[Gelöst] HTTPMOD Probleme mit der Website
Begonnen von raspklaus, 21 Juli 2014, 22:12:15
raspklaus
ich versuche gerade eine Website von einem Wiesemann&Theiss Thermometer auszulesen. Aber ich komme dabei nicht weiter.
Der Code:
define Servertemp HTTPMOD http://192.200.100.90/User.htm 600
attr Servertemp readingsName_Temp STemp
attr Servertemp readingsRegex_Temp <td class="bgAnLRed">Sensor)
attr Servertemp room System
attr Servertemp stateFormat STemp
attr Dieselpreis timeout 5
Das List:
   CHANGED
   DEF        http://192.200.100.90/User.htm 600
   Interval   600
   NAME       Servertemp
   NR         60
   STATE      STemp
   TYPE       HTTPMOD
   addr       http://192.200.100.90:80
   buf        HTTP/1.0 200 OK
Date: Mon, 21 Jul 2014 13:28:57 UTC
Last-Modified: Mon, 21 Jul 2014 13:28:56 UTC
Expires: Mon, 21 Jul 2014 13:28:57 UTC
Content-Length: 2808
Content-Type: text/html
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="style.css" type="text/css">
<title>USERUP</title>
</head>
<body>
<table border="0" cellpadding="0" cellspacing="0" width="600" align="center">
<tr><td colspan="3" align="center" class="size5"><b>User.htm</b></td></tr>
<tr><td colspan="3" align="center" class="size5"><b>Serverraum</b></td></tr>
<tr><td colspan="3" align="center" class="size4"> </td></tr>
<tr><td colspan="3">&nbsp;</td></tr>
<tr><td colspan="3" align="right"><p>last update: Mo, KW30,<br>21.07.2014 15:28:57&nbsp;* (UTC +02)</p></td></tr>
<tr>
<td colspan="3" align="center">
<table border="2">
<tr>
<th><a href="info.htm?Ili=0&amp;Ref=user.htm?Vpos=11669&amp;DTb=0&amp;">Sensor 1</a></th>
</tr>
<tr>
<td class="bgAnLRed">27,6 �C</td>
</tr>
<tr>
<th align="center">&Delta;T</th>
</tr>
<tr>
<td align="center" >  0,0 �C/min</td>
</tr>
</table></td>
</tr>
<tr>
<td align="center" colspan="3">&nbsp;</td>
</tr>
<tr>
<td colspan="3" align="center" class="size3"><b>Data Logger</b></td>
</tr>
<tr>
<table border="1">
<tr><td>
<form action="log.htm" method="POST" >
<table border="0" cellpadding="5%">
<tr>
<td align="center"><b>Ausgabe Datalogger</b></td>
</tr>
<tr>
<td align="center"><select name="DTb" size="1"><option selected value="4"> 60 Min</option></select></td>
</tr>
<tr>
<td align="center">
<input type="hidden" name="B2" value="&nbsp;&nbsp;OK&nbsp;&nbsp;"><input type="submit" name="B4" value="&nbsp;&nbsp;OK&nbsp;&nbsp;">
</td>
</tr>
</table></form>
</td>
<td>
<form action="thermo.csv" method="POST" >
<tr>
<td align="center"><b>Download Excelformat</b></td>
</tr>
<tr>
</tr>
<tr>
<td align="center">
</td>
</tr>
</table></form>
</td></tr>
</table>
</td>
</tr>
<tr><td align="center" colspan="3"><br><br><form action="user.htm" method="GET" ><input type="hidden" name="DTb" value="0"><input type="hidden" name="Vpos" value="11669"><input type="hidden" name="B2" value="Reload"><input type="submit" name="B4" value="Reload"></form></td></tr>
<tr><td align="center" colspan="3"><br><br><a href="index.htm" target="_top">zur&uuml;ck zur Web-Thermograph Homepage</a></td></tr>
</table>
</body>
</html>
   code       200
   conn
   displayurl http://192.200.100.90/User.htm
   host       192.200.100.90
   loglevel   4
   path       /User.htm
   protocol   http
   redirects  0
   timeout    2
   Readings:
   readingsRegex_Temp <td class="bgAnLRed">STemp[^0-9]+([0-9\.]+)
   room       System
   stateFormat STemp
   timeout    5
Es soll die Temperatur angezeigt werden
frank
versuche das:
attr Servertemp readingsRegex_Temp <td class="bgAnLRed">(.*)</td>
FHEM: 6.0(SVN) => Pi3(buster)
raspklaus
ok,
funktioniert fast  ;)
Es wird nun
27,6 �C
angezeigt. Das Fragezeichen steht anscheinend für das Gradzeichen. Wie bekomme ich das noch weg ?
frank
du hast doch sicherlich bemerkt, dass der text der durch "(.*)" ausgeblendet wird, in dein reading übernommen wird. wenn du weniger in deinem reading haben willst, musst du weniger ausblenden.
<td class="bgAnLRed">(.*) �C</td>
jetzt bekommst du nur den wert. die einheiten fügst du dann selber nach deinem geschmack zur "anzeige" hinzu.
attr Servertemp stateFormat meine_temperatur:STemp °C
raspklaus
Das funktioniert bei mir nicht. Es wird dann
meine_temperatur:27,7 �C °C
angezeigt
attr Servertemp readingsRegex_Temp <td class="bgAnLRed">(.*) �C</td>
Puschel74
da du 3 Stellen in deinem Reading haben willst kannst du ja auch (...) verwenden, oder nicht?
Wenn allerdings das Komma als ein Zeichen zählt musst du natürlich 4 Punkte machen.
Versuchs doch einfach mal.
Grüsse
justme1968
versuch es mal so: <td class="bgAnLRed">.*([\d.]*).*</td>
  andre
frank
hattest du denn auch 600 sekunden nach der änderung auf ein neues reading gewartet? ich glaube nicht.  ;)
raspklaus
Ich hatte gewartet. Habe es nun aber auf 60 Sekunden gesetzt
raspklaus
Fhem kann das � Zeichen nicht verarbeiten. Beide Versionen von oben ergeben:
HTTPMOD: Response didn't match Reading(s) STemp
Servertemp müsste mit einer Art Stringoperation bearbeitet werden so wie lstrg(4). Aber leider kenne ich zu wenig Perl um dies zu realisieren.
raspklaus
Die Funktion wäre :
  $Zeichen[$i] = substr($Satz,$i,1);
Aber wie das einbauen ?????????????????????????????????????
StefanStrobel
Eine Nachbearbeitung der Werte kann man mit ReadingsExpr machen.
Ist leider im Wiki noch nicht drin.
attr Servertemp readingsExpr_Temp substr($val, 1, 3)
oder ähnlich.
Naheliegender wäre es aber die Regex richtig hinzubiegen.
Die bisher genannten Beispiele sollten eigentlich funktionieren.
    Stefan
raspklaus
Die folgende Funktion brachte den Erfolg
attr Servertemp readingsExpr_Temp substr($val, 0, 4)
