HOME EASY HE842.
Begonnen von bigmacd, 26 März 2015, 19:29:38
bigmacd
I have a HOME EASY HE842.
It is appearing within TRX_ELSE.
I would like to define it within fhem and use the state change to trigger other events.
This should be possible??
Struggling to understand how to define the switch? Can be AC or Homeeasy.
appreciate any advice.
0B11000B0002998003000070
Packettype    = Lighting2
subtype       = AC
Sequence nbr  = 11
ID            = 0029980
Unit          = 3
Command       = Off
Signal level  = 7
0B11010C0000198003000040
subtype       = HomeEasy EU
Sequence nbr  = 12
ID            = 0001980
Unit          = 3
Command       = Off
Signal level  = 4
0B11000D0002998003010F70
subtype       = AC
Sequence nbr  = 13
ID            = 0029980
Unit          = 3
Command       = On
Signal level  = 7
0B11010E0000198003010F40
Sequence nbr  = 14
ID            = 0001980
Unit          = 3
Command       = On
Signal level  = 4
chris_z
AFAIK thers no Interface supported by fhem, that support HE, what Interface do you want to use ?
bigmacd
hi thanks for your reply.
I would like to use it to turn on and off a whole set of fhem enabled devices in a room.
They are not all Home easy devices but they all support fhem on/off events.
chris_z
First you need an Interface thats supports HomeEasy and is also supported by FHEM
bigmacd
OK I've got the RFXTRX433e installed?
KernSani
Typically HE devices work with RFXTRX, HomeEasy mode. Autocreate should work. Have no experience with HE842 though.
