bei mir ist das Problem trotz "verbose 3" noch vorhanden. Habe auf meinen COC die 1.61 gestern geflasht, leider keine Änderung. Ich dachte schon ich habe etwas falsch eingestellt, bei diesen ganzen nicht deutbaren Meldungen.
Tobias
2014.07.01 15:43:07 0: Server shutdown
2014.07.01 15:43:44 1: Including fhem.cfg
2014.07.01 15:43:45 3: Opening COC device /dev/ttyAMA0
2014.07.01 15:43:46 3: Setting COC baudrate to 38400
2014.07.01 15:43:46 3: COC device opened
2014.07.01 15:43:46 3: COC: Possible commands: mCFiAZOGMKRTVWXefltux
2014.07.01 15:43:46 2: Switched COC rfmode to HomeMatic
2014.07.01 15:43:46 3: telnetPort: port 7072 opened
2014.07.01 15:43:47 3: WEB: port 8083 opened
2014.07.01 15:43:47 3: WEBphone: port 8084 opened
2014.07.01 15:43:47 3: WEBtablet: port 8085 opened
2014.07.01 15:43:48 2: eventTypes: loaded 384 events from ./log/eventTypes.txt
2014.07.01 15:43:52 1: Including ./log/fhem.save
2014.07.01 15:43:52 1: usb create starting
2014.07.01 15:43:55 1: usb create end
2014.07.01 15:43:55 2: SecurityCheck: WEB,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute. Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.01 15:43:55 0: Server started with 42 defined entities (version $Id: fhem.pl 6080 2014-06-07 16:12:09Z rudolfkoenig $, os linux, user fhem, pid 2034)
2014.07.01 15:43:56 3: Device Badezimmer_RT added to ActionDetector with 000:10 time
2014.07.01 15:43:56 3: Device Balkontuer added to ActionDetector with 028:00 time
2014.07.01 15:43:56 3: Device Haustuer added to ActionDetector with 028:00 time
2014.07.01 15:43:56 3: Device Wohnzimmer_RT added to ActionDetector with 000:10 time
2014.07.01 15:44:19 3: COC: Unknown code A11D0A0021C1E601C55420475C5B9ADA19500::-102:COC, help me!
2014.07.01 15:44:19 3: COC: Unknown code A0ED080021C1E601C554200E45CB4EA::-102:COC, help me!
2014.07.01 15:44:35 3: COC: Unknown code A1169A0021C1E601F48BE0452392D21150900::-104:COC, help me!
2014.07.01 15:44:36 3: COC: Unknown code A0E6980021C1E601F48BE00AC85D69F::-103.5:COC, help me!
2014.07.01 15:49:28 3: COC: Unknown code A11D1A0021C1E601C5542049185796D61F500::-104:COC, help me!
2014.07.01 15:49:28 3: COC: Unknown code A0ED180021C1E601C554200FE41E4C2::-102.5:COC, help me!
2014.07.01 15:58:19 3: COC: Unknown code A11D3A0021C1E601C554204040A05F9EDE100::-102.5:COC, help me!
2014.07.01 15:58:19 3: COC: Unknown code A0ED380021C1E601C554200EC989AC3::-101.5:COC, help me!
2014.07.01 16:00:42 3: COC: Unknown code A116CA0021C1E601F48BE043D312519050B00::-102.5:COC, help me!
2014.07.01 16:00:43 3: COC: Unknown code A0E6C80021C1E601F48BE009283E06A::-100.5:COC, help me!
2014.07.01 16:04:09 3: COC: Unknown code A11D4A0021C1E601C554204D5C9A9AF352900::-102.5:COC, help me!
2014.07.01 16:04:09 3: COC: Unknown code A0ED480021C1E601C55420094F9B401::-103:COC, help me!
2014.07.01 16:05:50 3: COC: Unknown code A116DA0021C1E601F48BE0475695D5145AA00::-100.5:COC, help me!
2014.07.01 16:05:50 3: COC: Unknown code A0E6D80021C1E601F48BE00FD271A27::-103.5:COC, help me!
2014.07.01 16:09:30 3: COC: Unknown code A11D5A0021C1E601C554204C9BDB1A5990600::-102:COC, help me!
2014.07.01 16:09:30 3: COC: Unknown code A0ED580021C1E601C554200AF78AB56::-102:COC, help me!
2014.07.01 16:10:28 3: COC: Unknown code A116EA0021C1E601F48BE04594D413529FA00::-102:COC, help me!
2014.07.01 16:10:29 3: COC: Unknown code A0E6E80021C1E601F48BE00AA5C69C5::-102.5:COC, help me!
2014.07.01 16:14:23 3: COC: Unknown code A11D6A0021C1E601C554204998D8175695D00::-100:COC, help me!
2014.07.01 16:14:23 3: COC: Unknown code A0ED680021C1E601C554200D108C280::-101:COC, help me!
2014.07.01 16:14:38 3: COC: Unknown code A116FA0021C1E601F48BE040D01F5E9DDD100::-102:COC, help me!
2014.07.01 16:14:38 3: COC: Unknown code A0E6F80021C1E601F48BE002D725E88::-103:COC, help me!
2014.07.01 16:18:46 3: COC: Unknown code A11D7A0021C1E601C554204C1B5A99D918500::-102.5:COC, help me!
2014.07.01 16:18:46 3: COC: Unknown code A0ED780021C1E601C5542006D9EF213::-102.5:COC, help me!
2014.07.01 16:20:27 3: COC: Unknown code A1170A0021C1E601F48BE046155493D312500::-105.5:COC, help me!
2014.07.01 16:20:27 3: COC: Unknown code A0E7080021C1E601F48BE000AE8C70B::-103:COC, help me!
2014.07.01 16:24:49 3: COC: Unknown code A11D8A0021C1E601C5542043FDDD1C5B9AD00::-103:COC, help me!
2014.07.01 16:24:49 3: COC: Unknown code A0ED880021C1E601C5542002CF29B01::-102.5:COC, help me!
2014.07.01 16:25:47 3: COC: Unknown code A1171A0021C1E601F48BE046D6155493D3100::-102.5:COC, help me!
2014.07.01 16:25:47 3: COC: Unknown code A0E7180021C1E601F48BE0087081741::-101:COC, help me!
2014.07.01 16:30:23 3: COC: Unknown code A0ED980021C1E601C554200133C1C98::-102.5:COC, help me!
2014.07.01 16:30:38 3: COC: Unknown code A1172A0021C1E601F48BE04B9565C25190D00::-102:COC, help me!
2014.07.01 16:30:38 3: COC: Unknown code A0E7280021C1E601F48BE0023EA7E36::-103:COC, help me!
2014.07.01 16:35:00 3: COC: Unknown code A1173A0021C1E601F48BE044D4135291D1100::-103.5:COC, help me!
2014.07.01 16:35:01 3: COC: Unknown code A0E7380021C1E601F48BE00738BAC8D::-103.5:COC, help me!
2014.07.01 16:35:28 3: COC: Unknown code A11DAA0021C1E601C554204A195897D545A00::-101:COC, help me!
2014.07.01 16:35:28 3: COC: Unknown code A0EDA80021C1E601C554200333469E1::-101:COC, help me!
