How to Use two or more CUL or CUN devices with MAX! EQ3 heating devices
Begonnen von chapelhill, 15 September 2015, 08:16:23
Jam2
Verdammt! I should have asked before analyzing for one day verbose 5 logs :D
fhem update will give me the newest files, right?
FHEM / Intel NUC / 8xMAX Fensterkontakte + 16xMAX Thermostate + fakewt + CUL / 20x Technoline TX29 / Hue Bridge / duefern / fbdect / mysensors / homekit
RasPi ser2net CUL
FHEM / RasPi PI / buderus logamatic / temperatursensoren
Wzut
no not yet because its beta testing.
a. first make a normal FHEM update to get the latest versions of 00_CUL and MaxCommon
b. Download 10_MAX.pm and 14_CUL_MAX.pm from the Beta thread to replace the old ones
c. if you habe today more than one CULMAX (cm) device in your config : The beta version of 14_CUL_MAX supports only one device !
so delete the other ones. You can have as many CUL devices as you want but only one CULMAX device. (this one is doing everything)
d. save and restart FHEM
e. when FHEM is running go to every CUL devices and set the new attribut maxid (the second parameter from your CULMAX device most users have here 123456)
f. go to your CULMAX device (cm) and set the new attribute IOgrp (comma separate list of all your CULs )
g. now set one every of yor MAX devices the new attribute CULdev.  Set it to that CUL name that will doing the send job for this MAX device.
set also the new attribute debug to 1 on every MAX and your CULMAX device, this will give you more readings and will help to check your environment.
If somethings is not working : set the CULMAX device to verbose level 5 (not the CULs and not global) an have a look at the log file.
Jam2
Hallo Wzut,
zu Punkt e: heißt das, dass beide CUL die selbe Nummer bekommen, da es ja nur einen CULMAX gibt?
RasPi ser2net CUL
Wzut
nicht zwingend , ich habe das hier https://forum.fhem.de/index.php/topic,106577.msg1010410.html#msg1010410 näher beschrieben.
Ich persönlich rate aber davon ab zwei verschiedene IDs aktiv zu betreiben, ist aber eine brauchbare Notlösung zum direkten Wechsel (wenn man heute zwei hat) bis alles auf eine ID umgestellt ist.
Jam2
OK. Ich setzte dann alles mit der gleichen ID auf - das macht mehr Sinn.
Letzte Fragen:
1) "CULdev" - wenn nicht gesetzt, welcher CUL wird dann genommen?
Der erst genannte im CUL_MAX "IOgrp" oder der welcher zuletzt eine Nachricht empfangen hat?
2) Fensterkontakte Ist hier ein "CULdev" benötigt?
Bisher ist das Update gut verlaufen
RasPi ser2net CUL
Wzut
1. der im CULMAX Device im Internal als IODev steht. Und dieses IODev kann wechseln wenn ein Device einen anderen CUL will.
D.h. es wird imm der genommen der zuletzt gesendet hat (nicht empfangen ! )
2. Ich würde es gleich mit setzen (Stichwort Odnung) , denn vllt. soll ja mal ein assoicate oder deassoicate gesenden werden.
