FHEM - Anwendungen > Heizungssteuerung/Raumklima
THZ Tecalor (LWZ Stiebel Eltron) module support and code improvement.
<< < (214/216) > >>
Noobie47:
Yes, anyone with need for help, also in german language, is welcome, but i am afraid i am only a very shallow user who can only convert hints from others. But maybe this enough to help others.  8)
Now i get those values, please see attachment. Why does the plotting stop at 04:30 hrs?
Noobie47:
Hi, at the end i made fhem work and it runs, but the heating temperature range is too low for plotting. How can i adjust the plotting to show temperature above 32 Celsius?
Update: i found the editor and changed the range from 32 celsius to 44 celsius and used the button write gplot. now i see  the plotting.
Noobie47:
Hi, has  anyone an idea what is the reason for this error message? It appears almost exactly every 2 minutes.
msg2:  decode: command not known -- D1 -> 0103D5D11003
My Config looks like this with the kind help from immi:
--- Code: --- attr global userattr cmdIcon devStateIcon:textField-long devStateStyle icon sortby webCmd webCmdLabel:textField-long widgetOverride
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global statefile ./log/fhem.save
attr global verbose 3
setuuid WEB 61a541b6-f33f-ac07-9fdd-9793db672a2144fd
attr WEB editConfig 1
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log Logfile
setuuid Logfile 61a541b6-f33f-ac07-2380-fa0515e246a0ff30
define autocreate autocreate
setuuid autocreate 61a541b6-f33f-ac07-91ee-8e364cb8e92c13b2
attr autocreate filelog ./log/%NAME-%Y.log
define eventTypes eventTypes ./log/eventTypes.txt
setuuid eventTypes 61a541b6-f33f-ac07-44fe-7e7823105fa853ea
define initialUsbCheck notify global:INITIALIZED usb create
setuuid initialUsbCheck 61a541b6-f33f-ac07-1fce-231a8f24487c4ef4
attr initialUsbCheck disable 1
define Mythz THZ /dev/ttyUSB0@14400
setuuid Mythz 61a947be-f33f-ac07-0a98-b53c7c54ad616cf8
attr Mythz devStateIcon opened:10px-kreis-gruen disconnected:10px-kreis-rot
attr Mythz firmware 2.06
attr Mythz interval_sGlobal 300 # Internes Polling Intervall 5min
attr Mythz interval_sHistory 28800 # Internes Polling Intervall 8h
attr Mythz interval_sLast10errors 120 # Internes Polling Fehlerspeicher
define FileLog_Mythz FileLog ./log/Mythz-%Y.log Mythz
setuuid FileLog_Mythz 61a947be-f33f-ac07-a3d0-4e712db12e7dba43
define Plot_Temp SVG FileLog_Mythz:thz:CURRENT
setuuid Plot_Temp 61a947be-f33f-ac07-e211-f843f16e200a9413
attr Plot_Temp room Heizung
--- Ende Code ---
immi:
--- Zitat von: Noobie47 am 05 Dezember 2021, 22:27:54 ---Hi, has  anyone an idea what is the reason for this error message? It appears almost exactly every 2 minutes.
--- Ende Zitat ---
Well
you request register D1 every 120s  with the attribute interval_sLast10errors.
Just remove it, if your tecalor does not have it.
one more thing; you should consider using
--- Code: ---attr Mythz firmware 2.14
--- Ende Code ---
instead of the 2.06
immi
Noobie47:
@immi: regarding error message msg2:  decode: command not known -- D1 -> 0103D5D11003; removing it, was sucessful.
I also tried fw 2.14 instead of 2.06. It created a lot of error messages !!! I tried it for a couple of time, but at the end I switched back to 2.06. There are still some error messages but in general the plotting works.
I  asked within another thread in this forum for help analyzing my parameters and plottings. Maybe you also want to have a look ? here: https://forum.fhem.de/index.php/topic,33452.3750.html#lastPost
best,
noobie
Navigation
[0] Themen-Index
[#] Nächste Seite
[*] Vorherige Sete
Zur normalen Ansicht wechseln
