Modul: 98_livetracking - Geokoordinaten von OwnTracks / Life360 / Swarm (4Sq)
Begonnen von Markus M., 22 Mai 2015, 02:01:46
binford6000
Danke Markus,
ich sage nur "exclude from update"...  :-X
Und schwupps:
2019.01.17 15:47:31.899 4: OwnTracks HTTP request:
{"batt":17,"lon":8.123456,"acc":65,"p":98.4813232421875,"vac":10,"lat":50.123456,"inregions":["home"],"topic":"owntracks\/test\/iphone","t":"u","conn":"w","tst":1547736451,"alt":157,"_type":"location","tid":"SE"}
2019.01.17 15:47:31.901 4: iphone5SE OwnTracks: 2019-01-17 15:47:31  {"batt":17,"lon":8.123456,"acc":65,"p":98.4813232421875,"vac":10,"lat":50.123456,"inregions":["home"],"topic":"owntracks\/test\/iphone","t":"u","conn":"w","tst":1547736451,"alt":157,"_type":"location","tid":"SE"}
Merci!
pscl
Moin!
Ich hab eben ein Life360 device angelegt, bekomme aber leider nur die battery Readings :( ein get Life360 mit Verbose 5 zeigt das eigentlich alles ankommen sollte.
Im Prinzip muss ich ja nicht mehr als define TR livetracking mail pw machen oder? :c Ich habe schon mit den Attributen rumgespielt, ändert aber leider auch nix.
Die aktuellste Version habe ich.
2019.01.18 15:26:43 5: TR_Pascal Life360 data: /n{
  'locations' => [
                     'startTimestamp' => '1547817588',
                     'shortAddress' => '',
                     'address2' => '',
                     'isDriving' => '0',
                     'name' => 'Home',
                     'charge' => '0',
                     'battery' => 45,
                     'placeType' => 2,
                     'driveSDKStatus' => 'OFF',
                     'inTransit' => '0',
                     'since' => '1547817588',
                     'endTimestamp' => '1547821571',
                     'timestamp' => '1547821571',
                     'sourceId' => undef,
                     'source' => undef,
                     'accuracy' => '81.53214435591',
                     'latitude' => '41.558943262771',
                     'wifiState' => undef,
                     'longitude' => '52.7732321494024',
                     'speed' => 0,
                     'address1' => '',
                     'tripId' => undef
                     'since' => '1547816900',
                     'placeType' => undef,
                     'battery' => 52,
                     'charge' => '0',
                     'inTransit' => '1',
                     'name' => undef,
                     'startTimestamp' => '1547816900',
                     'isDriving' => '0',
                     'address2' => '',
                     'tripId' => undef,
                     'address1' => '',
                     'longitude' => '39.7214934',
                     'speed' => '1.08',
                     'latitude' => '32.5423378',
                     'accuracy' => '50',
                     'source' => undef,
                     'timestamp' => '1547816911',
                     'endTimestamp' => '1547816911'
                     'accuracy' => '72.469746486132',
                     'latitude' => '32.493250193216',
                     'address1' => '',
                     'tripId' => undef,
                     'longitude' => '4.7471658969878',
                     'speed' => 0,
                     'timestamp' => '1547816291',
                     'endTimestamp' => '1547816291',
                     'source' => undef,
                     'battery' => 55,
                     'placeType' => 1,
                     'charge' => '0',
                     'inTransit' => '0',
                     'driveSDKStatus' => 'ON',
                     'since' => '1547807861',
                     'startTimestamp' => '1547807861',
                     'isDriving' => '0',
                     'address2' => '',
                     'name' => 'Arbeit'
Markus M.
Hast du nicht mehr ;) Im SVN ist seit 5 Minuten eine neue, in der dieser Bug gefixt ist.
Bis die morgen im Update ist, solltest du aber auch so schon Daten sehen - zumindest wenn dein Telefon bis dahin nochmal das Haus verlässt.
Das Problem mit den anfangs fehlenden Readings tritt nur bei neu angelegten Devices auf - deshalb ist es mir nicht aufgefallen.
FHEM dev + HomeBridge + Lenovo Flex15 + HM-CFG-USB + RFXtrx433 + Fritz!Box 7590/7580/546E
HM Aktor/Sensor/Winmatic/Keymatic/Thermostat, HUE, Netatmo Weather/Security/Heating, Xiaomi AirPurifier/Vacuum, Withings Aura/BPM/Cardio/Go/Pulse/Thermo, VSX828, Harmony, Siro ERB15LE
https://paypal.me/mm0
pscl
binford6000
Hallo Markus,
hab jetzt mein livetracking device auf http (osmand) umgestellt.
Was mir auffällt ist, dass "enter" und "leave" Events nur im Log auftauchen, nicht aber im Event-Monitor:
Event-Monitor:
2019-01-22 12:01:27 livetracking iphone5SE latitude: 49.123456
2019-01-22 12:01:27 livetracking iphone5SE longitude: 8.123456
2019-01-22 12:01:27 livetracking iphone5SE location: 49.123456,8.123456
2019-01-22 12:01:27 livetracking iphone5SE id: SE
2019-01-22 12:01:27 livetracking iphone5SE accuracy: 65
2019-01-22 12:01:27 livetracking iphone5SE zone_1: inactive
2019-01-22 12:01:27 livetracking iphone5SE trigger: region
2019-01-22 12:01:27 livetracking iphone5SE distance: 39.1
Logfile:
2019.01.22 12:01:27 4: OwnTracks HTTP request:
{"t":"c","tst":1548154885,"acc":65,"_type":"transition","event":"leave","lon":8.123456,"topic":"owntracks\/fhemown\/iphone\/event","lat":49.123456,"wtst":1548006185,"tid":"SE","desc":"buero-mz"}
2019.01.22 12:01:27 4: iphone5SE OwnTracks: 2019-01-22 12:01:25  {"t":"c","tst":1548154885,"acc":65,"_type":"transition","event":"leave","lon":8.123456,"topic":"owntracks\/fhemown\/iphone\/event","lat":49.123456,"wtst":1548006185,"tid":"SE","desc":"buero-mz"}
2019.01.22 12:01:27 3: iphone5SE OwnTracks Zone Event: leave buero-mz
Ist das so gewollt? Kann man das konfigurieren? Ggf. ändern? Also zB. für
type":"transition","event":"leave" bzw
type":"transition","event":"enter"
als Event darstellen dass man mit notify/doif darauf reagieren kann?
Oder stehe ich gerade etwas aufm Schlauch?  :o
VG Sebastian
Markus M.
Schlauch? :)
Du mappst das doch auf zone_1 etc. und bekommst dafür auch Events?!
binford6000
Ja Momentan mache ich es per notify so:
iphone5SE:zone.*:.*
und werte dann auf active/inactive aus.
Hab mich nur gewundert, dass es im Logfile Einträge gibt zu leave und enter einer Zone,
diese aber nicht im Eventmonitor auftauchen...
Damit bräuchte ich nicht den Umweg über die Zone zu gehen...  ;)
VG Sebastian
Markus M.
Hmm ja, könnte man machen :)
Probier mal den Anhang aus
binford6000
Hallo Markus,
danke für den schnellen Patch. Hab ihn eingespielt und werde morgen berichten  ;)
VG Sebastian
binford6000
Hallo Markus,
habe soeben mal testen können. Die gewünschten Events kommen wie folgt an:
iphone5SE leave buero-mz
iphone5SE enter buero-mz
Perfekt!  8)
VG Sebastian
binford6000
Und die Logeinträge kommen jetzt nur noch unter Verbose 4:
2019.01.23 12:46:00 4: iphone5SE OwnTracks Zone Event: leave buero-mz
2019.01.23 12:59:32 4: iphone5SE OwnTracks Zone Event: enter buero-mz
Passt also alles.  :)
VG Sebastian
binford6000
Hallo Markus,
hast du den Patch schon in die neuste Version gepackt?
VG Sebastian
Markus M.
Nein. Du kannst die Datei aber einfach drin lassen, in der nächsten Version kommt es mit.
Bis dahin sollte ein Update eigentlich nichts überschreiben.
binford6000
OK. Dann noch ein kleiner Hinweis:
Attribut "createAddressReading" Laut Modulhilfe:
createAddressReading (0/1) Write reverse geocoding results to address reading
Das Attribut heisst aber aktuell noch "addressReading".  ;)
VG Sebastian
binford6000
Hallo Markus,
ich habe so das Gefühl das mit addressReading auf 1 keine Adressen geholt werden.
Erst mit meinem manuellen get iphone5se address wird die korrekte Adresse geholt:
2019.02.11 18:37:24 4: iphone5SE OwnTracks: 2019-02-11 18:37:21  {"t":"c","tst":1549906641,"acc":5,"_type":"transition","event":"enter","lon":8.123456789,"topic":"owntracks\/fhemown\/iphone\/event","lat":50.123456789,"wtst":1548005975,"tid":"SE","desc":"home"}
Und dann 30 Sekunden später via at aus einem notify:
2019.02.11 18:37:54 4: iphone5SE: address received
  'importance' => '0.1',
  'osm_id' => '23777327',
  'addresstype' => 'road',
  'display_name' => "L 320, Ort, Kreis, Land, 12345, Deutschland",
  'category' => 'highway',
  'lat' => '50.123456789',
  'address' => {
                 'road' => 'L 320',
                 'country_code' => 'de',
                 'country' => 'Deutschland',
                 'postcode' => '12345',
                 'village' => "Ort",
                 'state' => 'Land',
                 'county' => 'Kreis'
  'name' => 'L 320',
  'osm_type' => 'way',
  'type' => 'secondary',
  'licence' => "Data \x{c2}\x{a9} OpenStreetMap contributors, ODbL 1.0. https://osm.org/copyright",
  'boundingbox' => [
                     '50.123456789',
                     '50.123456789',
                     '8.123456789',
                     '8.123456789'
  'place_rank' => '26',
  'place_id' => '123456789',
  'lon' => '8.123456789'
2019.02.11 18:37:54 3: atTmpHomeCMD_Adresse_Wohnung: Straße
PLZ
Ort
Deutschland
Nach meinem Verständnis müsste doch zweimal die Adresse geholt werden oder?
Einmal v durch das Attribut addressReading auf 1 und dann nochgmal durch das manuelle
get iphone5se address aus dem at?   :o
VG Sebastian
