"Fehler" nach Update
Begonnen von GrayDeath, 09 Juni 2015, 17:31:43
GrayDeath
hab heute ein Update gemacht seit dem bekomme ich wieder mein LOG zugefüllt mit:
2015.06.09 17:25:09 3: HMLAN1: Unknown code A0BD9A2581299CE1247FC0000::-93:HMLAN1, help me!
2015.06.09 17:25:16 3: HMLAN1: Unknown code A0FED86102E64150000000A98C50F0F40::-103:HMLAN1, help me!
2015.06.09 17:25:19 3: HMLAN1: Unknown code A0C378670129ACF00000000E93B::-106:HMLAN1, help me!
2015.06.09 17:25:37 3: HMLAN1: Unknown code A0C1B867019E2B700000000E539::-83:HMLAN1, help me!
2015.06.09 17:25:39 3: HMLAN1: Unknown code A0B37A258129ACF1265560000::-105:HMLAN1, help me!
2015.06.09 17:25:39 3: HMLAN1: Unknown code A0E378202126556129ACF0101000035::-80:HMLAN1, help me!
2015.06.09 17:25:46 3: HMLAN1: Unknown code A0F75803F13C96C2E68AA02041D09C1FA::-82:HMLAN1, help me!
2015.06.09 17:25:57 3: HMLAN1: Unknown code A0B1BA25819E2B719DBBC0000::-82:HMLAN1, help me!
2015.06.09 17:26:04 3: HMLAN1: Unknown code A0E6B8202179FD51804D00101000033::-100:HMLAN1, help me!
2015.06.09 17:26:30 3: HMLAN1: Unknown code A0CA08670129BA900000000E739::-94:HMLAN1, help me!
2015.06.09 17:26:50 3: HMLAN1: Unknown code A0BA0A258129BA912654C0000::-95:HMLAN1, help me!
2015.06.09 17:26:50 3: HMLAN1: Unknown code A0EA0820212654C129BA90101000038::-93:HMLAN1, help me!
2015.06.09 17:27:12 3: HMLAN1: Unknown code A0CDA86701299CE00000000E83A::-92:HMLAN1, help me!
2015.06.09 17:27:32 3: HMLAN1: Unknown code A0BDAA2581299CE1247FC0000::-93:HMLAN1, help me!
2015.06.09 17:27:32 3: HMLAN1: Unknown code A0EDA82021247FC1299CE0101000031::-75:HMLAN1, help me!
2015.06.09 17:27:47 3: HMLAN1: Unknown code A0E87820214BCFA15B2FD0101008026::-107:HMLAN1, help me!
2015.06.09 17:27:50 3: HMLAN1: Unknown code A0C1C867019E2B700000000E539::-82:HMLAN1, help me!
2015.06.09 17:27:55 3: HMLAN1: Unknown code A0FEE86102E64150000000A98C60F0F40::-102:HMLAN1, help me!
2015.06.09 17:27:57 3: HMLAN1: Unknown code A0C388670129ACF00000000E93B::-103:HMLAN1, help me!
2015.06.09 17:28:10 3: HMLAN1: Unknown code A0B1CA25819E2B718364F0000::-82:HMLAN1, help me!
2015.06.09 17:28:10 3: HMLAN1: Unknown code A0E1C820218364F19E2B70101000036::-94:HMLAN1, help me!
2015.06.09 17:28:17 3: HMLAN1: Unknown code A0B38A258129ACF1265560000::-102:HMLAN1, help me!
2015.06.09 17:28:24 3: HMLAN1: Unknown code A0E6C8202179FD51804D00101000033::-101:HMLAN1, help me!
VCCU ist angelegt und hat bis vor dem Update funktioniert....
GrayDeath
hab jetzt mal bei der VCCU auf "update" geclickt, jetzt sind die Meldungen wieder weg ... seltsam ...
frank
wenn die meldungen dauerhaft verschwinden sollen, musst du die devices definieren und auf ignore setzen. sonst warte eine weile, dann sollten sie mit der zeit wieder von selbst verschwinden.
FHEM: 6.0(SVN) => Pi3(buster)
felix.steinbeis
ist bei mir jetzt auch so. Ein Klick auf "Update" hilft nur bis zum nächsten Neustart von FHEM.
Ein configCheck unter HMDIAG liefert mir "PairedTo missing/unknown VCCU1". Die VCCU1 gibt es aber und hat auch funktioniert.
Was muss ich tun, damit der Fehler behoben wird und auch meine Logs nicht volllaufen?
Danke und Gruß
Felix
Gernott
Das habe ich bei mir auch seit dem letzten Update. Ansonsten scheint aber alles zu funktionieren.
G.
felix.steinbeis
Nun ja, aber insbesondere die "Unknow code"-Meldungen im Log sind nervig.
Ich mache vermutlich ein Rollback, wenn es keine Lösung gibt.
Felix
frank
definiere die unknown devices und setze das attrbut ignore=1.
volschin
Gleiches Problem bei mir heute ebenfalls nach dem Update. Da ist in der letzten Woche was Komisches eingebaut worden.  :(
Intel NUC+Ubuntu 22.04+Docker+FHEM6
4xRPi, 4xCO20, OWL+USB, HarmonyHub, FRITZ!Box 7590, Echo Dots+Show8, Logi Circle 2, HomeBridge
TIG Stack (Telegraf, InfluxDB, Grafana)
volschin
Ich habe meinen 10_CUL_HM.pm auf den Stand vor einer Woche zurückgedreht, damit funktioniert es ohne die Log-Fehlermeldungen.  :)
volschin
Mit dem Update von heute ist bei mir alles wieder OK.
Danke an Martin.
