Vorstellung FHEM iOS APP
Begonnen von ak0815, 08 Januar 2015, 12:02:50
ak0815
Zitat von: deluxe41 am 11 Januar 2015, 18:34:14
Das kommt bei meiner Avm Steckdose :
Sorry, hab die Zahl vertauscht...
  "Arg":"FBDECT_16",
  "Results": [
    "Name":"FBDECT_16",
    "PossibleSets":"msgInterval off on blink toggle on-for-timer on-till off-for-timer intervals off-till",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings IODev do_not_notify:1,0 ignore:1,0 dummy:1,0 showtime:1,0 event-on-change-reading event-on-update-reading event-min-interval stateFormat model:Dect200,Powerline546E alarmDevice alarmSettings devStateIcon devStateStyle fp_Heizkoerper fp_Kinderzimmer fp_Wohnzimmer fp_plotsplan fp_test3 fp_test4 fp_test5 icon sortby webCmd widgetOverride userattr",
    "Internals": {
      "CHANGED": "null",
      "DEF": "16 powerMeter,switch",
      "LASTInputDev": "fbaha",
      "MSGCNT": "4763",
      "NAME": "FBDECT_16",
      "NR": "191",
      "STATE": "off",
      "TYPE": "FBDECT",
      "fbaha_MSGCNT": "4763",
      "fbaha_RAWMSG": "0703001c00000053001000000000000c000000160004000000000000",
      "fbaha_TIME": "2015-01-11 19:44:07",
      "id": "16",
      "props": "powerMeter,switch"
    "Readings": {
      "AktuellerBetriebEur": { "Value":"0", "Time":"2014-12-05 11:39:00" },
      "control": { "Value":"on fn=1 > 0.00 delay:0sec do:state off", "Time":"2015-01-10 16:05:10" },
      "current": { "Value":"0.0000 A", "Time":"2015-01-11 19:44:07" },
      "energy": { "Value":"457255 Wh", "Time":"2015-01-11 19:44:07" },
      "options": { "Value":"powerOnState:last,lock:none", "Time":"2015-01-10 16:05:09" },
      "power": { "Value":"0.00 W", "Time":"2015-01-11 19:44:07" },
      "powerFactor": { "Value":"0.000", "Time":"2015-01-11 19:44:07" },
      "relayTimes": { "Value":"disabled", "Time":"2014-09-15 18:45:27" },
      "state": { "Value":"off", "Time":"2015-01-11 19:44:07" },
      "tempadjust": { "Value":"0.0 C", "Time":"2015-01-10 16:05:09" },
      "temperature": { "Value":"22.1 C (measured)", "Time":"2015-01-11 19:44:07" },
      "voltage": { "Value":"227.277 V", "Time":"2015-01-11 19:44:07" }
    "Attributes": {
      "IODev": "fbaha",
      "devStateIcon": ".*off:it_television@black .*on:it_television@red",
      "event-min-interval": "power:120",
      "event-on-change-reading": "state",
      "fp_Wohnzimmer": "125,363,0,",
      "fp_test3": "127,569,0,",
      "fp_test5": "71,326,0,",
      "room": "1_Iphone"
  "totalResultsReturned":1
Sent from my iPhone using Tapatalk
Ist in der nächsten Version verfügbar.
FHEM APP für iOS
http://apple.co/1F7gNYu
ak0815
Zitat von: Blackcat am 12 Januar 2015, 10:18:37
wenn ihr noch einen Tester für iOS 6 sucht, könnte ich mit folgenden Geräten helfen:
iPhone 5, iPad mini, iPad 4
meine Hardware besteht aus Milights und Homematic Thermostaten
edit: habe gerade gelesen, dass es erst ab iOS 7 geht .... schade
wenn du mir eine PN mit deiner iTunes Email schickst füge ich dich hinzu.
Ja erst ab iOS7.
Andy
FHEM APP für iOS
ak0815
#47
ich habe das Update (v0.0.2.1.3) bei Apple eingereicht. Müsste in den nächsten Stunden freigegeben werden.
Changelog:
- Fehler Raumanzeige wenn Device nicht unterstützt wird
- MAX Thermostat Unterstützung - bitte testen
- Engima2 Unterstützung - bitte testen
- Sonos Unterstützung - bitte testen
- Dummy Erkennung
- AVM Power,Switch Steckdose Unterstützung - bitte testen
- iOS7 Background Problem
- HM_HM_CC_RT_DN Unterstützung - bitte testen
- HM-TC-IT-WM-W-EU Unterstützung - bitte testen
- FS20 Steckdose Unterstützung - bitte testen
- Harmony Befehlsliste
- Hue Livingcolors Unterstützung - bitte testen
- Hue Iris Unterstützung - bitte testen
Andy
FHEM APP für iOS
Mitch
Gerade mal auf die Schnelle getestet:
- Dummy: geht nicht
- FHT: geht nicht
- Sonso: lädt sich am Raum "tot"
- FS20: geht nur teilweise
- Keymatic: geht nicht
- KS300: geht nicht
- fhem2fhem: geht nicht
- FHEMduino: geht nicht
- FritzDECT: geht nicht
- Plots: gehen nicht
-ReadingsGroup: geht nicht
Ein Raum wo auch Squeeze drinnen ist lädt sich tot
Werde weiter testen.
FHEM im Proxmox Container
ak0815
#49
- Dummy: geht nicht
- FHT: geht nicht
- KS300: geht nicht
Danke!
- Dummy: mein Fehler - ist gefixt
- FHT: kannst du mir die Raum JSON senden?
- Sonso: kannst du mir die Raum JSON senden?
- FS20: Welche gehen nicht?
- Keymatic: nicht implementiert - Kannst du mir die JSON schicken?
- KS300: nicht implementiert - Kannst du mir die JSON schicken?
- fhem2fhem: derzeit nicht vorgesehen
- FHEMduino: nicht implementiert - Kannst du mir die JSON schicken? bzw. mehr Infos dazu
- FritzDECT: nicht implementiert - Kannst du mir die JSON schicken?
- Plots: derzeit nicht vorgesehen
- ReadingsGroup: derzeit nicht vorgesehen
Andy
FHEM APP für iOS
Mitch
FS20:
z.B. ein FS20 Unterputz-Wechselschalter FS20 UWS geht nicht oder ein Steckdosendimmer
Die jsonlist2 schicken ich per PN (ist mir lieber  8) )
Wie machen ich ein jsonlist2  auf einen Raum?
PSBC
Zitat von: Mitch am 12 Januar 2015, 14:52:30
FS20:
Hallo Mitch,
ein Raum kannst du so abfragen. Hier ein Beispiel mit Bad
http://IP:Port/fhem?cmd=jsonlist2%20room=Bad
Patric
Mitch
Sehr peinlich  :-[
Danke, hätte cih auch selber drauf kommen können  ;D
ak0815
ich habe ein Update hochgeladen.
Changelog:
- Dummy Bug behoben
- Sonos Bug behoben
- Keymatic hinzugefügt - bitte testen
Andy
FHEM APP für iOS
Mitch
Danke Andy.
Sobald in TF verfügbar werde ich testen.
FloZi
Mein Bericht:
(V0.0.2.1.3)
FB Dect: geht gar nichts
HUE (Bulb/Bloom/Stripe/LW-Dimmer: geht perfekt
LightScene: geht
INtertechno Steckdosen: geht nichts
Homematic Heizkörperthermostat: beim speichern einer neuen Temp. bleibts im speichern Fenster stehen (siehe Anhang)
Bei nicht unterst. Devices wird nur der Name angezeigt, aber kein Aufhängen oder totladen (Screenshot)
weiter bin ich leider noch nicht gekommen.
lg FloZi
ak0815
Zitat von: Mitch am 12 Januar 2015, 16:58:46
Danke Andy.
Danke dir!
Bei Sonos kommen noch Features dazu. Die mache ich morgen - Playlist abspielen,...
Andy
FHEM APP für iOS
ak0815
Zitat von: FloZi am 12 Januar 2015, 17:11:12
Mein Bericht:
(V0.0.2.1.3)
LightScene: geht
lg FloZi
Hallo FloZi,
Vielen Dank.
FB Dect: Da habe ich noch nichts gemacht. Werde ich die Tage einbauen.
INtertechno Steckdosen: Kannst du mir dazu ne JSON schicken?
Homematic Heizkörperthermostat: Welches Modell ist es genau? Kannst du mir auch ne JSON dazu senden?
Danke & Gruß
Andy
FHEM APP für iOS
FloZi
selbstverfreilich...
Die Intertechno Steckdosen sind keine echten sondern nachgebaute von ELRO (http://www.fhemwiki.de/wiki/Intertechno_Code_Berechnung#Elro_AB440)
  "Arg":"Wohnzimmer.Licht.Schreibtisch.Weiss",
  "Results": [
    "Name":"Wohnzimmer.Licht.Schreibtisch.Weiss",
    "PossibleSets":"off:noArg on:noArg  blink toggle on-for-timer on-till off-for-timer intervals off-till",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings IODev ITfrequency ITrepetition switch_rfmode:1,0 do_not_notify:1,0 ignore:0,1 dummy:1,0 model:itremote,itswitch,itdimmer loglevel:0,1,2,3,4,5,6 devStateIcon devStateStyle fm_type icon sortby webCmd widgetOverride Wohnzimmer.Licht.Couch Wohnzimmer.Licht.Couch_map lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0 structexclude userattr",
    "Internals": {
      "DEF": "00000FFFF0 FF F0",
      "NAME": "Wohnzimmer.Licht.Schreibtisch.Weiss",
      "NR": "265",
      "STATE": "off",
      "TYPE": "IT",
      "XMIT": "00000ffff0",
      "XMITdimdown": "00",
      "XMITdimup": "00",
      "XMIToff": "f0",
      "XMITon": "ff"
    "Readings": {
      "state": { "Value":"off", "Time":"2015-01-12 17:02:47" }
    "Attributes": {
      "IODev": "CUL",
      "Wohnzimmer.Licht.Couch": "STR.Wohnzimmer.Licht",
      "alias": "Licht.Schreibtisch.Weiss",
      "group": "Licht,Steckdosen",
      "model": "itswitch",
      "room": "Wohnzimmer,Schreibtisch,TEST",
      "userattr": "Wohnzimmer.Licht.Couch Wohnzimmer.Licht.Couch_map lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0 structexclude"
Das Thermostat ist das HM-CC-RT-DN
  "Arg":"Wohnzimmer.Thermostat",
  "Results": [
    "Name":"Wohnzimmer.Thermostat",
    "PossibleSets":"burstXmit clear:readings,trigger,register,rssi,msgEvents,all fwUpdate getConfig getRegRaw inhibit:on,off raw regBulk regSet reset sysTime unpair",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_off,1_on,2_full param ignore:1,0 dummy:1,0 IODev IOList IOgrp actCycle hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger rssiLog:1,0 serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesCommReq:1,0 repPeers peerIDs tempListTmpl levelRange levelMap event-on-change-reading event-on-update-reading event-min-interval stateFormat model:ASH550,ASH550I,CCU-FHEM,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-RT-DN,HM-CC-RT-DN-BoM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-Dis-WM55,HM-ES-PMSw1-Pl,HM-ES-PMSw1-Pl-DN-R1,HM-ES-PMSw1-Pl-DN-R3,HM-ES-PMSw1-Pl-DN-R4,HM-ES-PMSw1-Pl-DN-R5,HM-ES-TX-WM,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1-FM-2,HM-LC-Bl1-SM-2,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1L-CV-2,HM-LC-Dim1L-CV-644,HM-LC-Dim1L-Pl-2,HM-LC-Dim1L-Pl-3,HM-LC-Dim1L-Pl-644,HM-LC-Dim1PWM-CV,HM-LC-Dim1PWM-CV-2,HM-LC-Dim1T-CV-2,HM-LC-Dim1T-CV-644,HM-LC-Dim1T-FM-2,HM-LC-Dim1T-FM-644,HM-LC-Dim1T-Pl-2,HM-LC-Dim1T-Pl-3,HM-LC-Dim1T-Pl-644,HM-LC-Dim1TPBU-FM,HM-LC-Dim1TPBU-FM-2,HM-LC-Dim2L-SM-2,HM-LC-Dim2L-SM-644,HM-LC-Dim2T-SM,HM-LC-Dim2T-SM-2,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1-FM-2,HM-LC-Sw1-Pl-3,HM-LC-Sw1-Pl-DN-R1,HM-LC-Sw1-Pl-DN-R2,HM-LC-Sw1-Pl-DN-R3,HM-LC-Sw1-Pl-DN-R4,HM-LC-Sw1-Pl-DN-R5,HM-LC-Sw1-SM-2,HM-LC-Sw1PBU-FM,HM-LC-Sw2-DR-2,HM-LC-Sw2-FM-2,HM-LC-Sw4-DR-2,HM-LC-Sw4-PCB-2,HM-LC-Sw4-SM-2,HM-LC-Sw4-WM-2,HM-MOD-Em-8,HM-MOD-Re-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-4,HM-RC-4-2,HM-RC-4-B,HM-RC-8,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-Key4-2,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-Sec4-2,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-RHS,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCo,HM-SEC-SD,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sen-DB-PCB,HM-Sen-MDIR-O,HM-Sen-MDIR-O-2,HM-Sen-MDIR-WM55,HM-Sen-RD-O,HM-Sen-Wa-Od,HM-Sys-sRP-Pl,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550Tech,IS-WDS-TH-OD-S-R3,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,KS550LC,KS550TECH,KS888,PS-Th-Sens,PS-switch,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-130,Schueco_263-131,Schueco_263-132,Schueco_263-133,Schueco_263-134,Schueco_263-135,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-147,Schueco_263-155,Schueco_263-158,Schueco_263-160,Schueco_263-162,Schueco_263-167,Schueco_263-xxx,WDF-solar,WS888 subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,keyMatic,motionAndBtn,motionDetector,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,sensRain,sensor,singleButton,smokeDetector,swi,switch,thermostat,threeStateSensor,tipTronic,virtual,winMatic devStateIcon devStateStyle fm_type icon sortby webCmd widgetOverride userattr",
    "Internals": {
      "DEF": "2EEAEA",
      "HMLAN_MSGCNT": "104",
      "HMLAN_RAWMSG": "E2EEAEA,0000,0BC404B1,FF,FFCC,1486102EEAEA0000000AA8E4101640",
      "HMLAN_RSSI": "-52",
      "HMLAN_TIME": "2015-01-12 17:28:39",
      "LASTInputDev": "HMLAN",
      "MSGCNT": "104",
      "NAME": "Wohnzimmer.Thermostat",
      "NR": "198",
      "STATE": "CMDs_done",
      "TYPE": "CUL_HM",
      "channel_01": "Wohnzimmer.Thermostat_Weather",
      "channel_02": "Wohnzimmer.Thermostat_Climate",
      "channel_03": "Wohnzimmer.Thermostat_WindowRec",
      "channel_04": "Wohnzimmer.Thermostat_Clima",
      "channel_05": "Wohnzimmer.Thermostat_ClimaTeam",
      "channel_06": "Wohnzimmer.Thermostat_remote",
      "lastMsg": "No:14 - t:10 s:2EEAEA d:000000 0AA8E4101640",
      "protLastRcv": "2015-01-12 17:28:39",
      "protSnd": "3 last_at:2015-01-12 17:08:49",
      "protState": "CMDs_done",
      "rssi_at_HMLAN": "avg:-51.51 min:-65 max:-49 lst:-52 cnt:104 "
    "Readings": {
      "Activity": { "Value":"alive", "Time":"2015-01-12 13:25:58" },
      "CommandAccepted": { "Value":"yes", "Time":"2015-01-12 11:44:51" },
      "D-firmware": { "Value":"1.3", "Time":"2015-01-08 19:21:49" },
      "D-serialNr": { "Value":"LEQ0781583", "Time":"2015-01-08 19:21:49" },
      "PairedTo": { "Value":"0x29A28E", "Time":"2015-01-11 13:28:03" },
      "R-backOnTime": { "Value":"10 s", "Time":"2015-01-08 19:21:51" },
      "R-btnLock": { "Value":"off", "Time":"2015-01-08 19:21:51" },
      "R-burstRx": { "Value":"on", "Time":"2015-01-08 19:21:51" },
      "R-cyclicInfoMsg": { "Value":"on", "Time":"2015-01-08 19:21:51" },
      "R-globalBtnLock": { "Value":"off", "Time":"2015-01-08 19:21:51" },
      "R-localResDis": { "Value":"off", "Time":"2015-01-08 19:21:51" },
      "R-lowBatLimitRT": { "Value":"2.1 V", "Time":"2015-01-08 19:21:51" },
      "R-modusBtnLock": { "Value":"off", "Time":"2015-01-08 19:21:51" },
      "R-pairCentral": { "Value":"0x29A28E", "Time":"2015-01-08 19:21:51" },
      "RegL_00:": { "Value":"01:01 02:01 09:01 0A:29 0B:A2 0C:8E 0E:0A 0F:00  11:00 12:15 16:00 18:00 19:00 1A:00 00:00", "Time":"2015-01-11 13:28:03" },
      "RegL_07:": { "Value":"0 CA:11 CB:20 CC:27", "Time":"2015-01-12 17:08:49" },
      "actuator": { "Value":"22", "Time":"2015-01-12 17:28:39" },
      "battery": { "Value":"ok", "Time":"2015-01-12 11:44:52" },
      "batteryLevel": { "Value":"3.1", "Time":"2015-01-12 17:28:39" },
      "desired-temp": { "Value":"21.0", "Time":"2015-01-12 17:28:39" },
      "measured-temp": { "Value":"22.8", "Time":"2015-01-12 17:28:39" },
      "state": { "Value":"CMDs_done", "Time":"2015-01-12 17:08:49" },
      "time-request": { "Value":"-", "Time":"2015-01-12 14:23:45" }
    "Attributes": {
      "IODev": "HMLAN",
      "actCycle": "000:10",
      "actStatus": "alive",
      "autoReadReg": "4_reqStatus",
      "expert": "2_full",
      "firmware": "1.3",
      "group": "Heizung",
      "model": "HM-CC-RT-DN",
      "room": ".Heizung,Wohnzimmer,TEST",
      "serialNr": "LEQ0781583",
      "subType": "thermostat",
      "webCmd": "getConfig:clear msgEvents:burstXmit"
ak0815
Perfekt danke. Das Thermostat Problem habe ich schon gefixt.
Andy
FHEM APP für iOS
