Hallo Sailor,
bei "get mykm200" kommt:
Unknown argument , choose one of /system/holidayModes / /heatSources/actualDHWPower /heatSources/hs1/fuel /system/heatSources/hs1/actualPower /heatSources/ChimneySweeper /heatingCircuits/hc1/temporaryRoomSetpoint /system/holidayModes/hm4/hcMode /heatingCircuits/hc2/actualSupplyTemperature /solarCircuits/sc1/actuatorStatus /heatSources/actualsupplytemperature /heatingCircuits/hc1/temperatureLevels/eco /heatingCircuits/hc1/temperatureRoomSetpoint /solarCircuits/sc1/solarYield /heatSources/flameCurrent /gateway/uuid /heatingCircuits/hc2/activeSwitchProgram /heatingCircuits/hc1/fastHeatupFactor /heatingCircuits/hc2/heatCurveMin /heatingCircuits/hc2/solarInfluence /system/sensors/temperatures/return /heatSources/gasAirPressure /heatingCircuits/hc1/roomInfluence /system/holidayModes/hm2/dhwMode /system/appliance/actualSupplyTemperature /heatingCircuits/hc2/suWiSwitchMode /heatingCircuits/hc2/setpointOptimization /heatingCircuits/hc1/suWiThreshold /system/sensors/temperatures/switch /system/heatSources/hs1/nominalFuelConsumption /recordings/heatingCircuits/hc1/roomtemperature /system/holidayModes/hm4/assignedTo /gateway/instAccess /system/holidayModes/hm1/delete /gateway/DateTime /system/holidayModes/hm3 /system/holidayModes/hm3/hcMode /system/holidayModes/hm1/assignedTo /recordings/heatingCircuits/hc1 /system/systemType /heatingCircuits/hc2/suWiThreshold /recordings/system/sensors/temperatures /heatingCircuits/hc1/heatCurveMax /system/sensors/temperatures/hotWater_t2 /system/holidayModes/hm3/delete /system/holidayModes/hm1/hcMode /system/appliance/systemPressure /system/appliance/CHpumpModulation /system/heatSources/hs1/fuelConsmptCorrFactor /gateway /solarCircuits/sc1/dhwTankTemperature /heatSources/actualPower /heatSources/workingTime/centralHeating /heatingCircuits/hc1/suWiSwitchMode /system/heatSources/hs1/energyReservoir /recordings/heatSources /heatingCircuits/hc1/currentOpModeInfo /heatingCircuits/hc2/switchPrograms /system/bus /system/appliance/nominalBurnerLoad /heatingCircuits/hc2/currentRoomSetpoint /recordings/system/heatSources/hs1/actualPower /heatingCircuits/hc2/roomTempOffset /heatingCircuits/hc1/solarInfluence /heatingCircuits /heatSources/actualCHPower /recordings/heatSources/actualDHWPower /solarCircuits/sc2/status /recordings/system/sensors/temperatures/outdoor_t1 /heatSources/CHpumpModulation /system/appliance/workingTime /heatSources/systemPressure /heatSources/hs1/nominalFuelConsumption /heatSources/numberOfStarts /heatingCircuits/hc1/temperatureLevels/comfort2 /system/holidayModes/hm4/dhwMode /heatingCircuits/hc2/roomInfluence /heatingCircuits/hc1/heatCurveMin /notifications /gateway/firmware /system/info /solarCircuits/sc2/dhwTankTemperature /solarCircuits/sc2/collectorTemperature /heatingCircuits/hc2 /heatingCircuits/hc1/status /system/sensors/temperatures/chimney /solarCircuits/sc2 /heatingCircuits/hc2/currentOpModeInfo /heatingCircuits/hc1/roomTempOffset /gateway/instWriteAccess /gateway/haiPassword /heatSources/workingTime/secondBurner /heatingCircuits/hc1/controlType /system/brand /recordings/system/heatSources/hs1 /heatingCircuits/hc1/switchPrograms/B /system/holidayModes/hm4/delete /heatSources/workingTime /heatingCircuits/hc1/currentRoomSetpoint /system/heatSources/hs1/fuel /system/minOutdoorTemp /system/appliance/powerSetpoint /heatingCircuits/hc1/temperatureLevels /heatSources/hs1/reservoirAlert /system/holidayModes/hm1 /heatingCircuits/hc2/switchPrograms/A /recordings/system/sensors /system/holidayModes/hm4/startStop /system/holidayModes/hm2/startStop /heatSources/powerSetpoint /system/heatSources /system/holidayModes/hm2/delete /system/heatSources/hs1/fuel/caloricValue /heatingCircuits/hc1/setpointOptimization /heatingCircuits/hc1/actualSupplyTemperature /heatingCircuits/hc2/designTemp /solarCircuits/sc2/pumpModulation /heatingCircuits/hc2/roomtemperature /heatSources/hs1/actualPower /solarCircuits/sc1/pumpModulation /system/sensors/temperatures/supply_t1_setpoint /heatingCircuits/hc2/controlType /recordings/heatingCircuits /system/holidayModes/hm3/dhwMode /recordings/system /heatingCircuits/hc2/temporaryRoomSetpoint /heatingCircuits/hc2/temperatureLevels /heatingCircuits/hc2/operationMode /system/holidayModes/hm3/startStop /heatingCircuits/hc1 /heatingCircuits/hc1/manualRoomSetpoint /system/sensors/temperatures/supply_t1 /system/appliance/gasAirPressure /heatingCircuits/hc2/temperatureLevels/eco /heatSources/hs1/fuelConsmptCorrFactor /system/holidayModes/hm3/assignedTo /heatSources/flameStatus /system/holidayModes/hm1/startStop /heatingCircuits/hc1/temperatureLevels/night /system/holidayModes/hm2 /system/heatSources/hs1/actualModulation /system/sensors/temperatures /system /system/heatSources/hs1/fuel/density /solarCircuits /heatingCircuits/hc2/temperatureLevels/night /recordings/heatSources/actualCHPower /heatSources/nominalDHWPower /heatingCircuits/hc2/temperatureLevels/comfort2 /heatingCircuits/hc2/status /heatingCircuits/hc2/heatCurveMax /heatingCircuits/hc2/temperatureRoomSetpoint /system/appliance/flameStatus /solarCircuits/sc1 /heatingCircuits/hc2/temperatureLevels/day /heatingCircuits/hc2/manualRoomSetpoint /system/holidayModes/hm2/hcMode /heatingCircuits/hc1/switchPrograms /system/appliance/workingTime/centralHeating /heatingCircuits/hc2/pumpModulation /system/healthStatus /heatingCircuits/hc1/designTemp /gateway/versionFirmware /gateway/userpassword /heatingCircuits/hc2/switchPrograms/B /heatingCircuits/hc1/roomtemperature /recordings /heatingCircuits/hc2/fastHeatupFactor /system/sensors/temperatures/hotWater_t1 /heatingCircuits/hc1/operationMode /system/appliance/actualPower /solarCircuits/sc2/solarYield /system/holidayModes/hm2/assignedTo /solarCircuits/sc1/status /gateway/instPassword /system/holidayModes/hm1/dhwMode /system/appliance/flameCurrent /heatingCircuits/hc1/temperatureLevels/day /system/appliance/workingTime/totalSystem /system/sensors /system/appliance /system/heatSources/hs1 /system/appliance/ChimneySweeper /system/appliance/numberOfStarts /heatSources/workingTime/totalSystem /gateway/versionHardware /heatSources /system/heatSources/hs1/reservoirAlert /solarCircuits/sc1/collectorTemperature /solarCircuits/sc2/actuatorStatus /recordings/system/heatSources /system/sensors/temperatures/outdoor_t1 /system/appliance/workingTime/secondBurner /heatingCircuits/hc1/switchPrograms/A /recordings/heatSources/actualPower /heatSources/returnTemperature /heatingCircuits/hc1/activeSwitchProgram /heatSources/nominalCHPower /system/holidayModes/hm4 /heatSources/hs1/actualModulation /heatSources/hs1/energyReservoir /heatingCircuits/hc1/pumpModulation
bei "get mykm200/ heatingCircuits "kommt:
{"id":"/heatingCircuits","type":"refEnum","references":[{"id":"/heatingCircuits/hc1","uri":"
http://192.168.178.36/heatingCircuits/hc1"},{"id":"/heatingCircuits/hc2","uri":"
http://192.168.178.36/heatingCircuits/hc2"}]}
bei "get mykm200/ heatingCicuits/ hc1" kommt:
{"id":"/heatingCircuits/hc1","type":"refEnum","references":[{"id":"/heatingCircuits/hc1/operationMode","uri":"
http://192.168.178.36/heatingCircuits/hc1/operationMode"},{"id":"/heatingCircuits/hc1/activeSwitchProgram","uri":"
http://192.168.178.36/heatingCircuits/hc1/activeSwitchProgram"},{"id":"/heatingCircuits/hc1/switchPrograms","uri":"
http://192.168.178.36/heatingCircuits/hc1/switchPrograms"},{"id":"/heatingCircuits/hc1/temperatureLevels","uri":"
http://192.168.178.36/heatingCircuits/hc1/temperatureLevels"},{"id":"/heatingCircuits/hc1/heatingCurveSetting","uri":"
http://192.168.178.36/heatingCircuits/hc1/heatingCurveSetting"},{"id":"/heatingCircuits/hc1/holidayMode","uri":"
http://192.168.178.36/heatingCircuits/hc1/holidayMode"},{"id":"/heatingCircuits/hc1/status","uri":"
http://192.168.178.36/heatingCircuits/hc1/status"}]}
und bei "Get mykm200/system" kommt:
{"id":"/system","type":"refEnum","references":[{"id":"/system/brand","uri":"
http://192.168.178.36/system/brand"},{"id":"/system/bus","uri":"
http://192.168.178.36/system/bus"},{"id":"/system/systemType","uri":"
http://192.168.178.36/system/systemType"},{"id":"/system/sensors","uri":"
http://192.168.178.36/system/sensors"},{"id":"/system/appliance","uri":"
http://192.168.178.36/system/appliance"}]}
....und jetzt?
Grüsse.
Jörg
