Hallo Andy,
habe die beiden Dateien ersetzt und dann fhem mit "shutdown restart" neu gestartet.
So sieht dann die log aus:
2020.12.28 23:30:25 3: PWM Define FBH_PWM
2020.12.28 23:30:25 2: called PWM_Attr(set,FBH_PWM,overallHeatingSwitchThresholdTemp,<OWX_28_FF93176F1801:temperature:(\d+).*,25>)
2020.12.28 23:30:25 2: called PWM_Attr(set,FBH_PWM,room,<00_Heizung>)
2020.12.28 23:30:25 2: called PWM_Attr(set,FBH_PWM,valveProtectIdlePeriod,<30>)
2020.12.28 23:30:25 2: called PWM_Attr(set,FBH_PWM,verbose,<3>)
2020.12.28 23:30:25 1: reload: Error:Modul 93_PWMR deactivated:
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3406.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3406.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3417.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3417.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3417.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3427.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3427.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3427.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3437.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3437.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3437.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3447.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3447.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3447.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3457.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3457.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3457.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3467.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3467.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3467.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3477.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3477.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3477.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3487.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3487.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3487.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3497.
2020.12.28 23:30:25 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3497.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3497.
2020.12.28 23:30:25 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3497.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3508.
2020.12.28 23:30:26 1: reload: Error:Modul 93_PWMR deactivated:
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3508.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3508.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3518.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3518.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3518.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3528.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3528.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3528.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3538.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3538.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3538.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3548.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3548.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3548.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3558.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3558.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3558.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3558.
2020.12.28 23:30:26 3: PWM Define PWM_Test
2020.12.28 23:30:26 2: called PWM_Attr(set,PWM_Test,room,<00_Heizung>)
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Initialize redefined at ./FHEM/93_PWMR.pm line 121, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_getDesiredTempFrom redefined at ./FHEM/93_PWMR.pm line 152, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTempFromRule redefined at ./FHEM/93_PWMR.pm line 192, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_CalcDesiredTemp redefined at ./FHEM/93_PWMR.pm line 282, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Get redefined at ./FHEM/93_PWMR.pm line 391, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Set redefined at ./FHEM/93_PWMR.pm line 422, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Define redefined at ./FHEM/93_PWMR.pm line 569, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_Undef redefined at ./FHEM/93_PWMR.pm line 885, <$fh> line 3572.
2020.12.28 23:30:26 1: PERL WARNING: Subroutine PWMR_SetRoom redefined at ./FHEM/93_PWMR.pm line 904, <$fh> line 3572.
Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3572.
2020.12.28 23:30:26 0: Global symbol "$temperature" requires explicit package name (did you forget to declare "my $temperature"?) at ./FHEM/93_PWMR.pm line 1101, <$fh> line 3572.
2020.12.28 23:30:26 3: OWTHERM: Device OWX_28_9ECDFFFFFFFF defined.
2020.12.28 23:30:26 1: Including ./log/fhem.save
2020.12.28 23:30:28 1: Messages collected while initializing FHEM:configfile: Cannot load module PWMR
Please define EG_Bad_GPIO_07 5fe84244-f33f-e90d-945e-4fe44bc7734145d6 first
Please define EG_Kueche_GPIO_06 5fe8424c-f33f-e90d-f48f-547622d7d51bd2b3 first
Please define EG_WC_GPIO_09 5fe8425d-f33f-e90d-f3cd-b792670479b3817d first
Please define EG_Wohn_Esszimmer_GPIO_05 5fe8425e-f33f-e90d-c305-3291a584cea21812 first
Please define KG_Arbeitszimmer_GPIO_13 5fe8425e-f33f-e90d-bad6-099316670f14c9f3 first
Please define KG_Flur_GPIO_11 5fe8425e-f33f-e90d-5173-227971e4ba92d9e4 first
Please define KG_Hobbyraum_GPIO_15 5fe8425f-f33f-e90d-b335-622a8b44f7b85abd first
Please define KG_Kellerraum_GPIO_20 5fe8425f-f33f-e90d-865e-2a73741a0e3db766 first
Please define KG_Spielzimmer_GPIO_12 5fe84260-f33f-e90d-0ea8-a12adb787a9ef197 first
Please define OG_Bad_GPIO_10 5fe84260-f33f-e90d-2118-bb5ffa77650d5b2e first
Please define OG_Flur_GPIO_16 5fe84261-f33f-e90d-0c66-f17715861dc025fa first
Please define OG_Kizi_1_GPIO_17 5fe84261-f33f-e90d-4937-c5f19911257db62a first
Please define OG_Kizi_2_GPIO_18 5fe84262-f33f-e90d-7aef-2d2485fcd174c296 first
Please define OG_Kizi_3_GPIO_19 5fe84262-f33f-e90d-1327-f0cd5eb9d79efab5 first
Please define OG_Schalfzimmer_GPIO_14 5fe84263-f33f-e90d-7a28-86e01bc21239bff6 first
Please define EG_Flur_GPIO_08 5fe86469-f33f-e90d-355c-b1dd0509e11b47fc first
Please define EG_Naehzimmer_GPIO_04 5fe8931c-f33f-e90d-7362-881b2801901dbe17 first
Alle PWMR Definitionen sind in FHEM nicht mehr zu sehen. In der fhem.cfg sind diese noch definiert.
Johannes
