THZ Tecalor (LWZ Stiebel Eltron) module support and code improvement.
Begonnen von immi, 02 Februar 2015, 11:42:16
mlb
immi, you are great, thank you! :D
I also updated other fhem files from trunk, and overall it looks really nice.
@Willy - so far I tested unscheduled ventilation modes 0, 1, 2 - and they seem to work fine after I created controller for it, without prior update of unscheduled times. Just sometimes ventilatio does not start - I need to look at documentation, maybe it's related to other parameters. And of course it does not start when compressor is running.
My software version is 4.38, and at Fhem I set it as 4.39. So far I have not noticed serious issues with Fhem.  The only thing I have noticed are strange parameters at sHC1:
outsideTemp: -0.8 x08: 7 returnTemp: 17.7 integralHeat: 77 flowTemp: 32.6 heatSetTemp: 22.9 heatTemp: 32.6 seasonMode: winter integralSwitch: 90 opMode: setback roomSetTemp: 16.5 x60: 0 x64: 563.2 insideTempRC: 22.5 x72: 0 x76: 2.2
- but I do not know if those are working for others, or they are simply not yet supported by 00_THZ.
LWZ 403SOL, FHEM + HomeAssistant
willybauss
#91
Zitat von: mlb am 15 Februar 2015, 14:22:05
I'm happy to confirm the unscheduled ventilation started working after I created a control for it:
I managed to add a few sliders for setting the times as well. The final result is shown here.
I'd like to do the same for party mode as well, but I noticed that "party-time" is a read-only setting => why?. Additionally I assume there's a hidden flag for activation as well, which would need to be found first.
edit:
link updated
FHEM auf Raspberry Pi B und 2B; THZ (THZ-303SOL), CUL_HM, TCM-EnOcean, SamsungTV, JSONMETER, SYSMON, OBIS, STATISTICS
mlb
Your sliders look very useful, would you mind posting example code for one slider?
Indeed - p99FanStageParty I could set value 0 to 3 without errors, but there is no parameter on the list to modify party time range.
mlb
Ah I found it on wiki at release notes:
Zitatv0.108
    Party-Time set removed as it has never worked
willybauss
#94
Link to the code is in my post above, here again:  HERE IS THE LINK AGAIN
mlb
Thanks. I do not know why, but your previous link kept redirecting me to my own previous message, that's why I asked.
willybauss
immi
not too serius during carneval monday  ;D
The xXX just tell you values the heatpump delivers. We do not have a names for them. Someone has to find them out or ask tecalor for documentation.
v0.133+ uploaded
- fixed: According the manual our p99RoomThermCorrection is actually P76
micomat
oh man! you're so fast and i Really have no time to write the wiki articles =(
if somebody can write a short update for the "changelog" in the wiki, I'll add this :)
Synology DS218+ with fhem+iobroker in docker, 2x RasPi w. ser2net, CUL433+868, IT, EGPM2LAN, THZ/LWZ, FB_Callmonitor, HMS100TF, Homematic, 2x TX3-TH, Pushover, USB-IR-SML-Head, SONOS, GHoma, MBus, KLF200
mlb
@immi: I am not sure if this is THZ-specific, or more general topic. I know we can request data from THZ on interval basis. But we also do not want to do it too frequently.
However, I think we may have one exception -  when we send a a command to THZ, often it would be very useful to refresh status from THZ  at the next step, just to make sure the command has been actually successful. Is there a way of doing it?
immi
Zitat von: mlb am 20 Februar 2015, 14:56:52
@immi: I am not sure if this is THZ-specific, of more general topic. I know we can request data from THZ on interval basis. But we also do not want to do it too frequently.
The same register will always be read immediately automaticaly for confirmation after writing.
Other registers can be activated per "notify"; please look in the manual.
Example:you can tell fhem to read again sGlobal, each time you change the ventilator speed.
mlb
Nice :) Just - how to do that?  I checked documentation and tried it - but seems like I do not understand it because the following does not work (last line does not trigger refresh):
define Fan.Unscheduled dummy
attr Fan.Unscheduled alias Start
attr Fan.Unscheduled devStateIcon 0:vent_ventilation_level_0 1:vent_ventilation_level_1 2:vent_ventilation_level_2 3:vent_ventilation_level_3
attr Fan.Unscheduled group THZ-FansUnscheduled
attr Fan.Unscheduled setList 0 1 2 3
attr Fan.Unscheduled webCmd 0:1:2:3
define Notify_p99startUnschedVent notify Fan.Unscheduled set Mythz p99startUnschedVent $EVENT
define Notify_UnschedVent notify (Mythz.p99startUnschedVent.*) setstate Fan.Unscheduled $EVTPART1
define Notify_UnschedVentRefresh notify Fan.Unscheduled get Mythz sGlobal
willybauss
  • start the event monitor (button on left side bar)
  • in 2nd web interface window start an unscheduled ventilation
=> monitor window shows you the name on which your notify should trigger
mlb
Willy - yes I have done that already, and Event Monitor shows "dummy Fan.Unscheduled <number>", as expected. That's why I'm asking here, because my Notify_UnschedVentRefresh is not being triggered, so I cannot see any event about getting sGlobal that would follow the start of ventilation.
mlb
It suddenly started working!  ;D
And with the code exactly like I published earlier. I still do not understand why, does fhem require a couple of restarts before new notify is checked? Anyway, thanks for suggestions!
