70_PIONEERAVR.pm - Perl Warning
Begonnen von P.A.Trick, 23 August 2015, 18:40:36
P.A.Trick
Hallo, beim FHEM Start bekomme ich folgende Meldung vom Pioneer Modul!
Smartmatch is experimental at ./FHEM/70_PIONEERAVR.pm line 1092, <$fh> line 3069.
Smartmatch is experimental at ./FHEM/70_PIONEERAVR.pm line 1137, <$fh> line 3069.
Smartmatch is experimental at ./FHEM/70_PIONEERAVR.pm line 1153, <$fh> line 3069.
Smartmatch is experimental at ./FHEM/70_PIONEERAVR.pm line 1175, <$fh> line 3069.
Wäre klasse, wenn man die eliminieren könnte!? Vielen Dank im Voraus!
P.A.Trick
Beim Restart von FHEM bekomme ich auch noch einige Meldungen:
2015.09.02 20:53:24.854 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.854 3: stacktrace:
2015.09.02 20:53:24.855 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.855 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (2074)
2015.09.02 20:53:24.856 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.856 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.863 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.864 3: stacktrace:
2015.09.02 20:53:24.864 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.865 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.865 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.866 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.867 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.867 3: stacktrace:
2015.09.02 20:53:24.867 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.868 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.868 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.869 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.870 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.870 3: stacktrace:
2015.09.02 20:53:24.870 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.871 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.871 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.872 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.873 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.873 3: stacktrace:
2015.09.02 20:53:24.874 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.875 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.875 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.876 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.877 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.877 3: stacktrace:
2015.09.02 20:53:24.877 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.878 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.878 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.879 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.880 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.880 3: stacktrace:
2015.09.02 20:53:24.880 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.881 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.881 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.882 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.883 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.883 3: stacktrace:
2015.09.02 20:53:24.883 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.884 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.885 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.886 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.887 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.887 3: stacktrace:
2015.09.02 20:53:24.888 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.888 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.889 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.889 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.890 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.890 3: stacktrace:
2015.09.02 20:53:24.891 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.891 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.892 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.892 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.893 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.893 3: stacktrace:
2015.09.02 20:53:24.894 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.894 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.895 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.895 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.896 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.897 3: stacktrace:
2015.09.02 20:53:24.897 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.897 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.898 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.898 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.899 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.900 3: stacktrace:
2015.09.02 20:53:24.900 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.901 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.901 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.901 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.902 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.903 3: stacktrace:
2015.09.02 20:53:24.903 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.904 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.904 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.904 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.905 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.906 3: stacktrace:
2015.09.02 20:53:24.906 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.907 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.907 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.907 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.908 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.909 3: stacktrace:
2015.09.02 20:53:24.909 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.910 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.910 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.911 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.911 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.912 3: stacktrace:
2015.09.02 20:53:24.912 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.913 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.913 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.914 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.914 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.915 3: stacktrace:
2015.09.02 20:53:24.915 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.916 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.916 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.917 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.918 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.918 3: stacktrace:
2015.09.02 20:53:24.918 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.919 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.919 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.920 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.921 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.921 3: stacktrace:
2015.09.02 20:53:24.922 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.923 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.923 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.923 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.924 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.925 3: stacktrace:
2015.09.02 20:53:24.925 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.926 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.926 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.927 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.927 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.928 3: stacktrace:
2015.09.02 20:53:24.928 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.929 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.929 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.930 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.931 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.931 3: stacktrace:
2015.09.02 20:53:24.931 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.932 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.932 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.933 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.934 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.934 3: stacktrace:
2015.09.02 20:53:24.934 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.935 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.935 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.936 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.937 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.937 3: stacktrace:
2015.09.02 20:53:24.937 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.938 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.938 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.939 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.940 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.940 3: stacktrace:
2015.09.02 20:53:24.941 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.941 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.941 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.942 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.943 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.943 3: stacktrace:
2015.09.02 20:53:24.944 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.944 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.945 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.945 3:     main::CallFn                        called by fhem.pl (651)
2015.09.02 20:53:24.946 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 3894.
2015.09.02 20:53:24.946 3: stacktrace:
2015.09.02 20:53:24.947 3:     main::__ANON__                      called by fhem.pl (3894)
2015.09.02 20:53:24.947 3:     main::readingsBulkUpdate            called by ./FHEM/70_PIONEERAVR.pm (1680)
2015.09.02 20:53:24.948 3:     main::PIONEERAVR_Read               called by fhem.pl (3056)
2015.09.02 20:53:24.948 3:     main::CallFn                        called by fhem.pl (651)
Ich würde mich über ein Update freuen!
P.A.Trick
Nun zumindest diese Meldungen kann man wie folgt unterdrücken:
(im use header)
no if $] >= 5.017011, warnings => 'experimental::smartmatch';
P.A.Trick
P.A.Trick
