KM271: Attribute 'readingsFilter' added for suppressing not wanted Readings. Only readings which will match the defined regex will be reported and logged. (Forum #30473)
Begonnen von System, 05 Februar 2015, 02:00:07
System
KM271: Attribute 'readingsFilter' added for suppressing not wanted Readings. Only readings which will match the defined regex will be reported and logged. (Forum #30473)View Changes
Source: KM271: Attribute 'readingsFilter' added for suppressing not wanted Readings. Only readings which will match the defined regex will be reported and logged. (Forum #30473)
