FHEM > Sonstiges
49_SSCam: Fragen, Hinweise, Neuigkeiten und mehr rund um dieses Modul
<< < (485/486) > >>
juemuc:
Hallo Heiko,
ich hahbe heute diese Einträge im Log gefunden:
--- Code: ---2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7627.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7631.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7633.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7635.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7637.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7639.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7641.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7643.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7645.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7647.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value $uuid in concatenation (.) or string at ./FHEM/49_SSCam.pm line 7649.
2021.12.16 19:31:48 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/49_SSCam.pm line 7710.
--- Ende Code ---
Hast Du eine Idee, woher die Meldungen kommen?
Jürgen
DS_Starter:
Hallo Jürgen,
die Streamingdevices übermitteln ihre FUUID (Internal) oder besser gesagt ihren eigenen Namen über die Definition, z.B.
{FHEM::SSCam::streamDev('CamCP1','SSCamSTRM.CamCP1.mjpeg','mjpeg')}
Daraus wird der Gerätehash erstellt um verschiedene wichtige Informationen, wie eben die FUUID, zu extrahieren.
Wahrscheinlich wurde ein Name mit gesendet, den es nicht gibt. Oder "leer" evtl.
Aber warum genau es bei dir so war ... Glaskugel  ;)
LG,
Heiko
juemuc:
Hallo Heiko,
alles klar. Danke für die Info. Ist auch nicht mehr aufgetreten  ;D
Jürgen
Fredi69:
Ich bekomme seit heute den Fehler „ ERROR - API keys and values not completed“
Was kann das Problem sein?
DS_Starter:
Die API - Keys von der Syno SVS konnten nicht abgerufen werden.
Vermutlich gab es vorher noch Fehelermitteilungen ?
Ansonsten prophylaktisch das SVS Paket auf der Syno mal neu starten.
Navigation
[0] Themen-Index
[#] Nächste Seite
[*] Vorherige Sete
Zur normalen Ansicht wechseln
