Nach Neustart vom Raspberry keine Kommunikation zu Z-Wave-Teilnehmer [gelöst]
Begonnen von LAN-Opfer, 04 November 2015, 07:41:56
LAN-Opfer
Ich habe ein seltsammes Problem entdeckt: wenn ich mit shutdown reboot den Rechner neu starte, schlägt die Kommunikation zu einem Z-Wave-Teilnehmer (es ist immer der selbe - ZW.WZ_ZW_ST_DOSE) fehl:
2015.11.03 18:46:04 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501FF2503
2015.11.03 18:46:04 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501FF2502
2015.11.03 18:46:05 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:10 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:14 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501FF2503
2015.11.03 18:46:14 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501FF2502
2015.11.03 18:46:15 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:20 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:24 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501002503
2015.11.03 18:46:24 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501002502
2015.11.03 18:46:25 2: ZWave set ZW.WZ_ZW_ST_DOSE on
2015.11.03 18:46:25 2: ZWave set ZW.AS_ST_DOSE2 on
2015.11.03 18:46:25 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:30 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:34 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501002503
2015.11.03 18:46:34 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501002502
2015.11.03 18:46:35 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:40 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:44 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501002503
2015.11.03 18:46:44 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501002502
2015.11.03 18:46:45 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:50 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:46:54 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501FF2503
2015.11.03 18:46:54 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501FF2502
2015.11.03 18:47:42 2: ZWave set ZW.WZ_ZW_ST_DOSE off
2015.11.03 18:47:42 2: ZWave set ZW.AS_ST_DOSE2 off
2015.11.03 18:47:47 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:47:52 2: ZWave: No ACK from ZW.WZ_ZW_ST_DOSE after 10s for sent:1303032501002503
2015.11.03 18:48:58 2: ZWave set ZW.AS_ST_DOSE2 on
2015.11.03 18:49:05 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:49:05 2: ZWave set ZW.AS_ST_DOSE2 off
2015.11.03 18:49:08 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501FF2502
2015.11.03 18:49:14 2: ZWAVE1 transmit NO_ACK for 02
2015.11.03 18:49:18 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501002502
2015.11.03 19:03:40 2: FHT set FHT.BAD_TEMP desired-temp 17.0
2015.11.03 19:05:55 2: ZWAVE1 transmit NO_ACK for 0e
2015.11.03 19:21:51 2: ZWAVE1 transmit NO_ACK for 0e
2015.11.03 19:29:53 2: ZWave set ZW.WZ_ZW_ST_DOSE on
2015.11.03 19:29:53 2: ZWave set ZW.AS_ST_DOSE2 on
2015.11.03 19:29:54 2: ZWDongle_ProcessSendStack: no ACK, resending message 010e00130207600d01022501FF250275
2015.11.03 19:29:55 2: ZWave set ZW.AS_ST_DOSE2 on
2015.11.03 19:29:55 2: ZWave set ZW.WZ_ZW_ST_DOSE off
2015.11.03 19:29:55 2: ZWave set ZW.AS_ST_DOSE2 off
2015.11.03 19:29:56 2: ZWave set ZW.AS_ST_DOSE2 off
2015.11.03 19:30:05 2: ZWave: No ACK from ZW.AS_ST_DOSE after 10s for sent:130207600d01022501FF2502
ZW.WZ_ZW_ST_DOSE (nodeIdHex 03 - Everspring AN158 Plug-in Meter Appliance Module) und ZW.AS_ST_DOSE2 (nodeIdHex 02 - FIBARO System FGS221 Double Relay Switch 2x1.5kW) sind "gekoppelt" (ich missbrauche ZW.WZ_ZW_ST_DOSE als Fernbedienung für ZW.AS_ST_DOSE2):
#Schalterkopplung
define ST_HZon notify ZW.WZ_ZW_ST_DOSE:on set ZW.AS_ST_DOSE2 on
define ST_HZoff notify ZW.WZ_ZW_ST_DOSE:off set ZW.AS_ST_DOSE2 off
Wenn ich dann einen Power-On-Reset (aus- und wieder einstecken) bei der Everspring AN158 durchführe, funktioniert es wieder - bis zum nächsten Neustart des Raspberry :-(
Woran könnte das liegen?
Uwe
FHEM5.7 auf Raspberry 2 mit V 1.53 CUL868, HMLAN, Z-Wave 3.99
A.Harrenberg
in der Tat merkwürdig...
Könntest Du mal auch das Log VOR den NO_ACK posten? Am besten alles ab Neustart von FHEM, und am einfachsten als Dateianhang, dürfte ja etwas länger sein.
Und mal ein "list" von beiden Nodes machen und posten.
Andreas.
FB 7360, Homematic und ZWave
Support for ZWave-SECURITY
LAN-Opfer
...ich denke, ich habs gefunden: die SD-Karte ist wohl hin und kann nicht mehr beschrieben werden - lesen geht. Nach einem Neustart des Rechners waren alle Updates weg - so lange der Rechner lief, schienen die Updates zu funktionieren und waren nach einem Neustart von Fhem auch noch da.
Uwe
A.Harrenberg
ok, das kann natürlich alles mögliche auslösen. Der Effekt das es dann nach dem "Reset" der Steckdose wieder ging ist dadurch aber nicht sooo wirklich zu erklären. Aber gut, wenn es jetzt wieder geht.
Wenn Du Deinen ersten Post öffnest kannst Du den Betreff editieren und könntest ein "[gelöst]" davorschreiben, dann wissen alle Bescheid.
Andreas.
