[gelöst]Sehr häufige Meldung im Logfile
Begonnen von bm7777, 15 November 2014, 23:08:00
bm7777
in meinem Logfile werden ständig diese Meldungen generiert. Was bedeuten sie genau und wenn es "harmlose" Meldungen sind, kann ich Sie minimieren ?
2014.11.15 22:49:42 4: CUL_Parse: SCC A 14 57 845E 285664 000000 81732C00000B0024090103F8 -78
2014.11.15 22:49:42 5: SCC dispatch A1457845E28566400000081732C00000B0024090103::-78:SCC
2014.11.15 22:51:28 5: CUL/RAW: /A1483845
2014.11.15 22:51:28 5: CUL/RAW: A1483845/E2A4FDB0
2014.11.15 22:51:28 5: CUL/RAW: A1483845E2A4FDB0/0000089601F001CD
2014.11.15 22:51:28 5: CUL/RAW: A1483845E2A4FDB00000089601F001CD/10152090
2014.11.15 22:51:28 5: CUL/RAW: A1483845E2A4FDB00000089601F001CD10152090/902FA
2014.11.15 22:51:28 4: CUL_Parse: SCC A 14 83 845E 2A4FDB 000000 89601F001CD10152090902FA -77
2014.11.15 22:51:28 5: SCC dispatch A1483845E2A4FDB00000089601F001CD10152090902::-77:SCC
2014.11.15 22:52:24 5: CUL/RAW: /A1458845
2014.11.15 22:52:24 5: CUL/RAW: A1458845/E2856640
2014.11.15 22:52:24 5: CUL/RAW: A1458845E2856640/0000081732C00000
2014.11.15 22:52:24 5: CUL/RAW: A1458845E28566400000081732C00000/A0024090
2014.11.15 22:52:24 5: CUL/RAW: A1458845E28566400000081732C00000A0024090/004F9
2014.11.15 22:52:24 4: CUL_Parse: SCC A 14 58 845E 285664 000000 81732C00000A0024090004F9 -77.5
2014.11.15 22:52:24 5: SCC dispatch A1458845E28566400000081732C00000A0024090004::-77.5:SCC
2014.11.15 22:53:41 5: CUL/RAW: /A1484845E2A4FDB00000089603A001C8E0150090803FB
2014.11.15 22:53:41 4: CUL_Parse: SCC A 14 84 845E 2A4FDB 000000 89603A001C8E0150090803FB -76.5
2014.11.15 22:53:41 5: SCC dispatch A1484845E2A4FDB00000089603A001C8E0150090803::-76.5:SCC
2014.11.15 22:54:50 5: CUL/RAW: /A1459845
2014.11.15 22:54:50 5: CUL/RAW: A1459845/E2856640
2014.11.15 22:54:50 5: CUL/RAW: A1459845E2856640/0000081732C00000
2014.11.15 22:54:50 5: CUL/RAW: A1459845E28566400000081732C00000/B002408F
2014.11.15 22:54:50 5: CUL/RAW: A1459845E28566400000081732C00000B002408F/F02F8
Version
$Id: fhem.pl 6913 2014-11-08 10:32:44Z rudolfkoenig $
# $Id: 00_CUL.pm 6755 2014-10-12 13:12:10Z rudolfkoenig $
# $Id: 15_CUL_EM.pm 6825 2014-10-28 09:25:24Z arnoaugustin $
# $Id: 10_CUL_HM.pm 6863 2014-11-02 09:04:57Z martinp876 $
# $Id: 57_Calendar.pm 6742 2014-10-11 17:39:02Z borisneubert $
# $Id: 01_FHEMWEB.pm 6884 2014-11-04 22:03:52Z rudolfkoenig $
# $Id: 95_FLOORPLAN.pm 6174 2014-06-29 05:51:28Z ulimaass $
# $Id: 10_FS20.pm 5326 2014-03-26 07:15:25Z rudolfkoenig $
# $Id: 92_FileLog.pm 6769 2014-10-15 17:03:30Z rudolfkoenig $
# $Id: 55_GDS.pm 6798 2014-10-21 14:13:31Z betateilchen $
# $Id: 98_HTTPMOD.pm 6463 2014-08-26 16:14:30Z ststrobel $
# $Id: 02_HTTPSRV.pm 3830 2013-08-31 17:09:10Z borisneubert $
# $Id: 73_PRESENCE.pm 6950 2014-11-11 21:09:42Z markusbloch $
# $Id: 02_RSS.pm 6543 2014-09-12 15:13:15Z borisneubert $
# $Id: 16_STACKABLE_CC.pm 6190 2014-07-03 11:41:05Z rudolfkoenig $
# $Id: 99_SUNRISE_EL.pm 6765 2014-10-14 18:24:29Z rudolfkoenig $
# $Id: 98_SVG.pm 6756 2014-10-12 13:13:26Z rudolfkoenig $
# $Id: 42_SYSMON.pm 6970 2014-11-14 20:01:35Z hexenmeister $
# $Id: 59_Twilight.pm 6953 2014-11-11 23:04:30Z mrp666 $
# $Id: 99_Utils.pm 6660 2014-10-03 06:35:43Z rudolfkoenig $
# $Id: 59_Weather.pm 6705 2014-10-07 17:41:42Z borisneubert $
# $Id: 32_WifiLight.pm 68 2013-12-08 08:00:00Z herrmannj $
# $Id: 90_at.pm 6797 2014-10-21 12:32:19Z rudolfkoenig $
# $Id: 98_autocreate.pm 6505 2014-09-06 12:24:48Z rudolfkoenig $
# $Id: 98_dummy.pm 4934 2014-02-15 08:23:12Z rudolfkoenig $
# $Id: 91_eventTypes.pm 6792 2014-10-19 16:03:13Z rudolfkoenig $
# $Id: 91_notify.pm 6371 2014-08-07 05:33:37Z rudolfkoenig $
# $Id: 33_readingsGroup.pm 6262 2014-07-16 07:46:03Z justme1968 $
# $Id: 98_telnet.pm 6611 2014-09-24 07:48:32Z rudolfkoenig $
# $Id: 91_watchdog.pm 5622 2014-04-24 08:04:29Z rudolfkoenig $
./FHEM/95_webViewControl.pm: No such file or directory
# $Id: 98_weblink.pm 5608 2014-04-23 10:57:16Z rudolfkoenig $
Im Einsatz habe ich einen Rasberry PI mit 2 stapelbaren CC1101 Transceiver und einem CUL. Ich habe Homematic sowie F20 Devices und eine EnergieCam.
Viele Grüße,
Beate
Raspberry Pi Mod. B
CUL-Stick V3.4
betateilchen
Die Meldungen zeigen an, was in fhem "passiert" und werden in dieser Ausführlichkeit nur zum Debuggen gebraucht.
Vielleicht solltest Du Dein fhem einfach im Loglevel 3 anstatt 5 laufen lassen.
bm7777
 Ich habe die ganze Zeit nur nach dem global Verbose geschaut , doof. Hatte wohl mal den SCC auf Verbose 3 gestellt und es vergessen.  :o. Danke
Viele Grüße,
Beate
Raspberry Pi Mod. B
CUL-Stick V3.4
