So hier ist mal ein Logauszug:10.22 20:48:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:48:34 4: sduino2/msg READ: MU;P0=-19028;P1=482;P2=-987;P3=1462;D=012121212121212123212323212321232321212323232121212121232123212321232123212123232323232323212323232323232321212323232323232321232121212123212323232323212323232123232121232121;CP=1;R=3;
2018.10.22 20:48:34 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:48:34 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:48:34 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 1 0 1 0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 0 1 1 0 1 0 0
2018.10.22 20:48:34 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63EAAC040602F41134 length 88 RSSI = -72.5
2018.10.22 20:48:34 5: sduino2 Dispatch: P9#FF4A63EAAC040602F41134, test ungleich: disabled
2018.10.22 20:48:34 5: sduino2 Dispatch: P9#FF4A63EAAC040602F41134, -72.5 dB, dispatch
2018.10.22 20:48:34 5: sduino2: dispatch P9#FF4A63EAAC040602F41134
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse0 msg=FF4A63EAAC040602F41134 Bin=1111111101001010011000111110101010101100000001000000011000000010111101000001000100110100 syncp=1 length:88
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F5560203017A089A
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298FAAB010180BD044D
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63EAAC040602F41134 msg:P9#FF4A63EAAC040602F41134
2018.10.22 20:48:34 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63EAAC040602F41134 msg:P9#FF4A63EAAC040602F41134 CRC:132
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110101010101100000001000000011000000010111101000001000100110100 length:88
2018.10.22 20:48:34 3: sduino2: Unknown code P9#FF4A63EAAC040602F41134, help me!
2018.10.22 20:49:21 4: sduino2/msg READ: MU;P0=-21688;P1=477;P2=-995;P3=1457;P4=-31036;D=01212121212121212321232321232123232121232323212121212123212321232123212321212323232323232323212323232323232123232323232323232123212121212321232323232321232123232321232321212341212121212121212321232321232123232121232323212121212123212321232123212321212323;CP=1;R=29;O;
2018.10.22 20:49:21 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:49:21 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:49:21 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 1 0 1 0 1 0 1 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0
2018.10.22 20:49:21 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63EAAC020402F4144C length 88 RSSI = -59.5
2018.10.22 20:49:21 5: sduino2 Dispatch: P9#FF4A63EAAC020402F4144C, test ungleich: disabled
2018.10.22 20:49:21 5: sduino2 Dispatch: P9#FF4A63EAAC020402F4144C, -59.5 dB, dispatch
2018.10.22 20:49:21 5: sduino2: dispatch P9#FF4A63EAAC020402F4144C
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse0 msg=FF4A63EAAC020402F4144C Bin=1111111101001010011000111110101010101100000000100000010000000010111101000001010001001100 syncp=1 length:88
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:49:21 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F5560102017A0A26
2018.10.22 20:49:21 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F5560102017A0A26 msg:P9#FFA531F5560102017A0A26
2018.10.22 20:49:21 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F5560102017A0A26 msg:P9#FFA531F5560102017A0A26 CRC:0
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111010101010110000000010000001000000001011110100000101000100110 length:80
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000001 Dec: 0.3
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000010 Dec: 0.7
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=10.1, hum=86, winddir=10:SW wS=0.3, wG=0.7, rain=113.4
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111010101010110000000010000001000000001011110100000101000100110
2018.10.22 20:49:22 4: sduino2/msg READ: MU;P0=-992;P1=481;P2=1463;D=0101010201020102020202020201020202020202020201020101010102010202020202010201020202010202010102;CP=1;R=29;
2018.10.22 20:49:22 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:49:22 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:49:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:50:10 4: sduino2/msg READ: MU;P0=-30388;P1=474;P2=-981;P3=1463;D=012121212121212123212323212321232321212323232121212121232123232321232123212123232323232321232123232323232121232323232323232321232121212123212323232323212323232123212121212323;CP=1;R=29;
2018.10.22 20:50:10 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:10 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:50:10 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 1 1 1 1 0 0 0
2018.10.22 20:50:10 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E8AC0A0C02F41178 length 88 RSSI = -59.5
2018.10.22 20:50:10 5: sduino2 Dispatch: P9#FF4A63E8AC0A0C02F41178, test ungleich: disabled
2018.10.22 20:50:10 5: sduino2 Dispatch: P9#FF4A63E8AC0A0C02F41178, -59.5 dB, dispatch
2018.10.22 20:50:10 5: sduino2: dispatch P9#FF4A63E8AC0A0C02F41178
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse0 msg=FF4A63E8AC0A0C02F41178 Bin=1111111101001010011000111110100010101100000010100000110000000010111101000001000101111000 syncp=1 length:88
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:50:10 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F4560506017A08BC
2018.10.22 20:50:10 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F4560506017A08BC msg:P9#FFA531F4560506017A08BC
2018.10.22 20:50:10 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F4560506017A08BC msg:P9#FFA531F4560506017A08BC CRC:0
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111010001010110000001010000011000000001011110100000100010111100 length:80
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000101 Dec: 1.7
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000110 Dec: 2.0
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=10, hum=86, winddir=8:S wS=1.7, wG=2.0, rain=113.4
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111010001010110000001010000011000000001011110100000100010111100
2018.10.22 20:50:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:50:57 4: sduino2/msg READ: MU;P0=-18408;P1=467;P2=-999;P3=1442;P4=-31032;P5=-5436;D=01212121212121212321232321232123232121232323212121212123212323232123212321212323232323232321232323232323232121232323232323232123212121212321232323232323212123232121232121232141512121212321232321232123232121232323212121212123212323232123212321212323232323;CP=1;R=28;O;
2018.10.22 20:50:57 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:57 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:50:57 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 0 1 1 0 0 1 1 0 1 1 0 0 0
2018.10.22 20:50:57 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E8AC040602F40CD8 length 88 RSSI = -60
2018.10.22 20:50:57 5: sduino2 Dispatch: P9#FF4A63E8AC040602F40CD8, test ungleich: disabled
2018.10.22 20:50:57 5: sduino2 Dispatch: P9#FF4A63E8AC040602F40CD8, -60 dB, dispatch
2018.10.22 20:50:57 5: sduino2: dispatch P9#FF4A63E8AC040602F40CD8
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse0 msg=FF4A63E8AC040602F40CD8 Bin=1111111101001010011000111110100010101100000001000000011000000010111101000000110011011000 syncp=1 length:88
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F4560203017A066C
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298FA2B010180BD0336
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63E8AC040602F40CD8 msg:P9#FF4A63E8AC040602F40CD8
2018.10.22 20:50:57 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63E8AC040602F40CD8 msg:P9#FF4A63E8AC040602F40CD8 CRC:132
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110100010101100000001000000011000000010111101000000110011011000 length:88
2018.10.22 20:50:57 3: sduino2: Unknown code P9#FF4A63E8AC040602F40CD8, help me!
2018.10.22 20:50:58 4: sduino2/msg READ: MU;P0=-1005;P1=1443;P2=470;D=0102010101010101010102020101010101010102010202020201020101010101010202010102020102020102;CP=2;R=28;
2018.10.22 20:50:58 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:58 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:51:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:51:46 4: sduino2/msg READ: MU;P0=-9212;P1=469;P2=-1004;P3=1440;D=012121212121212123212323212321232321212323232121212121232321212321232123212123232323232321212323232323212323212323232323232321232121212123212323232323212123232321232321212121;CP=1;R=29;
2018.10.22 20:51:46 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:51:46 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:51:46 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 0 1 1 0 1 0 1 0 1 1 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 1 0 0 0 1 0 0 1 1 1 0 0
2018.10.22 20:51:46 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E6AC0C1202F4189C length 88 RSSI = -59.5
2018.10.22 20:51:46 5: sduino2 Dispatch: P9#FF4A63E6AC0C1202F4189C, test ungleich: disabled
2018.10.22 20:51:46 5: sduino2 Dispatch: P9#FF4A63E6AC0C1202F4189C, -59.5 dB, dispatch
2018.10.22 20:51:46 5: sduino2: dispatch P9#FF4A63E6AC0C1202F4189C
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse0 msg=FF4A63E6AC0C1202F4189C Bin=1111111101001010011000111110011010101100000011000001001000000010111101000001100010011100 syncp=1 length:88
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F3560609017A0C4E
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298F9AB030480BD0627
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63E6AC0C1202F4189C msg:P9#FF4A63E6AC0C1202F4189C
2018.10.22 20:51:46 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63E6AC0C1202F4189C msg:P9#FF4A63E6AC0C1202F4189C CRC:132
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110011010101100000011000001001000000010111101000001100010011100 length:88
2018.10.22 20:51:46 3: sduino2: Unknown code P9#FF4A63E6AC0C1202F4189C, help me!
2018.10.22 20:52:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:52:34 4: sduino2/msg READ: MU;P0=-989;P1=1453;P2=478;D=0101010101020101010101010101010102010202020201020101010101020101010201010101020202;CP=1;R=28;
2018.10.22 20:52:34 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:52:34 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:53:22 4: sduino2/msg READ: MU;P0=-32001;P1=356;P2=-991;P3=1447;P4=477;D=0123232424242424232324232324232423242324232323232323242323232323232423242323232323232324232424242423242323232323242323232423232423242423;CP=4;R=3;
2018.10.22 20:53:22 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:53:22 5: sduino2: Starting demodulation at Position 3
2018.10.22 20:53:22 5: sduino2: dispatching bits: 0 0 1 1 1 1 1 0 0 1 0 0 1 0 1 0 1 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 0 1 0 1 1 0 0
2018.10.22 20:53:22 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#3E4AA040A02F4112C length 68 RSSI = -72.5
2018.10.22 20:53:22 5: sduino2 Dispatch: P9#3E4AA040A02F4112C, test ungleich: disabled
2018.10.22 20:53:22 5: sduino2 Dispatch: P9#3E4AA040A02F4112C, -72.5 dB, dispatch
2018.10.22 20:53:22 5: sduino2: dispatch P9#3E4AA040A02F4112C
2018.10.22 20:53:22 3: sduino2: Unknown code P9#3E4AA040A02F4112C, help me!
2018.10.22 20:53:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:54:09 4: sduino2/msg READ: MU;P0=-31072;P1=486;P2=-986;P3=1454;D=01212121212121212321232321232123232121232323212121212123232123232123212321232123232323232321232323232323212323232323232323232123212121212321232323232323232323212321212321232301212121212121212321232321232123232121232323212121212123232123232123212321232123;CP=1;R=29;O;
2018.10.22 20:54:09 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:54:09 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:54:09 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 0 1 0 0 1 0 1 0 1 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 0 0 0 0 1 0 1 1 0 1 0 0 0
2018.10.22 20:54:09 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E4AA040802F40168 length 88 RSSI = -59.5
2018.10.22 20:54:09 5: sduino2 Dispatch: P9#FF4A63E4AA040802F40168, test ungleich: disabled
2018.10.22 20:54:09 5: sduino2 Dispatch: P9#FF4A63E4AA040802F40168, -59.5 dB, dispatch
2018.10.22 20:54:09 5: sduino2: dispatch P9#FF4A63E4AA040802F40168
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse0 msg=FF4A63E4AA040802F40168 Bin=1111111101001010011000111110010010101010000001000000100000000010111101000000000101101000 syncp=1 length:88
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:54:09 4: sduino2: SD_WS09_SHIFT_1 NOK rwa:FFA531F2550204017A00B4
2018.10.22 20:54:09 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F2550204017A00B4 msg:P9#FFA531F2550204017A00B4
2018.10.22 20:54:09 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F2550204017A00B4 msg:P9#FFA531F2550204017A00B4 CRC:0
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111001001010101000000100000010000000001011110100000000010110100 length:80
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000010 Dec: 0.7
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000100 Dec: 1.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=9.8, hum=85, winddir=0:N wS=0.7, wG=1.4, rain=113.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111001001010101000000100000010000000001011110100000000010110100
2018.10.22 20:54:10 4: sduino2/msg READ: MU;P0=-980;P1=481;P2=1459;D=0101010202010202020202020102020202020202020201020101010102010202020202020202020102010102010202;CP=2;R=3;
2018.10.22 20:54:10 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:54:10 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:54:28 4: sduino2/keepalive ok, retry = 0
Ich hoffe es hilft weiter.
Grüße Martin
