FIBARO System FGMS001 Motion Sensor Readings anzeigen
Begonnen von sun112, 20 August 2015, 18:49:38
sun112
Hallo!
Ich habe oben genannten Sensor (motion, temperatur, usw.) inkludiert und assoziiert. Hat auch alles gut geklappt.
System aktuell: "nothing to do"
2015.08.19 22:23:55 2: autocreate: define ZWave_SENSOR_BINARY_7 ZWave eea1e68e 7 308485808f567286708e319cef30319c
2015.08.19 22:23:55 2: autocreate: define FileLog_ZWave_SENSOR_BINARY_7 FileLog ./log/ZWave_SENSOR_BINARY_7-%Y.log ZWave_SENSOR_BINARY_7
2015.08.19 22:23:57 2: ZWave set ZWave_SENSOR_BINARY_7 associationAdd
2015.08.19 22:23:58 2: ZWave get ZWave_SENSOR_BINARY_7 model
2015.08.19 22:23:58 3: ZWave reading config for fibaro/fgms.xml
2015.08.19 22:23:58 1: ZWAVE INIT: get ZWave_SENSOR_BINARY_7 model: modelConfig:fibaro/fgms.xml
modelId:010f-0800-1001
model:FIBARO System FGMS001 Motion Sensor
Hab es zu sensor1 umbenannt.
In den Readings ist alles zu sehen was ich möchte (Temperatur usw.):
Das ist die log-Datei:
2015-08-20_18:33:14 sensor1 basicSet: ff
2015-08-20_18:33:44 sensor1 closed
2015-08-20_18:33:44 sensor1 reportedState: closed
2015-08-20_18:33:44 sensor1 basicSet: 00
2015-08-20_18:34:14 sensor1 open
2015-08-20_18:34:14 sensor1 reportedState: open
2015-08-20_18:34:14 sensor1 basicSet: ff
2015-08-20_18:36:09 sensor1 closed
2015-08-20_18:36:09 sensor1 reportedState: closed
2015-08-20_18:36:09 sensor1 basicSet: 00
2015-08-20_18:39:00 sensor1 open
2015-08-20_18:39:00 sensor1 reportedState: open
2015-08-20_18:39:00 sensor1 basicSet: ff
2015-08-20_18:39:55 sensor1 closed
2015-08-20_18:39:55 sensor1 reportedState: closed
2015-08-20_18:39:55 sensor1 basicSet: 00
2015-08-20_18:41:01 sensor1 open
2015-08-20_18:41:01 sensor1 reportedState: open
2015-08-20_18:41:01 sensor1 basicSet: ff
2015-08-20_18:41:40 sensor1 closed
2015-08-20_18:41:40 sensor1 reportedState: closed
2015-08-20_18:41:40 sensor1 basicSet: 00
2015-08-20_18:41:57 sensor1 open
2015-08-20_18:41:57 sensor1 reportedState: open
2015-08-20_18:41:57 sensor1 basicSet: ff
Wird also nur Bewegung angezeigt. In den Readings findet sich aber alles andere.
Wie kann ich die Informationen, also zunächst Temperatur, in der Weboberfläche anzeigen und ggf. auch loggen.
Ich habe da wohl ein Verständnisproblem.
Danke für die Hilfe.
Stefan
Die FileLog_ZWave_SENSOR_BINARY_7 Detailseite oeffnen, und da "Create SVG plot" anklicken.
Danach im SVG-Editor das gewuenschte Plot zusammenstellen.
sun112
Danke! Aber da erhalte ich ja nur Infos zur Bewegung. Dort steht keine Temperatur, Helligkeit usw..
Plot kommt später, wie das geht ist mir klar.
Ich hätte einfach gern in der Oberfläche eine Anzeige "Temperatur 23°C", so wie es in den Readings auch steht.
Vielleicht habe ich mich falsch ausgedrückt.
Ist sicher nur ein Verständnisfehler von mir und ganz einfach.
krikan
Wenn Du die Anzeige in der Raumübersicht meinst, musst Du das mit http://fhem.de/commandref#stateFormat anpassen.
Falls gewuenscht wird, dass die temperatur auch im Log steht, dann muss man die Log-Definition (siehe im FileLog Detail: add regexp part) erweitern. Fuer die Oberflaeche ist z.Bsp. stateFormat oder readingsGroup zustaendig.
sun112
Danke, das meinte ich. Jetzt hab ich was zu lesen und zu testen.
