UniPi - The Universal Raspberry Pi add-on board
Begonnen von betateilchen, 10 November 2014, 19:01:15
betateilchen
Demnächst in diesem Theater:
UniPi
Mal schauen, was sich damit anstellen lässt.
Hier werde ich jeweils den aktuellen Status der Implementierung bereitstellen.
UniPi Hardware: working out-of-the-box, when connected to RaspberryPi
apt-get install i2c-tools libi2c-dev
# i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- 18 -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 51 52 53 54 55 56 57 -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- 6f
Connecting UniPi to fhem - working out-of-the box
define i2c RPII2C 1
(http://up.picr.de/20123689pf.png)
Available i2c-devices
(http://up.picr.de/20123521xj.png)
to be checked: are there really two devices on address 0x57?
Hardware Clock: working in operation system, no need to be implemented in fhem.
# echo mcp7941x 0x6f > /sys/bus/i2c/devices/i2c-1/new_device
# hwclock -r
Mo 01 Jan 2001 01:00:02 CET  -0.512983 seconds
# hwclock -w
# hwclock -r
Fr 14 Nov 2014 19:33:58 CET  -0.512091 seconds
Relay via MCP23008 - working
New module 52_I2C_MCP23008 released 2014-11-18.
define relais I2C_MCP23008 32
attr relais IODev i2c
attr relais OutputPorts A0,A1,A2,A3,A4,A5,A6,A7
attr relais comment A0=Relay8 A1=Relay7 A2=Relay6 A3=Relay5 A4=Relay4 A5=Relay3 A6=Relay2 A7=Relay1
(http://up.picr.de/20342550zv.jpg)
1-wire - working with owfs
1. Install debian packages for owfs
dpkg -i owserver_2.8p17-1_armhf.deb libow-2.8-17_2.8p17-1_armhf.deb owfs-common_2.8p17-1_all.deb owhttpd_2.8p17-1_armhf.deb
2. Modify configuration file /etc/owfs.conf
  server: device = /dev/i2c-1
  http: port = 2121
  ftp: port = 2120
  server: port = localhost:4304
  Celsius
3. define 1-wire Master in fhem
define OWSERVER OWServer localhost:4304
4. check for available devices
get OWSERVER devices
Result: 28.DB9453060000 DS18B20
5. define 1-wire Device in fhem
define sensor OWDevice 28.DB9453060000 60
Result:
(http://up.picr.de/20237554bx.png)
tomster
Das Ding gibt es aber schon länger...
Allerdings scheinen alle meine Browser den Seitenquelltext nicht zu verstehen. Ich kann mit keinem Scrollen.
--edit--
Ok, mein Fehler. Hatte das Designelement "Scrollbar" nicht gefunden...
betateilchen
Ich hab ja nicht gesagt, dass das Board neu ist. Aber nun geht es darum, hier in der Community ein möglichst vollständiges fhem Modul dafür zu bauen.
tomster
#3
Das stimmt allerdings. Ich bin ehrlich gesagt aber doch ein Stück verwundert, dass sich bislang noch keiner dieses Boards angenommen hat.
Wenn das Ding noch eine Art CSM on-board hätte, wär's nahe an der eierlegenden Wollmilchsau. Ich vermute nämlich, dass bei Hutschieneneinbau nicht genug Platz im E-Kasten ist, um einen Stick an die USB-Ports anzustecken...
Nun ja, vielleicht geht's ja über den eingebauten UART-Port...
betateilchen
Vermutlich eine Preisfrage.
betateilchen
Willst Du testen? => email hier über das Forum an mich schicken.
betateilchen
Trari trara, die Post ist da...
Das Ding ist ja echt riesengroß...
(http://up.picr.de/20120979po.jpg)
(http://up.picr.de/20120980xq.jpg)
(http://up.picr.de/20120981vc.jpg)
tomster
klausw
Ich bin gespannt, müsste die nächsten Tage auch kommen...
RasPi B v2 mit FHEM 18B20 über 1Wire, LED PWM Treiber über I2C, Luchtdruck-, Feuchtesensor und ein paar Schalter/LED\'s zum testen
Module: RPI_GPIO, RPII2C, I2C_EEPROM, I2C_MCP23008, I2C_MCP23017, I2C_MCP342x, I2C_PCA9532, I2C_PCF8574, I2C_SHT21, I2C_BME280
betateilchen
im Moment suche ich grade ein Netzteil mit passendem Stecker... Warum konnte man statt der Buchse nicht einfach noch zwei weitere Schraubklemmen auf das Board montieren *grummel*
klausw
Was schneidest Du auch immer die Stecker ab  8)
Wird das Pi eigentlich mit über das Board versorgt?
betateilchen
Ich hab keinen Stecker abgeschnitten.
Die Spannungsversorgung kann man per Jumper einstellen. Das UniPi kann den Raspi mit versorgen.
klausw
Meins ist auch da.
Jetzt weisst ich, was Du meinst. Ich habe nur 12V Netzteile mit Stecker :-\
betateilchen
out-of-the-box:
# i2cdetect -y 1
alles gefunden, was auf dem Board drauf ist  8)
betateilchen
@Klaus: Wichtiger Hinweis: mach erst die CR2032 auf das Board, bevor Du Spannung anlegst.
