94_PWM.pm : add additional parameter in definition. OverallHeatingSwitch can be used to control pumps or heating systems if all rooms are switched off
Begonnen von System, 19 November 2015, 16:00:10
System
94_PWM.pm : add additional parameter in definition. OverallHeatingSwitch can be used to control pumps or heating systems if all rooms are switched offView Changes
Source: 94_PWM.pm : add additional parameter in definition. OverallHeatingSwitch can be used to control pumps or heating systems if all rooms are switched off
