Autor Thema: how to create a gplot for the keymatic  (Gelesen 2649 mal)
Offline alex
  • New Member
« am: 17 November 2014, 16:45:04 »
Hello,
I have installed the keymatic from Homematic and now I would like to create a plot which displays when the door is locked or unlocked. I tried the following gplot syntax but it doesn't show the correct information. And now I'm using two FileLog entries, but I think I need to use only one if I would like to display the locked/unlocked status by lines or bars.
Who can point me in the right direction?
Thanks,
Alex
# Created by FHEM/98_SVG.pm, 2014-11-17 16:39:40
set output '<OUT>.png'
set xdata time
set xlabel " "
set title '<L1>'
set ytics ("locked" 1.5, "unlocked" 0.3)
set y2tics ("locked" 0.3, "unlocked" 1.5)
set grid
set ylabel "Status"
set y2label "Status"
set yrange [-0.1:2]
set y2range [-0.1:2]
#FileLog 3:key.washok.lock\x3a:0:$fld[3]=~"locked"?1.5:-0.2
#FileLog 3:key.washok.lock\x3a:0:$fld[3]=~"unlocked"?0.3:-1
plot "<IN>" using 1:2 axes x1y1 title 'Locked' ls l0fill lw 2 with points,\
     "<IN>" using 1:2 axes x1y2 title 'Unlocked' ls l1fill lw 2 with points
Offline rudolfkoenig
  • Administrator
Antw:how to create a gplot for the keymatic
« Antwort #1 am: 17 November 2014, 16:59:33 »
I strongly recommend using the Plot-Editor by creating a new plot from the FileLog Detail-View in FHEMWEB.
Offline alex
  • New Member
« Antwort #2 am: 18 November 2014, 21:13:29 »
I thought I started from there creating the SVG plot.
Anyway, I created a new plot from the FileLog screen with the command 'Create SVG Plot'. From there I started entering the details but I still don't get the result that I want and that is:
A simple line in time that shows the different possible status of the keymatic: locked, unlocked, locked (uncertain), unlocked (uncertain).
Even trying to get only the 'locked' status in a plot result in some strange behaviour as it seems that is also includes the 'unlocked' lines:
With below logfile and gplot the graph shows 3 dots on 20.03, 20.44 and 20.57 while it should show the dot at 20.03.
What am I doing wrong?
(and yes, I've updated fhem to the latest version
Logfile:
2014-11-18_20:03:45 key.washok battery: ok
2014-11-18_20:03:45 key.washok uncertain: no
2014-11-18_20:03:45 key.washok direction: none
2014-11-18_20:03:45 key.washok error: none
2014-11-18_20:03:45 key.washok lock: unlocked
2014-11-18_20:03:45 key.washok unlocked
2014-11-18_20:44:13 key.washok set_lock
2014-11-18_20:44:14 key.washok aesKeyNbr: 00
2014-11-18_20:44:15 key.washok battery: ok
2014-11-18_20:44:15 key.washok uncertain: yes
2014-11-18_20:44:15 key.washok direction: down
2014-11-18_20:44:15 key.washok error: none
2014-11-18_20:44:15 key.washok lock: unlocked
2014-11-18_20:44:15 key.washok unlocked (uncertain)
2014-11-18_20:44:23 key.washok battery: ok
2014-11-18_20:44:23 key.washok uncertain: no
2014-11-18_20:44:23 key.washok direction: none
2014-11-18_20:44:23 key.washok error: none
2014-11-18_20:44:23 key.washok lock: locked
2014-11-18_20:44:23 key.washok locked
2014-11-18_20:57:29 key.washok battery: ok
2014-11-18_20:57:29 key.washok uncertain: no
2014-11-18_20:57:29 key.washok direction: none
2014-11-18_20:57:29 key.washok error: none
2014-11-18_20:57:29 key.washok lock: locked
2014-11-18_20:57:29 key.washok locked
Gplot file:
# Created by FHEM/98_SVG.pm, 2014-11-18 21:00:07
set xdata time
set xlabel " "
set title '<TL>'
set y2tics
set grid
set ylabel "Status"
set y2label "Temperature"
set yrange [-0.1:2]
#FileLog 3:key.washok.lock\x3a::$fld[3]=~"locked"?1.5:0
plot "<IN>" using 1:2 axes x1y1 title 'Line 1' ls l0 lw 1 with points
  • Administrator
« Antwort #3 am: 19 November 2014, 09:20:31 »
$fld[3]=~"locked" will also match "unlocked".
You probably should use $fld[3]=~"^locked"
Offline alex
  • New Member
« Antwort #4 am: 20 November 2014, 14:21:26 »
How simple can it be  :D Thanks, that part works now.
And I started directly to study a bit more on the rexexp possibilities.
Alex
decade-submarginal
