Autor Thema: "Probleme" mit RaspberryPi Model B  (Gelesen 3998 mal)
Offline selfarian
  • Full Member
« am: 08 Mai 2015, 12:38:20 »
ich hatte in der Vergangenheit Probleme, das mir ständig die Verbindung zu meinem HMLAN Adapter abgerissen ist, also habe ich mir mal gedacht ich räume mal richtig auf und habe den Pi komplett neu installiert und die Konfigration komplett von vorne begonnen. Im Zuge dessen habe ich auch gleich den Performancemonitor installiert. Leider fällt mir jetzt immer wieder vermehrt folgendes auf:
2015.05.08 00:02:37 1: Perfmon: possible freeze starting at 00:02:36, delay is 1.208
2015.05.08 00:03:07 1: Perfmon: possible freeze starting at 00:03:04, delay is 3.819
2015.05.08 00:05:42 1: Perfmon: possible freeze starting at 00:05:41, delay is 1.09
2015.05.08 00:07:56 1: Perfmon: possible freeze starting at 00:07:55, delay is 1.195
2015.05.08 00:08:40 1: Perfmon: possible freeze starting at 00:08:39, delay is 1.16
2015.05.08 00:09:01 1: Perfmon: possible freeze starting at 00:09:00, delay is 1.125
2015.05.08 00:11:10 1: Perfmon: possible freeze starting at 00:11:09, delay is 1.093
2015.05.08 00:11:38 1: Perfmon: possible freeze starting at 00:11:37, delay is 1.129
2015.05.08 00:12:56 1: Perfmon: possible freeze starting at 00:12:55, delay is 1.228
2015.05.08 00:13:08 1: Perfmon: possible freeze starting at 00:13:07, delay is 1.163
2015.05.08 00:15:30 1: Perfmon: possible freeze starting at 00:15:29, delay is 1.211
2015.05.08 00:16:09 1: Perfmon: possible freeze starting at 00:16:08, delay is 1.108
2015.05.08 00:17:56 1: Perfmon: possible freeze starting at 00:17:55, delay is 1.254
2015.05.08 00:20:15 1: Perfmon: possible freeze starting at 00:20:14, delay is 1.208
2015.05.08 00:22:16 1: Perfmon: possible freeze starting at 00:22:15, delay is 1.223
2015.05.08 00:22:56 1: Perfmon: possible freeze starting at 00:22:55, delay is 1.177
2015.05.08 00:23:30 1: Perfmon: possible freeze starting at 00:23:29, delay is 1.74
2015.05.08 00:27:56 1: Perfmon: possible freeze starting at 00:27:55, delay is 1.176
2015.05.08 00:28:34 1: Perfmon: possible freeze starting at 00:28:33, delay is 1.128
2015.05.08 00:30:04 1: Perfmon: possible freeze starting at 00:30:03, delay is 1.234
2015.05.08 00:31:57 1: Perfmon: possible freeze starting at 00:31:56, delay is 1.162
2015.05.08 00:32:56 1: Perfmon: possible freeze starting at 00:32:55, delay is 1.148
2015.05.08 00:33:59 1: Perfmon: possible freeze starting at 00:33:58, delay is 1.144
2015.05.08 00:34:32 1: Perfmon: possible freeze starting at 00:34:31, delay is 1.111
2015.05.08 00:35:08 1: Perfmon: possible freeze starting at 00:35:07, delay is 1.234
2015.05.08 00:37:40 1: Perfmon: possible freeze starting at 00:37:39, delay is 1.169
2015.05.08 00:37:56 1: Perfmon: possible freeze starting at 00:37:55, delay is 1.182
2015.05.08 00:42:46 1: Perfmon: possible freeze starting at 00:42:45, delay is 1.162
2015.05.08 00:42:56 1: Perfmon: possible freeze starting at 00:42:55, delay is 1.163
2015.05.08 00:46:31 1: Perfmon: possible freeze starting at 00:46:30, delay is 1.129
2015.05.08 00:47:56 1: Perfmon: possible freeze starting at 00:47:55, delay is 1.175
2015.05.08 00:47:58 1: Perfmon: possible freeze starting at 00:47:57, delay is 1.158
2015.05.08 00:49:15 1: Perfmon: possible freeze starting at 00:49:14, delay is 1.117
2015.05.08 00:50:58 1: Perfmon: possible freeze starting at 00:50:57, delay is 1
2015.05.08 00:51:46 1: Perfmon: possible freeze starting at 00:51:45, delay is 1.156
2015.05.08 00:52:17 1: Perfmon: possible freeze starting at 00:52:16, delay is 1.132
2015.05.08 00:52:56 1: Perfmon: possible freeze starting at 00:52:55, delay is 1.245
2015.05.08 00:53:49 1: Perfmon: possible freeze starting at 00:53:48, delay is 1.641
2015.05.08 00:54:34 1: Perfmon: possible freeze starting at 00:54:33, delay is 1.154
2015.05.08 00:55:23 1: Perfmon: possible freeze starting at 00:55:22, delay is 1.25
2015.05.08 00:55:34 1: Perfmon: possible freeze starting at 00:55:33, delay is 1.183
2015.05.08 00:57:56 1: Perfmon: possible freeze starting at 00:57:55, delay is 1.26
2015.05.08 00:58:18 1: Perfmon: possible freeze starting at 00:58:17, delay is 1.248
2015.05.08 01:00:30 1: Perfmon: possible freeze starting at 01:00:29, delay is 1.178
2015.05.08 01:01:31 1: Perfmon: possible freeze starting at 01:01:30, delay is 1.158
2015.05.08 01:03:07 1: Perfmon: possible freeze starting at 01:03:04, delay is 3.822
2015.05.08 01:03:09 1: Perfmon: possible freeze starting at 01:03:08, delay is 1.093
2015.05.08 01:07:05 1: Perfmon: possible freeze starting at 01:07:04, delay is 1.16
2015.05.08 01:07:56 1: Perfmon: possible freeze starting at 01:07:55, delay is 1.223
2015.05.08 01:12:10 1: Perfmon: possible freeze starting at 01:12:09, delay is 1.139
2015.05.08 01:12:56 1: Perfmon: possible freeze starting at 01:12:55, delay is 1.264
2015.05.08 01:13:57 1: Perfmon: possible freeze starting at 01:13:56, delay is 1.008
2015.05.08 01:16:15 1: Perfmon: possible freeze starting at 01:16:14, delay is 1.004
2015.05.08 01:17:56 1: Perfmon: possible freeze starting at 01:17:55, delay is 1.217
2015.05.08 01:22:56 1: Perfmon: possible freeze starting at 01:22:55, delay is 1.282
2015.05.08 01:23:51 1: Perfmon: possible freeze starting at 01:23:49, delay is 2.102
2015.05.08 01:23:53 1: Perfmon: possible freeze starting at 01:23:52, delay is 1.837
2015.05.08 01:25:40 1: Perfmon: possible freeze starting at 01:25:39, delay is 1.193
2015.05.08 01:27:56 1: Perfmon: possible freeze starting at 01:27:55, delay is 1.228
2015.05.08 01:28:02 1: Perfmon: possible freeze starting at 01:28:01, delay is 1.193
2015.05.08 01:32:56 1: Perfmon: possible freeze starting at 01:32:55, delay is 1.203
2015.05.08 01:33:07 1: Perfmon: possible freeze starting at 01:33:06, delay is 1.191
2015.05.08 01:36:53 1: Perfmon: possible freeze starting at 01:36:52, delay is 1.172
2015.05.08 01:37:47 1: Perfmon: possible freeze starting at 01:37:46, delay is 1.157
2015.05.08 01:37:56 1: Perfmon: possible freeze starting at 01:37:55, delay is 1.215
2015.05.08 01:38:56 1: Perfmon: possible freeze starting at 01:38:55, delay is 1.051
2015.05.08 01:40:31 1: Perfmon: possible freeze starting at 01:40:30, delay is 1.159
2015.05.08 01:42:07 1: Perfmon: possible freeze starting at 01:42:06, delay is 1.174
2015.05.08 01:42:56 1: Perfmon: possible freeze starting at 01:42:55, delay is 1.288
2015.05.08 01:43:49 1: Perfmon: possible freeze starting at 01:43:48, delay is 1.024
2015.05.08 01:46:26 1: Perfmon: possible freeze starting at 01:46:25, delay is 1.231
2015.05.08 01:47:56 1: Perfmon: possible freeze starting at 01:47:55, delay is 1.319
2015.05.08 01:49:14 1: Perfmon: possible freeze starting at 01:49:13, delay is 1.292
2015.05.08 01:51:20 1: Perfmon: possible freeze starting at 01:51:19, delay is 1.075
2015.05.08 01:52:56 1: Perfmon: possible freeze starting at 01:52:55, delay is 1.285
2015.05.08 01:53:51 1: Perfmon: possible freeze starting at 01:53:50, delay is 1.493
2015.05.08 01:54:12 1: Perfmon: possible freeze starting at 01:54:11, delay is 1.241
2015.05.08 01:55:04 1: Perfmon: possible freeze starting at 01:55:03, delay is 1.186
2015.05.08 01:56:21 1: Perfmon: possible freeze starting at 01:56:20, delay is 1.205
2015.05.08 01:57:11 1: Perfmon: possible freeze starting at 01:57:10, delay is 1.198
2015.05.08 01:57:56 1: Perfmon: possible freeze starting at 01:57:55, delay is 1.308
2015.05.08 01:59:02 1: Perfmon: possible freeze starting at 01:59:01, delay is 1.202
2015.05.08 02:03:07 1: Perfmon: possible freeze starting at 02:03:04, delay is 3.911
2015.05.08 02:06:10 1: Perfmon: possible freeze starting at 02:06:09, delay is 1.056
2015.05.08 02:07:56 1: Perfmon: possible freeze starting at 02:07:55, delay is 1.286
2015.05.08 02:08:45 1: Perfmon: possible freeze starting at 02:08:44, delay is 1.051
2015.05.08 02:12:56 1: Perfmon: possible freeze starting at 02:12:55, delay is 1.261
2015.05.08 02:13:12 1: Perfmon: possible freeze starting at 02:13:11, delay is 1.055
2015.05.08 02:16:42 1: HMLAN_Parse: HMLAN1 new condition timeout
2015.05.08 02:16:42 1: 192.168.150.11:1000 disconnected, waiting to reappear (HMLAN1)
2015.05.08 02:16:42 1: HMLAN_Parse: HMLAN1 new condition disconnected
2015.05.08 02:16:46 1: 192.168.150.11:1000 reappeared (HMLAN1)
2015.05.08 02:16:46 1: HMLAN_Parse: HMLAN1 new condition init
2015.05.08 02:16:46 1: Perfmon: possible freeze starting at 02:16:43, delay is 3.406
2015.05.08 02:16:46 1: HMLAN_Parse: HMLAN1 new condition ok
2015.05.08 02:17:56 1: Perfmon: possible freeze starting at 02:17:55, delay is 1.277
2015.05.08 02:19:32 1: Perfmon: possible freeze starting at 02:19:31, delay is 1.209
2015.05.08 02:20:21 1: Perfmon: possible freeze starting at 02:20:20, delay is 1.203
2015.05.08 02:21:58 1: Perfmon: possible freeze starting at 02:21:57, delay is 1.204
2015.05.08 02:22:27 1: Perfmon: possible freeze starting at 02:22:26, delay is 1.21
2015.05.08 02:22:56 1: Perfmon: possible freeze starting at 02:22:55, delay is 1.252
2015.05.08 02:23:53 1: Perfmon: possible freeze starting at 02:23:51, delay is 2.434
2015.05.08 02:25:56 1: Perfmon: possible freeze starting at 02:25:55, delay is 1.214
2015.05.08 02:26:33 1: Perfmon: possible freeze starting at 02:26:32, delay is 1.202
2015.05.08 02:27:34 1: Perfmon: possible freeze starting at 02:27:33, delay is 1.215
2015.05.08 02:27:56 1: Perfmon: possible freeze starting at 02:27:55, delay is 1.356
2015.05.08 02:28:22 1: Perfmon: possible freeze starting at 02:28:21, delay is 1.216
2015.05.08 02:29:33 1: Perfmon: possible freeze starting at 02:29:32, delay is 1.216
2015.05.08 02:32:56 1: Perfmon: possible freeze starting at 02:32:55, delay is 1.363
2015.05.08 02:37:56 1: Perfmon: possible freeze starting at 02:37:55, delay is 1.381
2015.05.08 02:42:56 1: Perfmon: possible freeze starting at 02:42:55, delay is 1.402
2015.05.08 02:43:59 1: Perfmon: possible freeze starting at 02:43:58, delay is 1.231
2015.05.08 02:47:56 1: Perfmon: possible freeze starting at 02:47:55, delay is 1.428
2015.05.08 02:50:25 1: Perfmon: possible freeze starting at 02:50:24, delay is 1.231
2015.05.08 02:52:18 1: Perfmon: possible freeze starting at 02:52:17, delay is 1.078
2015.05.08 02:52:35 1: Perfmon: possible freeze starting at 02:52:34, delay is 1.229
2015.05.08 02:52:56 1: Perfmon: possible freeze starting at 02:52:55, delay is 1.442
2015.05.08 02:53:53 1: Perfmon: possible freeze starting at 02:53:52, delay is 1.717
2015.05.08 02:54:35 1: Perfmon: possible freeze starting at 02:54:34, delay is 1.09
2015.05.08 02:54:51 1: Perfmon: possible freeze starting at 02:54:50, delay is 1.223
2015.05.08 02:57:56 1: Perfmon: possible freeze starting at 02:57:55, delay is 1.444
2015.05.08 02:59:30 1: Perfmon: possible freeze starting at 02:59:29, delay is 1.138
2015.05.08 02:59:35 1: Perfmon: possible freeze starting at 02:59:34, delay is 1.214
2015.05.08 03:03:07 1: Perfmon: possible freeze starting at 03:03:04, delay is 3.883
2015.05.08 03:03:09 1: Perfmon: possible freeze starting at 03:03:08, delay is 1.156
2015.05.08 03:03:52 1: Perfmon: possible freeze starting at 03:03:51, delay is 1.087
2015.05.08 03:04:06 1: Perfmon: possible freeze starting at 03:04:05, delay is 1.247
2015.05.08 03:06:52 1: Perfmon: possible freeze starting at 03:06:51, delay is 1.245
2015.05.08 03:07:01 1: Perfmon: possible freeze starting at 03:07:00, delay is 1.221
2015.05.08 03:07:56 1: Perfmon: possible freeze starting at 03:07:55, delay is 1.289
2015.05.08 03:09:25 1: Perfmon: possible freeze starting at 03:09:24, delay is 1.211
2015.05.08 03:11:29 1: Perfmon: possible freeze starting at 03:11:28, delay is 1.231
2015.05.08 03:12:56 1: Perfmon: possible freeze starting at 03:12:55, delay is 1.405
2015.05.08 03:13:00 1: Perfmon: possible freeze starting at 03:12:59, delay is 1.012
2015.05.08 03:15:08 1: Perfmon: possible freeze starting at 03:15:07, delay is 1.263
2015.05.08 03:17:56 1: Perfmon: possible freeze starting at 03:17:55, delay is 1.329
2015.05.08 03:18:06 1: Perfmon: possible freeze starting at 03:18:05, delay is 1.02
2015.05.08 03:20:49 1: Perfmon: possible freeze starting at 03:20:48, delay is 1.267
2015.05.08 03:21:37 1: Perfmon: possible freeze starting at 03:21:36, delay is 1.016
2015.05.08 03:22:56 1: Perfmon: possible freeze starting at 03:22:55, delay is 1.331
2015.05.08 03:23:18 1: Perfmon: possible freeze starting at 03:23:17, delay is 1.262
2015.05.08 03:23:46 1: Perfmon: possible freeze starting at 03:23:45, delay is 1.019
2015.05.08 03:23:59 1: Perfmon: possible freeze starting at 03:23:58, delay is 1.738
2015.05.08 03:27:56 1: Perfmon: possible freeze starting at 03:27:55, delay is 1.374
2015.05.08 03:32:56 1: Perfmon: possible freeze starting at 03:32:55, delay is 1.365
2015.05.08 03:34:24 1: Perfmon: possible freeze starting at 03:34:23, delay is 1.103
2015.05.08 03:37:31 1: Perfmon: possible freeze starting at 03:37:30, delay is 1.245
2015.05.08 03:37:56 1: Perfmon: possible freeze starting at 03:37:55, delay is 1.361
2015.05.08 03:39:30 1: Perfmon: possible freeze starting at 03:39:29, delay is 1.115
2015.05.08 03:40:11 1: Perfmon: possible freeze starting at 03:40:10, delay is 1.239
2015.05.08 03:42:56 1: Perfmon: possible freeze starting at 03:42:55, delay is 1.404
2015.05.08 03:44:48 1: Perfmon: possible freeze starting at 03:44:47, delay is 1.266
2015.05.08 03:46:10 1: Perfmon: possible freeze starting at 03:46:09, delay is 1.038
2015.05.08 03:46:57 1: Perfmon: possible freeze starting at 03:46:56, delay is 1.121
2015.05.08 03:47:42 1: Perfmon: possible freeze starting at 03:47:41, delay is 1.032
2015.05.08 03:47:56 1: Perfmon: possible freeze starting at 03:47:55, delay is 1.369
2015.05.08 03:50:35 1: Perfmon: possible freeze starting at 03:50:34, delay is 1.241
2015.05.08 03:51:47 1: Perfmon: possible freeze starting at 03:51:46, delay is 1.121
2015.05.08 03:51:49 1: Perfmon: possible freeze starting at 03:51:48, delay is 1.037
2015.05.08 03:52:56 1: Perfmon: possible freeze starting at 03:52:55, delay is 1.283
2015.05.08 03:53:07 1: Perfmon: possible freeze starting at 03:53:06, delay is 1.298
2015.05.08 03:53:32 1: Perfmon: possible freeze starting at 03:53:31, delay is 1.025
2015.05.08 03:54:17 1: Perfmon: possible freeze starting at 03:54:16, delay is 1.035
2015.05.08 03:54:28 1: Perfmon: possible freeze starting at 03:54:27, delay is 1.237
2015.05.08 03:56:43 1: Perfmon: possible freeze starting at 03:56:42, delay is 1.12
2015.05.08 03:57:56 1: Perfmon: possible freeze starting at 03:57:55, delay is 1.319
2015.05.08 04:00:29 1: Perfmon: possible freeze starting at 04:00:28, delay is 1.027
2015.05.08 04:02:59 1: Perfmon: possible freeze starting at 04:02:58, delay is 1.29
2015.05.08 04:03:07 1: Perfmon: possible freeze starting at 04:03:04, delay is 3.969
2015.05.08 04:04:27 1: Perfmon: possible freeze starting at 04:04:26, delay is 1.141
2015.05.08 04:06:03 1: Perfmon: possible freeze starting at 04:06:02, delay is 1.043
2015.05.08 04:07:16 1: Perfmon: possible freeze starting at 04:07:15, delay is 1.33
2015.05.08 04:07:32 1: Perfmon: possible freeze starting at 04:07:31, delay is 1.003
2015.05.08 04:07:56 1: Perfmon: possible freeze starting at 04:07:55, delay is 1.329
2015.05.08 04:09:07 1: Perfmon: possible freeze starting at 04:09:06, delay is 1.13
2015.05.08 04:10:39 1: Perfmon: possible freeze starting at 04:10:38, delay is 1.04
2015.05.08 04:12:56 1: Perfmon: possible freeze starting at 04:12:55, delay is 1.329
2015.05.08 04:17:56 1: Perfmon: possible freeze starting at 04:17:55, delay is 1.345
2015.05.08 04:18:57 1: Perfmon: possible freeze starting at 04:18:56, delay is 1.053
2015.05.08 04:19:35 1: Perfmon: possible freeze starting at 04:19:34, delay is 1.06
2015.05.08 04:22:57 1: Perfmon: possible freeze starting at 04:22:56, delay is 1.535
2015.05.08 04:23:17 1: Perfmon: possible freeze starting at 04:23:16, delay is 1.054
2015.05.08 04:23:29 1: Perfmon: possible freeze starting at 04:23:27, delay is 2.593
2015.05.08 04:25:23 1: Perfmon: possible freeze starting at 04:25:22, delay is 1.05
2015.05.08 04:27:57 1: Perfmon: possible freeze starting at 04:27:56, delay is 1.678
2015.05.08 04:32:58 1: Perfmon: possible freeze starting at 04:32:57, delay is 1.667
2015.05.08 04:37:49 1: Perfmon: possible freeze starting at 04:37:48, delay is 1.081
2015.05.08 04:37:57 1: Perfmon: possible freeze starting at 04:37:56, delay is 1.507
2015.05.08 04:40:23 1: Perfmon: possible freeze starting at 04:40:22, delay is 1.149
2015.05.08 04:42:57 1: Perfmon: possible freeze starting at 04:42:56, delay is 1.544
2015.05.08 04:43:25 1: Perfmon: possible freeze starting at 04:43:24, delay is 1.264
2015.05.08 04:44:43 1: Perfmon: possible freeze starting at 04:44:42, delay is 1.157
2015.05.08 04:46:14 1: Perfmon: possible freeze starting at 04:46:13, delay is 1.254
2015.05.08 04:47:57 1: Perfmon: possible freeze starting at 04:47:56, delay is 1.536
2015.05.08 04:48:49 1: Perfmon: possible freeze starting at 04:48:48, delay is 1.008
2015.05.08 04:51:09 1: Perfmon: possible freeze starting at 04:51:08, delay is 1.296
2015.05.08 04:52:37 1: Perfmon: possible freeze starting at 04:52:36, delay is 1.147
2015.05.08 04:52:58 1: Perfmon: possible freeze starting at 04:52:57, delay is 1.599
2015.05.08 04:53:15 1: Perfmon: possible freeze starting at 04:53:14, delay is 1.005
2015.05.08 04:53:37 1: Perfmon: possible freeze starting at 04:53:36, delay is 1.066
2015.05.08 04:54:17 1: Perfmon: possible freeze starting at 04:54:14, delay is 3.229
2015.05.08 04:57:45 1: Perfmon: possible freeze starting at 04:57:44, delay is 1.177
2015.05.08 04:57:58 1: Perfmon: possible freeze starting at 04:57:57, delay is 1.639
2015.05.08 04:58:41 1: Perfmon: possible freeze starting at 04:58:40, delay is 1.093
2015.05.08 05:02:47 1: Perfmon: possible freeze starting at 05:02:46, delay is 1.102
2015.05.08 05:02:59 1: Perfmon: possible freeze starting at 05:02:58, delay is 1.545
2015.05.08 05:03:10 1: Perfmon: possible freeze starting at 05:03:07, delay is 3.29
2015.05.08 05:04:55 1: Perfmon: possible freeze starting at 05:04:54, delay is 1.113
2015.05.08 05:06:05 1: Perfmon: possible freeze starting at 05:06:04, delay is 1.096
2015.05.08 05:07:58 1: Perfmon: possible freeze starting at 05:07:57, delay is 1.63
2015.05.08 05:10:06 1: Perfmon: possible freeze starting at 05:10:05, delay is 1.185
2015.05.08 05:10:36 1: Perfmon: possible freeze starting at 05:10:35, delay is 1.111
2015.05.08 05:11:57 1: Perfmon: possible freeze starting at 05:11:56, delay is 1.097
2015.05.08 05:12:58 1: Perfmon: possible freeze starting at 05:12:57, delay is 1.648
2015.05.08 05:14:10 1: Perfmon: possible freeze starting at 05:14:09, delay is 1.028
2015.05.08 05:15:04 1: Perfmon: possible freeze starting at 05:15:03, delay is 1.189
2015.05.08 05:16:14 1: Perfmon: possible freeze starting at 05:16:13, delay is 1.027
2015.05.08 05:16:51 1: Perfmon: possible freeze starting at 05:16:50, delay is 1.092
2015.05.08 05:17:58 1: Perfmon: possible freeze starting at 05:17:57, delay is 1.656
2015.05.08 05:23:33 1: Perfmon: possible freeze starting at 05:23:31, delay is 2.774
2015.05.08 05:24:32 1: Perfmon: possible freeze starting at 05:24:31, delay is 1.102
2015.05.08 05:29:10 1: Perfmon: possible freeze starting at 05:29:09, delay is 1.122
2015.05.08 05:32:07 1: Perfmon: possible freeze starting at 05:32:06, delay is 1.029
2015.05.08 05:32:48 1: Perfmon: possible freeze starting at 05:32:47, delay is 1.136
2015.05.08 05:34:38 1: Perfmon: possible freeze starting at 05:34:37, delay is 1.047
2015.05.08 05:35:15 1: Perfmon: possible freeze starting at 05:35:14, delay is 1.147
2015.05.08 05:40:24 1: Perfmon: possible freeze starting at 05:40:23, delay is 1.217
2015.05.08 05:43:19 1: Perfmon: possible freeze starting at 05:43:18, delay is 1.208
2015.05.08 05:48:26 1: Perfmon: possible freeze starting at 05:48:25, delay is 1.199
2015.05.08 05:50:14 1: Perfmon: possible freeze starting at 05:50:13, delay is 1.136
2015.05.08 05:50:38 1: Perfmon: possible freeze starting at 05:50:37, delay is 1.051
2015.05.08 05:53:08 1: Perfmon: possible freeze starting at 05:53:07, delay is 1.157
2015.05.08 05:53:30 1: Perfmon: possible freeze starting at 05:53:29, delay is 1.826
2015.05.08 05:54:39 1: Perfmon: possible freeze starting at 05:54:38, delay is 1.051
2015.05.08 05:54:58 1: Perfmon: possible freeze starting at 05:54:57, delay is 1.132
2015.05.08 05:57:43 1: Perfmon: possible freeze starting at 05:57:42, delay is 1.13
2015.05.08 05:59:23 1: Perfmon: possible freeze starting at 05:59:22, delay is 1.042
2015.05.08 06:02:30 1: Perfmon: possible freeze starting at 06:02:29, delay is 1.137
2015.05.08 06:03:10 1: Perfmon: possible freeze starting at 06:03:07, delay is 3.499
2015.05.08 06:13:01 1: Perfmon: possible freeze starting at 06:13:00, delay is 1.168
2015.05.08 06:13:27 1: Perfmon: possible freeze starting at 06:13:26, delay is 1.225
2015.05.08 06:18:31 1: Perfmon: possible freeze starting at 06:18:30, delay is 1.179
2015.05.08 06:19:22 1: Perfmon: possible freeze starting at 06:19:21, delay is 1.238
2015.05.08 06:21:35 1: Perfmon: possible freeze starting at 06:21:34, delay is 1.065
2015.05.08 06:24:17 1: Perfmon: possible freeze starting at 06:24:15, delay is 2.684
2015.05.08 06:24:55 1: Perfmon: possible freeze starting at 06:24:54, delay is 1.149
2015.05.08 06:26:01 1: Perfmon: possible freeze starting at 06:26:00, delay is 1.046
2015.05.08 06:26:55 1: Perfmon: possible freeze starting at 06:26:54, delay is 1.153
2015.05.08 06:36:00 1: Perfmon: possible freeze starting at 06:35:59, delay is 1.248
2015.05.08 06:38:22 1: Perfmon: possible freeze starting at 06:38:21, delay is 1.326
2015.05.08 06:40:58 1: Perfmon: possible freeze starting at 06:40:57, delay is 1.186
2015.05.08 06:41:41 1: Perfmon: possible freeze starting at 06:41:40, delay is 1.244
2015.05.08 06:42:59 1: Perfmon: possible freeze starting at 06:42:58, delay is 1.034
2015.05.08 06:44:10 1: Perfmon: possible freeze starting at 06:44:09, delay is 1.243
2015.05.08 06:47:59 1: Perfmon: possible freeze starting at 06:47:58, delay is 1.06
2015.05.08 06:50:06 1: Perfmon: possible freeze starting at 06:50:05, delay is 1.184
2015.05.08 06:52:35 1: Perfmon: possible freeze starting at 06:52:33, delay is 2.164
2015.05.08 06:52:59 1: Perfmon: possible freeze starting at 06:52:58, delay is 1.081
2015.05.08 06:55:11 1: Perfmon: possible freeze starting at 06:55:10, delay is 1.08
2015.05.08 06:55:27 1: Perfmon: possible freeze starting at 06:55:26, delay is 1.177
2015.05.08 06:55:47 1: Perfmon: possible freeze starting at 06:55:46, delay is 1.211
2015.05.08 06:57:14 1: Perfmon: possible freeze starting at 06:57:13, delay is 1.071
2015.05.08 06:57:46 1: Perfmon: possible freeze starting at 06:57:45, delay is 1.171
2015.05.08 06:58:17 1: Perfmon: possible freeze starting at 06:58:16, delay is 1.016
2015.05.08 06:58:50 1: Perfmon: possible freeze starting at 06:58:49, delay is 1.216
2015.05.08 07:01:13 1: Perfmon: possible freeze starting at 07:01:12, delay is 1.008
2015.05.08 07:02:46 1: Perfmon: possible freeze starting at 07:02:45, delay is 1.006
2015.05.08 07:03:10 1: Perfmon: possible freeze starting at 07:03:07, delay is 3.562
2015.05.08 07:07:59 1: Perfmon: possible freeze starting at 07:07:58, delay is 1.022
2015.05.08 07:08:34 1: Perfmon: possible freeze starting at 07:08:33, delay is 1.265
2015.05.08 07:13:02 1: Perfmon: possible freeze starting at 07:13:01, delay is 1.196
2015.05.08 07:17:47 1: Perfmon: possible freeze starting at 07:17:46, delay is 1.085
2015.05.08 07:18:51 1: Perfmon: possible freeze starting at 07:18:50, delay is 1.217
2015.05.08 07:22:38 1: Perfmon: possible freeze starting at 07:22:37, delay is 1.188
2015.05.08 07:23:40 1: Perfmon: possible freeze starting at 07:23:29, delay is 11.293
2015.05.08 07:24:39 1: Perfmon: possible freeze starting at 07:24:38, delay is 1.232
2015.05.08 07:27:59 1: Perfmon: possible freeze starting at 07:27:58, delay is 1.011
2015.05.08 07:28:08 1: Perfmon: possible freeze starting at 07:28:07, delay is 1.194
2015.05.08 07:29:45 1: Perfmon: possible freeze starting at 07:29:44, delay is 1.091
2015.05.08 07:30:00 2: ROOMMATE set rr_lennard home
2015.05.08 07:32:22 3: Watchdog wd.all.handy.alex.away triggered
2015.05.08 07:32:22 2: ROOMMATE set rr_alex absent
2015.05.08 07:32:25 1: Perfmon: possible freeze starting at 07:32:23, delay is 2.772
2015.05.08 07:32:42 1: Perfmon: possible freeze starting at 07:32:41, delay is 1.096
2015.05.08 07:35:39 1: Perfmon: possible freeze starting at 07:35:38, delay is 1.214
2015.05.08 07:37:53 1: Perfmon: possible freeze starting at 07:37:52, delay is 1.103
2015.05.08 07:39:29 1: Perfmon: possible freeze starting at 07:39:28, delay is 1.023
2015.05.08 07:40:53 1: Perfmon: possible freeze starting at 07:40:52, delay is 1.205
2015.05.08 07:44:38 1: Perfmon: possible freeze starting at 07:44:37, delay is 1.238
2015.05.08 07:47:23 1: Perfmon: possible freeze starting at 07:47:22, delay is 1.246
2015.05.08 07:47:59 1: Perfmon: possible freeze starting at 07:47:58, delay is 1
2015.05.08 07:50:54 1: Perfmon: possible freeze starting at 07:50:53, delay is 1.097
2015.05.08 07:52:03 1: Perfmon: possible freeze starting at 07:52:02, delay is 1.05
2015.05.08 07:52:59 1: Perfmon: possible freeze starting at 07:52:58, delay is 1.505
2015.05.08 07:55:55 1: Perfmon: possible freeze starting at 07:55:54, delay is 1.103
2015.05.08 07:57:59 1: Perfmon: possible freeze starting at 07:57:58, delay is 1.068
2015.05.08 07:58:36 1: Perfmon: possible freeze starting at 07:58:35, delay is 1.098
2015.05.08 07:59:55 1: Perfmon: possible freeze starting at 07:59:54, delay is 1.054
2015.05.08 08:02:02 1: Perfmon: possible freeze starting at 08:02:01, delay is 1.014
2015.05.08 08:03:10 1: Perfmon: possible freeze starting at 08:03:07, delay is 3.595
2015.05.08 08:04:10 1: Perfmon: possible freeze starting at 08:04:09, delay is 1.018
2015.05.08 08:04:40 1: Perfmon: possible freeze starting at 08:04:39, delay is 1.066
2015.05.08 08:05:25 1: Perfmon: possible freeze starting at 08:05:24, delay is 1.224
2015.05.08 08:06:16 1: Perfmon: possible freeze starting at 08:06:15, delay is 1.111
2015.05.08 08:06:41 1: Perfmon: possible freeze starting at 08:06:40, delay is 1.068
2015.05.08 08:07:59 1: Perfmon: possible freeze starting at 08:07:58, delay is 1.048
2015.05.08 08:08:28 1: Perfmon: possible freeze starting at 08:08:27, delay is 1.235
2015.05.08 08:11:36 1: Perfmon: possible freeze starting at 08:11:35, delay is 1.11
2015.05.08 08:12:59 1: Perfmon: possible freeze starting at 08:12:58, delay is 1.061
2015.05.08 08:13:51 1: Perfmon: possible freeze starting at 08:13:50, delay is 1.236
2015.05.08 08:17:59 1: Perfmon: possible freeze starting at 08:17:58, delay is 1.208
2015.05.08 08:18:16 1: Perfmon: possible freeze starting at 08:18:15, delay is 1.282
2015.05.08 08:21:11 1: Perfmon: possible freeze starting at 08:21:10, delay is 1.262
2015.05.08 08:22:59 1: Perfmon: possible freeze starting at 08:22:58, delay is 1.116
2015.05.08 08:26:25 1: Perfmon: possible freeze starting at 08:26:24, delay is 1.045
2015.05.08 08:27:59 1: Perfmon: possible freeze starting at 08:27:58, delay is 1.08
2015.05.08 08:30:29 3: Watchdog wd.all.handy.josi.away triggered
2015.05.08 08:30:29 2: ROOMMATE set rr_josi absent
2015.05.08 08:30:30 2: ROOMMATE set rr_lennard absent
2015.05.08 08:30:37 1: 192.168.150.11:1000 disconnected, waiting to reappear (HMLAN1)
2015.05.08 08:30:37 1: HMLAN_Parse: HMLAN1 new condition disconnected
2015.05.08 08:30:37 1: 192.168.150.11:1000 reappeared (HMLAN1)
2015.05.08 08:30:37 1: HMLAN_Parse: HMLAN1 new condition init
2015.05.08 08:30:37 1: Perfmon: possible freeze starting at 08:30:30, delay is 7.971
2015.05.08 08:30:37 1: HMLAN_Parse: HMLAN1 new condition ok
2015.05.08 08:32:02 1: Perfmon: possible freeze starting at 08:32:01, delay is 1.097
2015.05.08 08:32:59 1: Perfmon: possible freeze starting at 08:32:58, delay is 1.062
2015.05.08 08:34:29 1: Perfmon: possible freeze starting at 08:34:28, delay is 1.062
2015.05.08 08:36:50 1: Perfmon: possible freeze starting at 08:36:49, delay is 1.089
2015.05.08 08:37:59 1: Perfmon: possible freeze starting at 08:37:58, delay is 1.104
2015.05.08 08:39:08 1: Perfmon: possible freeze starting at 08:39:07, delay is 1.018
2015.05.08 08:41:32 1: Perfmon: possible freeze starting at 08:41:31, delay is 1.283
2015.05.08 08:42:59 1: Perfmon: possible freeze starting at 08:42:58, delay is 1.101
2015.05.08 08:46:32 1: Perfmon: possible freeze starting at 08:46:31, delay is 1.118
2015.05.08 08:47:59 1: Perfmon: possible freeze starting at 08:47:58, delay is 1.023
2015.05.08 08:52:02 1: Perfmon: possible freeze starting at 08:52:01, delay is 1.016
2015.05.08 08:52:59 1: Perfmon: possible freeze starting at 08:52:58, delay is 1.096
2015.05.08 08:54:22 1: Perfmon: possible freeze starting at 08:54:21, delay is 1.14
2015.05.08 08:57:07 1: Perfmon: possible freeze starting at 08:57:06, delay is 1.268
2015.05.08 08:57:59 1: Perfmon: possible freeze starting at 08:57:58, delay is 1.186
2015.05.08 08:58:23 1: Perfmon: possible freeze starting at 08:58:22, delay is 1.104
2015.05.08 08:59:06 1: Perfmon: possible freeze starting at 08:59:05, delay is 1.136
2015.05.08 08:59:18 1: Perfmon: possible freeze starting at 08:59:17, delay is 1.272
2015.05.08 08:59:37 1: Perfmon: possible freeze starting at 08:59:36, delay is 1.108
2015.05.08 09:00:41 1: Perfmon: possible freeze starting at 09:00:40, delay is 1.112
2015.05.08 09:03:10 1: Perfmon: possible freeze starting at 09:03:07, delay is 3.624
2015.05.08 09:03:56 1: Perfmon: possible freeze starting at 09:03:55, delay is 1.142
2015.05.08 09:05:05 1: Perfmon: possible freeze starting at 09:05:04, delay is 1.03
2015.05.08 09:05:23 1: Perfmon: possible freeze starting at 09:05:22, delay is 1.088
2015.05.08 09:05:38 1: Perfmon: possible freeze starting at 09:05:37, delay is 1.112
2015.05.08 09:07:59 1: Perfmon: possible freeze starting at 09:07:58, delay is 1.113
2015.05.08 09:09:54 1: Perfmon: possible freeze starting at 09:09:53, delay is 1.067
2015.05.08 09:10:41 1: Perfmon: possible freeze starting at 09:10:40, delay is 1.159
2015.05.08 09:10:59 1: Perfmon: possible freeze starting at 09:10:58, delay is 1.18
2015.05.08 09:12:14 1: Perfmon: possible freeze starting at 09:12:13, delay is 1.099
2015.05.08 09:12:51 1: Perfmon: possible freeze starting at 09:12:50, delay is 1.169
2015.05.08 09:12:59 1: Perfmon: possible freeze starting at 09:12:58, delay is 1.058
2015.05.08 09:16:37 1: Perfmon: possible freeze starting at 09:16:36, delay is 1.137
2015.05.08 09:17:44 1: Perfmon: possible freeze starting at 09:17:43, delay is 1.087
2015.05.08 09:17:59 1: Perfmon: possible freeze starting at 09:17:58, delay is 1.071
2015.05.08 09:22:00 1: Perfmon: possible freeze starting at 09:21:59, delay is 1.082
2015.05.08 09:22:59 1: Perfmon: possible freeze starting at 09:22:58, delay is 1.118
2015.05.08 09:27:43 1: Perfmon: possible freeze starting at 09:27:42, delay is 1.047
2015.05.08 09:27:59 1: Perfmon: possible freeze starting at 09:27:58, delay is 1.02
2015.05.08 09:30:13 1: Perfmon: possible freeze starting at 09:30:12, delay is 1.047
2015.05.08 09:32:59 1: Perfmon: possible freeze starting at 09:32:58, delay is 1.124
2015.05.08 09:37:59 1: Perfmon: possible freeze starting at 09:37:58, delay is 1.071
2015.05.08 09:42:32 1: Perfmon: possible freeze starting at 09:42:31, delay is 1.108
2015.05.08 09:42:59 1: Perfmon: possible freeze starting at 09:42:58, delay is 1.132
2015.05.08 09:44:39 1: Perfmon: possible freeze starting at 09:44:38, delay is 1.108
2015.05.08 09:47:17 1: Perfmon: possible freeze starting at 09:47:16, delay is 1.166
2015.05.08 09:47:59 1: Perfmon: possible freeze starting at 09:47:58, delay is 1.063
2015.05.08 09:50:05 1: Perfmon: possible freeze starting at 09:50:04, delay is 1.068
2015.05.08 09:50:18 1: Perfmon: possible freeze starting at 09:50:17, delay is 1.134
2015.05.08 09:52:33 1: Perfmon: possible freeze starting at 09:52:32, delay is 1.102
2015.05.08 09:52:35 1: Perfmon: possible freeze starting at 09:52:34, delay is 1.159
2015.05.08 09:52:59 1: Perfmon: possible freeze starting at 09:52:58, delay is 1.019
2015.05.08 09:57:50 1: Perfmon: possible freeze starting at 09:57:49, delay is 1.07
2015.05.08 09:57:59 1: Perfmon: possible freeze starting at 09:57:58, delay is 1.061
2015.05.08 09:59:48 1: Perfmon: possible freeze starting at 09:59:47, delay is 1.153
2015.05.08 10:03:10 1: Perfmon: possible freeze starting at 10:03:07, delay is 3.927
2015.05.08 10:03:17 1: Perfmon: possible freeze starting at 10:03:16, delay is 1.166
2015.05.08 10:04:50 1: Perfmon: possible freeze starting at 10:04:49, delay is 1.177
2015.05.08 10:05:44 1: Perfmon: possible freeze starting at 10:05:43, delay is 1.161
2015.05.08 10:07:59 1: Perfmon: possible freeze starting at 10:07:58, delay is 1.103
2015.05.08 10:09:58 1: Perfmon: possible freeze starting at 10:09:57, delay is 1.165
2015.05.08 10:10:34 1: Perfmon: possible freeze starting at 10:10:33, delay is 1.12
2015.05.08 10:12:59 1: Perfmon: possible freeze starting at 10:12:58, delay is 1.096
2015.05.08 10:13:25 1: Perfmon: possible freeze starting at 10:13:24, delay is 1.154
2015.05.08 10:15:41 1: Perfmon: possible freeze starting at 10:15:40, delay is 1.083
2015.05.08 10:15:51 1: Perfmon: possible freeze starting at 10:15:50, delay is 1.144
2015.05.08 10:17:28 1: Perfmon: possible freeze starting at 10:17:27, delay is 1.167
2015.05.08 10:17:59 1: Perfmon: possible freeze starting at 10:17:58, delay is 1.074
2015.05.08 10:22:59 1: Perfmon: possible freeze starting at 10:22:58, delay is 1.122
2015.05.08 10:26:17 1: Perfmon: possible freeze starting at 10:26:16, delay is 1.185
2015.05.08 10:27:59 1: Perfmon: possible freeze starting at 10:27:58, delay is 1.113
2015.05.08 10:28:32 1: Perfmon: possible freeze starting at 10:28:31, delay is 1.083
2015.05.08 10:30:44 1: Perfmon: possible freeze starting at 10:30:43, delay is 1.168
2015.05.08 10:30:53 1: Perfmon: possible freeze starting at 10:30:52, delay is 1.184
2015.05.08 10:32:59 1: Perfmon: possible freeze starting at 10:32:58, delay is 1.186
2015.05.08 10:33:29 1: Perfmon: possible freeze starting at 10:33:28, delay is 1.112
2015.05.08 10:33:37 1: Perfmon: possible freeze starting at 10:33:36, delay is 1.175
2015.05.08 10:36:08 1: Perfmon: possible freeze starting at 10:36:07, delay is 1.091
2015.05.08 10:37:59 1: Perfmon: possible freeze starting at 10:37:58, delay is 1.081
2015.05.08 10:39:11 1: Perfmon: possible freeze starting at 10:39:10, delay is 1.216
2015.05.08 10:41:28 1: Perfmon: possible freeze starting at 10:41:27, delay is 1.283
2015.05.08 10:46:23 1: Perfmon: possible freeze starting at 10:46:22, delay is 1.199
2015.05.08 10:47:59 1: Perfmon: possible freeze starting at 10:47:58, delay is 1.07
2015.05.08 10:48:47 1: Perfmon: possible freeze starting at 10:48:46, delay is 1.19
2015.05.08 10:51:37 1: Perfmon: possible freeze starting at 10:51:36, delay is 1.176
2015.05.08 10:52:59 1: Perfmon: possible freeze starting at 10:52:58, delay is 1.042
2015.05.08 10:53:22 1: Perfmon: possible freeze starting at 10:53:21, delay is 1.27
2015.05.08 10:56:08 1: Perfmon: possible freeze starting at 10:56:07, delay is 1.125
2015.05.08 10:56:32 1: Perfmon: possible freeze starting at 10:56:31, delay is 1.002
2015.05.08 10:56:34 1: Perfmon: possible freeze starting at 10:56:33, delay is 1.207
2015.05.08 10:57:59 1: Perfmon: possible freeze starting at 10:57:58, delay is 1.106
2015.05.08 10:58:45 1: Perfmon: possible freeze starting at 10:58:44, delay is 1.167
2015.05.08 10:58:50 1: Perfmon: possible freeze starting at 10:58:49, delay is 1.208
2015.05.08 10:59:16 1: Perfmon: possible freeze starting at 10:59:15, delay is 1.231
2015.05.08 11:01:37 1: Perfmon: possible freeze starting at 11:01:36, delay is 1.19
2015.05.08 11:03:11 1: Perfmon: possible freeze starting at 11:03:07, delay is 4.026
2015.05.08 11:03:16 1: Perfmon: possible freeze starting at 11:03:15, delay is 1.121
2015.05.08 11:04:01 1: Perfmon: possible freeze starting at 11:04:00, delay is 1.214
2015.05.08 11:04:19 1: Perfmon: possible freeze starting at 11:04:18, delay is 1.232
2015.05.08 11:06:02 1: Perfmon: possible freeze starting at 11:06:01, delay is 1.21
2015.05.08 11:07:59 1: Perfmon: possible freeze starting at 11:07:58, delay is 1.044
2015.05.08 11:12:59 1: Perfmon: possible freeze starting at 11:12:58, delay is 1.011
2015.05.08 11:13:50 1: Perfmon: possible freeze starting at 11:13:49, delay is 1.211
2015.05.08 11:15:41 1: Perfmon: possible freeze starting at 11:15:40, delay is 1.125
2015.05.08 11:17:59 1: Perfmon: possible freeze starting at 11:17:58, delay is 1.054
2015.05.08 11:18:54 1: Perfmon: possible freeze starting at 11:18:53, delay is 1.255
2015.05.08 11:19:37 1: Perfmon: possible freeze starting at 11:19:36, delay is 1.208
2015.05.08 11:21:06 1: Perfmon: possible freeze starting at 11:21:05, delay is 1.17
2015.05.08 11:22:12 1: Perfmon: possible freeze starting at 11:22:11, delay is 1.246
2015.05.08 11:22:59 1: Perfmon: possible freeze starting at 11:22:58, delay is 1.091
2015.05.08 11:26:39 1: Perfmon: possible freeze starting at 11:26:38, delay is 1.053
2015.05.08 11:27:59 1: Perfmon: possible freeze starting at 11:27:58, delay is 1.065
2015.05.08 11:29:35 1: Perfmon: possible freeze starting at 11:29:34, delay is 1.115
2015.05.08 11:32:59 1: Perfmon: possible freeze starting at 11:32:58, delay is 1.056
2015.05.08 11:33:38 1: Perfmon: possible freeze starting at 11:33:37, delay is 1.124
2015.05.08 11:34:44 1: Perfmon: possible freeze starting at 11:34:43, delay is 1.001
2015.05.08 11:36:55 1: Perfmon: possible freeze starting at 11:36:54, delay is 1.198
2015.05.08 11:37:59 1: Perfmon: possible freeze starting at 11:37:58, delay is 1.034
2015.05.08 11:38:53 1: Perfmon: possible freeze starting at 11:38:52, delay is 1.135
2015.05.08 11:39:09 1: Perfmon: possible freeze starting at 11:39:08, delay is 1.219
2015.05.08 11:39:57 1: Perfmon: possible freeze starting at 11:39:56, delay is 1.205
2015.05.08 11:41:41 1: Perfmon: possible freeze starting at 11:41:40, delay is 1.13
2015.05.08 11:42:04 1: Perfmon: possible freeze starting at 11:42:03, delay is 1.262
2015.05.08 11:42:59 1: Perfmon: possible freeze starting at 11:42:58, delay is 1.053
2015.05.08 11:47:59 1: Perfmon: possible freeze starting at 11:47:58, delay is 1.037
2015.05.08 11:48:38 1: Perfmon: possible freeze starting at 11:48:37, delay is 1.22
2015.05.08 11:52:36 1: Perfmon: possible freeze starting at 11:52:35, delay is 1.443
2015.05.08 11:52:59 1: Perfmon: possible freeze starting at 11:52:58, delay is 1.034
2015.05.08 11:54:12 1: Perfmon: possible freeze starting at 11:54:11, delay is 1.185
2015.05.08 11:54:45 1: Perfmon: possible freeze starting at 11:54:44, delay is 1.198
2015.05.08 11:57:44 1: Perfmon: possible freeze starting at 11:57:43, delay is 1.243
2015.05.08 11:57:59 1: Perfmon: possible freeze starting at 11:57:58, delay is 1.059
2015.05.08 11:59:50 1: Perfmon: possible freeze starting at 11:59:49, delay is 1.23
2015.05.08 12:02:59 1: Perfmon: possible freeze starting at 12:02:58, delay is 1.308
2015.05.08 12:03:10 1: Perfmon: possible freeze starting at 12:03:07, delay is 3.765
2015.05.08 12:05:36 1: Perfmon: possible freeze starting at 12:05:35, delay is 1.255
2015.05.08 12:07:59 1: Perfmon: possible freeze starting at 12:07:58, delay is 1.065
2015.05.08 12:12:59 1: Perfmon: possible freeze starting at 12:12:58, delay is 1.111
2015.05.08 12:14:19 1: Perfmon: possible freeze starting at 12:14:18, delay is 1.155
2015.05.08 12:15:10 1: Perfmon: possible freeze starting at 12:15:09, delay is 1.275
2015.05.08 12:16:57 1: Perfmon: possible freeze starting at 12:16:56, delay is 1.152
2015.05.08 12:17:13 1: Perfmon: possible freeze starting at 12:17:12, delay is 1.203
2015.05.08 12:17:55 1: Perfmon: possible freeze starting at 12:17:54, delay is 1.237
2015.05.08 12:17:59 1: Perfmon: possible freeze starting at 12:17:58, delay is 1.311
2015.05.08 12:20:20 1: Perfmon: possible freeze starting at 12:20:19, delay is 1.012
2015.05.08 12:22:42 1: Perfmon: possible freeze starting at 12:22:41, delay is 1.006
2015.05.08 12:22:53 1: Perfmon: possible freeze starting at 12:22:52, delay is 1.252
2015.05.08 12:22:59 1: Perfmon: possible freeze starting at 12:22:58, delay is 1.246
2015.05.08 12:25:27 1: Perfmon: possible freeze starting at 12:25:26, delay is 1.246
2015.05.08 12:27:35 1: Perfmon: possible freeze starting at 12:27:34, delay is 1.008
2015.05.08 12:27:59 1: Perfmon: possible freeze starting at 12:27:58, delay is 1.256
2015.05.08 12:28:11 1: Perfmon: possible freeze starting at 12:28:10, delay is 1.27
2015.05.08 12:30:12 1: Perfmon: possible freeze starting at 12:30:11, delay is 1.064
2015.05.08 12:30:23 1: Perfmon: possible freeze starting at 12:30:22, delay is 1.735
Ich weiß nicht, woran es liegt, ob es der Raspberry ist, oder meine Konfiguration. Eine Theorie, die ich noch so im Hinterkopf habe wäre die Stromversorgung des Pi. Ich meine mal gelesen zu haben, das es Performanceprobleme geben kann, wenn er nicht direkt an nem Netzteil hängt. Aktuell hängt er bei mir per USB an einer Fritzbox 7490. Netzwerk läuft über Kabel und ansonsten hängt noch ein Bluetooth Dongle dran.
Ergänzend habe ich hier noch die Ausgabe von apptime:
                                name             function    max  count    total  average maxDly
                tmr-watchdog_Trigger      HASH(0x20f0138)   7955      1     7955  7955.00      5 HASH(wd.all.handy.josi.away)
                             rr_josi         ROOMMATE_Set   7949    282     7974    28.28      0 HASH(rr_josi); rr_josi; absent
                     ntfy.all.eltern          notify_Exec   5582  10601    23733     2.24      0 HASH(ntfy.all.eltern); HASH(rr_josi)
                          rr_lennard         ROOMMATE_Set   5563    283     8968    31.69      0 HASH(rr_lennard); rr_lennard; state; absent
                             rgr_all     RESIDENTS_Notify   3893  10601    14138     1.33      0 HASH(rgr_all); HASH(rr_lennard)
                tmr-watchdog_Trigger      HASH(0x1c78b20)   3527      2     7015  3507.50      2 HASH(wd.all.handy.alex.away)
                             rr_alex         ROOMMATE_Set   3521    284    10454    36.81      0 HASH(rr_alex); rr_alex; absent
                              HMLAN1          HMLAN_Ready   3403      2     3831  1915.50      0 HASH(HMLAN1)
                tmr-watchdog_Trigger      HASH(0x1c68d58)   3359      2     4132  2066.00      8 HASH(wd.all.handy.alex.here)
                              HMLAN1           HMLAN_Read   2543   5704  2713749   475.76      0 HASH(HMLAN1)
                        ntfy.rgr_all          notify_Exec   2431     25    12694   507.76      0 HASH(ntfy.rgr_all); HASH(rgr_all)
                         tmr-at_Exec      HASH(0x21376a0)   1695      1     1695  1695.00      4 HASH(at.all.lennard.awake)
                         tmr-at_Exec      HASH(0x20f0f20)   1691      1     1691  1691.00      3 HASH(at.all.lennard.sleep)
                tmr-watchdog_Trigger      HASH(0x20f0830)    765      1      765   765.00      6 HASH(wd.all.handy.josi.here)
             ntfy.roommates.location          notify_Exec    759  10601    14823     1.40      0 HASH(ntfy.roommates.location); HASH(rr_josi)
            tmr-HMLAN_KeepAliveCheck   keepAliveCk:HMLAN1    598   2853      618     0.22   3429 keepAliveCk:HMLAN1
                        alarm4.off.N          notify_Exec    570  10601   460548    43.44      0 HASH(alarm4.off.N); HASH(FritzBox)
                        alarm6.off.N          notify_Exec    555  10601   460354    43.43      0 HASH(alarm6.off.N); HASH(FritzBox)
                        alarm2.off.N          notify_Exec    552  10601   458300    43.23      0 HASH(alarm2.off.N); HASH(FritzBox)
                        alarm7.off.N          notify_Exec    552  10601   460133    43.40      0 HASH(alarm7.off.N); HASH(FritzBox)
                        alarm5.off.N          notify_Exec    550  10601   460333    43.42      0 HASH(alarm5.off.N); HASH(FritzBox)
Für meinen Geschmack sieht es von Apptime her so aus, als wäre das Problem das roommate/residents Modul. Wobei ich gefühlstechnisch gesagt hätte, das die Performance-Monitor meldungen kamen, als ich die Fritzbox eingebunden habe.
Hat jemand eine Idee, wie ich dem Problem auf den Grund kommen kann?
Ich denke, ich habe jetzt nicht sooooo viele Perl-Funktionen und Geräte, die jetzt den Raspberry auslasten würden oder überschätze ich ihn?
Danke schonmal!
RasPi mit HMLAN, 5x HM-SEC-SC, HM LED16 als Alarmanlagendisplay, HM-TC-IT-WM-W-EU, 4x HM-CC-RT-DN, 1x HM PBU, 1x HM PBI-4
Offline Wernieman
Antw:"Probleme" mit RaspberryPi Model B
« Antwort #1 am: 08 Mai 2015, 13:52:52 »
Versorge mal den PasPi direkt mit einem 2A Netzteil und nicht über die FritzBox. Ich weiß nicht, wie viel die "liefern" kann...
- Bitte um Input für Output
Offline PeMue
« Antwort #2 am: 08 Mai 2015, 16:29:28 »
die FritzBox kann meines Wissens nur 500 mA in Summe (wie es der Standard halt vorschreibt). Ist vermutlich für Stromspitzen für den RaspberryPi zu wenig.
Gruß PeMue
1x FB7170 (29.04.88) 5.7 1xCUNO2 1.67 2xEM1000WZ 2xUniroll 1xASH2200 3xHMS100T(F)
1x RPi BV2LCDCSM 1.63 5.7 2xMAX HKT, 1xMAX RT, V200KW1
1xFB 7490 (113.06.05) 5.7 1xCUL V3 1.63 1xHM-CC-RT-DN 1.4 1xHM-TC-IT-WM 1.1 1xHB-UW-Sen-THPL-O 0.15 1x-I 0.14OTAU 1xRFXtrx 90 1xWT440H 1xCM160 3xTFA30.3150 5xFA21
Offline selfarian
  • Full Member
« Antwort #3 am: 08 Mai 2015, 21:54:43 »
Ok. Danke. Ich habe mir jetzt mal in 2A Netzteil bestellt. Schauen wir mal, ob es hilft.
Offline selfarian
  • Full Member
« Antwort #4 am: 14 Mai 2015, 01:29:43 »
Ich habe den Raspberry jetzt an einem extra Netzteil mit 2A hängen und die logmeldungen bezüglich des freezes bleiben leider bestehen :/
Offline selfarian
  • Full Member
« Antwort #5 am: 19 Mai 2015, 08:38:21 »
So, hier nachdem das Ganze jetzt eine Weile läuft, hier ein paar weitere Infos, vielleicht hilft das weiter:
Apptime:
                tmr-watchdog_Trigger      HASH(0x15d5e28)   7956      2    11513  5756.50      3 HASH(wd.all.handy.alex.away)
                             rr_alex         ROOMMATE_Set   7950      5    15838  3167.60      0 HASH(rr_alex); rr_alex; absent
                     ntfy.all.eltern          notify_Exec   5668   8784    20890     2.38      0 HASH(ntfy.all.eltern); HASH(rr_alex)
                          rr_lennard         ROOMMATE_Set   5649      2     7434  3717.00      0 HASH(rr_lennard); rr_lennard; state; absent
                             rgr_all     RESIDENTS_Notify   4043   8784    13133     1.50      0 HASH(rgr_all); HASH(rr_lennard)
                tmr-watchdog_Trigger      HASH(0x1a5f878)   3556      1     3556  3556.00      2 HASH(wd.all.handy.josi.away)
                             rr_josi         ROOMMATE_Set   3550      4     5344  1336.00      0 HASH(rr_josi); rr_josi; absent
                tmr-watchdog_Trigger      HASH(0x15faed0)   3419      2     4229  2114.50     12 HASH(wd.all.handy.alex.here)
                              HMLAN1          HMLAN_Ready   3010     82     3435    41.89      0 HASH(HMLAN1)
                              HMLAN1           HMLAN_Read   2717   4696  2299576   489.69      0 HASH(HMLAN1)
                        ntfy.rgr_all          notify_Exec   2563     29    13388   461.66      0 HASH(ntfy.rgr_all); HASH(rgr_all)
                         tmr-at_Exec      HASH(0x1a76400)   1793      1     1793  1793.00      4 HASH(at.all.lennard.sleep)
                            ntfy.PCs          notify_Exec    942   8784    12124     1.38      0 HASH(ntfy.PCs); HASH(eg.az.pc.alex)
                tmr-watchdog_Trigger      HASH(0x1a75d10)    791      1      791   791.00      7 HASH(wd.all.handy.josi.here)
             ntfy.roommates.location          notify_Exec    731   8784    15413     1.75      0 HASH(ntfy.roommates.location); HASH(rr_alex)
        FHEMWEB:192.168.178.202:1972              FW_Read    640      5      685   137.00      0 HASH(FHEMWEB:192.168.178.202:1972)
            tmr-HMLAN_KeepAliveCheck   keepAliveCk:HMLAN1    618   2347      628     0.27   3148 keepAliveCk:HMLAN1
                        alarm4.off.N          notify_Exec    563   8784   389942    44.39      0 HASH(alarm4.off.N); HASH(FritzBox)
                        alarm7.off.N          notify_Exec    563   8784   389271    44.32      0 HASH(alarm7.off.N); HASH(FritzBox)
                        alarm2.off.N          notify_Exec    562   8784   387167    44.08      0 HASH(alarm2.off.N); HASH(FritzBox)
                        alarm6.off.N          notify_Exec    561   8784   389144    44.30      0 HASH(alarm6.off.N); HASH(FritzBox)
Und das Logfile... relativ eintönig:
2015.05.19 00:04:37 1: Perfmon: possible freeze starting at 00:04:34, delay is 3.918
2015.05.19 00:04:39 1: Perfmon: possible freeze starting at 00:04:38, delay is 1.225
2015.05.19 00:06:49 1: Perfmon: possible freeze starting at 00:06:48, delay is 1.158
2015.05.19 00:09:26 1: Perfmon: possible freeze starting at 00:09:25, delay is 1.1
2015.05.19 00:10:10 1: Perfmon: possible freeze starting at 00:10:09, delay is 1.214
2015.05.19 00:14:26 1: Perfmon: possible freeze starting at 00:14:25, delay is 1.126
2015.05.19 00:16:01 1: Perfmon: possible freeze starting at 00:16:00, delay is 1.115
2015.05.19 00:17:44 1: Perfmon: possible freeze starting at 00:17:43, delay is 1.213
2015.05.19 00:19:21 1: Perfmon: possible freeze starting at 00:19:20, delay is 1.229
2015.05.19 00:19:26 1: Perfmon: possible freeze starting at 00:19:25, delay is 1.112
2015.05.19 00:20:45 1: Perfmon: possible freeze starting at 00:20:44, delay is 1.131
2015.05.19 00:21:21 1: Perfmon: possible freeze starting at 00:21:20, delay is 1.226
2015.05.19 00:23:00 1: Perfmon: possible freeze starting at 00:22:59, delay is 1.215
2015.05.19 00:24:26 1: Perfmon: possible freeze starting at 00:24:25, delay is 1.053
2015.05.19 00:29:26 1: Perfmon: possible freeze starting at 00:29:25, delay is 1.121
2015.05.19 00:30:27 1: Perfmon: possible freeze starting at 00:30:26, delay is 1.129
2015.05.19 00:32:45 1: Perfmon: possible freeze starting at 00:32:44, delay is 1.132
2015.05.19 00:34:26 1: Perfmon: possible freeze starting at 00:34:25, delay is 1.15
2015.05.19 00:39:26 1: Perfmon: possible freeze starting at 00:39:25, delay is 1.147
2015.05.19 00:40:44 1: Perfmon: possible freeze starting at 00:40:43, delay is 1.106
2015.05.19 00:42:57 1: Perfmon: possible freeze starting at 00:42:56, delay is 1.109
2015.05.19 00:44:26 1: Perfmon: possible freeze starting at 00:44:25, delay is 1.212
2015.05.19 00:47:42 1: Perfmon: possible freeze starting at 00:47:41, delay is 1.223
2015.05.19 00:49:26 1: Perfmon: possible freeze starting at 00:49:25, delay is 1.185
2015.05.19 00:49:42 1: Perfmon: possible freeze starting at 00:49:41, delay is 1.234
2015.05.19 00:53:10 1: Perfmon: possible freeze starting at 00:53:09, delay is 1.148
2015.05.19 00:54:26 1: Perfmon: possible freeze starting at 00:54:25, delay is 1.259
2015.05.19 00:55:07 1: Perfmon: possible freeze starting at 00:55:06, delay is 1.229
2015.05.19 00:57:10 1: Perfmon: possible freeze starting at 00:57:09, delay is 1.004
2015.05.19 00:57:29 1: Perfmon: possible freeze starting at 00:57:28, delay is 1.285
2015.05.19 00:59:26 1: Perfmon: possible freeze starting at 00:59:25, delay is 1.208
2015.05.19 01:04:37 1: Perfmon: possible freeze starting at 01:04:34, delay is 3.995
2015.05.19 01:05:19 1: Perfmon: possible freeze starting at 01:05:18, delay is 1.174
2015.05.19 01:07:27 1: Perfmon: possible freeze starting at 01:07:26, delay is 1.162
2015.05.19 01:07:39 1: Perfmon: possible freeze starting at 01:07:38, delay is 1.001
2015.05.19 01:09:26 1: Perfmon: possible freeze starting at 01:09:25, delay is 1.186
2015.05.19 01:12:43 1: Perfmon: possible freeze starting at 01:12:42, delay is 1.277
2015.05.19 01:12:54 1: Perfmon: possible freeze starting at 01:12:53, delay is 1.002
2015.05.19 01:13:08 1: Perfmon: possible freeze starting at 01:13:07, delay is 1.175
2015.05.19 01:14:26 1: Perfmon: possible freeze starting at 01:14:25, delay is 1.253
2015.05.19 01:15:00 1: Perfmon: possible freeze starting at 01:14:59, delay is 1.286
2015.05.19 01:16:33 1: Perfmon: possible freeze starting at 01:16:32, delay is 1.144
2015.05.19 01:17:03 1: Perfmon: possible freeze starting at 01:17:02, delay is 1.034
2015.05.19 01:18:15 1: Perfmon: possible freeze starting at 01:18:14, delay is 1.254
2015.05.19 01:18:36 1: Perfmon: possible freeze starting at 01:18:35, delay is 1.147
2015.05.19 01:19:26 1: Perfmon: possible freeze starting at 01:19:25, delay is 1.243
2015.05.19 01:19:55 1: Perfmon: possible freeze starting at 01:19:54, delay is 1.281
2015.05.19 01:20:34 1: Perfmon: possible freeze starting at 01:20:33, delay is 1.258
2015.05.19 01:22:33 1: Perfmon: possible freeze starting at 01:22:32, delay is 1.038
2015.05.19 01:24:26 1: Perfmon: possible freeze starting at 01:24:25, delay is 1.31
2015.05.19 01:24:56 1: Perfmon: possible freeze starting at 01:24:55, delay is 1.303
2015.05.19 01:25:16 1: Perfmon: possible freeze starting at 01:25:15, delay is 1.189
2015.05.19 01:25:33 1: Perfmon: possible freeze starting at 01:25:32, delay is 1.021
2015.05.19 01:27:05 1: Perfmon: possible freeze starting at 01:27:04, delay is 1.289
2015.05.19 01:29:26 1: Perfmon: possible freeze starting at 01:29:25, delay is 1.262
2015.05.19 01:29:43 1: Perfmon: possible freeze starting at 01:29:42, delay is 1.187
2015.05.19 01:30:38 1: Perfmon: possible freeze starting at 01:30:37, delay is 1.018
2015.05.19 01:32:39 1: Perfmon: possible freeze starting at 01:32:38, delay is 1.18
2015.05.19 01:32:49 1: Perfmon: possible freeze starting at 01:32:48, delay is 1.092
2015.05.19 01:34:27 1: Perfmon: possible freeze starting at 01:34:26, delay is 1.469
2015.05.19 01:35:49 1: Perfmon: possible freeze starting at 01:35:48, delay is 1.264
2015.05.19 01:38:35 1: Perfmon: possible freeze starting at 01:38:34, delay is 1.249
2015.05.19 01:39:09 1: Perfmon: possible freeze starting at 01:39:08, delay is 1.135
2015.05.19 01:39:27 1: Perfmon: possible freeze starting at 01:39:26, delay is 1.462
2015.05.19 01:40:00 1: Perfmon: possible freeze starting at 01:39:59, delay is 1.177
2015.05.19 01:42:24 1: Perfmon: possible freeze starting at 01:42:23, delay is 1.047
2015.05.19 01:43:24 1: Perfmon: possible freeze starting at 01:43:23, delay is 1.017
2015.05.19 01:44:01 1: Perfmon: possible freeze starting at 01:44:00, delay is 1.147
2015.05.19 01:44:27 1: Perfmon: possible freeze starting at 01:44:26, delay is 1.5
2015.05.19 01:45:00 1: Perfmon: possible freeze starting at 01:44:59, delay is 1.05
2015.05.19 01:45:50 1: Perfmon: possible freeze starting at 01:45:49, delay is 1.19
2015.05.19 01:48:19 1: Perfmon: possible freeze starting at 01:48:18, delay is 1.024
2015.05.19 01:49:27 1: Perfmon: possible freeze starting at 01:49:26, delay is 1.497
2015.05.19 01:50:57 1: Perfmon: possible freeze starting at 01:50:56, delay is 1.016
2015.05.19 01:51:07 1: Perfmon: possible freeze starting at 01:51:06, delay is 1.144
2015.05.19 01:54:04 1: Perfmon: possible freeze starting at 01:54:03, delay is 1.148
2015.05.19 01:54:27 1: Perfmon: possible freeze starting at 01:54:26, delay is 1.486
2015.05.19 01:58:28 1: Perfmon: possible freeze starting at 01:58:27, delay is 1.282
2015.05.19 01:59:15 1: Perfmon: possible freeze starting at 01:59:14, delay is 1.152
2015.05.19 01:59:27 1: Perfmon: possible freeze starting at 01:59:26, delay is 1.568
2015.05.19 01:59:49 1: Perfmon: possible freeze starting at 01:59:48, delay is 1.065
2015.05.19 02:02:52 1: Perfmon: possible freeze starting at 02:02:51, delay is 1.059
2015.05.19 02:03:42 1: Perfmon: possible freeze starting at 02:03:41, delay is 1.284
2015.05.19 02:04:39 1: Perfmon: possible freeze starting at 02:04:36, delay is 3.32
2015.05.19 02:05:57 1: Perfmon: possible freeze starting at 02:05:56, delay is 1.211
2015.05.19 02:08:43 1: Perfmon: possible freeze starting at 02:08:42, delay is 1.22
2015.05.19 02:09:27 1: Perfmon: possible freeze starting at 02:09:26, delay is 1.692
2015.05.19 02:10:49 1: Perfmon: possible freeze starting at 02:10:48, delay is 1.047
2015.05.19 02:12:16 1: Perfmon: possible freeze starting at 02:12:15, delay is 1.158
2015.05.19 02:13:25 1: Perfmon: possible freeze starting at 02:13:24, delay is 1.038
2015.05.19 02:14:27 1: Perfmon: possible freeze starting at 02:14:26, delay is 1.653
2015.05.19 02:17:17 1: Perfmon: possible freeze starting at 02:17:16, delay is 1.159
2015.05.19 02:17:54 1: Perfmon: possible freeze starting at 02:17:53, delay is 1.041
2015.05.19 02:19:27 1: Perfmon: possible freeze starting at 02:19:26, delay is 1.547
2015.05.19 02:19:58 1: Perfmon: possible freeze starting at 02:19:57, delay is 1.17
2015.05.19 02:22:53 1: Perfmon: possible freeze starting at 02:22:52, delay is 1.099
2015.05.19 02:23:33 1: Perfmon: possible freeze starting at 02:23:32, delay is 1.309
2015.05.19 02:24:27 1: Perfmon: possible freeze starting at 02:24:26, delay is 1.586
2015.05.19 02:27:38 1: Perfmon: possible freeze starting at 02:27:37, delay is 1.171
2015.05.19 02:28:15 1: Perfmon: possible freeze starting at 02:28:14, delay is 1.053
2015.05.19 02:28:41 1: Perfmon: possible freeze starting at 02:28:40, delay is 1.095
2015.05.19 02:29:27 1: Perfmon: possible freeze starting at 02:29:26, delay is 1.519
2015.05.19 02:32:58 1: Perfmon: possible freeze starting at 02:32:57, delay is 1.164
2015.05.19 02:34:07 1: Perfmon: possible freeze starting at 02:34:06, delay is 1.051
2015.05.19 02:34:27 1: Perfmon: possible freeze starting at 02:34:26, delay is 1.46
2015.05.19 02:39:01 1: Perfmon: possible freeze starting at 02:39:00, delay is 1.064
2015.05.19 02:39:27 1: Perfmon: possible freeze starting at 02:39:26, delay is 1.517
2015.05.19 02:40:56 1: Perfmon: possible freeze starting at 02:40:55, delay is 1.24
2015.05.19 02:43:32 1: Perfmon: possible freeze starting at 02:43:31, delay is 1.234
2015.05.19 02:44:27 1: Perfmon: possible freeze starting at 02:44:26, delay is 1.501
2015.05.19 02:46:42 1: Perfmon: possible freeze starting at 02:46:41, delay is 1.07
2015.05.19 02:48:40 1: Perfmon: possible freeze starting at 02:48:39, delay is 1.114
2015.05.19 02:49:27 1: Perfmon: possible freeze starting at 02:49:26, delay is 1.553
2015.05.19 02:51:20 1: Perfmon: possible freeze starting at 02:51:19, delay is 1.059
2015.05.19 02:51:25 1: Perfmon: possible freeze starting at 02:51:24, delay is 1.164
2015.05.19 02:54:27 1: Perfmon: possible freeze starting at 02:54:26, delay is 1.564
2015.05.19 02:59:27 1: Perfmon: possible freeze starting at 02:59:26, delay is 1.497
2015.05.19 03:02:54 1: Perfmon: possible freeze starting at 03:02:53, delay is 1.164
2015.05.19 03:04:13 1: Perfmon: possible freeze starting at 03:04:12, delay is 1.234
2015.05.19 03:04:39 1: Perfmon: possible freeze starting at 03:04:36, delay is 3.373
2015.05.19 03:07:54 1: Perfmon: possible freeze starting at 03:07:53, delay is 1.184
2015.05.19 03:09:07 1: Perfmon: possible freeze starting at 03:09:06, delay is 1.246
2015.05.19 03:09:27 1: Perfmon: possible freeze starting at 03:09:26, delay is 1.478
2015.05.19 03:09:52 3: Watchdog wd.all.handy.alex.away triggered
2015.05.19 03:09:52 2: ROOMMATE set rr_alex absent
2015.05.19 03:09:56 1: Perfmon: possible freeze starting at 03:09:53, delay is 3.153
2015.05.19 03:14:27 1: Perfmon: possible freeze starting at 03:14:26, delay is 1.557
2015.05.19 03:15:44 1: Perfmon: possible freeze starting at 03:15:43, delay is 1.2
2015.05.19 03:16:48 1: Perfmon: possible freeze starting at 03:16:47, delay is 1.014
2015.05.19 03:19:14 1: Perfmon: possible freeze starting at 03:19:13, delay is 1.067
2015.05.19 03:19:27 1: Perfmon: possible freeze starting at 03:19:26, delay is 1.598
2015.05.19 03:20:28 1: Perfmon: possible freeze starting at 03:20:27, delay is 1.173
2015.05.19 03:22:24 1: Perfmon: possible freeze starting at 03:22:23, delay is 1.074
2015.05.19 03:23:25 1: Perfmon: possible freeze starting at 03:23:24, delay is 1.128
2015.05.19 03:24:27 1: Perfmon: possible freeze starting at 03:24:26, delay is 1.079
2015.05.19 03:25:18 1: Perfmon: possible freeze starting at 03:25:17, delay is 1.176
2015.05.19 03:26:00 1: Perfmon: possible freeze starting at 03:25:59, delay is 1.134
2015.05.19 03:29:27 1: Perfmon: possible freeze starting at 03:29:26, delay is 1.542
2015.05.19 03:29:46 1: Perfmon: possible freeze starting at 03:29:45, delay is 1.251
2015.05.19 03:32:04 1: Perfmon: possible freeze starting at 03:32:03, delay is 1.264
2015.05.19 03:32:21 1: Perfmon: possible freeze starting at 03:32:20, delay is 1.191
2015.05.19 03:34:27 1: Perfmon: possible freeze starting at 03:34:26, delay is 1.592
2015.05.19 03:34:33 1: Perfmon: possible freeze starting at 03:34:32, delay is 1.096
2015.05.19 03:37:01 1: Perfmon: possible freeze starting at 03:37:00, delay is 1.035
2015.05.19 03:37:59 1: Perfmon: possible freeze starting at 03:37:58, delay is 1.245
2015.05.19 03:39:27 1: Perfmon: possible freeze starting at 03:39:26, delay is 1.558
2015.05.19 03:39:39 1: Perfmon: possible freeze starting at 03:39:38, delay is 1.101
2015.05.19 03:42:04 1: Perfmon: possible freeze starting at 03:42:03, delay is 1.012
2015.05.19 03:44:27 1: Perfmon: possible freeze starting at 03:44:26, delay is 1.5
2015.05.19 03:44:51 1: Perfmon: possible freeze starting at 03:44:50, delay is 1.082
2015.05.19 03:44:58 1: Perfmon: possible freeze starting at 03:44:57, delay is 1.253
2015.05.19 03:46:33 1: Perfmon: possible freeze starting at 03:46:32, delay is 1.132
2015.05.19 03:47:38 1: Perfmon: possible freeze starting at 03:47:37, delay is 1.013
2015.05.19 03:49:27 1: Perfmon: possible freeze starting at 03:49:26, delay is 1.674
2015.05.19 03:51:25 1: Perfmon: possible freeze starting at 03:51:24, delay is 1.156
2015.05.19 03:51:55 1: Perfmon: possible freeze starting at 03:51:54, delay is 1.252
2015.05.19 03:54:27 1: Perfmon: possible freeze starting at 03:54:26, delay is 1.671
2015.05.19 03:55:15 1: Perfmon: possible freeze starting at 03:55:14, delay is 1.029
2015.05.19 03:56:51 1: Perfmon: possible freeze starting at 03:56:50, delay is 1.117
2015.05.19 03:58:01 1: Perfmon: possible freeze starting at 03:58:00, delay is 1.283
2015.05.19 03:59:03 1: Perfmon: possible freeze starting at 03:59:02, delay is 1.174
2015.05.19 03:59:27 1: Perfmon: possible freeze starting at 03:59:26, delay is 1.582
2015.05.19 04:00:33 1: Perfmon: possible freeze starting at 04:00:32, delay is 1.048
2015.05.19 04:01:28 1: Perfmon: possible freeze starting at 04:01:27, delay is 1.187
2015.05.19 04:02:50 1: Perfmon: possible freeze starting at 04:02:49, delay is 1.3
2015.05.19 04:04:35 1: Perfmon: possible freeze starting at 04:04:34, delay is 1.259
2015.05.19 04:04:39 1: Perfmon: possible freeze starting at 04:04:36, delay is 3.456
2015.05.19 04:04:53 1: Perfmon: possible freeze starting at 04:04:52, delay is 1.045
2015.05.19 04:06:39 1: Perfmon: possible freeze starting at 04:06:38, delay is 1.243
2015.05.19 04:08:39 1: Perfmon: possible freeze starting at 04:08:38, delay is 1.203
2015.05.19 04:09:25 1: Perfmon: possible freeze starting at 04:09:24, delay is 1.142
2015.05.19 04:09:27 1: Perfmon: possible freeze starting at 04:09:26, delay is 1.634
2015.05.19 04:12:47 1: Perfmon: possible freeze starting at 04:12:46, delay is 1.05
2015.05.19 04:13:57 1: Perfmon: possible freeze starting at 04:13:56, delay is 1.215
2015.05.19 04:14:27 1: Perfmon: possible freeze starting at 04:14:26, delay is 1.625
2015.05.19 04:14:56 1: Perfmon: possible freeze starting at 04:14:55, delay is 1.31
2015.05.19 04:16:16 1: Perfmon: possible freeze starting at 04:16:15, delay is 1.033
2015.05.19 04:17:55 1: Perfmon: possible freeze starting at 04:17:54, delay is 1.238
2015.05.19 04:19:08 1: Perfmon: possible freeze starting at 04:19:07, delay is 1.199
2015.05.19 04:19:27 1: Perfmon: possible freeze starting at 04:19:26, delay is 1.608
2015.05.19 04:20:39 1: Perfmon: possible freeze starting at 04:20:38, delay is 1.308
2015.05.19 04:21:10 1: Perfmon: possible freeze starting at 04:21:09, delay is 1.207
2015.05.19 04:22:01 1: Perfmon: possible freeze starting at 04:22:00, delay is 1.166
2015.05.19 04:23:09 1: Perfmon: possible freeze starting at 04:23:08, delay is 1.333
2015.05.19 04:24:09 1: Perfmon: possible freeze starting at 04:24:08, delay is 1.189
2015.05.19 04:24:27 1: Perfmon: possible freeze starting at 04:24:26, delay is 1.579
2015.05.19 04:24:55 1: Perfmon: possible freeze starting at 04:24:54, delay is 1.133
2015.05.19 04:26:12 1: Perfmon: possible freeze starting at 04:26:11, delay is 1.204
2015.05.19 04:26:18 1: Perfmon: possible freeze starting at 04:26:17, delay is 1.18
2015.05.19 04:29:27 1: Perfmon: possible freeze starting at 04:29:26, delay is 1.592
2015.05.19 04:30:00 1: Perfmon: possible freeze starting at 04:29:59, delay is 1.118
2015.05.19 04:31:20 1: Perfmon: possible freeze starting at 04:31:19, delay is 1.199
2015.05.19 04:34:27 1: Perfmon: possible freeze starting at 04:34:26, delay is 1.585
2015.05.19 04:34:30 1: Perfmon: possible freeze starting at 04:34:29, delay is 1.191
2015.05.19 04:38:46 1: Perfmon: possible freeze starting at 04:38:45, delay is 1.201
2015.05.19 04:38:50 1: Perfmon: possible freeze starting at 04:38:49, delay is 1.216
2015.05.19 04:39:27 1: Perfmon: possible freeze starting at 04:39:26, delay is 1.583
2015.05.19 04:44:27 1: Perfmon: possible freeze starting at 04:44:26, delay is 1.643
2015.05.19 04:46:34 1: Perfmon: possible freeze starting at 04:46:33, delay is 1.186
2015.05.19 04:47:42 1: Perfmon: possible freeze starting at 04:47:41, delay is 1.21
2015.05.19 04:49:27 1: Perfmon: possible freeze starting at 04:49:26, delay is 1.72
2015.05.19 04:52:42 1: Perfmon: possible freeze starting at 04:52:41, delay is 1.14
2015.05.19 04:53:35 1: Perfmon: possible freeze starting at 04:53:34, delay is 1.063
2015.05.19 04:54:27 1: Perfmon: possible freeze starting at 04:54:26, delay is 1.644
2015.05.19 04:54:51 1: Perfmon: possible freeze starting at 04:54:50, delay is 1.155
2015.05.19 04:59:01 1: Perfmon: possible freeze starting at 04:59:00, delay is 1.23
2015.05.19 04:59:27 1: Perfmon: possible freeze starting at 04:59:26, delay is 1.647
2015.05.19 05:00:35 1: Perfmon: possible freeze starting at 05:00:34, delay is 1.223
2015.05.19 05:02:04 1: Perfmon: possible freeze starting at 05:02:03, delay is 1.226
2015.05.19 05:04:39 1: Perfmon: possible freeze starting at 05:04:36, delay is 3.475
2015.05.19 05:06:11 1: Perfmon: possible freeze starting at 05:06:10, delay is 1.13
2015.05.19 05:09:27 1: Perfmon: possible freeze starting at 05:09:26, delay is 1.657
2015.05.19 05:10:09 1: Perfmon: possible freeze starting at 05:10:08, delay is 1.237
2015.05.19 05:10:49 1: Perfmon: possible freeze starting at 05:10:48, delay is 1.198
2015.05.19 05:12:59 1: Perfmon: possible freeze starting at 05:12:58, delay is 1.225
2015.05.19 05:14:27 1: Perfmon: possible freeze starting at 05:14:26, delay is 1.632
2015.05.19 05:17:15 1: Perfmon: possible freeze starting at 05:17:14, delay is 1.207
2015.05.19 05:17:56 1: Perfmon: possible freeze starting at 05:17:55, delay is 1.231
2015.05.19 05:19:10 1: Perfmon: possible freeze starting at 05:19:09, delay is 1.094
2015.05.19 05:19:27 1: Perfmon: possible freeze starting at 05:19:26, delay is 1.751
2015.05.19 05:22:54 1: Perfmon: possible freeze starting at 05:22:53, delay is 1.19
2015.05.19 05:22:59 1: Perfmon: possible freeze starting at 05:22:58, delay is 1.237
2015.05.19 05:23:32 1: Perfmon: possible freeze starting at 05:23:31, delay is 1.1
2015.05.19 05:24:27 1: Perfmon: possible freeze starting at 05:24:26, delay is 1.649
2015.05.19 05:25:22 1: Perfmon: possible freeze starting at 05:25:21, delay is 1.184
2015.05.19 05:25:41 1: Perfmon: possible freeze starting at 05:25:40, delay is 1.24
2015.05.19 05:29:27 1: Perfmon: possible freeze starting at 05:29:26, delay is 1.657
2015.05.19 05:34:27 1: Perfmon: possible freeze starting at 05:34:26, delay is 1.697
2015.05.19 05:34:46 1: Perfmon: possible freeze starting at 05:34:45, delay is 1.003
2015.05.19 05:39:28 1: Perfmon: possible freeze starting at 05:39:27, delay is 1.101
2015.05.19 05:44:28 1: Perfmon: possible freeze starting at 05:44:27, delay is 1.09
2015.05.19 05:50:40 1: Perfmon: possible freeze starting at 05:50:39, delay is 1.196
2015.05.19 05:53:06 1: Perfmon: possible freeze starting at 05:53:05, delay is 1.263
2015.05.19 05:54:04 1: Perfmon: possible freeze starting at 05:54:03, delay is 1.112
2015.05.19 05:55:22 1: Perfmon: possible freeze starting at 05:55:21, delay is 1.268
2015.05.19 05:56:28 1: Perfmon: possible freeze starting at 05:56:27, delay is 1.2
2015.05.19 05:57:24 1: Perfmon: possible freeze starting at 05:57:23, delay is 1.015
2015.05.19 05:59:10 1: Perfmon: possible freeze starting at 05:59:09, delay is 1.014
2015.05.19 06:00:15 1: Perfmon: possible freeze starting at 06:00:14, delay is 1.302
2015.05.19 06:02:52 1: Perfmon: possible freeze starting at 06:02:51, delay is 1.02
2015.05.19 06:03:22 1: Perfmon: possible freeze starting at 06:03:21, delay is 1.191
2015.05.19 06:04:39 1: Perfmon: possible freeze starting at 06:04:36, delay is 3.871
2015.05.19 06:05:14 1: Perfmon: possible freeze starting at 06:05:13, delay is 1.296
2015.05.19 06:06:37 1: Perfmon: possible freeze starting at 06:06:36, delay is 1.139
2015.05.19 06:07:22 1: Perfmon: possible freeze starting at 06:07:21, delay is 1.29
2015.05.19 06:08:54 1: Perfmon: possible freeze starting at 06:08:53, delay is 1.213
2015.05.19 06:09:28 1: Perfmon: possible freeze starting at 06:09:27, delay is 1.098
2015.05.19 06:11:27 1: Perfmon: possible freeze starting at 06:11:26, delay is 1.134
2015.05.19 06:14:28 1: Perfmon: possible freeze starting at 06:14:27, delay is 1.066
2015.05.19 06:16:07 1: Perfmon: possible freeze starting at 06:16:06, delay is 1.286
2015.05.19 06:16:23 1: Perfmon: possible freeze starting at 06:16:22, delay is 1.131
2015.05.19 06:19:06 1: Perfmon: possible freeze starting at 06:19:05, delay is 1.305
2015.05.19 06:19:28 1: Perfmon: possible freeze starting at 06:19:27, delay is 1.022
2015.05.19 06:23:39 1: Perfmon: possible freeze starting at 06:23:38, delay is 1.04
2015.05.19 06:24:07 1: Perfmon: possible freeze starting at 06:24:06, delay is 1.138
2015.05.19 06:24:21 1: Perfmon: possible freeze starting at 06:24:20, delay is 1.183
2015.05.19 06:24:28 1: Perfmon: possible freeze starting at 06:24:27, delay is 1.012
2015.05.19 06:26:14 1: Perfmon: possible freeze starting at 06:26:13, delay is 1.055
2015.05.19 06:28:38 1: Perfmon: possible freeze starting at 06:28:37, delay is 1.006
2015.05.19 06:28:47 1: Perfmon: possible freeze starting at 06:28:46, delay is 1.149
2015.05.19 06:29:28 1: Perfmon: possible freeze starting at 06:29:27, delay is 1.037
2015.05.19 06:31:10 3: Watchdog wd.all.handy.alex.here triggered
2015.05.19 06:31:10 2: ROOMMATE set rr_alex home
2015.05.19 06:31:14 1: Perfmon: possible freeze starting at 06:31:11, delay is 3.29
2015.05.19 06:31:29 1: Perfmon: possible freeze starting at 06:31:28, delay is 1.021
2015.05.19 06:33:52 1: Perfmon: possible freeze starting at 06:33:51, delay is 1.235
2015.05.19 06:34:28 1: Perfmon: possible freeze starting at 06:34:27, delay is 1.215
2015.05.19 06:36:00 1: Perfmon: possible freeze starting at 06:35:59, delay is 1.237
2015.05.19 06:38:35 1: Perfmon: possible freeze starting at 06:38:34, delay is 1.254
2015.05.19 06:39:28 1: Perfmon: possible freeze starting at 06:39:27, delay is 1.121
2015.05.19 06:40:57 1: Perfmon: possible freeze starting at 06:40:56, delay is 1.056
2015.05.19 06:41:41 1: Perfmon: possible freeze starting at 06:41:40, delay is 1.221
2015.05.19 06:43:59 1: Perfmon: possible freeze starting at 06:43:58, delay is 1.063
2015.05.19 06:44:15 1: Perfmon: possible freeze starting at 06:44:14, delay is 1.26
2015.05.19 06:44:28 1: Perfmon: possible freeze starting at 06:44:27, delay is 1.127
2015.05.19 06:46:24 1: Perfmon: possible freeze starting at 06:46:23, delay is 1.222
2015.05.19 06:48:24 1: Perfmon: possible freeze starting at 06:48:23, delay is 1.218
2015.05.19 06:49:28 1: Perfmon: possible freeze starting at 06:49:27, delay is 1.185
2015.05.19 06:52:01 1: Perfmon: possible freeze starting at 06:52:00, delay is 1.271
2015.05.19 06:54:28 1: Perfmon: possible freeze starting at 06:54:27, delay is 1.149
2015.05.19 06:54:45 1: Perfmon: possible freeze starting at 06:54:44, delay is 1.169
2015.05.19 06:54:50 1: Perfmon: possible freeze starting at 06:54:49, delay is 1.277
2015.05.19 06:57:25 1: Perfmon: possible freeze starting at 06:57:24, delay is 1.017
2015.05.19 06:57:31 1: Perfmon: possible freeze starting at 06:57:30, delay is 1.169
2015.05.19 06:59:28 1: Perfmon: possible freeze starting at 06:59:27, delay is 1.13
2015.05.19 06:59:45 1: Perfmon: possible freeze starting at 06:59:44, delay is 1.262
2015.05.19 07:01:51 1: Perfmon: possible freeze starting at 07:01:50, delay is 1.024
2015.05.19 07:02:20 1: Perfmon: possible freeze starting at 07:02:19, delay is 1.172
2015.05.19 07:03:52 1: Perfmon: possible freeze starting at 07:03:51, delay is 1.08
2015.05.19 07:04:40 1: Perfmon: possible freeze starting at 07:04:37, delay is 3.201
2015.05.19 07:06:20 1: Perfmon: possible freeze starting at 07:06:19, delay is 1
2015.05.19 07:09:28 1: Perfmon: possible freeze starting at 07:09:27, delay is 1.163
2015.05.19 07:09:38 1: Perfmon: possible freeze starting at 07:09:37, delay is 1.068
2015.05.19 07:12:06 1: Perfmon: possible freeze starting at 07:12:05, delay is 1.255
2015.05.19 07:13:14 3: Watchdog wd.all.handy.josi.away triggered
2015.05.19 07:13:14 2: ROOMMATE set rr_josi absent
2015.05.19 07:13:17 1: Perfmon: possible freeze starting at 07:13:15, delay is 2.728
2015.05.19 07:14:26 1: Perfmon: possible freeze starting at 07:14:25, delay is 1.248
2015.05.19 07:14:29 1: Perfmon: possible freeze starting at 07:14:28, delay is 1.448
2015.05.19 07:15:08 1: Perfmon: possible freeze starting at 07:15:07, delay is 1.028
2015.05.19 07:17:55 1: Perfmon: possible freeze starting at 07:17:54, delay is 1.272
2015.05.19 07:19:28 1: Perfmon: possible freeze starting at 07:19:27, delay is 1.22
2015.05.19 07:20:28 1: Perfmon: possible freeze starting at 07:20:27, delay is 1.272
2015.05.19 07:21:19 1: Perfmon: possible freeze starting at 07:21:18, delay is 1.023
2015.05.19 07:24:13 1: Perfmon: possible freeze starting at 07:24:12, delay is 1.053
2015.05.19 07:24:28 1: Perfmon: possible freeze starting at 07:24:27, delay is 1.174
2015.05.19 07:24:54 1: Perfmon: possible freeze starting at 07:24:53, delay is 1.189
2015.05.19 07:25:17 3: Watchdog wd.all.handy.alex.away triggered
2015.05.19 07:25:17 2: ROOMMATE set rr_alex absent
2015.05.19 07:25:18 2: ROOMMATE set rr_lennard absent
2015.05.19 07:25:25 1: Perfmon: possible freeze starting at 07:25:18, delay is 7.937
2015.05.19 07:26:55 1: Perfmon: possible freeze starting at 07:26:54, delay is 1.231
2015.05.19 07:27:44 1: Perfmon: possible freeze starting at 07:27:43, delay is 1.284
2015.05.19 07:29:28 1: Perfmon: possible freeze starting at 07:29:27, delay is 1.166
2015.05.19 07:32:13 1: Perfmon: possible freeze starting at 07:32:12, delay is 1.1
2015.05.19 07:34:28 1: Perfmon: possible freeze starting at 07:34:27, delay is 1.15
2015.05.19 07:35:09 1: HMLAN_Parse: HMLAN1 new condition timeout
2015.05.19 07:35:09 1: 192.168.150.11:1000 disconnected, waiting to reappear (HMLAN1)
2015.05.19 07:35:09 1: HMLAN_Parse: HMLAN1 new condition disconnected
2015.05.19 07:35:14 1: Perfmon: possible freeze starting at 07:35:11, delay is 3.014
2015.05.19 07:36:14 1: 192.168.150.11:1000 reappeared (HMLAN1)
2015.05.19 07:36:14 1: HMLAN_Parse: HMLAN1 new condition init
2015.05.19 07:36:15 1: HMLAN_Parse: HMLAN1 new condition ok
2015.05.19 07:36:51 1: Perfmon: possible freeze starting at 07:36:50, delay is 1.024
2015.05.19 07:39:28 1: Perfmon: possible freeze starting at 07:39:27, delay is 1.252
2015.05.19 07:39:46 1: Perfmon: possible freeze starting at 07:39:45, delay is 1.27
2015.05.19 07:40:44 1: Perfmon: possible freeze starting at 07:40:43, delay is 1.041
2015.05.19 07:42:03 1: Perfmon: possible freeze starting at 07:42:02, delay is 1.277
2015.05.19 07:43:15 1: Perfmon: possible freeze starting at 07:43:14, delay is 1.036
2015.05.19 07:44:06 1: Perfmon: possible freeze starting at 07:44:05, delay is 1.027
2015.05.19 07:44:28 1: Perfmon: possible freeze starting at 07:44:27, delay is 1.689
2015.05.19 07:46:46 1: Perfmon: possible freeze starting at 07:46:45, delay is 1.11
2015.05.19 07:46:58 1: Perfmon: possible freeze starting at 07:46:57, delay is 1.262
2015.05.19 07:47:34 1: Perfmon: possible freeze starting at 07:47:33, delay is 1.01
2015.05.19 07:48:53 1: Perfmon: possible freeze starting at 07:48:52, delay is 1.103
2015.05.19 07:49:28 1: Perfmon: possible freeze starting at 07:49:27, delay is 1.639
2015.05.19 07:50:15 1: Perfmon: possible freeze starting at 07:50:14, delay is 1.176
2015.05.19 07:51:20 1: Perfmon: possible freeze starting at 07:51:19, delay is 1.477
2015.05.19 07:53:03 1: Perfmon: possible freeze starting at 07:53:02, delay is 1.276
2015.05.19 07:54:28 1: Perfmon: possible freeze starting at 07:54:27, delay is 1.708
2015.05.19 07:55:26 1: Perfmon: possible freeze starting at 07:55:25, delay is 1.266
2015.05.19 07:55:38 1: Perfmon: possible freeze starting at 07:55:37, delay is 1.235
2015.05.19 07:57:58 1: Perfmon: possible freeze starting at 07:57:57, delay is 1.258
2015.05.19 07:59:17 1: Perfmon: possible freeze starting at 07:59:16, delay is 1.039
2015.05.19 07:59:28 1: Perfmon: possible freeze starting at 07:59:27, delay is 1.689
2015.05.19 08:01:27 1: Perfmon: possible freeze starting at 08:01:26, delay is 1.031
2015.05.19 08:04:27 1: Perfmon: possible freeze starting at 08:04:26, delay is 1.135
2015.05.19 08:04:40 1: Perfmon: possible freeze starting at 08:04:37, delay is 3.49
2015.05.19 08:07:12 1: Perfmon: possible freeze starting at 08:07:11, delay is 1.034
2015.05.19 08:09:28 1: Perfmon: possible freeze starting at 08:09:27, delay is 1.711
2015.05.19 08:10:01 1: Perfmon: possible freeze starting at 08:10:00, delay is 1.079
2015.05.19 08:11:59 1: Perfmon: possible freeze starting at 08:11:58, delay is 1.041
2015.05.19 08:12:03 1: Perfmon: possible freeze starting at 08:12:02, delay is 1.137
2015.05.19 08:12:51 1: Perfmon: possible freeze starting at 08:12:50, delay is 1.029
2015.05.19 08:13:19 1: Perfmon: possible freeze starting at 08:13:18, delay is 1.021
2015.05.19 08:14:01 1: Perfmon: possible freeze starting at 08:14:00, delay is 1.035
2015.05.19 08:14:28 1: Perfmon: possible freeze starting at 08:14:27, delay is 1.705
2015.05.19 08:17:38 1: Perfmon: possible freeze starting at 08:17:37, delay is 1.146
2015.05.19 08:19:28 1: Perfmon: possible freeze starting at 08:19:27, delay is 1.712
2015.05.19 08:19:30 1: Perfmon: possible freeze starting at 08:19:29, delay is 1.012
2015.05.19 08:20:04 1: Perfmon: possible freeze starting at 08:20:03, delay is 1.143
2015.05.19 08:21:52 1: Perfmon: possible freeze starting at 08:21:51, delay is 1.287
2015.05.19 08:23:00 1: Perfmon: possible freeze starting at 08:22:59, delay is 1.211
2015.05.19 08:24:28 1: Perfmon: possible freeze starting at 08:24:27, delay is 1.83
2015.05.19 08:28:00 1: Perfmon: possible freeze starting at 08:27:59, delay is 1.314
2015.05.19 08:28:32 1: Perfmon: possible freeze starting at 08:28:31, delay is 1.245
2015.05.19 08:29:28 1: Perfmon: possible freeze starting at 08:29:27, delay is 1.769
2015.05.19 08:30:13 1: Perfmon: possible freeze starting at 08:30:12, delay is 1.312
2015.05.19 08:34:29 1: Perfmon: possible freeze starting at 08:34:28, delay is 1.499
2015.05.19 08:35:41 1: Perfmon: possible freeze starting at 08:35:40, delay is 1.191
2015.05.19 08:35:45 1: Perfmon: possible freeze starting at 08:35:44, delay is 1.709
2015.05.19 08:36:04 1: Perfmon: possible freeze starting at 08:36:03, delay is 1.131
2015.05.19 08:36:06 1: Perfmon: possible freeze starting at 08:36:05, delay is 1.279
Offline Wernieman
« Antwort #6 am: 19 Mai 2015, 10:04:48 »
Was sagt denn auf der Systemebene ein top?
Offline selfarian
  • Full Member
« Antwort #7 am: 19 Mai 2015, 15:02:02 »
Das hier wäre mein Top:
top - 15:01:19 up 5 days, 18:51,  1 user,  load average: 0,11, 0,14, 0,14
Tasks:  71 total,   1 running,  70 sleeping,   0 stopped,   0 zombie
%Cpu(s):  7,5 us,  0,5 sy,  0,0 ni, 91,8 id,  0,2 wa,  0,0 hi,  0,0 si,  0,0 st
KiB Mem:    444908 total,   429836 used,    15072 free,    57668 buffers
KiB Swap:   102396 total,        0 used,   102396 free,   291248 cached
  PID USER      PR  NI  VIRT  RES  SHR S  %CPU %MEM    TIME+  COMMAND
 5901 root      20   0  4676 2464 2088 R  20,4  0,6   0:00.10 top
    7 root      20   0     0    0    0 S   5,1  0,0   0:28.20 rcu_preempt
25623 fhem      20   0 42492  39m 5648 S   5,1  9,2 108:03.12 perl
    1 root      20   0  2148 1360 1256 S   0,0  0,3   0:22.75 init
    2 root      20   0     0    0    0 S   0,0  0,0   0:00.04 kthreadd
    3 root      20   0     0    0    0 S   0,0  0,0   0:23.22 ksoftirqd/0
    5 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 kworker/0:0H
    8 root      20   0     0    0    0 S   0,0  0,0   0:00.00 rcu_sched
    9 root      20   0     0    0    0 S   0,0  0,0   0:00.00 rcu_bh
   10 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 khelper
   11 root      20   0     0    0    0 S   0,0  0,0   0:00.01 kdevtmpfs
   12 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 netns
   13 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 perf
   14 root      20   0     0    0    0 S   0,0  0,0   0:00.42 khungtaskd
   15 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 writeback
   16 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 crypto
   17 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 bioset
   18 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 kblockd
   19 root      20   0     0    0    0 S   0,0  0,0   4:17.10 kworker/0:1
   20 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 rpciod
   21 root      20   0     0    0    0 S   0,0  0,0   0:00.70 kswapd0
   22 root      20   0     0    0    0 S   0,0  0,0   0:00.00 fsnotify_mark
   23 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 nfsiod
   29 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 kthrotld
   30 root       1 -19     0    0    0 S   0,0  0,0   0:00.00 VCHIQ-0
   31 root       1 -19     0    0    0 S   0,0  0,0   0:00.00 VCHIQr-0
   32 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 VCHIQs-0
   33 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 iscsi_eh
   34 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 dwc_otg
   35 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 DWC Notificatio
   37 root      20   0     0    0    0 S   0,0  0,0   0:00.00 VCHIQka-0
   38 root      10 -10     0    0    0 S   0,0  0,0   0:00.00 SMIO
   39 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 deferwq
   41 root      20   0     0    0    0 S   0,0  0,0   0:28.99 mmcqd/0
   42 root      20   0     0    0    0 S   0,0  0,0   0:00.00 kworker/0:2
   43 root      20   0     0    0    0 S   0,0  0,0   0:11.77 jbd2/mmcblk0p2-
   44 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 ext4-rsv-conver
  159 root      20   0  2912 2104 1628 S   0,0  0,5   0:00.66 udevd
  317 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 kworker/u3:0
  318 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 hci0
  319 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 hci0
  321 root       0 -20     0    0    0 S   0,0  0,0   0:00.00 kworker/u3:2
 1576 root      20   0  1752  984  900 S   0,0  0,2   1:44.08 ifplugd
Offline Wernieman
« Antwort #8 am: 20 Mai 2015, 10:36:07 »
91,8 id
Also das System ist es nicht.
Was macht eigentlich folgende "Prozedure":
Offline selfarian
  • Full Member
« Antwort #9 am: 20 Mai 2015, 10:52:14 »
Das ist einer von insgesamt 4 Watchdogs für die An-/Abwesenheit. Zwei davon sind für mich und zwei für meine Frau.
So sehen die Watchdogs aus:
define wd.all.handy.alex.away watchdog all.handy.alex:absent 00:05 all.handy.alex:present setstate wd.all.handy.alex.here defined ; set rr_alex absent
attr regexp1WontReactivate 1
define
wd.all.handy.alex.here watchdog all.handy.alex:present 00:00 all.handy.alex:absent setstate wd.all.handy.alex.away defined ; set rr_alex home
all.handy.alex ist eine PRESENCE über lan-ping auf mein Handy.
rr_alex ist ein ROOMMATE
Soll ich meine myUtils der Vollständigkeit halber mal posten?
Aber waits oder sleeps oder so habe ich dort eigentlich keine Drinnen.
Bei meiner Ursprünglichen Installation hatte ich mal probleme mit der Fritzbox, dort hatte er zig Verbindungen aufgebaut, bis garnichts mehr ging (webinterface war nichtmehr erreichbar). Aber das hatte sich dann damals in Luft aufgelöst und jetzt habe ich ja auch eine frische Installation ;)
« Letzte Änderung: 20 Mai 2015, 10:55:08 von selfarian »
Offline Wernieman
« Antwort #10 am: 20 Mai 2015, 13:58:36 »
Wie reallisert Du Lan-Pings?
Offline selfarian
  • Full Member
« Antwort #11 am: 20 Mai 2015, 14:02:41 »
Über PRESENCE:
define all.handy.alex presence lan-ping 192.168.150.22 60 180
attr all.handy.alex event-on-change-reading state
Offline Wernieman
« Antwort #12 am: 20 Mai 2015, 14:50:46 »
Mal als "Quick-Fix"
Setze mal ping_count runter (z.B. auf 2)
hast DU ein powerCmd gesetzt?
Offline selfarian
  • Full Member
« Antwort #13 am: 20 Mai 2015, 15:05:39 »
Ok. Pinguine count ist gesetzt (für mich: 15:03)
Soweit ich weiß, habe ich kein Power cmd gesetzt. Wie oder wo setzt man das?
Offline Wernieman
« Antwort #14 am: 20 Mai 2015, 15:19:14 »
"Pinguine count" *lolol*
Nicht Pinguine sonder pings sollst Du zählen ;o)
wegen powerCmd: siehe Doku zu presence
