F350082058035EB051AE36C74AB1564505EB13C86732CEECD6845EF214FC6026EA01C0FAC3C28A118238A4A49C6EA783E7E05B7691C6FF3AB5BCD5D88046D0308652B46A780::-51
2019-11-05 08:03:17 CUL CUL_0 UNKNOWNCODE b4F4465B29242942433077888780DFF5F350082078035BB1FCF813C49A67C858A5D25CA5F647BF1C1ABE5D0D17820A9E69C6864492C28C47D02C0E237158AA2CBF271038016AE65CCD16CDA82046D0308652BAC910C78837147352FED80::-73
2019-11-05 08:03:20 CUL CUL_0 UNKNOWNCODE b4F4465B26341942433078DA8780DFF5F350082078035AF1EF9F886DA5C1D9A29E3AD394772F941127D7821F8BA7CB1997801BD8E6A9A0CC9EBA4C5984EDF3351ECA0EBE1BED4B1A455AA919B046D0308652BC5CA0C7872684735CF6B82::-87.5
2019-11-05 08:03:21 CUL CUL_0 UNKNOWNCODE b49446532909693883508B017780DFF5F350082058035B103DD9E569D2D955B23292B0EADEA3DB99DA0694E0B3EDCBF58EE08DA707DAC6F3DBEAC7249454FE7752DBED2D93B35594FCCD8F892046D0308652B45C280::-59
2019-11-05 08:03:44 CUL CUL_0 UNKNOWNCODE b4F4465B295429424330746FA780DFF5F350082068035DAFFE2BF123021B403A6F5EE04BC91F6ECB92F3047E41F8314B12DC94E820C237163B0F1DCD665A8FECCC7C9713C3860B05AAC361086046D0308652B6D9A0C7887714735C32D80::-65
2019-11-05 08:03:52 CUL CUL_0 UNKNOWNCODE b49446532968593883508AECD780DFF5F350082068035717914AF79569C7E8BE19AE0BDD581B88EC9C2AC2238C79EEC08AAD7BB7C5D79ADACC53E9AA1A830757B65AA7E3F0C559C4102E95E81046D0408652BF96182::-89
2019-11-05 08:03:54 CUL CUL_0 UNKNOWNCODE b4F4465B29642942433073907780DFF5F350082068035F677B2CFBBE81651F0922C8C6B8A29D90962A9D4FA5335A55A217433E760AFA087EC63CE8DA942C470CE0534B8CFB501CCDA03F08AAF046D0308652BC2390C788071473562BD82::-79.5
2019-11-05 08:04:17 CUL CUL_0 UNKNOWNCODE b494465320382938835083BAC780DFF5F350082068035951CFA4EA0DD33A7E421CE4DCE8DA094F8C191D40AE4CC4EA879DF86BA7695FF81695B4FD5F05999EE94B16A59C4D1218349CE2DB9C5046D0308652B5AEE80::-65.5
2019-11-05 08:04:24 CUL CUL_0 UNKNOWNCODE b49446532919693883508719F780DFF5F350082058035FD92F789C2E03A1BF1685244D1763578A63317044ABDA6D3B333EF77CE787621C0E31CA4FC986359F155A280B2D18CFBE0C8893EC84E046D0408652BC49F80::-64
2019-11-05 08:04:26 CUL CUL_0 UNKNOWNCODE b494465320511002035086E9B780DFF5F350082058035AB54E2D98DAEE98AF3D723B94219D0D1F55C582743C717844969363A7CD9A431DFB680D1AC3E411A837C58EDBFC352955E9A6F482C95046D0308652BC9CE80::-58.5
2019-11-05 08:04:29 CUL CUL_0 UNKNOWNCODE b49446532899693883508C9D8780DFF5F350082058035D1DFFF83CCC56CA539961E3C19BB6B67F1E1C1A9E5FB1041416C75326CD77CE5B2526D2F759C7CB365BC5700B6DDDC29B9842423A856046D0408652BC0FA80::-56.5
2019-11-05 08:04:31 CUL CUL_0 UNKNOWNCODE b49446532028293883508FA24780DFF5F3500820580357449AAD0A9281331B0CFB216B6CBE570C916DD70EBC80EAB2F18E0EE0FD115F38CC86EA7B47142CF7E9DAD6A96468DFE91FDE2567873046D0408652BF3C881::-78.5
2019-11-05 08:04:50 CUL CUL_0 UNKNOWNCODE b43C465B253C1D003F0D8D7B7A08310008029B1003144653243029488EF5F35087A1D0000000B6E0600004B6E0000BB0D00426C5F2C326CFFFF046D0405652B82A080046C7F2A8B046E010000382680::-78.5
2019-11-05 08:04:51 CUL CUL_0 UNKNOWNCODE b4F4465B2214691243307C0DB780DFF5F350082068035F874723237016720A6200D9CCA6CA234002D7F74832E58D9848B3E7475A0F0BF68782889FF66948894280FFD8E341D8D6AFC8DDDD64D046D0408652BA1680C7861684735769481::-68
2019-11-05 08:05:14 CUL CUL_0 UNKNOWNCODE b4F4465B2184691243307CFA6780DFF5F35008206803547BAC8514EA4A069C65F48E6EBE28B97AE7EF7DF927350656B27C6E235CB4276A9716E8D6AE285035262E8050E5EADCD1055BF75BDFB046D0508652BCB5C0C7886714735F81D80::-59.5
2019-11-05 08:05:22 CUL CUL_0 UNKNOWNCODE b494465329296938835080E62780DFF5F35008205803525D58E40AA57D55E2C53C4CE42E55BB17A00D3F3F98E962A3F279719DF14554A9A6C2DF17F5CBA7919E5C3412E4A5C9E2B25B536EB71046D0508652BC58080::-48.5
2019-11-05 08:05:28 CUL CUL_0 UNKNOWNCODE b49446532909693883508B017780DFF5F350082058035763FA6DDD922220F23A1366C253CA4CE204980C4FA1B7A3DB93302FBEF6FF0EFA1CCDB245DB358ADDE5ACA8A382313CB84611671AC82046D0508652BF21780::-60.5
2019-11-05 08:05:35 CUL CUL_0 UNKNOWNCODE b49446532540891883508D11E780DFF5F3500820580354E0410D202E6D6FD41F6774D3F5216EB3D8AF4BAB010C2774B8F3947B9AC2FC342C16D521956AEF178A2E381CB772DB1633740F5FA1F046D0508652B96FD81::-88
2019-11-05 08:05:53 CUL CUL_0 UNKNOWNCODE b4F4465B295429424330746FA780DFF5F350082068035F103DBEA2D719E765CD43F42A3373B655F06148A1E9329A1DAB4072ACAACF44392F81AD32731DB33016D69F2FEB48678F2160588CD47046D0608652BE2B70C7887714735C32D81::-68.5
2019-11-05 08:06:03 CUL CUL_0 UNKNOWNCODE b4F4465B29642942433073907780DFF5F350082068035371E396956C9C05DDA8AB0163F679AF72108AE6B9F340F8C35E3ED8187C556802B9BD9D7123B1881AF5D270D46A5241C56020B2F4B85046D0608652BAB1E0C788071473562BD80::-78
2019-11-05 08:06:22 CUL CUL_0 UNKNOWNCODE b4F4465B22046912433070153780DFF5F3500820680350D3D091E943E48AA87DAFD32D1D3B94BE712D26BF94EDBE9073A5B41E69C56E9123C85E4C5030E2D313391CB4BCFF1F9F11D649EE601046D0608652BFE840C7856684735F79082::-92
2019-11-05 08:06:28 CUL CUL_0 UNKNOWNCODE b494465320382938835083BAC780DFF5F35008206803585DD08BB11DF078BE956AED1741B65397753B1A2D202F839EEEC5B66138B4079AAAF4CB81C98B7B6CCDA8AA561FE43536B0D6513FFBA046D0508652BB63181::-68.5
2019-11-05 08:06:32 CUL CUL_0 UNKNOWNCODE b49446532919693883508719F780DFF5F350082058035728486D18DE5C6D7F58ADB9F99B72023E3AB3550AC6B5AAE7131C23CE6909093B5DC01D7D5875635E2318C48CBC678DFEA921CC48772046D0608652B0FDA83::-83
2019-11-05 08:06:41 CUL CUL_0 UNKNOWNCODE b49446532028293883508FA24780DFF5F350082058035068B4B47F1B35129D3672C8599DF6A0B639C984FEBBA2CF45AB64C640D96D3F090F8E6323AC5D7212258535C9AAA9EC20165C79FB4BB046D0708652B960980::-73.5
2019-11-05 08:06:42 CUL CUL_0 UNKNOWNCODE b49446532190294883508FCCA780DFF5F35008205803517A0B0EAA618FCA651F386FB4E5637D5446AFAE59D291783C7062909BFCA02800621C6C2B5CA344AD6E2473E9A07734B206F895436C7046D0608652B763C83::-90
2019-11-05 08:07:00 CUL CUL_0 UNKNOWNCODE b4F4465B2214691243307C0DB780DFF5F3500820680353478CC57E5B647BD2DDC16937AE258F7B2973C5E4EF595C2923EAF55C824F7D05366847AB53BF10004D7D054B0567158D6430D227B9A046D0608652BDDA50C7861684735769480::-68
2019-11-05 08:07:10 CUL CUL_0 UNKNOWNCODE b49446532532794883508A06A780DFF5F350082068035D7780713BC96C083387C80EC28E6E3C3F2A725446E1A4867020B5A543F192AA606486D53F67F7B7996DBDF3B76D99FC7A5F452A61850046D0608652B310E83::-86
2019-11-05 08:07:21 CUL CUL_0 UNKNOWNCODE b4F4465B2184691243307CFA6780DFF5F35008206803524E348BEC239D811BD6C2E37237B2DF9FC4A10E44E8F4DCA0103FDABDB4DCE324CA83126A2183C6C4B15D962AB6585EB00C60C51B0C0046D0708652B9E320C7886714735F81D80::-61.5
UPDATE: OK im Flur hängt ein Q gateway 5, also scheinen die doch Mode S zu nutzen und die Daten "ständig" zu sammeln. Und vermutlich auch mit einem AES Schlüssel.
/Daniel
kaihs
Ja, das sind Daten von Qundis Wasser- und Wärmemengenzählern.
Die sind zwar nicht (gemäß OMS) verschlüsselt, aber alle interessanten Daten sind herstellerspezifisch codiert.
Trotzdem sollten dafür Devices angelegt werden.
Wird bei
list TYPE=WMBUS
etwas angezeigt? Falls nicht fehlen dir vielleicht perl Module die von WMBUS benötigt werden. Siehe commandref.
Bzgl. Empfang von WMBUS Typ C siehe meine Erläuterung in einem anderen Thread,
ext23
Super vielen Dank! Stimmt vollkommen, die Module haben gefehlt, jetzt hat er schon das erste Gerät angelegt, allerdings nicht meins, eher vom Nachbarn, aber gut ich lass es mal laufen einen Tag:
   DEF        LSE 24914621 51 7
   DeviceMedium Water
   DeviceType 7
   FUUID      5dc1d9e3-f33f-70a7-87ae-6292139eea90161c
   IODev      CUL_0
   IdentNumber 24914621
   Manufacturer LSE
   MessageEncoding CUL
   NAME       WMBUS_LSE_24914621_51_7
   NR         15
   STATE      no errors
   TYPE       WMBUS
   Version    51
   addr       LSE_24914621_51_7
     2019-11-05 21:21:55   1_storage_no    0
     2019-11-05 21:21:55   1_type          VIF_VOLUME
     2019-11-05 21:21:55   1_unit          m³
     2019-11-05 21:21:55   1_value         0.187
     2019-11-05 21:21:55   1_value_type    Instantaneous value
     2019-11-05 21:21:55   2_storage_no    1
     2019-11-05 21:21:55   2_type          VIF_VOLUME
     2019-11-05 21:21:55   2_unit          m³
     2019-11-05 21:21:55   2_value         0
     2019-11-05 21:21:55   2_value_type    Instantaneous value
     2019-11-05 21:21:55   3_storage_no    1
     2019-11-05 21:21:55   3_type          VIF_TIME_POINT_DATE
     2019-11-05 21:21:55   3_unit
     2019-11-05 21:21:55   3_value         invalid: ffffffffffffffff
     2019-11-05 21:21:55   3_value_type    Instantaneous value
     2019-11-05 21:21:55   4_storage_no    0
     2019-11-05 21:21:55   4_type          VIF_TIME_POINT_DATE
     2019-11-05 21:21:55   4_unit
     2019-11-05 21:21:55   4_value         invalid: ffffffffffffffff
     2019-11-05 21:21:55   4_value_type    Value during error state
     2019-11-05 21:21:55   5_storage_no    0
     2019-11-05 21:21:55   5_type          VIF_TIME_POINT_DATE_TIME
     2019-11-05 21:21:55   5_unit
     2019-11-05 21:21:55   5_value         2019-11-05 21:21
     2019-11-05 21:21:55   5_value_type    Instantaneous value
     2019-11-05 21:21:55   6_storage_no    0
     2019-11-05 21:21:55   6_type          VIF_FABRICATION_NO
     2019-11-05 21:21:55   6_unit
     2019-11-05 21:21:55   6_value         35476861
     2019-11-05 21:21:55   6_value_type    Instantaneous value
     2019-11-05 21:21:55   LQI             128
     2019-11-05 21:21:55   RSSI            -74.5
     2019-11-05 21:21:55   batteryState    ok
     2019-11-05 21:21:55   decryption_ok   1
     2019-11-05 21:21:55   is_encrypted    0
     2019-11-05 21:21:55   state           no errors
     2019-11-05 21:21:55   unit            m³
     2019-11-05 21:21:55   volume          0
   IODev      CUL_0
   room       WMBUS
Mit dem Typ C, das habe ich nur auf den Rauchmeldern gelesen, kann sein das die das wirklich anders machen. Allerdings würde mich das wundern wenn die ein Netz aufbauen und dann die Rauchmelder eine Sonderlocke spielen, aber gut ich werde es beobachten die Tage.
Wegen der Hersteller spezifischen Felder, kann man das irgendwie reengineeren?
/Daniel
kaihs
Die Daten sehen ja gut aus, da ist nichts herstellerspezifisches dabei.
Ich hatte mir zwei deiner Rawmessages angesehen, da sah das anders aus.
Warte mal ab, bis du Daten von deinen Zählern empfängst.
Reverse Engeneering ist prinzipiell möglich, kann aber mühsam werden.
Man muss versuchen die bekannten Daten des Zählers (Zählerstand, Datum, ...) in den Daten wieder zu finden.
