Wireless M-Bus für CUL
Begonnen von tostmann, 12 Juni 2014, 17:34:32
bilbolodz
#540
I've managed to reply (via pipe) message:
b32446850296586536980EDECA0058420000050080000DB07E7070000F62B00000000000000000000000000000000FFFF000000000000000000FF
and route it into Techem HKV object. Just for record, the key issue is: MANUAL CREATE device with correct ID. In that case:
define techem TechemHKV 53866529
Now I've to understand (more) how is working Techem and correctly convert to serve my meter. Question:
Function TechemHKV_SanityCheck checks CRC AND removed crc from message?
herrmannj
bilbolodz
One more question:
in TechemHKV_Parse there are calls to "more detailed parse functions". These functions get's as a parameter "message":
sub
TechemHKV_ParseID(@) {
  my @m = @_;
  return ("$m[6]$m[5]$m[4]$m[3]", "$m[4]$m[3]");
As I understand $m is striped from first byte (length) of original message? (actually two bytes because of "b")  Am I right? (serial number should be at 4567 position not 3456).
herrmannj
Can't recall from mind but I guess you are right
herrmannj
After reading again be careful. In your 9.04 post id does not match with define. The id start right after 6850
bilbolodz
Right. Incorrect CRTL+C CTRL+V. Corrected previous post.
bilbolodz
Hmmmm. Another problem. It looks that message doesn't get my parse function....
My message is:
Zitatb89441486D0F9020003034CCEA0812433000C4000142A0F0510011234023CDC4E0A0306FF0C394C2A00C7902A009D1BF3EC2A0071AA2B00A29C2D00C7722F001DD4404930001AAF31006E083200AC583200C8FE24A03200F8FA3200030000000037D4081F9D4F000000002000000000000023000000007C6224000000000000270000002800000000BB5F00002C00200301050C2F0000000000004B2480
Zitatsub
ApatorWM_Initialize(@) {
  my ($hash) = @_;
  # require "Broker.pm";
  $hash->{Match}      = "^b..441486[\\d]{8}0303....A0.*";
  $hash->{DefFn}      = "ApatorWM_Define";
  $hash->{UndefFn}    = "ApatorWM_Undef";
  $hash->{SetFn}      = "ApatorWM_Set";
  $hash->{GetFn}      = "ApatorWM_Get";
  $hash->{NotifyFn}   = "ApatorWM_Notify";
  $hash->{ParseFn}    = "ApatorWM_Parse";
  $hash->{AttrList}   = "".$readingFnAttributes;
Log3 ("ApatorWM", 0, "Init: $hash->{Match}");
  return undef;
ZitatInternals:
   CMDS       Nocmdsfordummies
   Clients    :TechemHKV:ApatorWM:WMBUS:HMS:CUL_IR:STACKABLE_CC:TSSTACKED:
   DEF        /home/bilbo/robota/fhem-5.8/CUL_fifo@directio 1234
   DeviceName /home/bilbo/robota/fhem-5.8/CUL_fifo@directio
   FD         20
   FHTID      1234
   MessageEncoding CUL
   NAME       cul_emu
   NEXT_OPEN  1516274997
   NR         20
   PARTIAL
   RAWMSG     b89441486D0F9020003034CCEA0812433000C4000142A0F0510011234023CDC4E0A0306FF0C394C2A00C7902A009D1BF3EC2A0071AA2B00A29C2D00C7722F001DD4404930001AAF31006E083200AC583200C8FE24A03200F8FA3200030000000037D4081F9D4F000000002000000000000023000000007C6224000000000000270000002800000000BB5F00002C00200301050C2F0000000000004B2480
   RSSI       -138
   STATE      Initialized
   TYPE       CUL
   VERSION    V
   cul_emu_MSGCNT 3
   cul_emu_TIME 2018-01-18 12:29:04
   initString X21
brt
   Matchlist:
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
     J:WMBUS    ^b.*
     M:TSSTACKED ^\*
   Readings:
     2018-01-18 12:28:57   cmds            No answer
     2018-01-18 12:29:04   state           Initialized
   dummy      1
   rfmode     WMBus_T
   room       WMBUS
sub
ApatorWM_Parse(@) {
Log3 ("ApatorWM", 0, "ApatorWM_Parse");
  my ($iohash, $msg) = @_;
  my ($message, $rssi);
  ($msg, $rssi) = split (/::/, $msg);
Log3 ("ApatorWM", 0, "Parse: $msg");
  $msg = ApatorWM_SanityCheck($msg);
Log3 ("ApatorWM", 0, "after ApatorWM_SanityCheck: $msg");
But in logs I can see:
2018.01.18 12:28:57 2: Switched cul_emu rfmode to WMBus_T
2018.01.18 12:28:57 0: Init: ^b..441486[\d]{8}0303....A0.*
2018.01.18 12:28:57 3: Define 195024
2018.01.18 12:47:57 2: WMBUS WMBUS_APT_00036030_3_3 Error during ApplicationLayer parse:Unsupported CI Field a0, remaining payload is 812433000c4000142a0f0510011234dc4e0a0306ff0c394c2a00c7902a009dec2a0071aa2b00a29c2d00c7722f001d4930001aaf31006e083200ac583200c8a03200f8fa3200030000000037d4081f000000002000000000000023000000002400000000000027000000280000000000002c00200301050c2f000000000000
What could be wrong?
herrmannj
#547
ZitatWhat could be wrong?
cant say ... but parse will not be called (at least I cant see the log entry for it). So it is in the area of matching the client regex. May be you must place some more log point in fhem.pl dispatch to see what happens ...
update:
from CUL internals:
So your module ís registered
bilbolodz
Zitat von: herrmannj am 18 Januar 2018, 13:07:42
update:
from CUL internals:
I know. There was an error in matching filed it should be:
^b..441486[0-9a-fA-F]{8}0303....A0.*
herrmannj
makes sense. That is an difference on how techem does their ID but it may be an wise move to adapt that.
bilbolodz
Finally working..... (first version). Now next questions (not about programming of FHEM internals but rather "generally"):
1) My Meter reports water volume in let's sat "ticks" (it's addon for regular mechanical meter). To convert it into real cubic meter it's to be multiply by some factor. Factor probably depends on mechanical meter. By comparing ticks and visual numbers on meter I've computed that my factor is about:  0.000333333 but it could be different for another meter. Should I report "raw ticks" from meter or should I multiply it by factor and return real water volume? If real water volume how to put factor into module? Hardcoding it into source is probably bad idea I think it should be a parameter which can be set by FHEM but how to do it?
2) Meter besides volume ticks reports:
Zitatday number - changes +1 every day
day of month (for 24.12 it's 24)
day of week (strange because Friday is 1 ... Sunday is 3 .... Monday is 4 ... Thursday is 7)
hour
minute
seconds
How should I report it into FHEM ("as what")?
Meter sends of course more information that I've wrote but I don't know a meaning of it.
setstate
Zitat von: kaihs am 17 Januar 2018, 21:31:57
Das wird nicht viel bringen, das sind ja nur die Indizes in den Puffer.
Am einfachsten ist es wahrscheinlich
static char cmdbuf[128+1];
zu verwenden. Dafür muss nichts in ringbuffer.c geändert werden.
Der code in ttydata.c verwendet sizeof für die Größenermittlung von cmdbuf und muss daher auch nicht angepasst werden.
Kann es sein, dass die ttydata.c auch an anderer Stelle noch nicht für Bufsize > 256 funktioniert?
uint8_t cmdlen;
herrmannj
you can do that by introducing a attribute but because of the central importance it may also be part of the define (maybe rpm or whatever)
kaihs
uint8_t cmdlen;
Ja, sieht so aus, die Größe dieses Puffers muss < 256 sein, damit es nicht zu einem Überlauf kommt.
Banana Pi, Add-On Board mit 1.8" TFT LCD und IR-Sender, CULFW V1.61, div. Homematic Komponenten, Pollin Funksteckdosen, Selbstbau CUL433 MHz, Jeelink Clone, EC3000
Selbstbau CUL868MHz für Wireless M-Bus, SIGNALduino mit Logilink Temp.-sensoren und Auriol Wetterstation
setstate
#554
Hab's jetzt hin bekommen mit getrennten Buffer-Größen.
128 für cmdbuf und TTY_Rx_Buffer;
358 für TTY_Tx_Buffer
static char cmdbuf[TTY_BUFSIZE_R+1];
extern rb_t TTY_Tx_Buffer;
extern rb_t_r TTY_Rx_Buffer;
die WMBUS Devices werden angelegt und die Werte kommen. Beispiel: ca. 19 für DeviceMedium Heat.
Leider senden die Geräte nur von 6:00-18:00 Uhr, deshalb konnte ich gestern Abend nicht mehr testen.
Wer kann die Änderung in der culfw jetzt offiziell einbauen?
Update:
Zu früh gefreut, der nanoCUL antwortet nicht mehr. Da hat sich was aufgegangen.
