Telegram instant messaging TelegramBot - Empfangen und Senden per FHEM
Begonnen von viegener, 20 Juni 2015, 18:59:41
dennis_n
Ich habe mal och Verbose auf 5 gesetzt und folgendes im Log dann:
2018.01.30 22:43:23 4: TelegramBot_Set FWStatus: called
2018.01.30 22:43:23 4: TelegramBot_Set FWStatus: Processing TelegramBot_Set( ? )
2018.01.30 22:43:23 5: TelegramBot_Get FWStatus: called
2018.01.30 22:43:23 5: TelegramBot_Get FWStatus: Processing TelegramBot_Get( ? )
2018.01.30 22:43:40 5: TelegramBot_Callback FWStatus: called from Polling
2018.01.30 22:43:40 5: TelegramBot_Callback FWStatus: data returned :{"ok":true,"result":[]}:
2018.01.30 22:43:40 5: TelegramBot_Deepencode FWStatus: found an ARRAY
2018.01.30 22:43:40 5: TelegramBot_Deepencode FWStatus: encoded a String from :1: to :1:
2018.01.30 22:43:40 5: TelegramBot_Deepencode FWStatus: found a HASH
2018.01.30 22:43:40 5: TelegramBot_Callback FWStatus: after encoding
2018.01.30 22:43:40 5: TelegramBot_Callback FWStatus: polling returned result? 0
2018.01.30 22:43:40 5: UpdatePoll FWStatus: number of results 0
2018.01.30 22:43:40 5: TelegramBot_UpdatePoll FWStatus: called
2018.01.30 22:43:40 5: TelegramBot_UpdatePoll FWStatus: - Initiate non blocking polling - With callback set
2018.01.30 22:43:40 5: TelegramBot_readToken: Read Telegram API token from file
2018.01.30 22:43:40 4: TelegramBot_UpdatePoll FWStatus: initiate polling with nonblockingGet with 20s
2018.01.30 22:43:40 5: TelegramBot_UpdatePoll FWStatus: - Ende > next polling started
2018.01.30 22:43:40 4: TelegramBot_Callback FWStatus: resulted in SUCCESS from Polling
2018.01.30 22:43:40 5: TelegramBot_Callback FWStatus: - Ende > Control back to FHEM
2018.01.30 22:43:41 5: TelegramBot_Callback FWStatus: called from Polling
2018.01.30 22:43:41 5: TelegramBot_Callback FWStatus: polling returned result? <undef>
2018.01.30 22:43:41 5: TelegramBot_UpdatePoll FWStatus: called
2018.01.30 22:43:41 5: TelegramBot_UpdatePoll FWStatus: - Initiate non blocking polling - With callback set
2018.01.30 22:43:41 5: TelegramBot_readToken: Read Telegram API token from file
2018.01.30 22:43:41 4: TelegramBot_UpdatePoll FWStatus: initiate polling with nonblockingGet with 20s
2018.01.30 22:43:41 5: TelegramBot_UpdatePoll FWStatus: - Ende > next polling started
2018.01.30 22:43:41 4: TelegramBot_Callback FWStatus: resulted in NonBlockingGet timed out on read from <hidden> after 45s from Polling
2018.01.30 22:43:41 5: TelegramBot_Callback FWStatus: - Ende > Control back to FHEM
viegener
@dennis_n: Der logauszug zu verbose 5 enthält keine Fehlermeldungen (aber auch kein Nachrichten senden) - das Empfangen scheint kein Problem zu haben.
Kannst Du einen Logauszug machen, wenn ein Sendebefehl ansteht?
Hast Du mal versucht utf8Special (attribut am bot) zu setzen?
JoWiemann
Jörg Wiemann
oli82
Zitat von: JoWiemann am 01 Februar 2018, 15:56:10
"Ungeeignete Inhalte": Apple wirft Messenger Telegram raus.
Zitat[Update 1.02.2018 18:35 Uhr] Telegram und Telegram X lassen sich inzwischen wieder über den App Store beziehen. Ob und welche "Schutzfunktionen" integriert wurden, bleibt unklar – ebenso wie der genaue Grund für das vorübergehende Verschwinden des Messengers.
Jump2016
wie kann ich denn eine ReadingGroup per Telegramm verschicken?
Hat dazu jemand eine Idee?
Jonas
dennis_n
Hi @viegener,
mein Problem hat sich erledigt. Es war ne Fehlkonfiguration des Devices. Sorry für die Panik.
Aber mal noch ne andere Frage: Bei Pushover hatte ich die Möglichkeit bestimmte Töne bei der Pushbenachrichtigung mit anzugeben. Gibt es das bei Telegram auch?
Also kann ich beispielsweise die Standard-Töne einer Pushbenachrichtigung des iPhone umgehen und einen eigenen Ton mitsenden?
Gruss
Dennis
viegener
Ich kenne leider nur die Möglichkeit Stumm / Benachrichtigung und Sounddatei (die wird aber nicht direkt abgespielt)
StephanFHEM
habe gerade angefangen die geniale Möglichkeit von silentmsg zu nutzen. Gibt es das auf für das Senden von Plots? also für cmdSend?
Stephan
andies
FHEM 6.1 auf RaspPi3 (Raspbian:  6.1.21-v8+; Perl: v5.32.1)
StephanFHEM
Danke, kannst du dann SilentCMD analog SilentImage auch noch einbauen? Das wäre echt klasse.
Komisch übrigens: hab Silentmsg vorhin erfolgreich getestet und meine doifs danach umgebaut und nu bekomme ich auf dem iphone plötzlich wieder Notifications ...
Ich glaub ich höre auf für heute:-)
StephanFHEM
hab mal die neue Telegram-Version aus dem github drauf gemacht und bekomme jetzt folgende Fehlermeldungen:
Bad Request: chat_id is empty
im Log steht davor folgendes:
PERL WARNING: Argument "Empfänger-Name" isn't numeric in numeric eq (==) at ./FHEM/50_TelegramBot.pm line 1696.
ich sende mit @ und dann Empfänger-Name ab. Das hat bisher auch immer funktioniert
viegener
Welches Kommando - liefert diese Fehler?
viegener
ich habe mal in github eine neue Version hochgeladen - die enthält einige Fixes und auch jetzt den Befehl cmdSentSilent
StephanFHEM
Das Kommando war ein einfaches:
set TelegramBot message @MeinTelegramName Test 123
viegener
@StephanFHEM: Kannst Du die letzte Version aus github mal verwenden, DU musst irgendeinen Zwischenstand erwischt haben, den ich eingechecked habe, bevor die Umbauten fertig waren.
